最近心血来潮,准备做“ugOPEN API函数参考手册中文版”,工作量巨大。 * r3 R5 _! |; c# x& i% H' M6 l7 U
我知道,对于英文有些底子的人来说,其实用处不大,但我想对于很多人来说,应该 是方便了很多,至少查找函数会省不少时间。 - Z5 ^; b( @" u
( y! _4 ?+ W5 L. p$ s- o. [, U* l/ ^5 ^- i# @1 p& c8 W; B! [; I
4.1.190 UF_ASSEM_where_is_part_used 59 4.1.191 UF_ASSEM_where_used_report 59 5 UF_ATTR 关于PART和对象属性的类型及函数定义. 59 5.1..... UF_ATTR Functions 59 5.2..... UF_ATTR Structures 59 5.3..... UF_ATTR Unions 59 6 UF_BOUND 关于边界的函数说明. 59 6.1..... UF_BOUND Functions 59 6.1.1 UF_BOUND_ask_boundary_data 59 6.1.2 UF_BOUND_ask_number_of_boundaries 59 6.1.3 UF_BOUND_create_boundary 59 7 UF_BREP 通过边界查询和创建实体和片体的函数. 60 7.1..... UF_BREP Functions 60 7.1.1 UF_BREP_ask_edge_class 60 7.1.2 UF_BREP_ask_geometry 60 7.1.3 UF_BREP_ask_identifier 60 7.1.4 UF_BREP_ask_topology 60 7.1.5 UF_BREP_ask_topology_source 60 7.1.6 UF_BREP_attach_geometry 60 7.1.7 UF_BREP_delete_geometry 60 7.1.8 UF_BREP_free_geometry_data 60 7.1.9 UF_BREP_heal_body 60 7.1.10 UF_BREP_make_body 60 7.1.11 UF_BREP_release_topology 60 7.1.12 UF_BREP_validate_topology 60 8 UF_CAM CAM模块的相关类型和函数定义. 61 8.1..... UF_CAM Functions 61 8.1.1 UF_CAM_ask_auto_blank 61 8.1.2 UF_CAM_ask_blank_matl_db_object 61 8.1.3 UF_CAM_ask_cam_preferences 61 8.1.4 UF_CAM_ask_clear_plane_data 61 8.1.5 UF_CAM_ask_clear_plane_status 61 8.1.6 UF_CAM_ask_clear_plane_tag 61 8.1.7 UF_CAM_ask_clear_plane_usage 61 8.1.8 UF_CAM_ask_config_file 61 8.1.9 UF_CAM_ask_cutter_db_object 61 8.1.10 UF_CAM_ask_doc_template_name 61 8.1.11 UF_CAM_ask_f_s_db_object 61 8.1.12 UF_CAM_ask_lower_limit_plane_data 61 8.1.13 UF_CAM_ask_lower_limit_plane_status 61 8.1.14 UF_CAM_ask_lower_limit_plane_tag 61 8.1.15 UF_CAM_ask_lower_limit_plane_usage 61 8.1.16 UF_CAM_ask_mach_tool_db_object 61 8.1.17 UF_CAM_ask_opt_template_object 61 8.1.18 UF_CAM_ask_post_template_name 61 8.1.19 UF_CAM_ask_tool_matl_db_object 61 8.1.20 UF_CAM_init_session 61 8.1.21 UF_CAM_is_session_initialized 61 8.1.22 UF_CAM_opt_add_type 61 8.1.23 UF_CAM_opt_ask_clsf_names 61 8.1.24 UF_CAM_opt_ask_doc_names 62 8.1.25 UF_CAM_opt_ask_object 62 8.1.26 UF_CAM_opt_ask_post_names 62 8.1.27 UF_CAM_opt_ask_subtypes 62 8.1.28 UF_CAM_opt_ask_types 62 8.1.29 UF_CAM_PREF_ask_data_type 62 8.1.30 UF_CAM_PREF_ask_integer_value 62 8.1.31 UF_CAM_PREF_ask_logical_value 62 8.1.32 UF_CAM_PREF_set_integer_value 62 8.1.33 UF_CAM_PREF_set_logical_value 62 8.1.34 UF_CAM_PREPRO_init_module 62 8.1.35 UF_CAM_PREPRO_mark_model_as_cam 62 8.1.36 UF_CAM_reinit_opt 62 8.1.37 UF_CAM_reinit_session 62 8.1.38 UF_CAM_set_auto_blank 62 8.1.39 UF_CAM_set_cam_preferences 62 8.1.40 UF_CAM_set_clear_plane_data 62 8.1.41 UF_CAM_set_clear_plane_status 62 8.1.42 UF_CAM_set_clear_plane_tag 62 8.1.43 UF_CAM_set_clear_plane_usage 62 8.1.44 UF_CAM_set_lower_limit_plane_data 62 8.1.45 UF_CAM_set_lower_limit_plane_status 62 8.1.46 UF_CAM_set_lower_limit_plane_tag 62 8.1.47 UF_CAM_set_lower_limit_plane_usage 62 8.1.48 UF_CAM_set_material 62 8.1.49 UF_CAM_update_list_object_customization 62 8.1.50 UF_CAM_update_single_object_customization 63 8.1.51 UF_CAM_wizard_ask_current_object 63 8.1.52 UF_CAM_wizard_set_current_object 63 8.1.53 UF_CAMBND_append_bnd_from_curve 63 8.1.54 UF_CAMBND_append_bnd_from_face 63 8.1.55 UF_CAMBND_append_item_ude 63 8.1.56 UF_CAMBND_ask_boundaries 63 8.1.57 UF_CAMBND_ask_boundary_app_data 63 8.1.58 UF_CAMBND_ask_boundary_data 63 8.1.59 UF_CAMBND_ask_boundary_group_data 63 8.1.60 UF_CAMBND_ask_boundary_items 63 8.1.61 UF_CAMBND_ask_item_app_data 63 8.1.62 UF_CAMBND_ask_item_entity 63 8.1.63 UF_CAMBND_ask_item_group_data 63 8.1.64 UF_CAMBND_ask_item_udes 63 8.1.65 UF_CAMBND_can_accept_item_ude 63 8.1.66 UF_CAMBND_delete_all_item_udes 63 8.1.67 UF_CAMBND_delete_boundaries 63 8.1.68 UF_CAMBND_delete_boundary 63 8.1.69 UF_CAMBND_delete_item_ude 63 8.1.70 UF_CAMBND_is_inherited 63 8.1.71 UF_CAMBND_set_boundary_app_data 63 8.1.72 UF_CAMBND_set_boundary_group_data 63 8.1.73 UF_CAMBND_set_boundary_plane 63 8.1.74 UF_CAMBND_set_item_app_data 63 8.1.75 UF_CAMBND_set_item_group_data 63 8.1.76 UF_CAMBND_WEDM_append_item_ude 64 8.1.77 UF_CAMBND_WEDM_ask_item_udes 64 8.1.78 UF_CAMBND_WEDM_delete_all_item_udes 64 8.1.79 UF_CAMBND_WEDM_delete_item_ude 64 8.1.80 UF_CAMGEOM_append_custom_points 64 8.1.81 UF_CAMGEOM_append_items 64 8.1.82 UF_CAMGEOM_ask_custom_points 64 8.1.83 UF_CAMGEOM_ask_geom_provider 64 8.1.84 UF_CAMGEOM_ask_item_app_data 64 8.1.85 UF_CAMGEOM_ask_item_entity 64 8.1.86 UF_CAMGEOM_ask_item_maxmin 64 8.1.87 UF_CAMGEOM_ask_items 64 8.1.88 UF_CAMGEOM_delete_custom_points 64 8.1.89 UF_CAMGEOM_delete_geometry 64 8.1.90 UF_CAMGEOM_delete_item 64 8.1.91 UF_CAMGEOM_eval_surface 64 8.1.92 UF_CAMGEOM_set_item_app_data 64 8.1.93 UF_CAMTEXT_append_items 64 8.1.94 UF_CAMTEXT_ask_item_entity 64 8.1.95 UF_CAMTEXT_ask_items 64 8.1.96 UF_CAMTEXT_delete_geometry 64 8.1.97 UF_CAMTEXT_delete_item 64 8.1.98 UF_CUT_LEVELS_add_levels_using_geom 64 8.1.99 UF_CUT_LEVELS_add_levels_using_z 64 8.1.100 UF_CUT_LEVELS_ask_level 64 8.1.101 UF_CUT_LEVELS_ask_top_off_level 64 8.1.102 UF_CUT_LEVELS_delete_level 65 8.1.103 UF_CUT_LEVELS_edit_level_using_geom 65 8.1.104 UF_CUT_LEVELS_edit_level_using_z 65 8.1.105 UF_CUT_LEVELS_free 65 8.1.106 UF_CUT_LEVELS_load 65 8.1.107 UF_CUT_LEVELS_reset_to_default 65 8.1.108 UF_CUT_LEVELS_set_range_type 65 8.1.109 UF_CUTTER_ask_holder_data 65 8.1.110 UF_CUTTER_ask_section_count 65 8.1.111 UF_CUTTER_ask_tracking_point_count 65 8.1.112 UF_CUTTER_ask_tracking_point_data 65 8.1.113 UF_CUTTER_ask_turn_tracking_point_data 65 8.1.114 UF_CUTTER_ask_type_and_subtype 65 8.1.115 UF_CUTTER_create 65 8.1.116 UF_CUTTER_create_holder_section 65 8.1.117 UF_CUTTER_create_tracking_point 65 8.1.118 UF_CUTTER_create_turn_tracking_point 65 8.1.119 UF_CUTTER_delete_holder_section 65 8.1.120 UF_CUTTER_delete_tracking_point 65 8.1.121 UF_CUTTER_edit_holder_section 65 8.1.122 UF_CUTTER_retrieve 65 8.1.123 UF_CUTTER_set_tracking_point_data 65 8.1.124 UF_CUTTER_set_turn_tracking_point_data 65 8.1.125 UF_CUTTER_update_from_lib 65 8.1.126 UF_FBM_GEOM_ask_accessibility_vectors 65 8.1.127 UF_FBM_GEOM_ask_available_criteria 65 8.1.128 UF_FBM_GEOM_ask_double_of_criteria 66 8.1.129 UF_FBM_GEOM_ask_double_value_of_classified_crit 66 8.1.130 UF_FBM_GEOM_ask_feature_entities 66 8.1.131 UF_FBM_GEOM_ask_feature_name 66 8.1.132 UF_FBM_GEOM_ask_features 66 8.1.133 UF_FBM_GEOM_ask_int_value_of_classified_crit 66 8.1.134 UF_FBM_GEOM_ask_integer_of_criteria 66 8.1.135 UF_FBM_GEOM_ask_list_of_feature_names 66 8.1.136 UF_FBM_GEOM_ask_logical_of_criteria 66 8.1.137 UF_FBM_GEOM_ask_logical_value_of_classified_crit 66 8.1.138 UF_FBM_GEOM_ask_representative_features 66 8.1.139 UF_FBM_GEOM_ask_string_of_criteria 66 8.1.140 UF_FBM_GEOM_ask_string_value_of_classified_crit 66 8.1.141 UF_FBM_GEOM_ask_type_of_criterion 66 8.1.142 UF_FBM_GEOM_ask_used_criteria 66 8.1.143 UF_FBM_GEOM_classify_by_criteria 66 8.1.144 UF_FBM_GEOM_create 66 8.1.145 UF_FBM_GEOM_free_classified_set_list 66 8.1.146 UF_FBM_GEOM_remove_accessibility_vectors 66 8.1.147 UF_FBM_GEOM_remove_feature 66 8.1.148 UF_FBM_GEOM_set_accessibility_vectors 66 8.1.149 UF_FBM_GEOM_set_classified_features 66 8.1.150 UF_FBM_GEOM_set_feature_name 66 8.1.151 UF_HMOP_ask_hole_axis 66 8.1.152 UF_HMOP_ask_hole_depth 66 8.1.153 UF_HMOP_ask_hole_top 66 8.1.154 UF_HMOP_set_hole_axis 67 8.1.155 UF_HMOP_set_hole_depth 67 8.1.156 UF_HMOP_set_hole_top 67 8.1.157 UF_MFM_ask_attribute_type 67 8.1.158 