一、入水:gate
4 y" ]+ E* }- m7 [) C: V. @进入位: gate location , D# P) w. a6 k
水口形式:gate type " L% h9 }: l2 h( O5 Y
大水口:edge gate
P$ ~+ p' T( _- C! R# I' W( Y9 i细水口: pin-point gate " J/ A& C' J# f: D
水口大小:gate size
. o7 n U# |" z: Y转水口: switching runner/gate & p3 t3 g# P8 I- X
唧嘴口径: sprue diameter
" ^7 N& U% X) ~! H8 p+ z- q二、流道: runner + U5 o3 _1 j/ a* |" o% i4 Z6 L
热流道: hot runner,hot manifold
2 R4 B; ~& [8 L6 d热嘴冷流道: hot sprue/cold runner
Y5 l" o) i0 U) j唧嘴直流: direct sprue gate
2 u+ F4 H: C8 u0 O+ P0 b; D- U* {圆形流道:round(full/half runner
/ K" P4 @: q% t8 H8 y流道电脑分析:mold flow analysis
) e. S! Y; s" A/ H# m流道平衡:runner balance
1 A7 u$ g; K1 z7 C8 n2 Q热嘴: hot sprue
& M- i. a4 q6 J4 F热流道板:hot manifold 2 a2 g4 d. b9 c! _
发热管:cartridge heater
# H; U# n+ w. C探针: thermocouples
3 O- s1 { l+ \) s# F5 c插头: connector plug ; ~3 k; R( U& A! M+ j# P8 h$ |' L
插座: connector socket
1 ?9 W; L: X M, D; E9 [0 D% K! |密封/封料: seal 4 u V& F) o9 Q& O2 j
三、运水:water line
/ [) K; c5 a8 x喉塞:line lpUG
/ d* Q/ j+ A) v$ `喉管:tube
0 O5 _4 U, v: I& P3 O* Y塑胶管:plastic tube
3 d' {5 S5 O6 p: b快速接头:jiffy quick connector plug/socker ; u3 R# x6 N- Y" B& ~) r8 Z2 O; G
四、模具零件: mold components
; b! ^( `7 U a4 I三板模:3-plate mold
# P! t: q' a7 N$ E& o @7 V# W二板模:2-plate mold
$ q) y8 I" u9 X8 p边钉/导边:leader pin/guide pin & j U9 C- b. t, }
边司/导套:bushing/guide bushing 2 G6 k# ` J4 `- R
中托司:shoulder guide bushing ) _% J9 d" X7 T$ L/ Y1 A+ p( V4 Z
中托边L:guide pin
$ k6 Q" m' `* D) Y6 G2 t* |# q顶针板:ejector retainner plate
$ H- B9 ^: Y( s3 D( N4 Z$ Q托板: support plate
" y2 f+ Q" [- l1 ]3 e0 O1 R6 m( y螺丝: screw ( J! d) f" H# P {% A. |4 I- k
管钉:dowel pin . m8 ~; @9 Z7 J( ]" G
开模槽:ply bar scot % ^; t+ L' A. U' u8 _
内模管位:core/cavity inter-lock
8 g- X4 B1 h' h {4 U$ k顶针: ejector pin i9 l2 D3 u( i% M
司筒:ejector sleeve
& o) V, N2 p% Y司筒针:ejector pin
4 v+ D- v7 e. Z; a# U推板:stripper plate 6 r6 Y: R& c( s1 d, r
缩呵:movable core,return core core puller 9 x, E/ k0 D8 S2 J
扣机(尼龙拉勾):nylon latch lock 1 O' K8 \! m# T1 ?1 A; `: b1 c8 a
斜顶:lifter 8 e- w: T2 N9 @8 H2 p2 |
模胚(架): mold base
