楼主 |
发表于 2011-5-11 12:04
显示全部楼层
附件程序:9 C, G6 H3 Z: E$ u7 ~/ N* S5 D
0 P0 ?& v3 f# a0 i4 W4 ~# f1 K& B<PEEK.M>
' ?# a* E' d2 c(Met/Dia=PEEK-OPTIMA/16.550MM)1 m7 o+ [' S* J0 |6 l, q( s
(Ugpart_Path_Name=C:\Documents and Settings\JWHWA\My Documents\PEEK.prt)
. ^% k* n8 |$ X# }* |(Program_Time=Wed May 11 11:38:50 2011)
% e1 W2 N: Y( m(Programer=JWHWA)1 @4 N1 z5 [- [# K( g! I
#503=11.000(P_L)
: V9 i) _( y; K7 L$ E#504=15.300(CUT_D)8 A$ c$ i* U G6 t
#814=16.550(BAR_D): ?3 Y2 ^ U h( ^0 b( @4 U
, r- \' f) O; ?T0 ! W" _% j4 a) R) U! R H
G52Z0# B2 ^% F. j$ @# q
G0X130 & U; Z$ W3 Z0 K& k e6 L t2 Y
G52Z[#503+25.5]- A0 p5 Z$ Z. s* M% e$ I
G92S3000
3 \0 K# J: E7 W Z3 ? 5 r' v$ p. V2 }- g1 v8 k
(***DGTR 12B-2D30/DGN 2202J-IC908***)8 z( T7 G( J6 o( d+ Z- O4 }
T0303(TAGLIO) _3 w3 T* Y. {$ N
G97S1500M3P117 N) E% x' y0 K2 X
G0Y0
6 l. U7 `/ y" a3 lG0Z-[#503+2.88]6 q( R: `" X$ b9 b3 J
G0X22. $ ^7 V# k* K7 _& v3 X& t3 Q5 @: h
#818=#5022 % q5 ]/ u) b3 U
G308P11# Q6 N( j7 r# S3 t1 [* E. j+ l
/G1X2G95F0.053 ]& v( @. U m: @' n0 {
/G1X-1F0.015
; o, u# r/ T$ V& JM5P11
! b3 Y+ i$ N0 I, M3 c- {N1
3 `$ L. e) H& IG4U.5
# _( d$ T9 L7 k9 r% h1 {. q, mIF[#1000EQ0]GOTO2
; p5 ^' W R# k. J" Q' AM98P99
9 _' a5 N b3 i }) b$ n& F0 EN2
$ n' N( ]9 F# \M33
+ f7 {/ A) h3 q3 X: H; T/M36 ' R( t% W6 U. e7 o
G4U0.2 ( ^4 X. g7 x5 ~
M69
4 Z( m$ E( ?" \( K' |$ k2 f! {3 zG1Z0.2G94F10000! }( t) k5 \+ y$ \5 O
G4U0.2 , S- D6 w H# ~- X
M37, s" C) d+ y o, f1 d: E0 i j
G4U0.2
' O" z ?5 ?6 U& f \# j9 gG0X22W0.5
, V# y& r2 z' b: Z5 S! Q! e; aG53X130
9 T9 X! s4 k4 [* @M100
* K/ z4 Q* D8 `3 ?4 |/ YG18
5 N B' d, h( n, B1 }) |
1 c4 S2 W7 z5 m, a' P' s! P( u( i% X
T0101G0Z5(F/T R0.4 P3)
! K/ W X3 u( A* O+ H2 w1 S+ q$ E/ cG97M3S2500G95P11 ' M8 p& Q) {2 b! z" L$ k0 E9 e
G0Y0 . _1 v& f7 u$ j4 M/ a
X22.Z2.
- j1 I) @4 _! y M/ H3 aG308P11
# B$ H, D3 e. |7 LG1X#504W-0.5F.1 ' V- h3 p1 h5 T# K
G1Z-[#503+3.]F.065 S E q% J# o
G1X[#814-.5]F0.05
+ e" l9 c* `- f4 l! L( m7 H7 M9 `G1X[#814+.5]W-1.5F0.1 $ I/ a# k/ Q% I
G1X[#814+3]W-1.5F15 ~5 |- S7 w& e1 k8 R
G1Z5.0F1.0 5 N7 g- ?4 C5 q" C- @
G53X130
- M6 F" H9 v+ Q$ r" c2 A5 _M05P11 f v9 p, z$ k( Y! ]
G53X130.
