想通过模具向导的坯料尺寸取得层中所有实体最大外形。的方法。以下代码无法取得,有那位大师知道指教一二。。谢谢
3 G3 y/ s, u, r- I, w5 [- Z+ | NXOpen.Tooling.StockSizeBuilder stockSizeBuilder1;
* g% U$ m) W& u5 }5 C9 @! j$ C stockSizeBuilder1 = thePart.ToolingManager.StockSizes.CreateStocksizeBuilder();
" g9 H! P Z7 T y) a) q2 j4 ? stockSizeBuilder1.StringStock = "0";0 g# y7 Q }/ S$ ` |1 }0 ?
stockSizeBuilder1.SizePrecision = 3;//返回或设置的尺寸精度
: _8 o/ Y/ a0 S/ y9 z stockSizeBuilder1.StockType = NXOpen.Tooling.StockSizeBuilder.Shape.Block;
+ W# @+ L/ R g4 C( B0 a0 l# a. c int i = 0;
2 K. j" e( T2 C. G/ Y; t% y; j+ { int k = 0;% H7 H% a; G* c1 f( P4 X
foreach (var item in thePart.Layers.GetAllObjectsOnLayer(int.Parse(tbx_layer.Text)))
3 @) d. G* A# T( |+ ^' A { }5 m# s6 a% c4 n) L. m2 f
if (item is NXOpen.Body)
# O$ k* x4 n, H4 d+ y# ~2 Q3 w& ] {
- r! c1 w% C) H }$ k if (item.Name != null)6 K$ P& C- X8 ]! S+ ]" r( C2 z
) T) H5 z5 x3 Y ?7 \! Y# a& C bool test = stockSizeBuilder1.SelectBody.Add((Body)item);% z! A: E2 E( D, u- G, j( ^8 H
listBox1.Items.Add(item.Name + " " + stockSizeBuilder1.StringStock);! f4 G$ w+ `* H& e' m# K
i++;
5 P, B; z/ l) S' u2 T) K2 T( o }3 E0 l! |" V6 `% b% y& n; B* I f" `; L0 C
else* ]7 z8 |! y5 A5 i2 \ i, o
4 J0 j( m% O1 U; y k++;
4 }7 ?* J' P; P2 ^4 ?* \ }$ W7 T6 p$ d! y# @1 K2 y
5 t S0 f) v( o' d: ^} |
