为什么我用 开始——所有程序——Siemens NX 10.0——转换器——“Step AP203”或者“Step AP14”会显示请各位大神帮忙看看是什么问题
7 X; a2 J8 V6 N' N! d/ I) t" n$ gugII_JAVA_HOME must be defined' M6 U3 V' @. S5 r- u( L& j1 Q
The Java Runtime Enviroment (JRE) was not found.
% C2 g% {5 l! H$ G& K; _. K/ a Install your own JRE and set UGII_JAVA_HOME5 r% V. `) U6 d; D& e/ r6 Q
in C:\Program Files\Siemens\NX 11.0\ugii\ugii_env.dat5 m$ P8 S4 }; M) T0 J5 ?2 F
to the directory containing the bin and
, O _% R+ ]+ B9 g5 q+ ^ lib directories.
' n9 B8 P* \9 o# G W请按任意键继续. . .( ]0 e n, t8 U$ ^2 g8 t; X# n
! ?1 m2 F3 z! P9 a" u; B. p& l! R! Z( W