& g- G; b: q* I1 RT1515G0Z15(CENTER_DRILL_D6.*90D) . ]4 k g, Z( a! j3 Y0 h0 W
M03S1500G94P11
+ M+ N, w5 V1 g, gG308P11+ ?7 l2 }! A! Q/ h
G0X0.0Y0.0 ( `: M" Z6 E; p- g- l" c
Z5.
9 [1 l g1 ^* Q1 ]; l/ o7 X$ mG1Z2.F1500 + B0 @( H+ D" J% j p
G65P7079Z-1.000W3.I2.J0.5U.2V.5E250F150
0 F4 g2 j$ M9 ?* mG0Z15. 6 Y3 c9 g' [0 O
M05P11
1 A' m: g9 v/ E+ n$ dG53X130.
7 T( y6 o d; Y$ p2 Y. p, H! \( vT1313G0Z15.
+ i! b; B U* `" L6 b; T; o$ y(DRILL_D=2.0 OR END_MILL_D=2.0)8 ?" t/ q1 d& D, Q( Q/ z8 Q' F5 P
M03S1500G94P11 4 u0 }7 N! U; A; k; m" S- F
G308P11; f0 ~2 K" O. x6 c) \2 {
G0X0.0Y0.0 4 a- \2 m2 c9 k, |) o+ a$ O: n
Z5.. ?9 K! x& x# @" y+ Z" g$ K
G1Z2.F1500
, u5 \5 p8 C- [+ Q4 K; c: t, ?. LG65P7079Z-5.500W3.I1.J0.5U.2V.5E250F80
6 |2 }& A3 i! k; U2 {: aG0Z15. o, h4 t8 }4 ? k* b- I' j- F: o
M05P11
5 d, l$ }8 e8 Y% O" E% {- c) AG53X130. - R! Z6 ?! e* M4 g
G1G94F5000Z5." m/ x1 Y% g& J( G+ ?
$ i* Y; c6 u$ ?) l5 LM05P129 e3 n& @! p. L9 g8 w, x; v
G53X130.4 @ `' u0 {1 v
G1G94F5000.Z5.
& E; K3 T/ J- V5 d- f7 N- H1 l1 PN0010T0707G0Y0(MILL_D4)
+ X+ I5 ]8 M9 ]9 J' F# AM03S3450G94P12! ]; S9 V& t _
G308P12
4 t, b6 _9 J( C g9 R(#=======================#)
! r1 |* [! g4 W' [4 r- `5 d) g' D(Tool_DIA=3.990 Tool_Radius=0.000)
& m1 S5 B8 o( q) h" L6 v( }, O(Operation_Name=D4_1_0)
) g# P- j' d* Z" z2 x7 e# ?(Part_Stock=0.000)
8 k2 C$ a7 q+ P9 Z(Operation_Type=Planar Milling)
( V" u9 M: N8 l+ X8 C o2 P(Cut_Feed=350) b7 t9 D9 l/ t1 Q. w. y5 r' L
(Spindle_Speed=3450)
1 U& k5 |( ?2 t1 `9 P& Q7 B(Now_tool_No=T07 Next_tool_No=T09)8 v1 `# [# k2 b& _+ T
6 Y! ~; ]* V1 N9 G5 O m0 H0 D( W1 kG40G0X24.Y10.495
' X$ V( W: G& }% Q* a( nZ-11.505
- m: s f' a/ d/ m, x2 cM19B0.0P11, r8 p5 p6 e) z6 a8 o9 U3 ^& s8 W i
X13.1
- S5 f6 X9 m2 q* q- E9 G+ wG1X11.1F350( j$ Z, t. @! @
Y8.5
L0 J. ?8 o6 o" O4 xY4.468( A% Q- J$ W- y
Y5.096Z-1.244
7 n" {1 a& l) e A/ i8 F# c6 ~G19G3Y1.108Z2.995R3.9952 ] {3 o: n+ C- z
G1Y-1.108
. Z8 ^: _7 ?& l6 HG3Y-5.096Z-1.244R3.995' c* }! u& p* l
G1Y-4.468Z-11.505
" P- n! M; b; ?Y-8.5
! Y) \3 P' t, AX13.1) K! H f" m( t4 |7 d& A' N& F1 Q
G0X24.
