常用塑料英语缩略语 ( Z g6 G) L1 D$ e" X+ F; n
英文简称 英文全称 中文全称. u; ]) P4 \; m# s
ABA Acrylonitrile-butadiene-acrylate 丙烯腈/丁二烯/丙烯酸酯共聚物8 E6 [8 k3 i7 M5 O( l" J2 \( u
ABS Acrylonitrile-butadiene-styrene 丙烯腈/丁二烯/苯乙烯共聚物, N- H3 x. H/ I: S
AES Acrylonitrile-ethylene-styrene 丙烯腈/乙烯/苯乙烯共聚物
+ ~! f7 w9 d9 z T, o/ m3 `3 b2 _AMMA Acrylonitrile/methyl Methacrylate 丙烯腈/甲基丙烯酸甲酯共聚物* V$ s. l2 {9 ~% [
ARP Aromatic polyester 聚芳香酯8 z+ K8 Q; h, _# w$ d3 w
AS Acrylonitrile-styrene resin 丙烯腈-苯乙烯树脂0 w8 C/ M( }! C$ l
ASA Acrylonitrile-styrene-acrylate 丙烯腈/苯乙烯/丙烯酸酯共聚物7 b. ?$ j2 V& E/ c* A6 p
CA Cellulose acetate 醋酸纤维塑料
, P0 B% q9 J/ \6 q# ECAB Cellulose acetate butyrate 醋酸-丁酸纤维素塑料0 k: n$ m- p' v2 O/ d9 D
CAP Cellulose acetate propionate 醋酸-丙酸纤维素; c) P6 Y* @: @: D. \$ S5 }
CE Cellulose plastics, general 通用纤维素塑料# s% {. h+ S! \# m/ i
CF Cresol-formaldehyde 甲酚-甲醛树脂- n: Q6 h I o
CMC Carboxymethyl cellulose 羧甲基纤维素$ s. O4 z' E0 I& j# t' k( X+ Z
CN Cellulose nitrate 硝酸纤维素. |+ U- z, ?5 B! w) |- D- ^. o7 W
CP Cellulose propionate 丙酸纤维素! h3 o" y# a! h2 a3 p5 G( u) }% J
CPE Chlorinated polyethylene 氯化聚乙烯& |( Q5 s4 D3 O9 E9 e' U
CPVC Chlorinated poly(vinyl chloride) 氯化聚氯乙烯
! ~3 A7 i: O3 x- w) g9 a7 BCS Casein 酪蛋白0 L$ ^; N0 I# e
CTA Cellulose triacetate 三醋酸纤维素
5 G' y) W7 P# [EC Ethyl cellulose 乙烷纤维素8 @' q7 j: E: n( }
EMA Ethylene/methacrylic acid 乙烯/甲基丙烯酸共聚物
6 t! j# V% _" f$ f5 FEP Epoxy, epoxide 环氧树脂' J8 s) G3 R; j" I, O7 h* q* t- W; r& j
EPD Ethylene-propylene-diene 乙烯-丙烯-二烯三元共聚物
+ T# p" [6 H1 g" b2 z: wEPM Ethylene-propylene polymer 乙烯-丙烯共聚物
4 z9 s0 Y) F/ ^& ~: H- ~0 p' rEPS Expanded polystyrene 发泡聚苯乙烯; B4 S. g( J; ^# w/ _: E" ?, w) g
ETFE Ethylene-tetrafluoroethylene 乙烯-四氟乙烯共聚物# u, a' b) v7 m* q$ u/ q) I
EVA Ethylene/vinyl acetate 乙烯-醋酸乙烯共聚物
" `" u" y/ C( o" |: sEVAL Ethylene-vinyl alcohol 乙烯-乙烯醇共聚物! p9 t' v' s6 |# O
FEP Perfluoro(ethylene-propylene) 全氟(乙烯-丙烯)塑料
0 @) @. B5 s& _* J; N2 U7 wFF Furan formaldehyde 呋喃甲醛
7 c7 s/ _0 k. v7 Y/ r0 ]3 YHDPE High-density polyethylene plastics 高密度聚乙烯塑料
