提示
) Z3 I$ ^: }# K" f
- Z% P; S- e S1 G& R, ougII_JAVA_HOME must be defined
( E- O: H1 W9 @% nThe Java Runtime Enviroment (JRE) was not found.3 n, S5 n* J% N0 ?
Install your own JRE and set UGII_JAVA_HOME
% Z+ H) { \0 b( _3 O& H in C:\Program Files\Siemens\NX 12.0\ugii\ugii_env.dat4 r" ~1 }8 {8 k; h) Z9 T$ c0 t
to the directory containing the bin and
8 E, x- L+ H+ P/ x# K lib directories.! }( a w0 E' s4 F) R1 M% S5 m
% t5 }% a$ t* V2 b3 F怎么处理,求助
7 W- q. h% o; U) k! e8 D5 M
' E, j7 Z( O) h- P. w. V% ^系统已安装了Java10.0
- Y! [2 \+ V- s0 S& k |