: D* o9 c1 @ l* e6 ^7 qY10.4958 g3 ~) j Y5 x" `- E- j
X9.2; S( F1 d' c4 r3 m$ Y& A
G1X7.2
$ d- N- W5 _6 d0 R \Y8.5& T* W. }! g1 |( g7 Z
Y4.468( ^ h( i) o$ S" R4 o
Y5.096Z-1.244
- Q* ]7 G# c' a3 vG3Y1.108Z2.995R3.995
5 q2 }+ J6 _( AG1Y-1.108 [+ y# a! i5 t% ?
G3Y-5.096Z-1.244R3.995. k) @( B, T* l; ?7 R8 w
G1Y-4.468Z-11.505
& n) q8 Z" f9 QY-8.5
7 S% Q5 O) S% p0 aX9.2
$ ^5 t8 c2 S! l. [, HG0X24.& @9 Q, V6 E, R. q8 U5 Y! q
Y10.495
* J6 {% n T1 x; [' |5 t+ [/ gX5.3
[' q1 H# [9 o, j" \ wG1X3.3" v: s5 t4 n) U: M
Y8.57 @2 }, F2 s$ P; k' _. j
Y4.468
. W8 l5 u( }# }- B, U, ?Y5.096Z-1.244# [) {, i$ Z6 z) H x0 H C
G3Y1.108Z2.995R3.9959 ^' D$ ^ A: n# L
G1Y-1.108. k) E. _! w Z$ t- b$ f, ^
1 R7 @2 q% B5 S6 \# `' I7 OG1Y-4.468Z-11.5051 A, d8 U! C9 @6 \
Y-8.5/ G6 A8 u! P) @+ M
X5.3
: a& L2 L* |9 u5 [9 c5 W; rG0X24.' B- ^ B. C+ }/ M
Y10.495
- M+ J3 k' Z5 {& O" M7 D6 z k# U X+ cX1.4+ c+ G( u# v2 k
G1X-.68 e- `* P+ n4 U! H. e0 J4 }" I- n
Y8.5
; b4 I! W6 M0 ~7 IY4.468
& K$ v- a5 o( |Y5.096Z-1.244. y, e% E7 {. ~
) V! S' k; @6 o! q; S4 hG1Y-1.108' ]; p. N/ F4 V( ]; d
G3Y-5.096Z-1.244R3.9954 P q# ~# c) ^
G1Y-4.468Z-11.5051 W8 y; f5 K7 @' c& P" t
Y-8.5( e) B, w" I6 v: H4 u! l' \3 a
X1.4/ b F! P3 ?; h
G0X24.
9 j# l0 [& c/ b# d+ RN00203 B' P% Y; d0 K, b4 O, C( G% q, g
(#=======================#)6 s1 y( N# {) u0 r
/ P9 E3 u" U3 a(Operation_Name=D4_2_0)
* y/ j+ x2 |5 O(Part_Stock=0.000); w' R/ Y! [& m9 _/ ~
(Operation_Type=Planar Milling), {* K& C7 m, Z$ k$ s
(Cut_Feed=350)
a" C" I+ c2 h0 q; ](Spindle_Speed=3450)
% s& X2 p3 G) x; d( @(Now_tool_No=T07 Next_tool_No=T09)
0 ~2 o; C5 H3 \. @! B2 v8 g(#=======================#)1 e, w5 {# E0 @- J4 Y
G0X24.Y10.495! R+ Y6 O4 }+ Q( F) K/ Z' e, Y
M19B180.P11' X- Q! M4 f# F5 ?" @
M03S3450P12
4 ?/ F `3 J- m, l* ?. u- \X13.1
$ O' m! n% V, f: C. `7 j5 HG1X11.1Z-11.505F350
4 M6 j7 }# K. A' Q Y. X% D' OY8.5. {5 f# R# l* V
Y4.468. U5 o5 P. N- S G
Y5.096Z-1.2440 w: D4 m/ e8 q& {) N
G3Y1.108Z2.995R3.9959 ]# U) \( v! a, X! k
G1Y-1.108
1 Z* k$ b5 |0 Y0 e6 F( M0 J+ jG3Y-5.096Z-1.244R3.995
, ~+ J2 @8 l/ u/ b! ~G1Y-4.468Z-11.505
8 y' s( N* E2 S( f6 t/ iY-8.5
( A5 d% B; ~ r3 I, p2 l' HX13.16 q6 f4 U! f) x3 n7 l
G0X24.