& W! K1 p% c' C m1 O上内模:cavity insert 7 G4 z" Z+ ^5 I D. ]/ x
下内模:core insert
. c$ ~3 @( Q2 s行位(滑块): slide
P. N7 O( e# P( K0 ~& C2 r6 b镶件:insert & _7 m y C$ [9 a" P* @$ v
压座/斜鸡:wedge - \1 @* C4 f7 l4 a* P
耐磨板/油板:wedge wear plate ' g7 U: F5 i' e- Z0 N2 |
压条:plate 撑头: support pillar 8 R$ X1 ?4 o# `, f
唧嘴: sprue bushing * i: F, o/ z3 L7 k h, u( h% C( z) w
挡板:stop plate 7 o( t! K2 W; F; U# g5 s
定位圈:locating ring
5 D9 V4 b0 \' C8 N锁扣:latch $ O) o2 S+ n( }2 P. K* \
扣鸡:parting lock set # e7 y4 h1 P& }7 n/ X
推杆:push bar ( N& ?* n) N; F8 L4 }0 x
栓打螺丝:S.H.S.B ) x$ j" h0 B7 c: W' v" i: h
顶板:eracuretun
! l# V% X5 n; j& G活动臂:lever arm ; C! }) v' I8 u" t; r) H0 g% d
分流锥:spure sperader
: a1 G: B. B. a* Q* W水口司:bush
, Y' h+ Y, E! g% T# o垃圾钉:stop pin
/ B: k$ o, ~( Q5 H& I, \+ O隔片:buffle ; C; A4 R( A% X2 n+ }' X2 R3 b
弹弓柱:spring rod
$ M5 C( K/ ]5 r) }弹弓:die spring # o! x. f, H) L3 T+ ~
中托司:ejector guide bush + u% f7 @6 S) s8 {% Q. C$ e" ^' }
中托边:ejector guide pin
3 r9 s5 S9 }3 G# y$ t镶针:pin 6 @# b, Z, I' f1 J6 W
销子:dowel pin
5 c! }0 E' _, u! U! A8 G$ S7 ~波子弹弓:ball catch
5 d' _9 A3 |) s* h% k0 ^4 B' N喉塞: pipe plug
$ G4 [: G1 J, O( w锁模块:lock plate
. P. z" Q$ j7 W7 M! G# W斜顶:angle from pin / }7 q5 T3 s3 x0 V9 L# X: g
斜顶杆:angle ejector rod 8 X5 w; ?. h4 d- E8 E
尼龙拉勾:parting locks 1 v! S% {8 E+ u1 |5 b; \2 ?
活动臂:lever arm * A) {! M3 v k4 i' w7 T- [7 u+ ]
复位键、提前回杆:early return bar 1 h3 c& M6 G7 K! U- y5 D* q
气阀:valves
8 n. [! D# b& x! o' M斜导边:angle pin
2 Q# E x1 P6 _术语:terms
! o: N1 Y! P5 v3 @承压平面平衡:parting surface support balance
# \1 {3 k. D* C0 K+ {模排气:parting line venting + J2 e* a1 j& O0 T
回针碰料位:return pin and cavity interference , k. u r; S% n/ u9 J+ D' l
模总高超出啤机规格:mold base shut hight
! q, Y' |. I1 \% l顶针碰运水:water line interferes withejector pin & f# E1 L- I" c5 s. @- p1 c/ @
料位出上/下模:part from cavith (core) side # I' t# g# l$ L
模胚原身出料位:cavity direct cut on A-plate,core direct cut onB-plate. 1 @% g+ ?3 |; X! |0 k. h1 f$ R
不准用镶件: Do not use (core/cavity) insert ' v1 k$ ]+ [, l( M {3 L K
用铍铜做镶件: use beryllium copper insert - z4 y- l1 n) e4 a8 x3 t
