楼主 |
发表于 2007-12-12 19:54
显示全部楼层
回复 10楼 的帖子
1.复制OUYANG。PRT到C:\Program Files\UGS\NX 4.0\MACH\resource\template_part\metric文件里,8 {/ J7 L/ m$ Q# J
2.找到C:\Program Files\UGS\NX 4.0\MACH\resource\template_set的cam_general.opt文件用记事本打开,看下面的写法
8 ]0 r6 g1 M6 |5 R. w${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}mill_planar.prt
) A2 ?- Q; R* Q2 i5 |* Y6 G${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}mill_contour.prt
. J; I8 i$ o& S. |, a4 S7 g" z1 [* z1 w${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}mill_multi-axis.prt
+ J4 n* b2 k- k: q4 Z% r( V${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}drill.prt9 m7 D& v( i( c
${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}hole_making.prt8 {1 g& r7 A! `5 C" g" i0 d8 O
${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}turning.prt$ W- U# J3 r& d) r
${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}wire_edm.prt
, A1 M& U* |! a/ x) u& X% V# g##& Y& h0 c+ O8 @- g
${UGII_CAM_TEMPLATE_PART_METRIC_DIR}mill_planar.prt+ s2 L9 I6 p2 G$ g4 [
${UGII_CAM_TEMPLATE_PART_METRIC_DIR}mill_contour.prt
* l- m z$ H7 g- q1 l${UGII_CAM_TEMPLATE_PART_METRIC_DIR}OUYANG.prt
* B2 P, ^ T: y6 }" a' k: F% o+ @${UGII_CAM_TEMPLATE_PART_METRIC_DIR}mill_multi-axis.prt
0 Y! q: Z* P9 j& u+ u! n1 a8 L( H${UGII_CAM_TEMPLATE_PART_METRIC_DIR}drill.prt
0 g2 \( D, O' j2 B* e2 a% }${UGII_CAM_TEMPLATE_PART_METRIC_DIR}hole_making.prt; d: r1 r/ |9 y' h3 }2 }' H+ }
${UGII_CAM_TEMPLATE_PART_METRIC_DIR}turning.prt
. t1 D) [5 e7 m/ \' v5 O a# d3 z${UGII_CAM_TEMPLATE_PART_METRIC_DIR}wire_edm.prt
" W& H' S U$ I3 U- f5 x! W- x重新啟動UG就OK了,在初始化界面就可以选你要的那个,
8 K8 V3 H7 ]7 X" x: u& ?0 N 还有不明白的加我QQ328435334 |