UF_MFM_ask_attributes 67 8.1.159 UF_MFM_ask_candidate_machining_feature_types 67 8.1.160 UF_MFM_ask_double_value_of_attribute 67 8.1.161 UF_MFM_ask_feature_name 67 8.1.162 UF_MFM_ask_feature_type 67 8.1.163 UF_MFM_ask_geometry_groups 67 8.1.164 UF_MFM_ask_integer_value_of_attribute 67 8.1.165 UF_MFM_ask_list_of_faces 67 8.1.166 UF_MFM_ask_logical_value_of_attribute 67 8.1.167 UF_MFM_ask_machined_status 67 8.1.168 UF_MFM_ask_machining_feature_types 67 8.1.169 UF_MFM_ask_machining_features_of_part 67 8.1.170 UF_MFM_ask_machining_features_of_type 67 8.1.171 UF_MFM_ask_overridden_status 67 8.1.172 UF_MFM_ask_selected_fea_list 67 8.1.173 UF_MFM_ask_source_type 67 8.1.174 UF_MFM_ask_string_value_of_attribute 67 8.1.175 UF_MFM_clean_selected_fea_list 67 8.1.176 UF_MFM_create_machining_feature 67 8.1.177 UF_MFM_create_machining_features_from_modeling_features 67 8.1.178 UF_MFM_create_machining_features_from_recognized_features 67 8.1.179 UF_MFM_create_machining_features_from_tagged_arcs 68 8.1.180 UF_MFM_create_machining_features_from_tagged_edges 68 8.1.181 UF_MFM_create_machining_features_from_tagged_faces 68 8.1.182 UF_MFM_create_machining_features_from_tagged_points 68 8.1.183 UF_MFM_create_machining_features_from_user_defined_features 68 8.1.184 UF_MFM_delete_machining_features 68 8.1.185 UF_MFM_has_selected_fea_list 68 8.1.186 UF_MFM_recognize_holes 68 8.1.187 UF_MFM_set_double_UG_attribute 68 8.1.188 UF_MFM_set_double_value_of_attribute 68 8.1.189 UF_MFM_set_feature_name 68 8.1.190 UF_MFM_set_int_ug_attribute 68 8.1.191 UF_MFM_set_integer_value_of_attribute 68 8.1.192 UF_MFM_set_logical_value_of_attribute 68 8.1.193 UF_MFM_set_selected_fea_list 68 8.1.194 UF_MFM_set_string_ug_attribute 68 8.1.195 UF_MFM_set_string_value_of_attribute 68 8.1.196 UF_OPER_ask_name 68 8.1.197 UF_OPER_ask_oper 68 8.1.198 UF_OPER_ask_path 68 8.1.199 UF_OPRBND_append_item_ude 68 8.1.200 UF_OPRBND_ask_boundary_app_data 68 8.1.201 UF_OPRBND_ask_item_app_data 68 8.1.202 UF_OPRBND_ask_item_udes 68 8.1.203 UF_OPRBND_can_accept_item_ude 68 8.1.204 UF_OPRBND_delete_all_item_udes 68 8.1.205 UF_OPRBND_delete_item_ude 69 8.1.206 UF_OPRBND_set_boundary_app_data 69 8.1.207 UF_OPRBND_set_item_app_data 69 8.1.208 UF_TURN_ask_cut_region_of_index 69 8.1.209 UF_TURN_ask_cut_regions_exist 69 8.1.210 UF_TURN_create_blank_from_boundary 69 8.1.211 UF_TURN_create_parametric_blank 69 8.1.212 UF_TURN_ipw_box 69 8.1.213 UF_TURN_map_angle_from_wcs 69 8.1.214 UF_TURN_map_angle_to_wcs 69 8.1.215 UF_TURN_map_pnt2_from_wcs 69 8.1.216 UF_TURN_map_pnt2_to_acs 69 8.1.217 UF_TURN_map_pnt2_to_wcs 69 8.1.218 UF_TURN_map_pnt3_from_acs 69 8.1.219 UF_TURN_map_tooltrackingpoint_from_wcs 69 8.1.220 UF_TURN_map_tooltrackingpoint_to_wcs 69 8.1.221 UF_TURN_map_vec2_from_wcs 69 8.1.222 UF_TURN_map_vec2_to_acs 69 8.1.223 UF_TURN_map_vec2_to_wcs 69 8.1.224 UF_TURN_map_vec3_from_acs 69 8.1.225 UF_TURN_save_spinning_ipw_as_part 69 8.1.226 UF_TURN_teachmode_create_subop 69 8.1.227 UF_UDE_ask_boolean 69 8.1.228 UF_UDE_ask_double 69 8.1.229 UF_UDE_ask_integer 69 8.1.230 UF_UDE_ask_name 69 8.1.231 UF_UDE_ask_param_toggle 70 8.1.232 UF_UDE_ask_param_type 70 8.1.233 UF_UDE_ask_params 70 8.1.234 UF_UDE_ask_point 70 8.1.235 UF_UDE_ask_string 70 8.1.236 UF_UDE_ask_vector 70 8.1.237 UF_UDE_is_param_optional 70 8.1.238 UF_UDE_set_boolean 70 8.1.239 UF_UDE_set_double 70 8.1.240 UF_UDE_set_integer 70 8.1.241 UF_UDE_set_param_toggle 70 8.1.242 UF_UDE_set_point 70 8.1.243 UF_UDE_set_string 70 8.1.244 UF_UDE_set_vector 70 8.1.245 UF_UI_ONT_ask_selected_nodes 70 8.1.246 UF_UI_ONT_ask_view 70 8.1.247 UF_UI_ONT_collapse_view 70 8.1.248 UF_UI_ONT_expand_view 70 8.1.249 UF_UI_ONT_refresh 70 8.1.250 UF_UI_ONT_switch_view 70 8.1.251 UF_UI_PARAM_edit_object 70 9 UF_CFI 文件操作的函数说明. 70 9.1..... UF_CFI Functions 70 9.1.1 uc4500 70 9.1.2 uc4504 70 9.1.3 uc4506 71 9.1.4 uc4507 71 9.1.5 uc4508 71 9.1.6 uc4509 71 9.1.7 uc4510 71 9.1.8 uc4511 71 9.1.9 uc4512 71 9.1.10 uc4513 71 9.1.11 uc4514 71 9.1.12 uc4516 71 9.1.13 uc4517 71 9.1.14 uc4518 71 9.1.15 uc4519 71 9.1.16 uc4520 71 9.1.17 uc4521 71 9.1.18 uc4522 71 9.1.19 uc4523 71 9.1.20 uc4524 71 9.1.21 uc4525 71 9.1.22 uc4526 71 9.1.23 uc4527 71 9.1.24 uc4530 71 9.1.25 uc4531 71 9.1.26 uc4532 71 9.1.27 uc4533 71 9.1.28 uc4534 71 9.1.29 uc4535 72 9.1.30 uc4536 72 9.1.31 uc4540 72 9.1.32 uc4544 72 9.1.33 uc4547 72 9.1.34 uc4548 72 9.1.35 uc4549 72 9.1.36 uc4560 72 9.1.37 uc4561 72 9.1.38 uc4562 72 9.1.39 uc4563 72 9.1.40 uc4564 72 9.1.41 uc4565 72 9.1.42 uc4566 72 9.1.43 uc4567 72 9.1.44 uc4570 72 9.1.45 uc4571 72 9.1.46 uc4572 72 9.1.47 uc4573 72 9.1.48 uc4574 72 9.1.49 uc4575 72 9.1.50 uc4576 72 9.1.51 uc4577 72 9.1.52 uc4578 72 9.1.53 uc4579 72 9.1.54 uc4580 72 9.1.55 uc4581 73 9.1.56 uc4582 73 9.1.57 uc4583 73 9.1.58 uc4595 73 9.1.59 uc4596 73 9.1.60 uc4599 73 9.1.61 uc4600 73 9.1.62 uc4601 73 9.1.63 uc4602 73 9.1.64 uc4603 73 9.1.65 uc4605 73 9.1.66 uc4606 73 9.1.67 uc4607 73 9.1.68 uc4608 73 9.1.69 uc4609 73 9.1.70 uc4612 73 9.1.71 uc4613 73 9.1.72 uc4617 73 9.1.73 uc4618 73 9.1.74 uc4620 73 9.1.75 uc4621 73 9.1.76 uc4622 73 9.1.77 uc4623 73 9.1.78 uc4624 73 9.1.79 uc4650 73 9.1.80 uc4901 73 9.1.81 UF_CFI_ask_file_exist 74 9.1.82 UF_CFI_spawn 74 9.1.83 UF_CFI_spawn_check_status 74 10 UF_CGM 与CGM导入导出操作相关的函数. 74 10.1... UF_CGM Functions 74 10.1.1 UF_CGM_ask_default_custom_colors 74 10.1.2 UF_CGM_ask_default_custom_widths 74 10.1.3 UF_CGM_ask_default_export_options 74 10.1.4 UF_CGM_ask_session_custom_colors 74 10.1.5 UF_CGM_ask_session_custom_widths 74 10.1.6 UF_CGM_ask_session_export_options 74 10.1.7 UF_CGM_export_cgm 74 10.1.8 UF_CGM_import_cgm 74 10.1.9 UF_CGM_init_import_options 74 10.1.10 UF_CGM_set_session_custom_colors 74 10.1.11 UF_CGM_set_session_custom_widths 74 10.1.12 UF_CGM_set_session_export_options 74 11 UF_CLEAR 查询、分析、创建区域清除函数的说明. 74 11.1... UF_CLEAR Functions 74 11.1.1 UF_CLEAR_ask_analysis_mode 74 11.1.2 UF_CLEAR_ask_dataset_name 74 11.1.3 UF_CLEAR_ask_dataset_version 74 11.1.4 UF_CLEAR_ask_default_clear_zone 74 11.1.5 UF_CLEAR_ask_exclude_rules 75 11.1.6 UF_CLEAR_ask_interf_data 75 11.1.7 UF_CLEAR_ask_next_dataset 75 11.1.8 UF_CLEAR_ask_next_interf 75 11.1.9 UF_CLEAR_ask_num_lists 75 11.1.10 UF_CLEAR_ask_obj_all_but_list 75 11.1.11 UF_CLEAR_ask_obj_list 75 11.1.12 UF_CLEAR_ask_object_clear_zone 75 11.1.13 UF_CLEAR_ask_pair_clear_zone 75 11.1.14 UF_CLEAR_ask_preferences 75 11.1.15 UF_CLEAR_ask_results 75 11.1.16 UF_CLEAR_copy_dataset 75 11.1.17 UF_CLEAR_count_datasets 75 11.1.18 UF_CLEAR_count_interferences 75 11.1.19 UF_CLEAR_create_dataset 75 11.1.20 UF_CLEAR_delete_all 75 11.1.21 UF_CLEAR_delete_dataset 75 11.1.22 UF_CLEAR_delete_interf 75 11.1.23 UF_CLEAR_do_clearance_analysis 75 11.1.24 UF_CLEAR_find_dataset 75 11.1.25 UF_CLEAR_is_pair_changed 75 11.1.26 UF_CLEAR_is_pair_included 75 11.1.27 UF_CLEAR_rename_dataset 75 11.1.28 UF_CLEAR_set_analysis_mode 75 11.1.29 UF_CLEAR_set_default_clear_zone 75 11.1.30 UF_CLEAR_set_exclude_rules 75 11.1.31 UF_CLEAR_set_interf_text 76 11.1.32 UF_CLEAR_set_obj_list 76 11.1.33 UF_CLEAR_set_object_clear_zone 76 11.1.34 UF_CLEAR_set_pair_clear_zone 76 11.1.35 UF_CLEAR_set_pair_exclusion 76 11.1.36 UF_CLEAR_set_pair_inclusion 76 11.1.37 UF_CLEAR_set_preferences 76 12 UF_CLONE 基于PDM装配下的导入导出函数. 