SiemensNX 8.5-10.0 version 2015.03 Solvers Updates 8 v9 F* D) Z( |4 H& \' X
9 A" i$ S; Y) w SiemensNX 8.5-10.0 version 2015.03 Solvers Updates | 527.4 mb ( r+ V* X/ S3 G* i6 ^8 \# l
Siemens PLM Software has released an updates of NXCAE_EXTRAS module to SiemensNX 8.5-10.0, is used to address thermal analysis requirements in a wide rangeof industries.
" U& U0 [$ U- u$ a8 A4 H- z8 W) p& S `
NX Thermal software provides heat transfer solutions and is an add-on module toeither NX Advanced FEM or NX Advanced Simulation. NX Thermal can simulateconduction, convection and radiation phenomena for complex products and largeassemblies. NX Thermal is used to address thermal analysis requirements in awide range of industries including aerospace and defense, automotive andtransportation, consumer products and appliances, energy, medical, electronicsand semiconductors. In addition, NX Thermal can also be used with NX Flow, theNX-integrated CFD solution, for coupled thermo-fluid simulation.
A/ O/ e+ p9 O/ I
1 E, W" V% T' p: {2 M) [' a3 jNX Thermal continues Siemens’ long heritage in thermal simulation and leveragesthe same technology that underpinned the I-deas TMG solution. NX Thermal useshigh-order finite volume-based technology on a FE mesh to accurately andefficiently simulate heat transfer phenomenon. It combines the versatility ofFE-based analysis with the accuracy of a finite volume scheme. The NX Thermalsolver technology allows simulation of NX parts and assemblies within complexthermal environments. file:///E:/TEMP/msohtmlclip1/01/clip_image004.pngIncluded: Siemens NX 8.5 TMG 8.5.302 Thermal/Flow Simulation SolversWin32/64 (update only)
* q# y! @ E u1 k }/ l& wSiemens NX 9.0 TMG 9.0.443 Thermal/Flow Simulation Solvers Win64 (update only)9 m+ |7 ^. e( `6 c: {3 F. J! T. o
Siemens NX 10.0 TMG 10.0.208 Thermal/Flow Simulation Solvers Win64 (updateonly)
- N! U( C8 @3 p5 `* E e/ D/ Q NAbout Siemens Industry Automation Division
. _0 P1 `: e4 O. a
- [8 {1 Z+ @- l7 f" F3 @The Siemens Industry Automation Division (Nuremberg, Germany) supports theentire value chain of its industrial customers – from product design toproduction and services – with an unmatched combination of automationtechnology, industrial control technology, and industrial software. With itssoftware solutions, the Division can shorten the time-to-market of new productsby up to 50 percent. Industry Automation comprises five Business Units:Industrial Automation Systems, Control Components and Systems Engineering,Sensors and Communications, Siemens PLM Software, and Water Technologies.
5 l, F+ Y+ ?* V! T* u8 m0 w ~0 v4 U! [- J, I
Name: Siemens / r6 P \4 F# s( L2 p; E2 b7 S; j) F$ c
Version: NX 8.5-10.0 TMG Solvers Updates 3 O& r9 x; ~) B5 p/ s- g: V
Home: www.plm.automation.siemens.com
# Q) @2 V8 f/ ~) Q& o, X6 C. CInterface: multilanguage
, Q* e) M7 |$ y8 ?/ [' r0 N oOS: Windows XP / Vista / 7even / 8 6 W8 S1 ]- [4 [
System Requirements: Siemens NX 8.5-10.0 with NXCAE_EXTRAS moduleand SSQ's crack to be preinstalled 9 _# _$ Z0 v% s( e& H% [
) W' D' V8 h9 h4 |" J- f* i, s" t8 ~# g2 |5 ~# d7 ^9 E
Special Thanks Team-SolidSQUAD& O6 ` }+ \5 m1 d5 G
- U# |$ r7 F7 sATTENTION! It's NX 8.5-10.0 TMG (Thermal/Flow) solvers updates only! To installit and to use a crack you need NX8.5-10.0 Win with NXCAE_EXTRAS module andSSQ's crack to be preinstalled! w4 ]" W8 x/ W G" o4 X9 N9 b
$ b) p; o) X0 a4 Z0 A$ Y