' w4 i6 y4 |4 F( YHIPS High impact polystyrene 高冲聚苯乙烯" t0 ^6 F8 L4 ~& @* r* I
IPS Impact-resistant polystyrene 耐冲击聚苯乙烯1 a6 R) u* Z+ F2 K
LCP Liquid crystal polymer 液晶聚合物- S) f& f8 |2 M3 c
LDPE Low-density polyethylene plastics 低密度聚乙烯塑料0 }2 h9 \* @+ g/ o6 ~( I) }" |
LLDPE Linear low-density polyethylene 线性低密聚乙烯" R* ?5 _3 u0 u0 |( Q! @
LMDPE Linear medium-density polyethylene 线性中密聚乙烯& w% X% M2 i" s, F
MBS Methacrylate-butadiene-styrene 甲基丙烯酸-丁二烯-苯乙烯共聚物" Z5 s: y5 [# j6 `- Q( E
MC Methyl cellulose 3 p; s R+ @/ R
MDPE Medium-density polyethylene 中密聚乙烯
~$ [ Q9 N7 ^7 B9 X' Y3 hMF Melamine-formaldehyde resin 密胺-甲醛树脂
% m& i2 U+ }2 I( fMPF Melamine/phenol-formaldehyde 密胺/酚醛树脂
4 q0 E+ G% D% u" I' T0 @$ UPA Polyamide (nylon) 聚酰胺(尼龙)7 o5 F6 n c! q
PAA Poly(acrylic acid) 聚丙烯酸- ?2 d9 _7 w( z1 G* d4 v6 g: N
PADC Poly(allyl diglycol carbonate) 碳酸-二乙二醇酯· 烯丙醇酯树脂
& k2 d3 f& `: J6 V9 I. D& tPAE Polyarylether 聚芳醚& w9 t. P% k0 B2 w2 r
PAEK Polyaryletherketone 聚芳醚酮
$ a; T$ D: I% W4 o6 g# rPAI Polyamide-imide 聚酰胺-酰亚胺' [* ]& v& N7 y# y* {( W h( c4 o1 ?
PAK Polyester alkyd 聚酯树脂
% D, b5 f1 M% K `/ B) ~2 xPAN Polyacrylonitrile 聚丙烯腈) H C" `' o0 Z! d; V
PARA Polyaryl amide 聚芳酰胺
6 |) T3 v2 c* G& aPASU Polyarylsulfone 聚芳砜
1 e6 f% O [8 j) S+ B) bPAT Polyarylate 聚芳酯
- L3 }! g; Q+ P9 O- k* vPAUR Poly(ester urethane) 聚酯型聚氨酯% @) q6 [! E( s4 q" D
PB Polybutene-1 聚丁烯-[1] ( N' e# h" w. f* w0 W
PBA Poly(butyl acrylate) 聚丙烯酸丁酯% A7 X% ~: a" e' U, E: [2 C Z8 H
PBAN Polybutadiene-acrylonitrile 聚丁二烯-丙烯腈5 J0 o. [! ?+ \2 J
PBS Polybutadiene-styrene 聚丁二烯-苯乙烯1 Q6 f8 j9 x% y2 a E
PBT Poly(butylene terephthalate) 聚对苯二酸丁二酯4 j, w5 h& G; ?' l5 A/ W
PC Polycarbonate 聚碳酸酯
. H5 O. i3 h8 l) u- D- Y6 [4 {PCTFE Polychlorotrifluoroethylene 聚氯三氟乙烯4 B! ]8 U* K0 k8 d3 u4 `8 q
PDAP Poly(diallyl phthalate) 聚对苯二甲酸二烯丙酯' t1 q+ H, v# b! S
PE Polyethylene 聚乙烯! r! T4 {/ N$ g$ k
PEBA Polyether block amide 聚醚嵌段酰胺$ W3 M4 l: B6 T
PEBA Thermoplastic elastomer polyether 聚酯热塑弹性体
# S0 ?0 Q$ o' nPEEK Polyetheretherketone 聚醚醚酮
* [: v2 d8 ]$ g5 f- m0 N; EPEI Poly(etherimide) 聚醚酰亚胺. s0 D. C2 ~. N" F3 {) K