77 12.1... UF_CLONE Functions 77 12.1.1 UF_CLONE_add_assembly 77 12.1.2 UF_CLONE_add_part 77 12.1.3 UF_CLONE_apply_defaults 77 12.1.4 UF_CLONE_apply_selective_export_xml 77 12.1.5 UF_CLONE_ask_action 77 12.1.6 UF_CLONE_ask_assoc_file_copy 77 12.1.7 UF_CLONE_ask_assoc_file_dir 77 12.1.8 UF_CLONE_ask_assoc_file_root_dir 77 12.1.9 UF_CLONE_ask_attach_log_file 77 12.1.10 UF_CLONE_ask_ci 77 12.1.11 UF_CLONE_ask_ci_comment_checking 77 12.1.12 UF_CLONE_ask_co 77 12.1.13 UF_CLONE_ask_cvt_callbacks 77 12.1.14 UF_CLONE_ask_def_action 77 12.1.15 UF_CLONE_ask_def_assoc_file_copy 77 12.1.16 UF_CLONE_ask_def_ci 77 12.1.17 UF_CLONE_ask_def_ci_comment_checking 77 12.1.18 UF_CLONE_ask_def_co 77 12.1.19 UF_CLONE_ask_def_directory 77 12.1.20 UF_CLONE_ask_def_folder 77 12.1.21 UF_CLONE_ask_def_group 77 12.1.22 UF_CLONE_ask_def_item_type 77 12.1.23 UF_CLONE_ask_def_naming 77 12.1.24 UF_CLONE_ask_def_nm_copy 78 12.1.25 UF_CLONE_ask_def_owner 78 12.1.26 UF_CLONE_ask_def_pdm_desc 78 12.1.27 UF_CLONE_ask_def_pdm_name 78 12.1.28 UF_CLONE_ask_def_validation_options 78 12.1.29 UF_CLONE_ask_dryrun 78 12.1.30 UF_CLONE_ask_family_treatment 78 12.1.31 UF_CLONE_ask_group 78 12.1.32 UF_CLONE_ask_item_type 78 12.1.33 UF_CLONE_ask_logfile 78 12.1.34 UF_CLONE_ask_naming 78 12.1.35 UF_CLONE_ask_nm_copy 78 12.1.36 UF_CLONE_ask_ntfy_callbacks 78 12.1.37 UF_CLONE_ask_operation_class 78 12.1.38 UF_CLONE_ask_owner 78 12.1.39 UF_CLONE_ask_part_attrs 78 12.1.40 UF_CLONE_ask_part_state 78 12.1.41 UF_CLONE_ask_pdm_desc 78 12.1.42 UF_CLONE_ask_pdm_name 78 12.1.43 UF_CLONE_ask_rev_up 78 12.1.44 UF_CLONE_ask_validation_abort_option 78 12.1.45 UF_CLONE_ask_validation_options 78 12.1.46 UF_CLONE_create_log_file 78 12.1.47 UF_CLONE_execute_log_file 78 12.1.48 UF_CLONE_free_validation_options 78 12.1.49 UF_CLONE_generate_report 78 12.1.50 UF_CLONE_init_log_file_failure 79 12.1.51 UF_CLONE_init_naming_failures 79 12.1.52 UF_CLONE_initialise 79 12.1.53 UF_CLONE_iterate 79 12.1.54 UF_CLONE_load_logfile 79 12.1.55 UF_CLONE_part_under_specified 79 12.1.56 UF_CLONE_perform_clone 79 12.1.57 UF_CLONE_register_cvt_callback 79 12.1.58 UF_CLONE_register_ntfy_callback 79 12.1.59 UF_CLONE_remove_cvt_callback 79 12.1.60 UF_CLONE_remove_ntfy_callback 79 12.1.61 UF_CLONE_reset_to_default 79 12.1.62 UF_CLONE_set_action 79 12.1.63 UF_CLONE_set_assoc_file_copy 79 12.1.64 UF_CLONE_set_assoc_file_dir 79 12.1.65 UF_CLONE_set_assoc_file_root_dir 79 12.1.66 UF_CLONE_set_attach_log_file 79 12.1.67 UF_CLONE_set_ci 79 12.1.68 UF_CLONE_set_ci_comment_checking 79 12.1.69 UF_CLONE_set_co 79 12.1.70 UF_CLONE_set_def_action 79 12.1.71 UF_CLONE_set_def_assoc_file_copy 79 12.1.72 UF_CLONE_set_def_ci 79 12.1.73 UF_CLONE_set_def_ci_comment_checking 79 12.1.74 UF_CLONE_set_def_co 79 12.1.75 UF_CLONE_set_def_directory 79 12.1.76 UF_CLONE_set_def_folder 80 12.1.77 UF_CLONE_set_def_group 80 12.1.78 UF_CLONE_set_def_item_type 80 12.1.79 UF_CLONE_set_def_naming 80 12.1.80 UF_CLONE_set_def_nm_copy 80 12.1.81 UF_CLONE_set_def_owner 80 12.1.82 UF_CLONE_set_def_pdm_desc 80 12.1.83 UF_CLONE_set_def_pdm_name 80 12.1.84 UF_CLONE_set_def_validation_options 80 12.1.85 UF_CLONE_set_dryrun 80 12.1.86 UF_CLONE_set_family_treatment 80 12.1.87 UF_CLONE_set_group 80 12.1.88 UF_CLONE_set_item_type 80 12.1.89 UF_CLONE_set_logfile 80 12.1.90 UF_CLONE_set_name_rule 80 12.1.91 UF_CLONE_set_naming 80 12.1.92 UF_CLONE_set_nm_copy 80 12.1.93 UF_CLONE_set_owner 80 12.1.94 UF_CLONE_set_pdm_desc 80 12.1.95 UF_CLONE_set_pdm_name 80 12.1.96 UF_CLONE_set_propagate_actions 80 12.1.97 UF_CLONE_set_rev_up 80 12.1.98 UF_CLONE_set_validation_abort_option 80 12.1.99 UF_CLONE_set_validation_options 80 12.1.100 UF_CLONE_start_iteration 80 12.1.101 UF_CLONE_stop_iteration 80 12.1.102 UF_CLONE_terminate 81 12.1.103 UF_CLONE_unapply_defaults 81 13 UF_CSYS 坐标系的操作函数与类型说明. 82 13.1... UF_CSYS Functions 82 13.1.1 UF_CSYS_ask_csys_info 82 13.1.2 UF_CSYS_ask_matrix_of_object 82 13.1.3 UF_CSYS_ask_matrix_values 82 13.1.4 UF_CSYS_ask_wcs 82 13.1.5 UF_CSYS_create_csys 82 13.1.6 UF_CSYS_create_matrix 82 13.1.7 UF_CSYS_create_temp_csys 82 13.1.8 UF_CSYS_edit_matrix_of_object 82 13.1.9 UF_CSYS_map_point 82 13.1.10 UF_CSYS_set_origin 82 13.1.11 UF_CSYS_set_wcs 82 13.1.12 UF_CSYS_set_wcs_display 82 14 UF_CURVE 曲线和点的操作函数及相关信息说明. 82 14.1... UF_CURVE Functions 82 14.1.1 uf5063 82 14.1.2 uf5070 82 14.1.3 uf5071 82 14.1.4 uf5072 82 14.1.5 uf5072x 82 14.1.6 uf5073 82 14.1.7 uf5074 82 14.1.8 uf5074x 83 14.1.9 uf5075 83 14.1.10 uf5080 83 14.1.11 uf5081 83 14.1.12 uf5082 83 14.1.13 uf5083 83 14.1.14 uf5083x 83 14.1.15 uf5084 83 14.1.16 uf5085 83 14.1.17 uf5445 83 14.1.18 uf5446 83 14.1.19 uf5447 83 14.1.20 uf5463 83 14.1.21 uf5466 83 14.1.22 uf5900 83 14.1.23 uf5901 83 14.1.24 uf5903 83 14.1.25 uf5910 83 14.1.26 uf5911 83 14.1.27 uf5930 83 14.1.28 uf5931 83 14.1.29 uf5932 83 14.1.30 UF_CURVE_add_faces_ocf_data 83 14.1.31 UF_CURVE_add_string_to_ocf_data 83 14.1.32 UF_CURVE_ask_analysis_display 83 14.1.33 UF_CURVE_ask_arc_data 83 14.1.34 UF_CURVE_ask_arc_length 84 14.1.35 UF_CURVE_ask_bridge_feature 84 14.1.36 UF_CURVE_ask_centroid 84 14.1.37 UF_CURVE_ask_combine_curves 84 14.1.38 UF_CURVE_ask_conic_data 84 14.1.39 UF_CURVE_ask_curve_fit_data 84 14.1.40 UF_CURVE_ask_curve_inflections 84 14.1.41 UF_CURVE_ask_curve_struct 84 14.1.42 UF_CURVE_ask_curve_struct_data 84 14.1.43 UF_CURVE_ask_curve_turn_angle 84 14.1.44 UF_CURVE_ask_feature_curves 84 14.1.45 UF_CURVE_ask_int_curve_parents 84 14.1.46 UF_CURVE_ask_int_curves 84 14.1.47 UF_CURVE_ask_int_parms 84 14.1.48 UF_CURVE_ask_int_parms_sc 84 14.1.49 UF_CURVE_ask_isocline 84 14.1.50 UF_CURVE_ask_joined_parms 84 14.1.51 UF_CURVE_ask_line_arc_data 84 14.1.52 UF_CURVE_ask_line_arc_output 84 14.1.53 UF_CURVE_ask_line_data 84 14.1.54 UF_CURVE_ask_ocf_data 84 14.1.55 UF_CURVE_ask_offset_curves 84 14.1.56 UF_CURVE_ask_offset_direction 84 14.1.57 UF_CURVE_ask_offset_parms 84 14.1.58 UF_CURVE_ask_parameterization 84 14.1.59 UF_CURVE_ask_point_data 84 14.1.60 UF_CURVE_ask_proj_curve_parents 85 14.1.61 UF_CURVE_ask_proj_curves 85 14.1.62 UF_CURVE_ask_spline_data 85 14.1.63 UF_CURVE_ask_spline_feature 85 14.1.64 UF_CURVE_ask_spline_sap 85 14.1.65 UF_CURVE_ask_spline_thru_pts 85 14.1.66 UF_CURVE_ask_trim 85 14.1.67 UF_CURVE_ask_wrap_curve_parents 85 14.1.68 UF_CURVE_ask_wrap_curves 85 14.1.69 UF_CURVE_ask_wrap_parms 85 14.1.70 UF_CURVE_auto_join_curves 85 14.1.71 UF_CURVE_convert_conic_to_gen 85 14.1.72 UF_CURVE_convert_conic_to_std 85 14.1.73 UF_CURVE_create_arc 85 14.1.74 UF_CURVE_create_arc_3point 85 14.1.75 UF_CURVE_create_arc_3tangent 85 14.1.76 UF_CURVE_create_arc_center_radius 85 14.1.77 UF_CURVE_create_arc_center_tangent 85 14.1.78 UF_CURVE_create_arc_point_center 85 14.1.79 UF_CURVE_create_arc_point_point_radius 85 14.1.80 UF_CURVE_create_arc_point_point_tangent 85 14.1.81 UF_CURVE_create_arc_point_tangent_point 85 14.1.82 UF_CURVE_create_arc_point_tangent_radius 85 14.1.83 UF_CURVE_create_arc_point_tangent_tangent 85 14.1.84 UF_CURVE_create_arc_tangent_point_point 85 14.1.85 UF_CURVE_create_arc_tangent_point_tangent 85 14.1.86 UF_CURVE_create_arc_tangent_tangent_point 86 14.1.87 UF_CURVE_create_arc_tangent_tangent_radius 86 14.1.88 UF_CURVE_create_arc_thru_3pts 86 14.1.89 UF_CURVE_create_bridge_curve 86 14.1.90 UF_CURVE_create_bridge_feature 86 14.1.91 UF_CURVE_create_combine_curves 86 14.1.92 UF_CURVE_create_conic 86 14.1.93 UF_CURVE_create_fillet 86 14.1.94 UF_CURVE_create_int_object 86 14.1.95 UF_CURVE_create_isocline 86 14.1.96 UF_CURVE_create_joined_curve 86 14.1.97 