/ [6 @* @- F/ H0 e) @2 w; X% PY10.495' a' I, d" Z9 m- Z- n& q' X
X9.29 `) T& h3 x% Q; A9 P
G1X7.23 Y0 t* ]8 S# s4 I# u
Y8.5
- A0 C* a0 }/ r) l2 _ L6 p5 B; B) cY4.468+ V1 T" H: u5 z. J, Y: y& o5 {
Y5.096Z-1.2441 N X' G5 B) e4 |+ e1 t
G3Y1.108Z2.995R3.995( _4 B* M# p7 l l3 J; `" x
G1Y-1.108( T& F# w1 R' ]8 _+ P
' y+ o0 }5 ~$ Y$ B. S) U8 S+ EG1Y-4.468Z-11.5053 N A# O2 s, j) b7 H
Y-8.5
" _+ b5 ]1 h2 ~8 o$ VX9.2. b- m. w! a3 _( I' F
G0X24.5 I; K$ Q2 L" i2 g. I2 B' C1 w
Y10.495: L) e& g9 y4 k0 d) X$ S9 J
X5.3+ |/ [- ?5 L: b/ i; {$ u3 O; M
G1X3.37 \- o- l! z' e' Z4 S
Y8.5: z& I5 R G8 n X
Y4.468
! E* g3 E* k, x$ ?" g" t8 `/ xY5.096Z-1.2446 \$ {& [- b% N9 O4 T+ L W' W& w
G3Y1.108Z2.995R3.995% Y$ O# p+ A1 j2 A
G1Y-1.108 }# V1 k# ]# K2 R1 ^$ n
G3Y-5.096Z-1.244R3.995' R: k8 f/ _0 G x: R
G1Y-4.468Z-11.505" d$ A7 b; K+ ]7 G$ f
Y-8.5
! A8 |, D% a; ^6 a2 ]! oX5.32 K- n4 c( d, ~$ a' ]$ ~* o$ c
G0X24.
* A7 t; j( Q `* N' _ pY10.495
; g+ D: h5 ^2 ]! c2 X" {! A& TX1.4
( M9 q G: X# yG1X-.6
8 O; V3 w, ~' gY8.50 P) l2 Y9 z, D( F" }
Y4.4682 V2 p/ _2 D2 t, E j
Y5.096Z-1.244
( B! n# J' N' z4 d6 BG3Y1.108Z2.995R3.995
5 G \# g% j5 Y: ^G1Y-1.108: d! F4 ^9 M& ?2 ~9 w
G3Y-5.096Z-1.244R3.9951 V8 e( t/ \7 [9 o: e% f0 r
G1Y-4.468Z-11.5053 y- f, b/ f/ n+ ^# v1 u# g
Y-8.5
1 V9 T" z8 k* u7 ~2 dX1.4# ?, {; R9 o5 _/ k
G0X24." L! J/ W4 S' l8 z5 F" B4 I
N00309 r7 p. B; q6 l% I" q
- x. o, J, O- \1 p2 k( q(Tool_DIA=3.990 Tool_Radius=0.000)
6 M6 G7 l. x$ ^0 e% l(Operation_Name=D4_3_.15)4 K& C& S, @9 I8 ?% ~
(Part_Stock=0.150)
* j% r8 q3 _0 e( Y1 I(Operation_Type=Planar Milling)
" P' n; f5 v* u& Z: o(Cut_Feed=350)
9 m u B8 m; c' y6 O1 h(Spindle_Speed=3450)