初步(正式)模图设计:preliinary (final) mold design $ N" c2 M0 T }5 r; L
反呵:reverse core
: M4 D8 c4 t" \" v4 i! C弹弓压缩量:spring compressed length 2 K8 f8 V0 X6 s1 s
稳定性好:good stability,stable
; X- X4 u1 i5 A强度不够:insufficient rigidity
# A' j. L) M. V8 w7 h! U均匀冷却:even cooling ; F" n) Z3 b+ |/ G+ t
扣模:sticking % t4 J) H5 ]+ C& t! r, a
热膨胀:thero expansion + ]5 @8 A2 D( F- }0 A1 m' O
公差:tolorance
) H# z& I5 Y4 w. x$ r- u铜公(电极):copperelectrod
/ d7 j, l# V2 Q! F6 s
英文简称 英文全称 中文全称 , W7 g% p* A1 I% C
ABA Acrylonitrile-butadiene-acrylate 丙烯腈/丁二烯/丙烯酸酯共聚物 5 Y4 j3 r2 h% D0 y$ z
ABS Acrylonitrile-butadiene-styrene 丙烯腈/丁二烯/苯乙烯共聚物 ) {( S9 M; c* }+ \" w: B
AES Acrylonitrile-ethylene-styrene 丙烯腈/乙烯/苯乙烯共聚物 3 b4 x0 o {+ ]! E9 G1 j+ s) P
AMMA Acrylonitrile/methyl Methacrylate 丙烯腈/甲基丙烯酸甲酯共聚物
7 b. a( T7 a9 \* YARP Aromaticpolyester 聚芳香酯
( g0 h9 `/ O9 W; f4 z2 sAS Acrylonitrile-styrene resin 丙烯腈-苯乙烯树脂 4 D1 w, m3 H* t* W
ASA Acrylonitrile-styrene-acrylate 丙烯腈/苯乙烯/丙烯酸酯共聚物
6 `8 l4 w+ A+ s; ]$ PCA Celluloseacetate 醋酸纤维塑料 - K2 p. N: H4 i d+ a2 F) J
CAB Cellulose acetate butyrate 醋酸-丁酸纤维素塑料 & z }( x% q0 U0 q; a1 H$ s: f- j
CAP Cellulose acetate propionate 醋酸-丙酸纤维素 2 R& V( R4 V' n+ ^7 v9 x
CE Cellulose plastics, general 通用纤维素塑料 7 B" s2 S+ J( P' N7 d# f
CF Cresol-formaldehyde 甲酚-甲醛树脂 0 H4 `$ @8 E9 h6 x9 p6 t4 G
CMC Carboxymethylcellulose 羧甲基纤维素 # }2 B3 q- D/ S
CN Cellulosenitrate 硝酸纤维素 2 N; N7 _7 z) h5 \# P ^
CP Cellulosepropionate 丙酸纤维素
- B9 O z7 G. \CPE Chlorinatedpolyethylene 氯化聚乙烯
1 d( s. t1 I; w/ ~! k- KCPVC Chlorinated poly(vinyl chloride) 氯化聚氯乙烯 - W( U% {) L! {+ U! ^
CS Casein 酪蛋白 4 h& g: n- V$ ]# b
CTA Cellulosetriacetate 三醋酸纤维素 G; ?& \* V5 R
EC Ethylcellulose 乙烷纤维素
: u) Y( A% J$ l9 OEMA Ethylene/methacrylicacid 乙烯/甲基丙烯酸共聚物 . o- Q2 @4 y! T' X5 P9 S* y% w
EP Epoxy,epoxide 环氧树脂 1 p( G" _6 b H& o! B. {* }
EPD Ethylene-propylene-diene 乙烯-丙烯-二烯三元共聚物
4 a4 Q% `2 I' T6 A3 ]EPM Ethylene-propylene polymer 乙烯-丙烯共聚物 8 A+ a! R$ l+ T, E' q
EPS Expandedpolystyrene 发泡聚苯乙烯 9 ~' ?; \: w6 j$ c' o B0 U
ETFE Ethylene-tetrafluoroethylene 乙烯-四氟乙烯共聚物
+ d& E& r& w6 {' XEVA Ethylene/vinylacetate 乙烯-醋酸乙烯共聚物
