3# libeer
1 D& S. a, ~; M: a3 t+ p6 h& |
) B. S" V5 ~( j8 `- Kfastmode$ : 1 #Posting speed optimizition
N7 f& m( K0 k% t obug1$ : 2 #0=No display, 1=Generic list box, 2=Editor* l! P9 \0 j0 F
bug2$ : 30 #Append postline labels, non-zero is column position?
. O1 l/ B4 R" [, M! V' I8 ]9 ebug3$ : 0 #Append whatline no. to each NC line?6 Z+ X# k3 {4 L9 R3 s) e) r. Z
bug4$ : 1 #Append NCI line no. to each NC line?5 t" \1 A( y( G8 o
whatno$ : yes$ #Do not perform whatline branches? (leave as yes): T+ R2 J+ E9 l. l, o
linktolvar$ : 1 #Associate X tolerance variables to V9- variable?
2 b$ k Z! u8 b+ A' A* plinkplnvar$ : 1 #Associate X plane specific variables to V9- variable? H$ m& U$ j7 n9 Y0 x7 e
linklvar$ : 1 #Associate X lathe specific variables to V9- variable?
1 C) C6 O# X: m2 L* A$ wget_1004$ : 1 #Find gcode 1004 with getnextop?! t9 }1 w9 n* T( Z `8 h
rpd_typ_v7$ : 0 #Use Version 7 style contour flags/processing?8 U0 |$ X; w5 e
strtool_v7$ : 2 #Use Version 7+ toolname?
- i, ~! h& Y; f, z" K7 ytlchng_aft$ : 2 #Delay call to toolchange until move line 7 ?4 ~" ^0 p6 q/ t; ~
cant_tlchng$ : 1 #Ignore cantext entry on move with tlchng_aft # r% C: G( I# n# z8 |
newglobal$ : 1 #Error checking for global variables
, C/ E% _6 K; A& W- ngetnextop$ : 0 #Build the next variable table8 I9 F' v5 c- q# w3 ]6 y
tooltable$ : 1 #Pre-read, call the pwrtt postblock
7 D2 J8 B: d" o; q! ierror_msg$ : 1 #0=file and prompt, 1=to screen, 2=one to screen8 z6 ?5 m( w+ R e8 M' `+ D" T! Y8 G
err_file$ : 1 #0=fatal, 1=all errors, 2=inc mprint, 3=inc prompts, 4=always |