UF_CURVE_create_joined_feature 86 14.1.98 UF_CURVE_create_line 86 14.1.99 UF_CURVE_create_line_arc 86 14.1.100 UF_CURVE_create_line_point_angle 86 14.1.101 UF_CURVE_create_line_point_point 86 14.1.102 UF_CURVE_create_line_point_principal_axis 86 14.1.103 UF_CURVE_create_line_point_tangent 86 14.1.104 UF_CURVE_create_line_tangent_point 86 14.1.105 UF_CURVE_create_ocf_feature 86 14.1.106 UF_CURVE_create_offset_curve 86 14.1.107 UF_CURVE_create_offset_object 86 14.1.108 UF_CURVE_create_point 86 14.1.109 UF_CURVE_create_proj_curves 86 14.1.110 UF_CURVE_create_proj_curves1 86 14.1.111 UF_CURVE_create_shadow_outline 86 14.1.112 UF_CURVE_create_silhouette 87 14.1.113 UF_CURVE_create_simplified_curve 87 14.1.114 UF_CURVE_create_spline 87 14.1.115 UF_CURVE_create_spline_feature 87 14.1.116 UF_CURVE_create_spline_thru_pts 87 14.1.117 UF_CURVE_create_trim 87 14.1.118 UF_CURVE_create_wrap_object 87 14.1.119 UF_CURVE_edit_arc_data 87 14.1.120 UF_CURVE_edit_bridge_feature 87 14.1.121 UF_CURVE_edit_by_curve_fit_data 87 14.1.122 UF_CURVE_edit_combine_curves 87 14.1.123 UF_CURVE_edit_conic_data 87 14.1.124 UF_CURVE_edit_int_object 87 14.1.125 UF_CURVE_edit_isocline 87 14.1.126 UF_CURVE_edit_joined_feature 87 14.1.127 UF_CURVE_edit_length 87 14.1.128 UF_CURVE_edit_line_arc 87 14.1.129 UF_CURVE_edit_line_data 87 14.1.130 UF_CURVE_edit_move_mult_points 87 14.1.131 UF_CURVE_edit_ocf_feature 87 14.1.132 UF_CURVE_edit_offset_object 87 14.1.133 UF_CURVE_edit_point_data 87 14.1.134 UF_CURVE_edit_proj_curves 87 14.1.135 UF_CURVE_edit_proj_curves1 87 14.1.136 UF_CURVE_edit_spline_feature 87 14.1.137 UF_CURVE_edit_spline_thru_pts 87 14.1.138 UF_CURVE_edit_trim 88 14.1.139 UF_CURVE_edit_trim_curve 88 14.1.140 UF_CURVE_edit_with_template 88 14.1.141 UF_CURVE_edit_wrap_object 88 14.1.142 UF_CURVE_evaluate_curve 88 14.1.143 UF_CURVE_evaluate_curve_structure 88 14.1.144 UF_CURVE_fix_spline_data 88 14.1.145 UF_CURVE_free_curve_struct 88 14.1.146 UF_CURVE_free_ocf_data 88 14.1.147 UF_CURVE_free_offset_parms 88 14.1.148 UF_CURVE_free_trim 88 14.1.149 UF_CURVE_free_wrap_parms 88 14.1.150 UF_CURVE_init_ocf_data 88 14.1.151 UF_CURVE_init_proj_curves_data 88 14.1.152 UF_CURVE_init_proj_curves_data1 88 14.1.153 UF_CURVE_intersect 88 14.1.154 UF_CURVE_is_spline_in_sync 88 14.1.155 UF_CURVE_is_spline_self_int 88 14.1.156 UF_CURVE_LINE_ARC__is_arc_equal 88 14.1.157 UF_CURVE_LINE_ARC__is_line_equal 88 14.1.158 UF_CURVE_modify_offsets_in_string 88 14.1.159 UF_CURVE_ocf_ask_curves 88 14.1.160 UF_CURVE_ocf_offset_pt_direction 88 14.1.161 UF_CURVE_remove_string_from_ocf_data 88 14.1.162 UF_CURVE_section_ask_parallel_data 88 14.1.163 UF_CURVE_section_ask_perpcrv_data 88 14.1.164 UF_CURVE_section_ask_planes_data 89 14.1.165 UF_CURVE_section_ask_radial_data 89 14.1.166 UF_CURVE_section_ask_type 89 14.1.167 UF_CURVE_section_curve_ask_parents 89 14.1.168 UF_CURVE_section_from_parallel_planes 89 14.1.169 UF_CURVE_section_from_perpcrv_planes 89 14.1.170 UF_CURVE_section_from_planes 89 14.1.171 UF_CURVE_section_from_radial_planes 89 14.1.172 UF_CURVE_set_analysis_display 89 14.1.173 UF_CURVE_set_spline_sap 89 14.1.174 UF_CURVE_smooth_spline_data 89 14.1.175 UF_CURVE_smooth_spline_data_st 89 14.1.176 UF_MODL_ask_curve_fit_data 89 14.1.177 UF_MODL_set_curve_fit_data 89 14.1.178 UF_SF_CURVE_create_arc_3point 89 14.1.179 UF_SF_CURVE_create_arc_center_radius 89 14.1.180 UF_SF_CURVE_create_arc_point_center 89 14.1.181 UF_SF_CURVE_create_arc_point_point_radius 89 14.1.182 UF_SF_CURVE_create_line_arc 89 14.1.183 UF_SF_CURVE_create_line_point_point 89 15 UF_DBC_MLD DBC_MOLD模块函数说明. 90 15.1... UF_DBC_MLD Functions 90 16 UF_DIEENG 90 16.1... UF_DIEENG Functions 90 16.1.1 UF_DIE_ask_binder_wrap 90 16.1.2 UF_DIE_ask_draw_faces 90 16.1.3 UF_DIE_ask_material_properties 90 16.1.4 UF_DIE_create_binder_wrap 90 16.1.5 UF_DIE_edit_binder_wrap 90 16.1.6 UF_DIE_free_binder_wrap 90 16.1.7 UF_DIEENG_create_dol_report_file 90 17 UF_DIRPATH 对于目录搜索路径模块初始化的函数. 90 17.1... UF_DIRPATH Functions 90 17.1.1 UF_DIRPATH_append 90 17.1.2 UF_DIRPATH_append_from_dirs 90 17.1.3 UF_DIRPATH_append_from_env 90 17.1.4 UF_DIRPATH_ask_curr_dir 90 17.1.5 UF_DIRPATH_ask_dir_count 90 17.1.6 UF_DIRPATH_ask_dir_index 90 17.1.7 UF_DIRPATH_ask_dirs 90 17.1.8 UF_DIRPATH_ask_next_dir 90 17.1.9 UF_DIRPATH_ask_nth_dir 90 17.1.10 UF_DIRPATH_ask_prev_dir 91 17.1.11 UF_DIRPATH_create_from_dirs 91 17.1.12 UF_DIRPATH_create_from_env 91 17.1.13 UF_DIRPATH_find_file 91 17.1.14 UF_DIRPATH_start_dir_iteration 91 18 UF_DISP 与显示相关的函数及类型定义. 91 18.1... UF_DISP Functions 91 18.1.1 UF_DISP_activate_grid 91 18.1.2 UF_DISP_add_item_to_display 91 18.1.3 UF_DISP_ask_closest_color 91 18.1.4 UF_DISP_ask_closest_color_in_displayed_part 91 18.1.5 UF_DISP_ask_closest_color_in_part 91 18.1.6 UF_DISP_ask_color 91 18.1.7 UF_DISP_ask_color_count 91 18.1.8 UF_DISP_ask_current_grid_context 91 18.1.9 UF_DISP_ask_display 91 18.1.10 UF_DISP_ask_display_context 91 18.1.11 UF_DISP_ask_drawing_display 91 18.1.12 UF_DISP_ask_grid_parameters 91 18.1.13 UF_DISP_ask_material 91 18.1.14 UF_DISP_ask_model_bounds 91 18.1.15 UF_DISP_ask_model_bounds_tag 91 18.1.16 UF_DISP_ask_name_display_status 91 18.1.17 UF_DISP_ask_name_view_status 91 18.1.18 UF_DISP_ask_srfanl_params 91 18.1.19 UF_DISP_ask_system_parameters 92 18.1.20 UF_DISP_ask_texture_space_info 92 18.1.21 UF_DISP_ask_work_plane_dim_clr 92 18.1.22 UF_DISP_ask_work_plane_emphasis 92 18.1.23 UF_DISP_ask_work_plane_sel 92 18.1.24 UF_DISP_assign_material 92 18.1.25 UF_DISP_batch_shade 92 18.1.26 UF_DISP_batch_shade_options 92 18.1.27 UF_DISP_compute_model_bounds 92 18.1.28 UF_DISP_conehead 92 18.1.29 UF_DISP_copy_material 92 18.1.30 UF_DISP_create_animation 92 18.1.31 UF_DISP_create_framed_image 92 18.1.32 UF_DISP_create_image 92 18.1.33 UF_DISP_deactivate_grid 92 18.1.34 UF_DISP_delete_material 92 18.1.35 UF_DISP_display_arc 92 18.1.36 UF_DISP_display_circle 92 18.1.37 UF_DISP_display_facets 92 18.1.38 UF_DISP_display_ogp_arc 92 18.1.39 UF_DISP_display_ogp_circle 92 18.1.40 UF_DISP_display_ogp_line 92 18.1.41 UF_DISP_display_ogp_polyline 92 18.1.42 UF_DISP_display_points 92 18.1.43 UF_DISP_display_polygon 92 18.1.44 UF_DISP_display_polyline 92 18.1.45 UF_DISP_display_rpo_dimensions 93 18.1.46 UF_DISP_display_sket_dimensions 93 18.1.47 UF_DISP_display_temporary_arc 93 18.1.48 UF_DISP_display_temporary_line 93 18.1.49 UF_DISP_display_temporary_point 93 18.1.50 UF_DISP_display_temporary_text 93 18.1.51 UF_DISP_display_text 93 18.1.52 UF_DISP_export_windows_metafile 93 18.1.53 UF_DISP_get_conehead_attrb 93 18.1.54 UF_DISP_j3d_free_geometry 93 18.1.55 UF_DISP_j3d_geometry 93 18.1.56 UF_DISP_labeled_conehead 93 18.1.57 UF_DISP_load_color_table 93 18.1.58 UF_DISP_make_display_up_to_date 93 18.1.59 UF_DISP_print_window_ug_image 93 18.1.60 UF_DISP_refresh 93 18.1.61 UF_DISP_regenerate_display 93 18.1.62 UF_DISP_regenerate_view 93 18.1.63 UF_DISP_reset_conehead_attrb 93 18.1.64 UF_DISP_set_color 93 18.1.65 UF_DISP_set_conehead_attrb 93 18.1.66 UF_DISP_set_display 93 18.1.67 UF_DISP_set_drawing_display 93 18.1.68 UF_DISP_set_grid_parameters 93 18.1.69 UF_DISP_set_highlight 93 18.1.70 UF_DISP_set_model_bounds 93 18.1.71 UF_DISP_set_name_display_status 94 18.1.72 UF_DISP_set_name_view_status 94 18.1.73 UF_DISP_set_srfanl_params 94 18.1.74 UF_DISP_set_system_parameters 94 18.1.75 UF_DISP_set_texture_space_info 94 18.1.76 UF_DISP_set_work_plane_dim_clr 94 18.1.77 UF_DISP_set_work_plane_emphasis 94 18.1.78 UF_DISP_set_work_plane_sel 94 19 UF_DPUD 关于面驱动路径操作的函数. 