int CAM_set_cut_feeds(void)- u# O {' j* d
! c( Q c2 y# p) E0 t- M* ~
h q; T2 e g6 | UF_PARAM_feedrate_t value;
5 n$ m1 y' R3 y/ P8 r int count;, w5 a" R& l4 F( w% e. l
" T% S f5 R B9 K0 k& O tag_t *objects,oper_tag=NULL_TAG;
( W* \& v9 p! }2 n% n% o. {6 J' z+ }6 n; a
UF_UI_ONT_ask_selected_nodes(&count,&objects);
4 o0 c; j- Q& D( e
5 Y3 [, A$ E3 R- q2 e6 v oper_tag=objects[0];) @+ X! Y# P+ ?. I$ z) X
. ?/ C$ o0 s5 c- m( N0 I if (oper_tag==NULL_TAG)
+ F! N- c! N2 C6 ? { Y' O8 n6 z; r7 }
return -1;2 Y* p F4 w- T0 V% @ \
}; g0 _4 q0 N z
" X' |* |2 m: R
UF_PARAM_ask_subobj_ptr_value(oper_tag,UF_PARAM_FEED_TRAVERSAL ,&value); // 查询的目的,是填充value的值.2 r4 a+ Y5 g: M! j
value.value=5555; // 改变其中的一项值
/ c3 L7 @) v6 C " ]! t; H H: X6 I
$ N% p8 I# ^. L5 s$ A) A$ s- b
UF_PARAM_set_subobj_ptr_value(oper_tag,UF_PARAM_FEED_TRAVERSAL,&value); //重新设置其值.
% s# O8 L" h% d: [% {) e/ d7 R9 ~7 Y9 ?8 b8 G3 X! K, x0 [
return 0;7 F- u2 V+ I. [- ~: z) V" X
) k( l& U% w) }! S) Q
! [2 N; i5 O4 ], y" c
: H4 X- e( I# d3 A& O
7 \2 y+ F1 z- Y5 I/ k
& t4 n- @. ] D& _
: B3 P: l- }7 N8 R* g8 e# h+ A/ l! D: q" b1 r
