To use this update, change to the directory where you unzipped the nx-8.0.3.mp11.zip file, make sure the entire set of new MP files have execute access.
Then do either one of the following:
1. Run 'run_ugsupdate.exe'
This will read the %UGII_BASE_DIR% from the Registry and apply the update to the NX 8 folder.
2. OR, you may follow the instructions below to run ugs_update.bat directly.
Before running the script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 8 release or set to the appropriate installed directory on your system. Then execute the 'ugs_update.bat' script.
) ]/ S9 b2 f' f1 e/ u2 Y& ZFor example:
7 r9 P7 |* f1 Q( d( j
Set UGII_BASE_DIR="C:\Program Files\Siemens\NX 8.0"
cd nx803_mp118 g: u9 d) N1 I i
ugs_update.bat /v+ [0 F1 k& W" Y3 T, ^
+ v1 s/ x. M5 i1 c
The script supports a "/v" switch to turn on verbose messages while doing the file updates. The default operation of the script is non-verbose.2 _$ j/ w6 w3 M8 A2 m
) K8 E7 O# h+ f4 J9 QThe script supports a "/d" switch. This will turn off the script confirmation prompts; useful for running the update in a batch job.! s, x7 b9 U& ^6 P3 _7 V; u
6 t& C( _, ~; K4 P0 C9 e/ V
The script also supports a "/p" switch. This will turn off the initial confirmation prompt but it will display the final 'done' prompt. This is useful for running the update in a batch job where a final prompt is desired.
; A& i$ ^* v; u" E1 i! @6 M
2 q, J( K7 u' @; @
9 `; o$ d8 j4 T7 t" A- ?. Q- G" C' v1 j2 a) m# }
" k( R; }5 ]1 w! x3 P# Q5 ALINUX update instructions
The files contained in nx-8.0.3.mp11.tar.gz are provided as replacements for previously installed NX 8.0 products.
For the Linux64 platform, you should have at least 3.13 GB of free space.
: m1 B/ B" w4 D; e! G. XVersion NX 8.0.3 must be installed before updating to version NX 8.0.3.mp11. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.
To use this update, change to the directory where you extracted the nx-8.0.3.mp11.tar.gz distribution file, make sure the entire set of new MP files have execute access, then execute the “ugs_update” script.
cd nx803_mp11
chmod 555 *
./ugs_update -v
The script will interrogate your installed NX directory, and update the installed files. The normal operation of the script is non-verbose; stop to confirm default answers.
The update script supports 2 switches:
-v = Display verbose messages.
-d = Take all default answers (i.e.: script will not stop to ask questions).
) R4 H+ R$ F, v( ]
, f7 N/ s" K( C% o% ?" X3 W2 r8 X+ X, {& b! f
After the MP update has run successfully, the following identifying text will be written into the system log of every NX session:
"NX 8.0.3.4 r MP11, 18Aug14. See Maintenance Pack letter for detailed list of fixes."
3 T1 L2 o5 L$ n: f1 v* ]. L7 CIf you have any issues with the installation or support of these fixes, please contact your local Siemens PLM GTAC support group.
, f# L O1 r2 L5 R) m b" D7 r! B! gSincerely,
$ m; M3 ^. _$ Y6 z. z# O3 `
The Siemens PLM NX Team
8 F" z- m4 h& b' W/ q
0 p- V- t7 [) Z+ j: i7 Q