PEK Polyether ketone 聚醚酮
( G5 K8 F n8 O) IPEO Poly(ethylene oxide) 聚环氧乙烷
/ n- d0 _. a) \4 n3 ^! R+ SPES Poly(ether sulfone) 聚醚砜6 f2 j" j% R( [
PET Poly(ethylene terephthalate) 聚对苯二甲酸乙二酯
* @! z6 `) a1 ]. R3 S+ qPETG Poly(ethylene terephthalate) glycol 二醇类改性PET 1 H: g2 U% }& C
PEUR Poly(ether urethane) 聚醚型聚氨酯; I+ V$ O9 K4 r* C4 A& g
PF Phenol-formaldehyde resin 酚醛树脂6 S' M" F% x: K! a$ U. K
PFA Perfluoro(alkoxy alkane) 全氟烷氧基树脂
4 C4 M- Z" L8 ]0 V3 FPFF Phenol-furfural resin 酚呋喃树脂% }6 |. ^% P# M
PI Polyimide 聚酰亚胺3 u7 a+ j! i* I
PIB Polyisobutylene 聚异丁烯* r5 o) f" A5 ^4 F
PISU Polyimidesulfone 聚酰亚胺砜
; }- w# a. k' F( e0 {/ T1 \PMCA Poly(methyl-alpha-chloroacrylate) 聚α-氯代丙烯酸甲酯
. ?; @2 T* i( pPMMA Poly(methyl methacrylate) 聚甲基丙烯酸甲酯
2 x: u) Q2 g% `/ {PMP Poly(4-methylpentene-1) 聚4-甲基戊烯-1 5 K+ i6 G% v8 ^
PMS Poly(alpha-methylstyrene) 聚α-甲基苯乙烯
3 l9 r% F" t( X$ ~! z4 h8 OPOM Polyoxymethylene, polyacetal 聚甲醛 5 I! I8 }0 ^+ j) H
8 I3 z8 [3 i, c$ b2 I$ `# CPP Polypropylene 聚丙烯% W7 J" B3 n' F( s7 b3 C- K
PPA Polyphthalamide 聚邻苯二甲酰胺
' r% ^$ h$ }8 ]PPE Poly(phenylene ether) 聚苯醚
% d5 ^: f, r: @7 V" w/ yPPO Poly(phenylene oxide) deprecated 聚苯醚# f: ?- A* I5 w, _4 S" Y
PPOX Poly(propylene oxide) 聚环氧(丙)烷! j! d; m9 P; d! P, {- \- Y% s
PPS Poly(phenylene sulfide) 聚苯硫醚
8 Q( }. m- P! `. m/ C% v5 a! GPPSU Poly(phenylene sulfone) 聚苯砜3 h4 S O, @7 u
PS Polystyrene 聚苯乙烯
+ Z7 k' I6 @& x5 i0 x) Q, ?6 iPSU Polysulfone 聚砜6 V3 _9 I& ]) s8 p0 w. _( F2 ^
PTFE Polytetrafluoroethylene 聚四氟乙烯" q5 Z G2 z0 G
PUR Polyurethane 聚氨酯
$ y \" j$ ^- H6 r/ K& H% o% wPVAC Poly(vinyl acetate) 聚醋酸乙烯
6 ]3 |1 O7 q4 x: ?, [7 j, s5 qPVAL Poly(vinyl alcohol) 聚乙烯醇
7 \. {5 H4 Q! M* o \" NPVB Poly(vinyl butyral) 聚乙烯醇缩丁醛4 W" o5 `" a8 U& W/ L+ `* _2 ^
PVC Poly(vinyl chloride) 聚氯乙烯
8 z( S" P; } z* {8 P5 h4 SPVCA Poly(vinyl chloride-acetate) 聚氯乙烯醋酸乙烯酯3 L+ I& T" R( }
PVDC Poly(vinylidene chloride) 聚(偏二氯乙烯)7 a4 |' h } n" z4 a3 L