94 19.1... UF_DPUD Functions 94 19.1.1 UF_DPUD_ask_dpud 94 19.1.2 UF_DPUD_ask_drpos0 94 19.1.3 UF_DPUD_ask_drpos1 94 19.1.4 UF_DPUD_ask_drpos2 94 19.1.5 UF_DPUD_ask_oper 94 19.1.6 UF_DPUD_ask_proj_option 94 19.1.7 UF_DPUD_ask_proj_vec 94 19.1.8 UF_DPUD_ask_purpose 94 19.1.9 UF_DPUD_ask_ratio 94 19.1.10 UF_DPUD_ask_taxis_option 94 19.1.11 UF_DPUD_ask_tool_axis 94 19.1.12 UF_DPUD_set_user_data_size 94 20 UF_DRAW 与制图相关的函数和类型的定义(截面线、图等的创建及查询). 94 20.1... UF_DRAW Functions 95 20.1.1 uc6476 95 20.1.2 uc6477 95 20.1.3 uc6478 95 20.1.4 uc6479 95 20.1.5 uc6480 95 20.1.6 uc6481 95 20.1.7 uc6482 95 20.1.8 uc6483 95 20.1.9 uc6484 95 20.1.10 uc6485 95 20.1.11 uc6486 95 20.1.12 uc6488 95 20.1.13 uc6489 95 20.1.14 uc6492 95 20.1.15 uc6494 95 20.1.16 uc6495 95 20.1.17 uc6496 95 20.1.18 uc6497 95 20.1.19 uc6498 95 20.1.20 uc6499 95 20.1.21 UF_DRAW_add_auxiliary_view 95 20.1.22 UF_DRAW_add_circ_detail_view 95 20.1.23 UF_DRAW_add_detail_view 95 20.1.24 UF_DRAW_add_orthographic_view 95 20.1.25 UF_DRAW_add_sxline_sxseg 95 20.1.26 UF_DRAW_add_sxseg 96 20.1.27 UF_DRAW_ask_auto_update 96 20.1.28 UF_DRAW_ask_body_sils_in_view 96 20.1.29 UF_DRAW_ask_border_color 96 20.1.30 UF_DRAW_ask_border_display 96 20.1.31 UF_DRAW_ask_bound_by_objects 96 20.1.32 UF_DRAW_ask_boundary_curves 96 20.1.33 UF_DRAW_ask_boundary_type 96 20.1.34 UF_DRAW_ask_break_region_data 96 20.1.35 UF_DRAW_ask_break_regions 96 20.1.36 UF_DRAW_ask_breakout_data 96 20.1.37 UF_DRAW_ask_comp_section_in_view 96 20.1.38 UF_DRAW_ask_current_drawing 96 20.1.39 UF_DRAW_ask_curve_group_members 96 20.1.40 UF_DRAW_ask_curve_of_sxedge 96 20.1.41 UF_DRAW_ask_display_state 96 20.1.42 UF_DRAW_ask_displayed_objects 96 20.1.43 UF_DRAW_ask_dmv_rotation_plane 96 20.1.44 UF_DRAW_ask_drawing_info 96 20.1.45 UF_DRAW_ask_drawing_of_view 96 20.1.46 UF_DRAW_ask_drawing_ref_pt 96 20.1.47 UF_DRAW_ask_drawings 96 20.1.48 UF_DRAW_ask_face_of_sil 96 20.1.49 UF_DRAW_ask_face_sils_in_view 96 20.1.50 UF_DRAW_ask_group_of_curve 96 20.1.51 UF_DRAW_ask_half_sxline 96 20.1.52 UF_DRAW_ask_num_drawings 97 20.1.53 UF_DRAW_ask_num_views 97 20.1.54 UF_DRAW_ask_pictorial_sxline 97 20.1.55 UF_DRAW_ask_render_set_objects 97 20.1.56 UF_DRAW_ask_render_set_parms 97 20.1.57 UF_DRAW_ask_render_sets 97 20.1.58 UF_DRAW_ask_render_sets_of_view 97 20.1.59 UF_DRAW_ask_revolved_sxline 97 20.1.60 UF_DRAW_ask_simple_sxline 97 20.1.61 UF_DRAW_ask_simplified_curve 97 20.1.62 UF_DRAW_ask_solid_of_section 97 20.1.63 UF_DRAW_ask_stepped_sxline 97 20.1.64 UF_DRAW_ask_suppress_view_updat 97 20.1.65 UF_DRAW_ask_sxedges_of_sxsolid 97 20.1.66 UF_DRAW_ask_sxline_default_prfs 97 20.1.67 UF_DRAW_ask_sxline_display 97 20.1.68 UF_DRAW_ask_sxline_of_sxview 97 20.1.69 UF_DRAW_ask_sxline_sxseg 97 20.1.70 UF_DRAW_ask_sxline_type 97 20.1.71 UF_DRAW_ask_sxsolids_of_sxview 97 20.1.72 UF_DRAW_ask_sxview_display 97 20.1.73 UF_DRAW_ask_unfolded_sxline 97 20.1.74 UF_DRAW_ask_view_anchor 97 20.1.75 UF_DRAW_ask_view_angle 97 20.1.76 UF_DRAW_ask_view_borders 97 20.1.77 UF_DRAW_ask_view_display 97 20.1.78 UF_DRAW_ask_view_label 98 20.1.79 UF_DRAW_ask_view_label_parms 98 20.1.80 UF_DRAW_ask_view_notes 98 20.1.81 UF_DRAW_ask_view_of_drawing 98 20.1.82 UF_DRAW_ask_view_of_note 98 20.1.83 UF_DRAW_ask_view_of_view_label 98 20.1.84 UF_DRAW_ask_view_parm_scale 98 20.1.85 UF_DRAW_ask_view_scale 98 20.1.86 UF_DRAW_ask_view_status 98 20.1.87 UF_DRAW_ask_view_thd_app_pitch 98 20.1.88 UF_DRAW_ask_view_thd_meth 98 20.1.89 UF_DRAW_ask_views 98 20.1.90 UF_DRAW_ask_xhatch_of_sxsolid 98 20.1.91 UF_DRAW_attach_note_to_view 98 20.1.92 UF_DRAW_copy_view 98 20.1.93 UF_DRAW_create_break_region 98 20.1.94 UF_DRAW_create_breakout 98 20.1.95 UF_DRAW_create_drawing 98 20.1.96 UF_DRAW_create_half_sxview 98 20.1.97 UF_DRAW_create_render_set 98 20.1.98 UF_DRAW_create_revolved_sxview 98 20.1.99 UF_DRAW_create_simple_sxview 98 20.1.100 UF_DRAW_create_simplified_curve 98 20.1.101 UF_DRAW_create_stepped_sxview 98 20.1.102 UF_DRAW_create_sxview_from_dmv 98 20.1.103 UF_DRAW_create_unfolded_sxview 98 20.1.104 UF_DRAW_create_view_label 99 20.1.105 UF_DRAW_define_bound_by_objects 99 20.1.106 UF_DRAW_define_view_auto_rect 99 20.1.107 UF_DRAW_define_view_boundary 99 20.1.108 UF_DRAW_define_view_manual_rect 99 20.1.109 UF_DRAW_delete_drawing 99 20.1.110 UF_DRAW_delete_sxline_sxseg 99 20.1.111 UF_DRAW_delete_view_label 99 20.1.112 UF_DRAW_detach_note_from_view 99 20.1.113 UF_DRAW_edit_boundary_point 99 20.1.114 UF_DRAW_edit_sxline_display 99 20.1.115 UF_DRAW_erase_sxview_objects 99 20.1.116 UF_DRAW_free_boundary 99 20.1.117 UF_DRAW_get_view_model_view_part 99 20.1.118 UF_DRAW_import_view 99 20.1.119 UF_DRAW_initialize_view_info 99 20.1.120 UF_DRAW_is_drafting_component 99 20.1.121 UF_DRAW_is_object_out_of_date 99 20.1.122 UF_DRAW_is_sxview 99 20.1.123 UF_DRAW_is_thread_curve 99 20.1.124 UF_DRAW_move_sxline_rotpt 99 20.1.125 UF_DRAW_move_sxline_sxseg 99 20.1.126 UF_DRAW_move_sxseg 99 20.1.127 UF_DRAW_move_view 99 20.1.128 UF_DRAW_move_view_to_drawing 99 20.1.129 UF_DRAW_open_drawing 99 20.1.130 UF_DRAW_redefine_sxline_hinge 100 20.1.131 UF_DRAW_remove_break_region 100 20.1.132 UF_DRAW_remove_breakout 100 20.1.133 UF_DRAW_remove_dmv_rotation_plane 100 20.1.134 UF_DRAW_rename_drawing 100 20.1.135 UF_DRAW_retrieve_drawing_cgm 100 20.1.136 UF_DRAW_set_auto_update 100 20.1.137 UF_DRAW_set_border_color 100 20.1.138 UF_DRAW_set_border_display 100 20.1.139 UF_DRAW_set_boundary_assoc 100 20.1.140 UF_DRAW_set_break_region_data 100 20.1.141 UF_DRAW_set_breakout_data 100 20.1.142 UF_DRAW_set_comp_section_in_view 100 20.1.143 UF_DRAW_set_display_state 100 20.1.144 UF_DRAW_set_dmv_rotation_plane 100 20.1.145 UF_DRAW_set_drawing_info 100 20.1.146 UF_DRAW_set_drawing_ref_pt 100 20.1.147 UF_DRAW_set_render_set_objects 100 20.1.148 UF_DRAW_set_render_set_parms 100 20.1.149 UF_DRAW_set_render_sets_for_view 100 20.1.150 UF_DRAW_set_suppress_view_updat 100 20.1.151 UF_DRAW_set_sxline_default_prfs 100 20.1.152 UF_DRAW_set_sxview_display 100 20.1.153 UF_DRAW_set_view_anchor 100 20.1.154 UF_DRAW_set_view_angle 100 20.1.155 UF_DRAW_set_view_display 100 20.1.156 UF_DRAW_set_view_label_parms 101 20.1.157 UF_DRAW_set_view_parm_scale 101 20.1.158 UF_DRAW_set_view_scale 101 20.1.159 UF_DRAW_set_view_status 101 20.1.160 UF_DRAW_set_view_thd_app_pitch 101 20.1.161 UF_DRAW_set_view_thd_meth 101 20.1.162 UF_DRAW_upd_out_of_date_views 101 20.1.163 UF_DRAW_update_one_view 101 21 UF_DRF 制图的符号、标注、尺寸等函数的定义. 