) y+ f% n. [; b( y4 x6 {1 c4 D3 W(Now_tool_No=T07 Next_tool_No=T09)
: N7 q% U* r4 O9 M- s' N! P# |* \% o(#=======================#)5 t. i0 m" W( d) G& ^' ^
G0Z-11.355
5 |/ A3 ?5 [" X' s9 o9 qX24.Y9.: i4 K$ G4 \* h
M19B270.P11 U* q- S/ w. V1 F
M03S3450P12" B, | D( H6 t/ V! A$ Y" _" O
X5.5
v, V, t1 G: a" g! vG1X3.5F350
% @: G% }- C* \# Y3 F% SY8.5
8 a, v+ @: c% S! AY7.971
' u) e. @: e0 r0 L3 L% F% pG3Y9.157Z-2.151R38.145) {* P/ e" U4 {0 B, G+ J
Y6.332Z1.424R3.645
5 E8 E% L/ _% Q) B; VY-6.332R28.145* C; j3 A# j6 q, O6 f
Y-9.157Z-2.151R3.645
; A# J; N6 k+ O5 R# Z# IY-7.971Z-11.355R38.145+ L) P, u; v- `0 g9 S
* L3 u9 p2 [+ a。
; I( J5 E/ F% c。' E5 r- ^" b' C8 E$ ^2 W
。& I6 L3 X6 x6 Q/ B
。. {4 H1 D- c/ ^6 v) l5 j& W9 a# S
N0350% I. h- h4 H1 W2 L" ?+ v5 H! u& u
8 T8 f/ h O% K$ o/ N1 \(Tool_DIA=1.190 Tool_Radius=0.000)# P. B% }4 j& r. X) p7 k
(Operation_Name=Z2)' i* X/ C' e8 x
(Part_Stock=0.070)
- V0 R7 [3 Q4 O: q(Operation_Type=Z-Level Milling)% X6 L9 a4 e4 [+ w8 L8 l
(Cut_Feed=600)6 F! l' S; h) ~$ h# U8 f8 n% F
(Spindle_Speed=3000)
/ T" g8 n8 \) y0 D) y5 d% h(Now_tool_No=T09 Next_tool_No=T07)/ G- ^* H1 i% T3 V) C
(#=======================#)( H. r9 T" i/ x- Z: [: T3 p
G0Z-12.0121 I: ?' n, f, k0 J! ?$ ]0 l4 u
X24.Y3.505
0 _& ^" N" J5 X; X. ]! HM19B90.P11
9 n+ u9 t- S) H2 Y$ U7 y8 lM03S3000P12
' E# e2 e( N& j2 b) E; J7 fX12.0644 I4 r: J8 j8 g% j
G1X4.064F150
) C1 f. I8 B5 O7 p5 w7 KG2Y4.022Z-11.4R.595
1 G3 K$ F$ B0 V5 a) i% O+ r0 gG3Y5.117Z-11.235R30.665F6008 g0 o' }* K+ N4 `* G( u! H
Y5.258Z-11.195R.665
x7 Z' a* Q. j4 D- z% e- tG1Y5.31Z-11.1938 }/ L4 q; J/ H5 Y# O$ u
G3Y5.692Z-11.053R2.1658 k6 C' M1 Q) B
G2Y6.419Z-11.224R.595. d0 \ G& n0 a: M f: a
G1X12.064: H, D4 O# M" n
G0X24.