0 F! ?; }# Z w1 _EVAL Ethylene-vinylalcohol 乙烯-乙烯醇共聚物
$ {6 i* x% d) P# C- yFEP Perfluoro(ethylene-propylene) 全氟(乙烯-丙烯)塑料 - J5 Z9 ?2 Y/ T6 N. i& W, E
FF Furanformaldehyde 呋喃甲醛
: Q$ x, u) ^# i. kHDPE High-density polyethylene plastics高密度聚乙烯塑料 0 {3 d; a; `0 [$ s
HIPS High impactpolystyrene 高冲聚苯乙烯 0 `4 Z3 F U9 z& Y( V1 v
IPS Impact-resistant polystyrene 耐冲击聚苯乙烯 " _8 S# s, D8 |3 R9 j' t
LCP Liquid crystalpolymer 液晶聚合物 0 x+ T0 m# ]/ R4 G8 f# U
LDPE Low-density polyethylene plastics 低密度聚乙烯塑料 ' i" v& u( A0 A2 R" X9 O
LLDPE Linear low-density polyethylene 线性低密聚乙烯 . H% p% r2 i" P! n$ R' s
LMDPE Linear medium-density polyethylene 线性中密聚乙烯 # \+ H1 Y7 s" [, H
MBS Methacrylate-butadiene-styrene 甲基丙烯酸-丁二烯-苯乙烯共聚物
" n0 |8 S5 {8 e" Q6 F1 T& FMDPE Medium-density polyethylene 中密聚乙烯
' _. e z" B+ A6 i" rMF Melamine-formaldehyde resin 密胺-甲醛树脂 * c* }3 W7 B7 O2 B" S
MPF Melamine/phenol-formaldehyde 密胺/酚醛树脂 英文简称 英文全称 中文全称 * l& k9 ^$ X6 ]
PA Polyamide(nylon) 聚酰胺(尼龙)
( d4 q' S3 t- HPAA Poly(acrylic acid) 聚丙烯酸 & Y% h! }. J# Q4 k* g1 x
PADC Poly(allyl diglycol carbonate) 碳酸-二乙二醇酯· 烯丙醇酯树脂
+ f) t% y# k0 w) vPAE Polyarylether 聚芳醚
0 ]+ f; V, _7 e( T HPAEK Polyaryletherketone 聚芳醚酮 : y L' Z) s4 P/ E! j
PAI Polyamide-imide 聚酰胺-酰亚胺
r. @1 _+ T+ W% kPAK Polyester alkyd 聚酯树脂
" j6 f2 V. @$ C8 y6 h3 E) ~PAN Polyacrylonitrile 聚丙烯腈 3 ~3 M- W, V2 n R
PARA Polyaryl amide 聚芳酰胺
9 e# n3 C& C! b( w- dPASU Polyarylsulfone 聚芳砜 . v% @8 x3 p8 z9 y7 q
PAT Polyarylate 聚芳酯 2 X) V, N; \/ ~, v. M z& H
PAUR Poly(ester urethane) 聚酯型聚氨酯
# T6 F! X" y1 K/ f' a3 rPB Polybutene-1 聚丁烯-[1]
/ l8 ]+ ?# R v3 p$ GPBA Poly(butyl acrylate) 聚丙烯酸丁酯
- ~: k0 k; v$ l9 `/ fPBAN Polybutadiene-acrylonitrile 聚丁二烯-丙烯腈 + ?/ Z7 ?- V, O! K
PBS Polybutadiene-styrene 聚丁二烯-苯乙烯 9 o& ]- w6 i5 \; V
PBT Poly(butylene terephthalate) 聚对苯二酸丁二酯
2 r2 i0 F: a! `- vPC Polycarbonate 聚碳酸酯
/ R( E: [2 j n& sPCTFE Polychlorotrifluoroethylene 聚氯三氟乙烯 ) k4 G! V; W: N0 J& Q0 L% E5 W
PDAP Poly(diallyl phthalate) 聚对苯二甲酸二烯丙酯
$ p8 r7 ?+ o r$ t6 B" j- PPE Polyethylene 聚乙烯
+ M' t& T) R& NPEBA Polyether block amide 聚醚嵌段酰胺 7 B/ y( T$ }1 v) G [, h- V- {7 L
