想通过模具向导的坯料尺寸取得层中所有实体最大外形。的方法。以下代码无法取得,有那位大师知道指教一二。。谢谢
' j2 q& D9 z9 H/ M1 | NXOpen.Tooling.StockSizeBuilder stockSizeBuilder1;
% r6 [4 W7 H" ?- h: k7 _$ s stockSizeBuilder1 = thePart.ToolingManager.StockSizes.CreateStocksizeBuilder();
% [! o3 u4 j! V stockSizeBuilder1.StringStock = "0";
: A: u3 \$ w; j/ y; C [' ? stockSizeBuilder1.SizePrecision = 3;//返回或设置的尺寸精度2 A/ z4 C, f3 e% [2 y
stockSizeBuilder1.StockType = NXOpen.Tooling.StockSizeBuilder.Shape.Block;
2 D$ S( ]+ ~1 I& @ v4 J int i = 0;
4 b8 v6 S! C0 v; _, j int k = 0;( v! P* p: P& y; u6 R
foreach (var item in thePart.Layers.GetAllObjectsOnLayer(int.Parse(tbx_layer.Text)))/ Z5 L+ t1 S. ?/ A3 S. N9 Y8 ~
( @1 X$ x1 B+ }. \4 { ] if (item is NXOpen.Body)
$ F/ y* t6 C# {# { { v$ v" v# ]2 N8 a
if (item.Name != null)" B: P5 b) F5 G5 _& S: P
{% w' |& W* m5 Q! ~; l! g0 M" ^
bool test = stockSizeBuilder1.SelectBody.Add((Body)item);
- i+ f) |# b# d$ P- G listBox1.Items.Add(item.Name + " " + stockSizeBuilder1.StringStock);
/ L* V# b3 J. h i++;! @2 {4 l8 N' d0 j+ m# y
4 [: E9 Y6 a5 j& h3 V% B) Y6 c5 H( A; | else
1 S7 Q1 y4 s, V& ?" A% | {9 I1 V3 @2 |- n3 k+ g+ f8 m+ K
k++;
% p) ?" Z9 P# t0 w }
+ s( u* ^$ ?. K3 k5 o } ?7 n, w* ?/ B( _( x