, d0 Y4 l6 _1 ZY2.696
5 F6 W) G/ T2 p& G% P! AZ-12.105( U. M( U% T$ E
X11.679
% |2 @, r5 w) _! U" } KG1X3.679F150
% _+ \/ [2 V' ^( z/ |0 ~4 U" _G2Y3.228Z-11.495R.595 J; t3 I5 @0 c( I' W' J
G3Y5.117Z-11.235R30.665F600: _5 y7 w' ?$ s- q6 z5 o
Y5.258Z-11.195R.665. M$ G9 a7 e V. ^ p c2 z
G1Y5.31Z-11.193
/ ~( @ s; j9 e% J/ g4 fG3Y6.061Z-10.828R2.165: r T" J* c' t. O6 G4 R; ], E% R
G2Y6.793Z-10.838R.595
1 G& n: T7 @/ c5 LG1X11.6796 q o- C" a; r( h& c- Z4 z
G0X24.( {; ?* }) l S8 ]4 n A
Y-6.4239 q5 S$ H0 z+ G5 ] e# w
Z-11.221( K1 O+ d* h8 U1 ?6 W& M
X12.064
* N; g* f l9 v7 J" r7 l+ [1 [9 EG1X4.064F150# R6 a$ O* S$ {/ d7 k
G2Y-5.696Z-11.051R.595; r" [3 y a' N( z
G3Y-5.117Z-11.235R2.165F6002 K: W0 C/ c0 c# Y
Y-3.913Z-11.414R30.665
" ?( R( Q* X" H% CG2Y-3.398Z-12.078R.595
8 A# [3 y. g1 C5 BG1X12.064
4 x% j5 `* G+ R. PG0X24.
( t8 }* m3 v3 I/ @4 D U* gZ-10.8666 q, o& F$ _# q% u
Y-6.79
0 g2 G* u! J, g& @+ \2 k6 VX11.679
+ }) z0 o9 A8 I/ c) i5 j/ w& SG1X3.679F150; }" m6 V2 ^$ M& f5 T; l6 ]
G2Y-6.047Z-10.839R.595
/ u4 N# K' r; BG3Y-5.315Z-11.192R2.165F600
% n: U( O/ K2 k/ B q5 B. bG1Y-5.255Z-11.196
9 b; R6 m) @% }( K+ i/ W' RG3Y-5.117Z-11.235R.665
- j8 b& J: T4 s7 `) L7 r! z- ]Y-3.185Z-11.499R30.665
) G) C# ] W$ L, QG2Y-2.655Z-12.15R.595
+ S0 E* e2 \) |- x* }6 \G1X11.679) R8 ?7 _0 ], I$ o
G0X24.
7 z- T. Z" c: b% Z" YZ-9.4313 T' h7 b6 H! r- X. y7 j
Y-7.496& P. _/ M6 d) O+ Y- H6 f1 T, l, `
X11.294
* }- b7 r. T7 h6 IG1X3.294F150
, r$ U7 @4 k. O) }% n7 @1 N9 zG2Y-6.8Z-9.814R.595
2 r. r; k& }: V* Q9 n* [: lG3Y-5.117Z-11.235R2.165F600
- I" H5 a$ Y/ e- [Y-1.07Z-11.646R30.665, v. ?% F2 n) Z
G1Y1.070 |$ F' M( R/ v. r9 x: b g# a( a
& H+ b8 ?" J0 [7 N% r: ZY5.258Z-11.195R.6650 K1 i4 G2 d4 l3 T
G1Y5.31Z-11.193 {' ]) Y$ C# e! ]% k
G3Y6.831Z-9.719R2.1656 I: N3 p2 F1 x! g/ \
G2Y7.527Z-9.308R.595
4 b. k1 F7 \! v. tG1X11.294
9 x( D$ |/ s+ M3 Y7 ~' o7 r: EG0X24.) h' {7 i3 G/ x
Z-9.092
! G1 w4 ~( v r1 E8 e% tY-7.5756 `& r/ F! c& W( Z; q( _2 |' Q
X10.915 ]2 b; z ?0 l/ r6 _! M/ G0 C
G1X2.91F150
$ u* E$ j0 G" c& | Y$ R7 QG2Y-6.874Z-9.551R.595% C1 e0 s( M) a4 B* V