PEBA Thermoplastic elastomer polyether 聚酯热塑弹性体
( c' _+ U, \% }1 t# wPEEK Polyetheretherketone 聚醚醚酮
* }% _9 o/ V% u9 y7 d2 {PEI Poly(etherimide) 聚醚酰亚胺
- s7 Y6 d. R# E& APEK Polyether ketone 聚醚酮
! G- N' q. q: G1 ]PEO Poly(ethylene oxide) 聚环氧乙烷 ) l! h" q2 p, Q
PES Poly(ether sulfone) 聚醚砜
0 X# \) X; ?1 `& C9 L* XPET Poly(ethylene terephthalate) 聚对苯二甲酸乙二酯
. Q5 D. t4 p% l2 N1 bPETG Poly(ethylene terephthalate) glycol 二醇类改性PET% z% ~/ o9 b7 u4 O9 _: ]" T) c) L
PEUR Poly(ether urethane) 聚醚型聚氨酯 + Z2 O/ A; q V( g
PF Phenol-formaldehyde resin 酚醛树脂
7 x, L, B+ G4 |% q% i; x q2 QPFA Perfluoro(alkoxy alkane) 全氟烷氧基树脂
! {& v& B( X5 e ^% |$ W. a$ oPFF Phenol-furfural resin 酚呋喃树脂
: z- A+ d2 `6 |# s: U A: m1 yPI Polyimide 聚酰亚胺 9 f9 y) A, |" T6 t/ R
PIB Polyisobutylene 聚异丁烯
2 q! E. N) X) G, l: N3 ^/ SPISU Polyimidesulfone 聚酰亚胺砜
2 q; g! \/ ^! C; y) Q! ~! B: |PMCA Poly(methyl-alpha-chloroacrylate) 聚α-氯代丙烯酸甲酯 - M6 i& A0 X" w
PMMA Poly(methyl methacrylate) 聚甲基丙烯酸甲酯 6 Q, b! ^" \0 ]: e/ [9 D; f; u
PMP Poly(4-methylpentene-1) 聚4-甲基戊烯-1
; X! G2 O/ V( C& i- w0 `' WPMS Poly(alpha-methylstyrene) 聚α-甲基苯乙烯 ' F2 I( M! a: U" F3 B3 n8 r$ d) e
POM Polyoxymethylene, polyacetal 聚甲醛 1 p2 d0 R1 W6 R
PP Polypropylene 聚丙烯
2 l, z1 I9 }# k# N& |* X3 CPPA Polyphthalamide 聚邻苯二甲酰胺 , O }/ d! m# X3 R/ m! W
PPE Poly(phenylene ether) 聚苯醚 , _* m- K4 P& j: R& k& G* t
PPO Poly(phenylene oxide) deprecated 聚苯醚
/ m8 M3 L5 ]; g$ SPPOX Poly(propylene oxide) 聚环氧(丙)烷 . B$ D4 P% F% y1 U: y
PPS Poly(phenylene sulfide) 聚苯硫醚
: r1 q6 V& f4 X1 ~& ZPPSU Poly(phenylene sulfone) 聚苯砜 4 O+ y6 `- ]4 N M7 O, S( I
PS Polystyrene 聚苯乙烯
, K( P" f) l+ u7 a: W7 e cPSU Polysulfone 聚砜 . Z9 S* N) c2 N$ o( x j4 t
PTFE Polytetrafluoroethylene 聚四氟乙烯
V, ^ X/ h+ b( S3 {5 T' pPUR Polyurethane 聚氨酯5 Q' T8 g, L$ N8 R
PVAC Poly(vinyl acetate) 聚醋酸乙烯
; f* d. v) t6 S+ D- |# OPVAL Poly(vinyl alcohol) 聚乙烯醇
! t u0 ^" j. Z, z9 ~ N: [$ }PVB Poly(vinyl butyral) 聚乙烯醇缩丁醛
% w& x' }: W% A. [PVC Poly(vinyl chloride) 聚氯乙烯 - D5 x8 J6 J( y* ^) T4 g
PVCA Poly(vinyl chloride-acetate) 聚氯乙烯醋酸乙烯酯