102 21.1... UF_DRF Functions 102 21.1.1 uc5530 102 21.1.2 uc5531 102 21.1.3 uc5532 102 21.1.4 uc5533 102 21.1.5 uc5534 102 21.1.6 uc5540 102 21.1.7 uc5541 102 21.1.8 uc5542 102 21.1.9 uc5543 102 21.1.10 uc5550 102 21.1.11 uc5551 102 21.1.12 uc5563 102 21.1.13 uc5566 102 21.1.14 uc5574 102 21.1.15 uf5505 102 21.1.16 uf5506 102 21.1.17 uf5522 102 21.1.18 uf5523 102 21.1.19 uf5524 102 21.1.20 uf5547 102 21.1.21 uf554a 102 21.1.22 uf554b 102 21.1.23 uf554c 102 21.1.24 uf5552 103 21.1.25 uf5553 103 21.1.26 uf5554 103 21.1.27 uf5555 103 21.1.28 uf5561 103 21.1.29 uf5562 103 21.1.30 uf5564 103 21.1.31 uf5565 103 21.1.32 uf5575 103 21.1.33 UF_DRF_add_assortpart_to_ann 103 21.1.34 UF_DRF_add_compound_weld_symbol 103 21.1.35 UF_DRF_add_controlling_exp 103 21.1.36 UF_DRF_add_symbol_to_object 103 21.1.37 UF_DRF_add_to_dimension 103 21.1.38 UF_DRF_are_draft_objects_const 103 21.1.39 UF_DRF_ask_ang_obj_suppress_zeros 103 21.1.40 UF_DRF_ask_ang_obj_units_format 103 21.1.41 UF_DRF_ask_ann_arc_seg_angles 103 21.1.42 UF_DRF_ask_ann_data 103 21.1.43 UF_DRF_ask_ann_line_seg_ends 103 21.1.44 UF_DRF_ask_annotation_template 103 21.1.45 UF_DRF_ask_annotation_text_box 103 21.1.46 UF_DRF_ask_appended_text 103 21.1.47 UF_DRF_ask_areafill_data 103 21.1.48 UF_DRF_ask_arrow_data 103 21.1.49 UF_DRF_ask_assoc_exp 103 21.1.50 UF_DRF_ask_associative_origin 104 21.1.51 UF_DRF_ask_associativity_data 104 21.1.52 UF_DRF_ask_boundaries 104 21.1.53 UF_DRF_ask_callout_of_annotation 104 21.1.54 UF_DRF_ask_callout_row_members 104 21.1.55 UF_DRF_ask_centerline_info 104 21.1.56 UF_DRF_ask_chamfer_dimension_data 104 21.1.57 UF_DRF_ask_controlling_exp 104 21.1.58 UF_DRF_ask_controlling_member_of_callout 104 21.1.59 UF_DRF_ask_custom_symbol_angle 104 21.1.60 UF_DRF_ask_custom_symbol_attach_locations 104 21.1.61 UF_DRF_ask_custom_symbol_leader 104 21.1.62 UF_DRF_ask_custom_symbol_name 104 21.1.63 UF_DRF_ask_custom_symbol_scale 104 21.1.64 UF_DRF_ask_diameter_radius_preferences 104 21.1.65 UF_DRF_ask_dim_appended_text_space_factor 104 21.1.66 UF_DRF_ask_dim_dim_line_space_factor 104 21.1.67 UF_DRF_ask_dim_info 104 21.1.68 UF_DRF_ask_dim_inspection_type 104 21.1.69 UF_DRF_ask_dim_reference_type 104 21.1.70 UF_DRF_ask_dim_tolerance_text_space_factor 104 21.1.71 UF_DRF_ask_dimension_preferences 104 21.1.72 UF_DRF_ask_dimension_set_offset 104 21.1.73 UF_DRF_ask_dimension_text 104 21.1.74 UF_DRF_ask_dimensions_of_set 104 21.1.75 UF_DRF_ask_dogleg_info 104 21.1.76 UF_DRF_ask_draft_aid_text_info 105 21.1.77 UF_DRF_ask_embedded_uds_font_info 105 21.1.78 UF_DRF_ask_folded_radius_info 105 21.1.79 UF_DRF_ask_gdt_symbol_info 105 21.1.80 UF_DRF_ask_hatch_fill_preferences 105 21.1.81 UF_DRF_ask_id_symbol_geometry 105 21.1.82 UF_DRF_ask_id_symbol_info 105 21.1.83 UF_DRF_ask_id_symbol_type 105 21.1.84 UF_DRF_ask_image_data 105 21.1.85 UF_DRF_ask_label_info 105 21.1.86 UF_DRF_ask_lettering_preferences 105 21.1.87 UF_DRF_ask_line_arrow_preferences 105 21.1.88 UF_DRF_ask_narrow_dimension_data 105 21.1.89 UF_DRF_ask_number_blocks 105 21.1.90 UF_DRF_ask_number_rows_in_callout 105 21.1.91 UF_DRF_ask_obj_suppress_pre_zeros 105 21.1.92 UF_DRF_ask_obj_text_above_ldr 105 21.1.93 UF_DRF_ask_object_preferences 105 21.1.94 UF_DRF_ask_objects_controlled_by_exp 105 21.1.95 UF_DRF_ask_ordorigin_info 105 21.1.96 UF_DRF_ask_origin 105 21.1.97 UF_DRF_ask_parent_of_inherited_pmi 105 21.1.98 UF_DRF_ask_plot_drawing_images 105 21.1.99 UF_DRF_ask_preferences 105 21.1.100 UF_DRF_ask_retain_color_font_width 105 21.1.101 UF_DRF_ask_retained_state 105 21.1.102 UF_DRF_ask_sbf_file 106 21.1.103 UF_DRF_ask_set_of_dimension 106 21.1.104 UF_DRF_ask_suppress_pre_zeros 106 21.1.105 UF_DRF_ask_suppress_view_update 106 21.1.106 UF_DRF_ask_symbol_data 106 21.1.107 UF_DRF_ask_symbol_data_from_name 106 21.1.108 UF_DRF_ask_symbol_mirror_and_flip 106 21.1.109 UF_DRF_ask_symbol_preferences 106 21.1.110 UF_DRF_ask_symbols_used 106 21.1.111 UF_DRF_ask_text_above_leader 106 21.1.112 UF_DRF_ask_ud_symbol_font_info 106 21.1.113 UF_DRF_ask_uds_object_size 106 21.1.114 UF_DRF_ask_units_format_preferences 106 21.1.115 UF_DRF_ask_vertical_note 106 21.1.116 UF_DRF_ask_weld_symbol 106 21.1.117 UF_DRF_count_text_substring 106 21.1.118 UF_DRF_cre_text_block 106 21.1.119 UF_DRF_create_3pt_cline_fbolt 106 21.1.120 UF_DRF_create_3pt_cline_fcir 106 21.1.121 UF_DRF_create_3pt_cline_pbolt 106 21.1.122 UF_DRF_create_3pt_cline_pcir 106 21.1.123 UF_DRF_create_angular_dim 106 21.1.124 UF_DRF_create_arclength_dim 106 21.1.125 UF_DRF_create_areafill 106 21.1.126 UF_DRF_create_assortpart_aid 106 21.1.127 UF_DRF_create_assortpart_dim 106 21.1.128 UF_DRF_create_block_cline 107 21.1.129 UF_DRF_create_chamfer_dim 107 21.1.130 UF_DRF_create_concir_dim 107 21.1.131 UF_DRF_create_cpt_cline_fbolt 107 21.1.132 UF_DRF_create_cpt_cline_fcir 107 21.1.133 UF_DRF_create_cpt_cline_pbolt 107 21.1.134 UF_DRF_create_cpt_cline_pcir 107 21.1.135 UF_DRF_create_crosshatch 107 21.1.136 UF_DRF_create_custom_symbol_instance 107 21.1.137 UF_DRF_create_cylindrical_dim 107 21.1.138 UF_DRF_create_diameter_dim 107 21.1.139 UF_DRF_create_foldedradius_dim 107 21.1.140 UF_DRF_create_gdt_symbol 107 21.1.141 UF_DRF_create_gdt_symbol_with_multiple_leaders 107 21.1.142 UF_DRF_create_hole_dim 107 21.1.143 UF_DRF_create_horizontal_baseline_dimension 107 21.1.144 UF_DRF_create_horizontal_chain_dimension 107 21.1.145 UF_DRF_create_horizontal_dim 107 21.1.146 UF_DRF_create_id_symbol 107 21.1.147 UF_DRF_create_image 107 21.1.148 UF_DRF_create_image_from_file 107 21.1.149 UF_DRF_create_label 107 21.1.150 UF_DRF_create_linear_cline 107 21.1.151 UF_DRF_create_non_assoc_hatch 107 21.1.152 UF_DRF_create_note 107 21.1.153 UF_DRF_create_offctrpt_cx 107 21.1.154 UF_DRF_create_offctrpt_cy 108 21.1.155 UF_DRF_create_offctrpt_fx 108 21.1.156 UF_DRF_create_offctrpt_fy 108 21.1.157 UF_DRF_create_offctrpt_nx 108 21.1.158 UF_DRF_create_offctrpt_ny 108 21.1.159 UF_DRF_create_offcyl_cline_obj 108 21.1.160 UF_DRF_create_offcyl_cline_off 108 21.1.161 UF_DRF_create_orddimension 108 21.1.162 UF_DRF_create_ordinate_dim 108 21.1.163 UF_DRF_create_ordinate_margin 108 21.1.164 UF_DRF_create_ordinate_origin 108 21.1.165 UF_DRF_create_ordmargin 108 21.1.166 UF_DRF_create_ordorigin 108 21.1.167 UF_DRF_create_parallel_dim 108 21.1.168 UF_DRF_create_perpendicular_dim 108 21.1.169 UF_DRF_create_radius_dim 108 21.1.170 UF_DRF_create_sbf_file 108 21.1.171 UF_DRF_create_side_seam 108 21.1.172 UF_DRF_create_sym_cline 108 21.1.173 UF_DRF_create_symbol_font 108 21.1.174 UF_DRF_create_top_seam 108 21.1.175 UF_DRF_create_vertical_baseline_dimension 108 21.1.176 UF_DRF_create_vertical_chain_dimension 108 21.1.177 UF_DRF_create_vertical_dim 108 21.1.178 UF_DRF_create_weld_symbol 108 21.1.179 UF_DRF_create_xhatch 108 21.1.180 UF_DRF_edit_dim_assoc 109 21.1.181 UF_DRF_edit_weld_symbol 109 21.1.182 UF_DRF_flip_image_about_height 109 21.1.183 UF_DRF_flip_image_about_width 109 21.1.184 UF_DRF_frdim 109 21.1.185 UF_DRF_free_appended_text 109 21.1.186 UF_DRF_free_centerline 109 21.1.187 UF_DRF_free_comp_data 109 21.1.188 UF_DRF_free_dimension 109 21.1.189 UF_DRF_free_font 109 21.1.190 UF_DRF_free_gdtsymbol 109 21.1.191 UF_DRF_free_idsymbol 109 21.1.192 UF_DRF_free_image_data 109 21.1.193 UF_DRF_free_label 109 21.1.194 UF_DRF_free_leader_data 109 21.1.195 UF_DRF_free_text 109 21.1.196 UF_DRF_get_symbol_divider 109 21.1.197 UF_DRF_get_text_bars 109 21.1.198 UF_DRF_get_text_substring 109 21.1.199 UF_DRF_get_xhatch_parms 109 21.1.200 UF_DRF_has_associative_origin 109 21.1.201 UF_DRF_inherit_feature_data 109 21.1.202 UF_DRF_init_associativity_data 109 21.1.203 UF_DRF_init_assortpart_arc 109 21.1.204 UF_DRF_init_assortpart_arrow 109 21.1.205 UF_DRF_init_assortpart_line 109 21.1.206 UF_DRF_init_assortpart_text 110 21.1.207 UF_DRF_init_image_data 110 21.1.208 UF_DRF_init_line_object 110 21.1.209 UF_DRF_init_object_structure 110 21.1.210 UF_DRF_init_symbol_create_data 110 21.1.211 UF_DRF_initialize_custom_symbol_data 110 21.1.212 UF_DRF_initialize_custom_symbol_text_data 110 21.1.213 UF_DRF_initialize_leader_data 110 21.1.214 UF_DRF_is_annotation_retained 110 21.1.215 UF_DRF_is_block_centerline 110 21.1.216 UF_DRF_is_chamfer_dimension 110 21.1.217 UF_DRF_is_inherited_pmi 110 