G3Y-5.315Z-11.192R2.165F600' a# f, f3 U9 M$ c
G1Y-5.255Z-11.196
3 {8 `/ T1 O' k9 [G3Y-5.117Z-11.235R.6652 _3 z& P3 L8 b
Y5.117R30.6650 G; b' U$ n( ?4 f( @0 R9 G' p
Y5.258Z-11.195R.665. j6 U* V C b5 R& z; T
G1Y5.31Z-11.193
/ {8 G4 c. Q0 }; zG3Y6.874Z-9.551R2.165
c* E8 D/ o1 ]0 pG2Y7.575Z-9.092R.595) u8 @. w! H$ s. n3 H
G1X10.91
/ ~8 G' J; C- O: R- n9 d$ N9 W% kG0X24.- S5 g5 O' y2 a; J8 b1 c6 I& ~
Y-7.575
$ i$ z R/ Y2 O( T. h* RX10.525# h- T7 Q ^" v( y" }
G1X2.525F150* q* ~& s7 f; h# D
2 P1 V9 x, f6 H) I& |: g% ^G3Y-5.315Z-11.192R2.165F600" K4 {4 E2 \4 @/ d
G1Y-5.255Z-11.196
0 \2 t0 X% ^$ P1 UG3Y-5.117Z-11.235R.665
$ w8 Z6 {1 b0 f" VY5.117R30.665, e4 O h% U+ R" e8 d
Y5.258Z-11.195R.665
; U& a; }! j! m0 N6 GG1Y5.31Z-11.193
9 u: T1 b/ y! y7 r/ W0 TG3Y6.874Z-9.551R2.165
+ a' l% f, s) ~6 H! X0 UG2Y7.575Z-9.092R.595
! F# r4 C6 K+ G @& C; K* q5 ?3 AG1X10.525+ d c& K: O6 A) f
G0X24.
! S* q# ~; d7 W/ DY-7.575
& B, L6 i6 G6 |! DX10.14
; H. M: y/ e% G. q! B7 j+ AG1X2.14F1505 M4 m$ f; l- L& j' D
$ k; W+ Z) F+ a6 k4 X9 x* KG3Y-5.117Z-11.235R2.165F600# R! \$ f! L q; C Q" K
Y5.117R30.665. P5 @( \+ |) g/ p, V
Y5.258Z-11.195R.665
0 h* f, Y- x* RG1Y5.31Z-11.193
0 a3 H8 p" e% kG3Y6.874Z-9.551R2.165
# i$ g* N7 p% a; u" Z0 rG2Y7.575Z-9.092R.595
5 M2 P# R. I4 w' }! gG1X10.14/ h& t5 a: M( h& |. z9 D( J1 w
G0X24.
/ }2 U8 u* F h4 L6 m8 n- GG18
9 R: {( v7 {# s# C/ pM05P12
_& S" [7 ~; z% m, L( I; D( vG53X130.
4 t; R% A+ \) N3 N% a! V(SUB END)1 J. Y% F/ z9 z% [; w: z( |
& }1 L. k* a) K; i" u ?3 b1 Y% d
T0303G0Z12(CUT-OFF)* n7 G7 T6 \- K( \# d
G97G95M3S1200P11
; X7 I+ J+ v' L, j$ B3 ~9 E" Y. KG0Y0- d2 j3 I) `4 |6 U2 h
X22.0Z-[#503+2.88]) |! s& q# c9 Z, k( d( m
G97G95M3S1500P11
+ F4 b* @. a4 B9 H9 [# I2 lG308P117 y; @9 y# _% V( w
G1X[#814+.5]F.2& I0 y# Q4 P& \( H6 I F( O
+ I+ o3 x; i& ^) a9 Y/ [3 LG1X1.5F.05/ W0 V' a+ V* G8 v, X
M1
3 s9 K6 q5 [/ u5 G) \3 V, x( TX-3.F.05 ( s+ u% @- h9 ~0 H- `6 f& }
/M18
2 \! f+ H3 ~( |! bM5 2 ?+ X" W6 L" x8 H/ q
M1! z8 J( d0 J* e2 l! ~- H! |: s
(MC_TIME=33')1 s1 `, I8 E+ z& e
(SUB END)
! p3 ?% Y: R& Z3 W. CM99P1% [1 b7 c v$ M- C0 ~
