本机特点采用SLA立体制版技术,这与著名的Form 1采用的同一种技术。机身采用铝合金架构。可持久耐用。
& v8 c( x* ]" Y8 g* j( O& a+ y
, Z h% Q K0 Z3 w6 \/ s" l- v- <P> </P>
- `, X- `5 Z5 q: v* B/ b/ l - <P>技术参数:</P>. u6 t* X: u( W4 n. Z1 x5 M) c
- <P>Maximum VAT Area: 30cm x 30cm (X and Y). H/ N, Q6 j: j) Y
- Maximum Lifting distance: 20cm (Z axis)+ L, N& y- c1 M. o* ? X
- Starting Layer Resolution: 0.0125mm (12.5 micron) with Full Step Motor Configuration! _- T. B9 B) V6 t
- Metal Ball Bearing Spindle Resolution: 2.5mm Pitch# ^$ q8 T. d6 D5 k* Z8 {2 w# g
- Repeat Accuracy: Less than 0.01mm on a length of 300mm
. W: u- O2 o# R9 o - Motor Maximum Resolution: 1/16 of a Step
/ A" g' ~: {6 Q7 d- o- k l( e* K, e - Motor Specifications: Nema 23, 4 lead Bipolar, 3A, Step Angle – 1.8deg, 270oz.in
3 w6 h; V4 b `6 _2 }' l2 C! @ - Control Circuit: 3 Stepper Motor Control (4 Leads) – 3.5A, 1 Relay Control, 4 Additional Inputs
& {# @# t* q9 j& t3 d* x: f; t - Electronic Features: Selectable Decay, Selectable Micro-stepping (up to 16m-steps)3doprint.com
) t* l3 o0 D3 S$ R* h1 r2 ^$ d - Power Supply: 350W, 24VDC/14.6A
- [% j, S k- Q$ H - Assembled Kit Dimensions: ~60cm (L) x ~50cm (W) x ~120cm (H)</P>
复制代码 2 [" J0 ^1 k/ W1 u
$ v* k! R1 j4 U5 t5 p$ S
