查看: 1475|回复: 6
[疑难] 那位高手可以指点一下实体偏置OFFSRF的问题
发表于 2013-11-21 22:06 | 显示全部楼层 |阅读模式
目标如图的效果。最后一步卡住了,那位高手可以指点一下实体偏置OFFSRF 的gri源码。
! N* \, o4 p4 _用下面命令出错了:  z6 f4 ~9 O9 S0 i, ]" I% J7 k  f6 w
entity/obj1,obj2(100),obj3(100),$
- o8 h9 e: C, T/ H/ B- b! [7 `solid1,solid2,solid3,solid4,solid5,solid6, j$ O+ J  z9 Q: H4 N1 \' k5 }
number/h1,h2,mat1(12)
- n! {$ {1 F, b" a+ YNUMBER/poin(3)
# H8 O8 ~$ E# q3 Z- Bmask/710 l; W( D9 T4 K, x. P. ~; [7 P
ident/'选择要拉升的平面:',obj1,cnt,num,rsp; b% I& H) m0 J( R' i
jump/reject1:,term:,,rsp
( l. d. M5 g8 y* v2 B7 V! Q; V1 _6 K2 g8 Y# X3 _
+ g, n2 i' F0 r* l. B
1 D$ ]4 v9 T" q. F  D" s
solid2=solext/obj2(1..c),height,h1+h2,AXIS,poin(1),poin(2),poin4 v! m, t4 s# k+ X' e
。。。% }7 B  b! Q) ~
solid4=OFFSRF/solid2,.4 运行到这句就出错  R1 ~. {# k  Q
/ R4 w6 D7 V1 ~6 @3 O8 A' `4 j
1 G4 e+ l- t7 ~4 s2 ~8 K
$ j/ ^$ i( R4 u! R8 m- F( L
目标
目标
现在
现在
发表于 2013-12-13 12:40 | 显示全部楼层
ENTITY/obj4 G2 X6 Q9 l. ?+ [  \# M4 S$ `
NUMBER/poin(3)
# m( V- {( u0 W; Hstart: ) h. D* |( _' p- d! E+ i
   h=2/ _. R% B( V" s; v) S. g
L10:
0 R8 |+ ?+ C- t1 w+ M8 j      param/'请输入偏置距离',$
) N- S8 B& c. V             '偏置距离=',h,resp5 `2 H. ]" u% z6 i/ _
      JUMP/L10:,END:,,,resp
: K( a( r) d3 w5 T0 f8 SL20:
5 u# s1 l7 C/ {) k& ?" N      MASK/71
0 S6 v* ?6 s: M0 V  S) N- ^! B      ident/'请选择目标面',obj,resp
0 h$ L# P. e! q7 j! h3 F      JUMP/L10:,END:,,,resp
3 X- j3 B1 }3 D# x! }3 S1 Q+ e( O; U( Z: D2 ^$ F. w
' ~1 x3 [8 i. a/ a( A
9 Y. B$ ]" m( l4 ?5 i" q; W" K/ NL30:& ?$ h1 U8 `* L$ y# D8 I- M
poin=snorf(obj,.5,.5)
3 X# P" F: C' o: f  A4 V4 jIF/h==0,JUMP/L10:& G3 U4 t5 Z: n) M: Y3 W
IF/h>0,FACMOV/obj,TRIM,HEIGHT,h,AXIS,poin(1),poin(2),poin(3),IFERR,BN:
1 h5 j$ W) l; k" |' bIF/h<0,FACMOV/obj,TRIM,HEIGHT,ABSF(h),AXIS,-poin(1),-poin(2),-poin(3),IFERR,BN:
- D6 F. u2 y8 g0 N9 k, _3 Q/ K* MJUMP/L20:
4 z. t- ~3 M) T2 v7 p/ [1 [0 V! J$ t% F1 E* i
END:
8 ?+ ^& n. ~& F' `HALT- C- r/ C) |' ?+ j/ z- w% g- g
" }4 W6 E& `- b' u3 ^) NBN:3 s8 t2 G; d; Y# A# H3 \
PRINT/'由于参数不符...所以不能偏置此面...'- O: w/ E* _& {
JUMP/END:" e6 h* N1 R) A
" k& \4 m$ c" A  y% m
回复 支持 1 反对 0
 楼主| 发表于 2013-11-25 12:42 | 显示全部楼层
没人理,自己顶
发表于 2013-11-25 17:03 | 显示全部楼层
偏置面命令,在GRIP中没有;- ~/ _6 {& W/ \3 |2 r( O; n
如果要求不高,可以用 FACMOV 代替;也就是单向偏执
 楼主| 发表于 2013-11-25 21:00 | 显示全部楼层
-KASA- 发表于 2013-11-25 17:03
7 J4 K" Z3 V. O2 ^& p9 H偏置面命令,在GRIP中没有;
7 H* V- D# m/ J- n8 ^$ n如果要求不高,可以用 FACMOV 代替;也就是单向偏执
* |3 ~) q9 [1 m' @# j
,我试试' v; M, m8 c" `7 G- p6 e
 楼主| 发表于 2013-12-13 23:24 | 显示全部楼层
yeyanqiu 发表于 2013-12-13 12:40
3 U- z( y2 H* z- J9 BENTITY/obj, O/ H: G+ b1 K+ G" ~) A6 o) X
NUMBER/poin(3)
5 G8 I4 }& u( f/ i! ostart:
, C4 t# E- n0 t4 ]0 y方形就没问题,方体一有R倒角时会出现变形,平面正常,R面就变得奇形怪状,还是没办法。
" V/ I/ o0 h/ R5 |. a
GMT+8, 2025-6-29 04:13 , Processed in 0.059401 second(s), 25 queries .
