5 o. h0 |# @- l( r! y( K! _
1 A$ A# m& q- N8 I4 i
3 A# j7 _9 j$ N% z! }& w4 O( C! {: n- T" H
% ~1 Y7 _) z4 @% \die 五金模具 mould 塑料模具 figure file, chart file图档 cutting die, blanking die冲裁模 progressive die, follow (-on)die 连续模 compound die复合模 punched hole冲孔 panel board镶块 to cutedges=side cut=side scrap切边 to bending折弯 to pull, to stretch拉伸 Line streching, line pulling线拉伸 engraving, to engrave刻印 upsiding down edges翻边 to stake铆合 designing, to design设计 design modification设计变化 die block模块 folded block折弯块 slider 滑块 location pin定位销 lifting pin顶料销 die plate, front board模板 padding block垫块 stepping bar垫条 upper die base上模座 lower die base下模座 upper supporting blank上承板 upper padding plate blank上垫板 spare dies模具备品 spring 弹簧 bolt螺栓 document folder文件夹 file folder资料夹 to put file in order整理资料 spare tools location手工备品仓 first count初盘人 first check初盘复棹人 second count 复盘人 second check复盘复核人 equipment设备 waste materials废料 work in progress product在制品 casing = containerazation装箱 quantity of physical invetory second count 复盘点数量 quantity of customs count 会计师盘,点数量 the first page第一联 filed by accounting department for reference会计部存查 end-user/using unit(department)使用单位 summary of year-end physical inventory bills 年终盘点截止单据汇总表 bill name单据名称 This sheet and physical inventory list will be sent to accounting department together (Those of NHK will be sent to financial department)本表请与盘点清册一起送会计部-(NHK厂区送财会部) 3 L" p- X S. E2 o8 i6 D9 `. E, C2 W- R
Application status records of year-end physical inventory List and physical inventory card 年终盘点卡与清册使用-状况明细表 blank and waste sheet NO. 空白与作废单号 plate电镀 mold成型 material for engineering mold testing工程试模材料 not included in physical inventory不列入盘点 sample样品 incoming material to be inspected进货待验 description品名 steel/rolled steel钢材 material statistics sheet 物料统计明细表 meeting minutes会议记录 meeting type 会别 distribution department分发单位 location地点 chairman主席 present members出席人员 subject主题 conclusion结论 decision items决议事项 responsible department负责单位 pre-fixed finishing date预定完成日 approved by / checked by / prepared by核准/审核/承办 PCE assembly production schedule sheet PCE组装厂生产排配表 model机锺 work order工令 revision版次 remark备注 production control confirmation生产确认 checked by初审 approved by核准 department部门 stock age analysis sheet 库存货龄分析表 on-hand inventory现有库存 available material良品可使用 obsolete material良品已呆滞 to be inspected or reworked 待验或重工 total合计 cause description原因说明 part number/ P/N 料号 type形态 item/group/class类别 quality品质 prepared by制表 notes说明 year-end physical inventory difference analysis sheet 年终盘点差异分析表 physical inventory盘点数量 physical count quantity帐面数量 difference quantity差异量 cause analysis原因分析 raw materials原料 materials物料 finished product成品 semi-finished product半成品 packing materials包材 good product/accepted goods/ accepted parts/good parts良品 defective product/non-good parts不良品 disposed goods处理品 warehouse/hub仓库 on way location在途仓 oversea location海外仓 spare parts physical inventory list备品盘点清单 spare molds location模具备品仓 skid/pallet栈板 tox machine自铆机 wire EDM线割 EDM放电机 coil stock卷料 sheet stock片料 tolerance工差 score=groove压线 cam block滑块 pilot导正筒 trim剪外边 pierce剪内边 drag form压锻差 pocket for the punch head挂钩槽 feature die公母模 expansion dwg展开图 radius半径 shim(wedge)楔子 torch-flame cut火焰切割 set screw止付螺丝 form block折刀 stop pin定位销 round pierce punch=die button圆冲子 shape punch=die insert异形子 stock locater block定位块 under cut=scrap chopper清角 active plate活动板 baffle plate挡块 cover plate盖板 male die公模 female die母模 groove punch压线冲子 air-cushion eject-rod气垫顶杆 spring-box eject-plate弹簧箱顶板 bushing block衬套 insert 入块 club car高尔夫球车 capability能力 parameter参数 factor系数 phosphate皮膜化成 viscosity涂料粘度 alkalidipping脱脂 main manifold主集流脉 bezel斜视规 blanking穿落模 dejecting顶固模 demagnetization去磁;消磁 high-speed transmission高速传递 heat dissipation热传 rack上料 degrease脱脂 rinse水洗 alkaline etch龄咬 desmut剥黑膜 D.I. rinse纯水次 Chromate铬酸处理 Anodize阳性处理 seal封孔 revision版次 part number/P/N料号 good products良品 scraped products报放心品 defective products不良品 finished products成品 disposed products处理品 barcode条码 flow chart流程表单 assembly组装 stamping冲压 molding成型 spare parts=buffer备品 coordinate座标 dismantle the die折模 auxiliary fuction辅助功能 poly-line多义线 heater band 加热片 thermocouple热电偶 sand blasting喷沙 grit 砂砾 derusting machine除锈机 degate打浇口 dryer烘干机 induction感应 induction light感应光 response=reaction=interaction感应 ram连杆 edge finder巡边器 concave凸 convex凹 short射料不足 nick缺口 speck瑕疵 shine亮班 splay 银纹 gas mark焦痕 delamination起鳞 blush 导色 gouge沟槽;凿槽 satin texture段面咬花 witness line证示线 patent专利 grit沙砾 granule=peuet=grain细粒 grit maker抽粒机 cushion缓冲 magnalium镁铝合金 magnesium镁金 metal plate钣金 lathe车 mill锉 plane刨 grind磨 drill铝 boring镗 blinster气泡 fillet镶;嵌边 through-hole form通孔形式 voller pin formality滚针形式 cam driver铡楔 shank摸柄 crank shaft曲柄轴 augular offset角度偏差 velocity速度 production tempo生产进度现状 torque扭矩 spline=the multiple keys花键 quenching淬火 tempering回火 annealing退火 carbonization碳化 alloy合金 tungsten high speed steel钨高速的 moly high speed steel钼高速的 organic solvent有机溶剂 bracket小磁导 liaison联络单 volatile挥发性 resistance电阻 ion离子 titrator滴定仪 beacon警示灯 coolant冷却液 crusher破碎机 ; d0 l2 S1 S9 W: c
6 }/ t& Y; m7 h" V2 n2 S7 F/ Oplain die简易模 pierce die冲孔模 forming die成型模 progressive die连续模 gang dies复合模 shearing die剪边模 riveting die铆合模 pierce冲孔 forming成型(抽凸,冲凸) draw hole抽孔 bending折弯 trim切边 emboss凸点 dome凸圆 semi-shearing半剪 stamp mark冲记号 deburr or coin压毛边 punch riveting冲压铆合 side stretch侧冲压平 reel stretch卷圆压平 groove压线 blanking下料 stamp letter冲字(料号) shearing剪断 tick-mark nearside正面压印 tick-mark farside反面压印 冲压名称类 extension dwg展开图 procedure dwg工程图 die structure dwg模具结构图 material材质 material thickness料片厚度 factor系数 upward向上 downward向下 press specification冲床规格 die height range适用模高 die height闭模高度 burr毛边 gap间隙 weight重量 total wt.总重量 punch wt.上模重量 8 j N R- j/ @# Y2 Y+ s/ h9 `
, G- s0 b9 W2 J" Y
: f$ m5 `- }: S