21.1.218 UF_DRF_is_narrow_dimension 110 21.1.219 UF_DRF_is_object_out_of_date 110 21.1.220 UF_DRF_is_pmi_display_instance 110 21.1.221 UF_DRF_is_sbf_symbol 110 21.1.222 UF_DRF_margin_to_cline 110 21.1.223 UF_DRF_place_symbol 110 21.1.224 UF_DRF_record_draft_objects 110 21.1.225 UF_DRF_remove_controlling_exp 110 21.1.226 UF_DRF_render_arrowhead 110 21.1.227 UF_DRF_render_text 110 21.1.228 UF_DRF_rotate_image 110 21.1.229 UF_DRF_set_annotation_template 110 21.1.230 UF_DRF_set_appended_text 110 21.1.231 UF_DRF_set_areafill_angle 110 21.1.232 UF_DRF_set_areafill_material 111 21.1.233 UF_DRF_set_areafill_scale 111 21.1.234 UF_DRF_set_associative_origin 111 21.1.235 UF_DRF_set_associativity_data 111 21.1.236 UF_DRF_set_chamfer_dimension_data 111 21.1.237 UF_DRF_set_custom_symbol_angle 111 21.1.238 UF_DRF_set_custom_symbol_scale 111 21.1.239 UF_DRF_set_customer_sbf_file 111 21.1.240 UF_DRF_set_cyl_dim 111 21.1.241 UF_DRF_set_diameter_radius_preferences 111 21.1.242 UF_DRF_set_dim_appended_text_space_factor 111 21.1.243 UF_DRF_set_dim_dim_line_space_factor 111 21.1.244 UF_DRF_set_dim_inspection_type 111 21.1.245 UF_DRF_set_dim_reference_type 111 21.1.246 UF_DRF_set_dim_tolerance_text_space_factor 111 21.1.247 UF_DRF_set_dimension_preferences 111 21.1.248 UF_DRF_set_dimension_set_offset 111 21.1.249 UF_DRF_set_draft_common 111 21.1.250 UF_DRF_set_hatch_fill_preferences 111 21.1.251 UF_DRF_set_image_align_position 111 21.1.252 UF_DRF_set_image_aspect_ratio_lock 111 21.1.253 UF_DRF_set_image_height 111 21.1.254 UF_DRF_set_image_width 111 21.1.255 UF_DRF_set_lettering_preferences 111 21.1.256 UF_DRF_set_line_arrow_preferences 111 21.1.257 UF_DRF_set_narrow_dimension_data 111 21.1.258 UF_DRF_set_object_preferences 112 21.1.259 UF_DRF_set_origin 112 21.1.260 UF_DRF_set_plot_drawing_images 112 21.1.261 UF_DRF_set_preferences 112 21.1.262 UF_DRF_set_retain_color_font_width 112 21.1.263 UF_DRF_set_retained_state 112 21.1.264 UF_DRF_set_specified_sbf_file 112 21.1.265 UF_DRF_set_suppress_pre_zeros 112 21.1.266 UF_DRF_set_suppress_view_update 112 21.1.267 UF_DRF_set_symbol_preferences 112 21.1.268 UF_DRF_set_text_above_leader 112 21.1.269 UF_DRF_set_tolerance 112 21.1.270 UF_DRF_set_uds_size 112 21.1.271 UF_DRF_set_ugdefault_sbf_file 112 21.1.272 UF_DRF_set_units_format_preferences 112 21.1.273 UF_DRF_set_vertical_note 112 21.1.274 UF_DRF_set_weld_symbol_standard 112 21.1.275 UF_DRF_set_xhatch_mat 112 21.1.276 UF_DRF_transfer_to_drawing 112 21.1.277 UF_DRF_update_views 112 22 UF_DRPOS CAM面驱动函数. 113 22.1... UF_DRPOS Functions 113 22.1.1 UF_DRPOS_ask_custom_feed 113 22.1.2 UF_DRPOS_ask_drive_direction 113 22.1.3 UF_DRPOS_ask_grid_params 113 22.1.4 UF_DRPOS_ask_position 113 22.1.5 UF_DRPOS_ask_proj_vec 113 22.1.6 UF_DRPOS_ask_surface_identifier 113 22.1.7 UF_DRPOS_ask_surface_params 113 22.1.8 UF_DRPOS_ask_tool_axis 113 22.1.9 UF_DRPOS_ask_type 113 22.1.10 UF_DRPOS_ask_user_data 113 22.1.11 UF_DRPOS_ask_zig_zag_dir 113 22.1.12 UF_DRPOS_create_cut 113 22.1.13 UF_DRPOS_create_final_lift 113 22.1.14 UF_DRPOS_create_first_cut 113 22.1.15 UF_DRPOS_create_local_lift 113 22.1.16 UF_DRPOS_create_stepover 113 22.1.17 UF_DRPOS_delete 113 22.1.18 UF_DRPOS_set_custom_feed 113 22.1.19 UF_DRPOS_set_drive_direction 113 22.1.20 UF_DRPOS_set_position 113 22.1.21 UF_DRPOS_set_proj_vec 113 22.1.22 UF_DRPOS_set_tool_axis 113 22.1.23 UF_DRPOS_set_user_data 113 22.1.24 UF_DRPOS_set_zig_zag_dir 114 23 UF_EVAL 获取曲线和边的函数. 114 23.1... UF_EVAL Functions 114 23.1.1 UF_EVAL_ask_arc 114 23.1.2 UF_EVAL_ask_ellipse 114 23.1.3 UF_EVAL_ask_hyperbola 114 23.1.4 UF_EVAL_ask_limits 114 23.1.5 UF_EVAL_ask_line 114 23.1.6 UF_EVAL_ask_parabola 114 23.1.7 UF_EVAL_ask_spline 114 23.1.8 UF_EVAL_ask_spline_control_pts 114 23.1.9 UF_EVAL_ask_spline_knots 114 23.1.10 UF_EVAL_copy 114 23.1.11 UF_EVAL_evaluate 114 23.1.12 UF_EVAL_evaluate_closest_point 114 23.1.13 UF_EVAL_evaluate_unit_vectors 114 23.1.14 UF_EVAL_free 114 23.1.15 UF_EVAL_initialize 114 23.1.16 UF_EVAL_is_arc 114 23.1.17 UF_EVAL_is_ellipse 114 23.1.18 UF_EVAL_is_equal 114 23.1.19 UF_EVAL_is_hyperbola 114 23.1.20 UF_EVAL_is_line 114 23.1.21 UF_EVAL_is_parabola 114 23.1.22 UF_EVAL_is_periodic 114 23.1.23 UF_EVAL_is_spline 115 23.1.24 UF_EVALSF_ask_face_uv_minmax 115 23.1.25 UF_EVALSF_ask_minimum_face_dist 115 23.1.26 UF_EVALSF_evaluate 115 23.1.27 UF_EVALSF_evaluate_array 115 23.1.28 UF_EVALSF_find_closest_point 115 23.1.29 UF_EVALSF_free 115 23.1.30 UF_EVALSF_initialize 115 24 UF_EXIT 用户出口的函数说明. 115 24.1... UF_EXIT Functions 115 24.1.1 dpud 115 24.1.2 udop 115 24.1.3 uf2da 115 24.1.4 ufcams 115 24.1.5 ufccp 115 24.1.6 ufcdp 115 24.1.7 ufclg 115 24.1.8 ufclso 115 24.1.9 ufclsr 115 24.1.10 ufclss 115 24.1.11 ufcre 115 24.1.12 ufcwp 115 24.1.13 ufdcp 115 24.1.14 uffcp 115 24.1.15 uffpud 115 24.1.16 ufgen 116 24.1.17 ufget 116 24.1.18 ufgrp 116 24.1.19 ufgrpd 116 24.1.20 ufmcp 116 24.1.21 ufmrg 116 24.1.22 ufncp 116 24.1.23 ufnopr 116 24.1.24 ufplt 116 24.1.25 ufpost 116 24.1.26 ufput 116 24.1.27 ufrcp 116 24.1.28 ufrrs 116 24.1.29 ufscpi 116 24.1.30 ufscpo 116 24.1.31 ufspcl 116 24.1.32 ufspop 116 24.1.33 ufspuf 116 24.1.34 ufspup 116 24.1.35 ufsta 116 24.1.36 ufsvas 116 24.1.37 ufuds 116 24.1.38 ufufun 116 24.1.39 ufusd 116 25 UF_FACET 面片化的相关函数及数据结构说明. 116 25.1... UF_FACET Functions 117 25.1.1 UF_FACET_add_facet_to_model 117 25.1.2 UF_FACET_ask_adjacent_facet 117 25.1.3 UF_FACET_ask_available_solid 117 25.1.4 UF_FACET_ask_default_parameters 117 25.1.5 UF_FACET_ask_edge_convexity 117 25.1.6 UF_FACET_ask_face_id_of_facet 117 25.1.7 UF_FACET_ask_face_id_of_solid_face 117 25.1.8 UF_FACET_ask_max_facet_verts 117 25.1.9 UF_FACET_ask_model_parameters 117 25.1.10 UF_FACET_ask_models_of_solid 117 25.1.11 UF_FACET_ask_n_facets_in_model 117 25.1.12 UF_FACET_ask_normals_of_facet 117 25.1.13 UF_FACET_ask_num_faces 117 25.1.14 UF_FACET_ask_num_facets_in_face 117 25.1.15 UF_FACET_ask_num_verts_in_facet 117 25.1.16 UF_FACET_ask_params_of_facet 117 25.1.17 UF_FACET_ask_plane_equation 117 25.1.18 UF_FACET_ask_solid_face_of_face_id 117 25.1.19 UF_FACET_ask_solid_face_of_facet 117 25.1.20 UF_FACET_ask_solid_of_model 117 25.1.21 UF_FACET_ask_vertex_convexity 117 25.1.22 UF_FACET_ask_vertices_of_facet 117 25.1.23 UF_FACET_create_model 117 25.1.24 UF_FACET_cycle_facets 117 25.1.25 UF_FACET_cycle_facets_in_face 117 25.1.26 UF_FACET_del_facet_from_model 118 25.1.27 UF_FACET_delete_all_facets_from_model 118 25.1.28 UF_FACET_disassoc_from_solid 118 25.1.29 UF_FACET_facet_solid 118 25.1.30 UF_FACET_find_edge_in_facet 118 25.1.31 UF_FACET_is_facet_convex 118 25.1.32 UF_FACET_is_model_convex 118 25.1.33 UF_FACET_is_model_up_to_date 118 25.1.34 UF_FACET_model_edits_done 118 25.1.35 UF_FACET_rebuild_adjacencies 118 25.1.36 UF_FACET_set_adjacent_facet 118 25.1.37 UF_FACET_set_default_parameters 118 25.1.38 UF_FACET_set_vertex_of_facet 118 25.1.39 UF_FACET_update_model 118 26 UF_FAM 关于零件族的操作函数及数据结构说明. 