. y! t3 r/ O' iPVDC Poly(vinylidene chloride) 聚(偏二氯乙烯) 5 C- Q' m" C3 H8 P' p* v+ w# A
- r2 Y! A- b3 u$ t7 Y G( O3 P; v z: J" T: a }! I% _7 K2 H4 P
PVDF Poly(vinylidene fluoride) 聚(偏二氟乙烯)
( v* v. V. ~: M8 V' d5 F' JPVF Poly(vinyl fluoride) 聚氟乙烯 # D7 ]1 f/ D2 K! `
PVFM Poly(vinyl formal) 聚乙烯醇缩甲醛 # ^9 a2 }- W: \6 M
PVK Polyvinylcarbazole 聚乙烯咔唑
8 o& }3 Y: y1 o' i2 zPVP Polyvinylpyrrolidone 聚乙烯吡咯烷酮
n5 c: B# F' B% S; @& vS/MA Styrene-maleic anhydride plastic 苯乙烯-马来酐塑料 : I- A& r# T- N5 M& ^ \+ m& c- V: }* {
SAN Styrene-acrylonitrile plastic 苯乙烯-丙烯腈塑料 ; Q4 ?$ W( q4 E! _$ g$ T4 \
SB Styrene-butadiene plastic 苯乙烯-丁二烯塑料 # D! q& U: k2 I# x2 d; f
Si Silicone plastics 有机硅塑料
4 [' U A r: t) m4 ~SMS Styrene/alpha-methylstyrene plastic 苯乙烯-α-甲基苯乙烯塑料
/ z ~/ O/ S4 _9 w' Y" Z# g) USP Saturated polyester plastic 饱和聚酯塑料 2 h* c/ Q$ |$ D# X0 P2 l
SRP Styrene-rubber plastics 聚苯乙烯橡胶改性塑料 - T; S, q% e* N( b3 P
TEEE Thermoplastic Elastomer,Ether-Ester 醚酯型热塑弹性体
% X) B5 J8 _' B# kTEO Thermoplastic Elastomer, Olefinic 聚烯烃热塑弹性体
! g4 w$ c$ w$ {1 S9 W4 W8 ?. D8 R' qTES Thermoplastic Elastomer, Styrenic 苯乙烯热塑性弹性体 " \6 k" k! }" n0 L4 {" O
TPEL Thermoplastic elastomer 热塑(性)弹性体 3 J7 u, z. k! @# f+ z- c
TPES Thermoplastic polyester 热塑性聚酯
' H% m0 {; H* k0 G0 P1 m# u8 WTPUR Thermoplastic polyurethane 热塑性聚氨酯
; d$ G& u8 c1 \3 O0 F. iTSUR Thermoset polyurethane 热固聚氨酯 0 @/ J- K8 a/ B) P V+ |' K; I& `6 X
UF Urea-formaldehyde resin 脲甲醛树脂
# k; [1 s8 f% r7 b- L' MUHMWPE Ultra-high molecular weight PE 超高分子量聚乙烯
3 ]. L- c2 n9 I: x1 ~UP Unsaturated polyester 不饱和聚酯 ! r+ G1 N2 S- ? k/ I
VCE Vinyl chloride-ethylene resin 氯乙烯/乙烯树脂
; |- @3 v. C& k* q! ?5 WVCEV Vinyl chloride-ethylene-vinyl 氯乙烯/乙烯/醋酸乙烯共聚物 / `- i3 s, V8 v" U, b8 F
VCMA Vinyl chloride-methyl acrylate 氯乙烯/丙烯酸甲酯共聚物 & g! s( A1 H: F
VCMMA Vinyl chloride-methylmethacrylate 氯乙烯/甲基丙烯酸甲酯共聚物
( L) Y+ M& r% c% K1 ^: qVCOA Vinyl chloride-octyl acrylate resin 氯乙烯/丙烯酸辛酯树脂 * l- C& H( w F
VCVAC Vinyl chloride-vinyl acetate resin 氯乙烯/醋酸乙烯树脂 0 O' P9 z/ V2 x! G$ s
VCVDC Vinyl chloride-vinylidene chloride 氯乙烯/偏氯乙烯共聚物 9 c* q5 `* |1 j$ v" E. ]" ^
( x0 V- e0 p/ h1 p: O, C) j" g |