PVDF Poly(vinylidene fluoride) 聚(偏二氟乙烯)1 R3 X4 m# L! T' t6 }! R l8 I0 f7 B
PVF Poly(vinyl fluoride) 聚氟乙烯
2 x* s; }5 N& y4 o5 BPVFM Poly(vinyl formal) 聚乙烯醇缩甲醛
s7 U4 v; \& H$ D8 s" ~PVK Polyvinylcarbazole 聚乙烯咔唑$ d) E7 d$ f ?8 y- ]# I
PVP Polyvinylpyrrolidone 聚乙烯吡咯烷酮
- e* E: R3 I3 g# F6 qS/MA Styrene-maleic anhydride plastic 苯乙烯-马来酐塑料
! D+ k# z2 `" k8 ^4 w; xSAN Styrene-acrylonitrile plastic 苯乙烯-丙烯腈塑料
0 d2 E: p5 l- {" qSB Styrene-butadiene plastic 苯乙烯-丁二烯塑料) G9 R3 K+ J& g" Q, j, x* T
Si Silicone plastics 有机硅塑料, `9 M, N6 K& Y! D: ]# N
SMS Styrene/alpha-methylstyrene plastic 苯乙烯-α-甲基苯乙烯塑料. p* q/ E" m4 y1 D4 E' K* Y* X
SP Saturated polyester plastic 饱和聚酯塑料
8 I% C3 k( H- V6 h$ e" {SRP Styrene-rubber plastics 聚苯乙烯橡胶改性塑料
, g+ q, x5 [8 L9 ?TEEE Thermoplastic Elastomer,Ether-Ester 醚酯型热塑弹性体& ~" \0 r& c( l4 | w- u7 Z
TEO Thermoplastic Elastomer, Olefinic 聚烯烃热塑弹性体
% c% k0 o% j2 T$ K4 c2 o; UTES Thermoplastic Elastomer, Styrenic 苯乙烯热塑性弹性体1 j2 k5 O. s( K! R8 `
TPEL Thermoplastic elastomer 热塑(性)弹性体
/ X6 x! f/ ~5 L( t# X) g8 m4 ^TPES Thermoplastic polyester 热塑性聚酯: I! j' y! }+ Q R
TPUR Thermoplastic polyurethane 热塑性聚氨酯1 @8 g5 M: n; ~$ e' R8 Y8 U
TSUR Thermoset polyurethane 热固聚氨酯1 k+ c) M! D4 q7 i
UF Urea-formaldehyde resin 脲甲醛树脂& V" s' z1 l* j: } W# o, H* c; Y( E
UHMWPE Ultra-high molecular weight PE 超高分子量聚乙烯
. C* l; e. s3 s1 F. ^& v$ ?UP Unsaturated polyester 不饱和聚酯
+ G8 H7 ]# l6 G9 w1 j. b+ X$ }1 ]7 wVCE Vinyl chloride-ethylene resin 氯乙烯/乙烯树脂
7 B; \! F8 ?* m) h) OVCEV Vinyl chloride-ethylene-vinyl 氯乙烯/乙烯/醋酸乙烯共聚物 O! h6 ]9 K$ p+ _3 U$ |
VCMA Vinyl chloride-methyl acrylate 氯乙烯/丙烯酸甲酯共聚物
5 ^& u, ~. W& L/ KVCMMA Vinyl chloride-methylmethacrylate 氯乙烯/甲基丙烯酸甲酯共聚物
' n: s; |$ X0 A% {) H2 _. q0 _) o9 g, q- O" B3 P6 r
VCOA Vinyl chloride-octyl acrylate resin 氯乙烯/丙烯酸辛酯树脂
+ d% v: v( p7 \6 s' \/ x) CVCVAC Vinyl chloride-vinyl acetate resin 氯乙烯/醋酸乙烯树脂
2 I* [ R/ P# V3 ]9 y% \VCVDC Vinyl chloride-vinylidene chloride 氯乙烯/偏氯乙烯共聚物
- C$ c- c) v8 G2 n: T8 `5 E7 I
4 i. Y) z: [/ }; v2 }+ ] R: ]" e4 s% y
, x- _" @& I; t5 Y/ I$ | |