118 26.1... UF_FAM Functions 118 26.1.1 UF_FAM_add_member 118 26.1.2 UF_FAM_ask_attribute_data 118 26.1.3 UF_FAM_ask_class_count 118 26.1.4 UF_FAM_ask_class_data 118 26.1.5 UF_FAM_ask_class_name 118 26.1.6 UF_FAM_ask_family_data 118 26.1.7 UF_FAM_ask_instance_data 118 26.1.8 UF_FAM_ask_member_column_data 118 26.1.9 UF_FAM_ask_member_row_data 118 26.1.10 UF_FAM_check_attribute_status 119 26.1.11 UF_FAM_check_family_status 119 26.1.12 UF_FAM_check_member_status 119 26.1.13 UF_FAM_create_attribute 119 26.1.14 UF_FAM_create_family 119 26.1.15 UF_FAM_create_instance 119 26.1.16 UF_FAM_delete_instance 119 26.1.17 UF_FAM_delete_member 119 26.1.18 UF_FAM_edit_attribute 119 26.1.19 UF_FAM_edit_family 119 26.1.20 UF_FAM_edit_member 119 26.1.21 UF_FAM_evaluate_intent_data 119 26.1.22 UF_FAM_free_attribute_data 119 26.1.23 UF_FAM_free_class_data 119 26.1.24 UF_FAM_free_family_data 119 26.1.25 UF_FAM_free_member_data 119 27 UF_FLTR 119 27.1... UF_FLTR Functions 119 28 UF_FORGEO 119 28.1... UF_FORGEO Functions 119 28.2... UF_FORGEO Callbacks 119 28.3... UF_FORGEO Structures 119 29 UF_GDT 120 29.1... UF_GDT Functions 120 29.2... UF_GDT Structures 120 29.3... UF_GDT Enumerations 120 30 UF_GENT 120 30.1... UF_GENT Functions 120 31 UF_GEXP 120 31.1... UF_GEXP Functions 120 31.2... UF_GEXP Enumerations 120 32 UF_GROUP 与群组有关的操作函数说明. 120 32.1... UF_GROUP Functions 120 33 UF_HELP 120 33.1... UF_HELP Files 120 33.2... UF_HELP Functions 120 34 UF_KF 与知识融合的接口声明. 120 34.1... UF_KF Functions 121 34.2... UF_KF Callbacks 121 34.3... UF_KF Enumerations 121 35 UF_LAYER 与层有关的函数声明. 121 35.1... UF_LAYER Functions 121 35.2... UF_LAYER Structures 121 36 UF_LAYOUT 与布局有关的函数声明. 121 36.1... UF_LAYOUT Functions 121 37 UF_LIB 121 37.1... UF_LIB Functions 121 37.2... UF_LIB Enumerations 121 38 UF_LINKED_EXTERIOR 121 38.1... UF_LINKED_EXTERIOR Functions 121 39 UF_MB 121 39.1... UF_MB Functions 121 39.2... UF_MB Callbacks 122 39.3... UF_MB Structures 122 39.4... UF_MB Enumerations 122 40 UF_MODL 与模型创建、查询有关的函数声明和数据类型定义. 122 40.1... UF_MODL Functions 122 40.2... UF_MODL Callbacks 122 40.3... UF_MODL Structures 122 40.4... UF_MODL Enumerations 122 40.5... UF_MODL Unions 122 41 UF_MOM 122 41.1... UF_MOM Functions 122 41.2... UF_MOM Callbacks 122 42 UF_MOTION 对传动机构进行干涉分析、测量、轨迹跟踪等函数声明. 122 42.1... UF_MOTION Functions 122 42.2... UF_MOTION Structures 123 42.3... UF_MOTION Enumerations 123 43 UF_MTX 关于矩阵操作的函数声明. 123 43.1... UF_MTX Functions 123 44 UF_NCGROUP 123 44.1... UF_NCGROUP Functions 123 44.2... UF_NCGROUP Callbacks 123 44.3... UF_NCGROUP Enumerations 123 45 UF_NX2D 123 45.1... UF_NX2D Functions 123 46 UF_NXSM 123 46.1... UF_NXSM Functions 123 46.2... UF_NXSM Structures 123 46.3... UF_NXSM Enumerations 123 47 UF_OBJ 有关对象及属性的访问函数定义. 123 47.1... UF_OBJ Functions 124 47.2... UF_OBJ Structures 124 48 UF_OBJECT_TYPES 有关对象及属性结构的定义. 124 48.1... UF_OBJECT_TYPES Files 124 49 UF_OPER 124 49.1... UF_OPER Functions 124 49.2... UF_OPER Structures 124 49.3... UF_OPER Enumerations 124 50 UF_PARAM 124 50.1... UF_PARAM Functions 124 50.2... UF_PARAM Structures 124 50.3... UF_PARAM Enumerations 124 51 UF_PART 与部件文件操作有关的函数及数据类型声明. 124 51.1... UF_PART Functions 124 51.2... UF_PART Structures 124 51.3... UF_PART Enumerations 125 52 UF_PATH 125 52.1... UF_PATH Functions 125 52.2... UF_PATH Structures 125 52.3... UF_PATH Enumerations 125 53 UF_PATT 125 53.1... UF_PATT Functions 125 53.2... UF_PATT Enumerations 125 54 UF_PD 125 54.1... UF_PD Functions 125 54.2... UF_PD Structures 125 54.3... UF_PD Enumerations 125 54.4... UF_PD Unions 125 55 UF_PLIST 125 55.1... UF_PLIST Functions 125 55.2... UF_PLIST Structures 126 55.3... UF_PLIST Enumerations 126 56 UF_PLOT 与绘图(出图)有关的函数声明. 126 56.1... UF_PLOT Functions 126 56.2... UF_PLOT Structures 126 56.3... UF_PLOT Enumerations 126 57 UF_POINT 126 57.1... UF_POINT Functions 126 58 UF_PROCESS_AID 126 58.1... UF_PROCESS_AID Functions 126 58.2... UF_PROCESS_AID Structures 126 58.3... UF_PROCESS_AID Enumerations 126 58.4... UF_PROCESS_AID Unions 126 59 UF_PS 提供直接访问Parasolid的函数功能. 126 59.1... UF_PS Functions 126 59.2... UF_PS Callbacks 127 59.3... UF_PS Structures 127 60 UF_ROUTE 127 60.1... UF_ROUTE Functions 127 60.2... UF_ROUTE Callbacks 127 60.3... UF_ROUTE Structures 127 60.4... UF_ROUTE Unions 127 61 UF_RULE 127 61.1... UF_RULE Functions 127 61.2... UF_RULE Callbacks 127 62 UF_SC 127 62.1... UF_SC Functions 127 62.2... UF_SC Structures 127 62.3... UF_SC Unions 127 63 UF_SCOP 127 63.1... UF_SCOP Functions 128 63.2... UF_SCOP Structures 128 63.3... UF_SCOP Enumerations 128 64 UF_SETUP 128 64.1... UF_SETUP Functions 128 64.2... UF_SETUP Enumerations 128 65 UF_SF 128 65.1... UF_SF Functions 128 65.2... UF_SF Structures 128 65.3... UF_SF Enumerations 128 65.4... UF_SF Unions 128 66 UF_SIM 128 66.1... UF_SIM Functions 128 66.2... UF_SIM Enumerations 128 67 UF_SKET 有关草图的函数及结构声明. 128 67.1... UF_SKET Functions 129 67.2... UF_SKET Structures 129 67.3... UF_SKET Enumerations 129 68 UF_SMD 129 68.1... UF_SMD Functions 129 68.2... UF_SMD Structures 129 68.3... UF_SMD Enumerations 129 68.4... UF_SMD Unions 129 69 UF_SO NX/OPEN与敏捷对象(smart Object)的公共接口. 129 69.1... UF_SO Functions 129 69.2... UF_SO Structures 129 69.3... UF_SO Enumerations 129 70 UF_SPSD 129 70.1... UF_SPSD Functions 129 70.2... UF_SPSD Callbacks 129 71 UF_STD 130 71.1... UF_STD Functions 130 71.2... UF_STD Structures 130 72 UF_STUDIO 130 72.1... UF_STUDIO Functions 130 72.2... UF_STUDIO Structures 130 72.3... UF_STUDIO Enumerations 130 73 UF_STYLER 有关UIStyler的操作函数声明. 130 73.1... UF_STYLER Functions 130 73.2... UF_STYLER Callbacks 130 73.3... UF_STYLER Structures 130 73.4... UF_STYLER Unions 130 74 UF_SUBDIV 130 74.1... UF_SUBDIV Functions 130 74.2... UF_SUBDIV Structures 130 74.3... UF_SUBDIV Enumerations 131 74.4... UF_SUBDIV Unions 131 75 UF_SURF_REG 131 75.1... UF_SURF_REG Functions 131 75.2... UF_SURF_REG Structures 131 75.3... UF_SURF_REG Enumerations 131 75.4... UF_SURF_REG Unions 131 76 UF_TABNOT 131 76.1... UF_TABNOT Functions 131 76.2... UF_TABNOT Structures 131 76.3... UF_TABNOT Enumerations 131 77 UF_TEXT 131 77.1... UF_TEXT Functions 131 77.2... UF_TEXT Enumerations 131 78 UF_TRNS 提供对坐标、矩阵、位置及对象的转换功能(移动、选择、镜像、缩放)的函数声明 132 78.1... UF_TRNS Functions 132 79 UF_UDOBJ 132 79.1... UF_UDOBJ Functions 132 79.2... UF_UDOBJ Callbacks 132 79.3... UF_UDOBJ Structures 132 79.4... UF_UDOBJ Enumerations 132 80 UF_UDOP 132 80.1... UF_UDOP Functions 132 80.2... UF_UDOP Enumerations 132 81 UF_UGFONT 132 81.1... UF_UGFONT Functions 132 81.2... UF_UGFONT Structures 132 82 UF_UGMGR 132 82.1... UF_UGMGR Functions 133 82.2... UF_UGMGR Callbacks 133 82.3... UF_UGMGR Structures 133 82.4... UF_UGMGR Enumerations 133 83 UF_UI 用户界面功能的相应函数及结构声明. 133 83.1... UF_UI Functions 133 83.2... UF_UI Callbacks 133 83.3... UF_UI Structures 133 83.4... UF_UI Enumerations 133 83.5... UF_UI Unions 133 84 UF_UI_XT 133 84.1... UF_UI_XT Functions 133 85 UF_UNDO 关于Undo操作的相应函数及结构声明. 133 85.1... UF_UNDO Functions 133 85.2... UF_UNDO Callbacks 133 85.3... UF_UNDO Enumerations 134 86 UF_UNIT 134 86.1... UF_UNIT Enumerations 134 87 UF_VDAC 134 87.1... UF_VDAC Functions 134 87.2... UF_VDAC Structures 134 87.3... UF_VDAC Enumerations 134 87.4... UF_VDAC Unions 134 88 UF_VEC 向量操作的函数声明. 134 88.1... UF_VEC Functions 134 89 UF_VIEW 视图的操作、查询等函数声明. 134 89.1... UF_VIEW Functions 134 89.2... UF_VIEW Structures 134 89.3... UF_VIEW Enumerations 134 90 UF_WAVE WAVE功能的相应函数声明. 134 90.1... UF_WAVE Functions 135 90.2... UF_WAVE Structures 135 90.3... UF_WAVE Enumerations 135 91 UF_WEB 135 91.1... UF_WEB Functions 135 92 UF_WEIGHT 135 92.1... UF_WEIGHT Functions 135 92.2... UF_WEIGHT Structures 135 92.3... UF_WEIGHT Enumerations 135 93 UF_WELD 135 93.1... UF_WELD Functions 135 93.2... UF_WELD Structures 135 93.3... UF_WELD Enumerations 135 94 UF_XS 与电子表格相关的函数声明. 135 94.1... UF_XS Functions 135
; S5 D5 F# z* T- B |
