在一个装配环境中选择一个零件载入装配环境,
+ X# |3 Z, t) t% ? R按下apply后没反应。请高手帮忙看下问题所在:2 F% V2 V& a( R8 Y5 S w7 n' z
列表框的回调函数
- @5 P/ E6 o B6 d' Gint SELPART_action1_cb ( int dialog_id,* v0 t5 i- m# Z) L6 Q1 p5 `
void * client_data,; c) n. w6 i( m7 P- }' x& Q
UF_STYLER_item_value_type_p_t callback_data)6 y4 I' @! @) a1 {3 @! h
* O. E* _/ v5 @; G9 Z /* Make sure User Function is available. */
) | I M' h$ b" v7 ~ if ( UF_initialize() != 0)
1 m/ o4 n. O# p return ( UF_UI_CB_CONTINUE_DIALOG ); C6 p# u/ U2 ]1 y
, ^; y4 ?1 P- [0 ^4 k& l
/* ---- Enter your callback code here ----- */
. x# z$ A) z% g# I% T( h UF_STYLER_item_value_type_t value;
" c2 S9 B3 w* i& I" ~ value.item_attr=UF_STYLER_VALUE;& s& Q9 G/ p! r8 Z$ K
value.item_id=SELPART_SEL_BOX_0;
6 j- ~: C. @- l: ]3 f& ?1 S value.indicator=UF_STYLER_STRING_VALUE;
5 d4 _ z+ K, I5 l4 G UF_STYLER_ask_value(dialog_id,&value);
: T1 A |% c. W4 x strcpy(item,value.value.string);
$ }4 }* Y9 m* l7 E UF_STYLER_free_value(&value);& q# D3 a: V6 D$ A6 k
UF_terminate ();
5 [8 y- }4 a. I5 }% G' v7 @. c: d! M# r6 `$ E6 F# g
/* Callback acknowledged, do not terminate dialog */
+ c6 B+ E1 F: o0 d% k return (UF_UI_CB_CONTINUE_DIALOG);
4 n8 m C" B0 A* [/ }3 y
V" j p2 S+ @- Q5 V: k- y% Q/ q B1 D /* or Callback acknowledged, terminate dialog. */4 Q. M+ o4 d Y; b: K3 n* y
/* return ( UF_UI_CB_EXIT_DIALOG ); */& I) U! n' L& O' B
( Y# `# w9 o& y, Y
}0 x8 L) `1 N4 Z6 g
" }& p0 M4 v: o2 z. I
apply回调函数0 p. B: Y$ O# J
int SELPART_apply_cb ( int dialog_id,
: c! Z. _( T: Q9 S0 h6 v3 f void * client_data,7 V% E7 [6 n( J& q0 Z/ s) ~
- m: t1 V+ N# e0 }{% t2 j) I, W, G
$ k1 Z, Z$ t3 E5 U; c( M if ( UF_initialize() != 0)
0 ?' [6 `+ p3 z& o0 G* m return ( UF_UI_CB_CONTINUE_DIALOG );
7 `7 n( B+ Q, n) B0 g& y, q( \3 p- X5 x# T) X- h( w# g. \
$ N1 s6 V+ z2 Q) h! p! C
8 `. y+ _: C1 y3 e A! D tag_t parent=UF_ASSEM_ask_work_part();
4 o" H. z) c L" q$ N6 Y char *part_name;
, p3 K: a& M& ?% Q: b5 A4 Q char *p1="part1";' @6 l. G: I5 j3 N- D; e
char *p2="part2";8 Q" D! {& M" e5 [: L
if(strcmp(item,p1)==0)3 t# I5 _9 s2 q9 A" h( s
part_name="D:\\thesis\\ug\\part base\\part\\part1.prt";
8 F9 K# I1 u _! ]3 i H# c else if(strcmp(item,p2)==0)
; X! x5 p0 h% A3 q2 w5 w part_name="D:\\thesis\\UG\\part base\\part\\part2.prt";; C8 \5 I- z! Z6 ?
else part_name="D:\\thesis\\ug\\part base\\base elements\\2Gz1030.prt";5 R h/ U* |4 { ~% P: [% Q
double origin[3]={0,0,-100};
) ~0 S2 y% X: ~8 x; ~) D# S) | double csys_matrix[6]={1,0,0,0,1,0};2 Q: U* q* U5 o+ `5 w/ D
int layer=0;5 _8 H; T4 Q% k2 @
tag_t instance;
4 P( Z9 Y6 u, Y UF_PART_load_status_t error_status;
, R/ b0 p/ |# J0 V UF_ASSEM_add_part_to_assembly(parent,part_name,NULL,NULL,origin,csys_matrix,layer,&instance,&error_status);
# ]' ^7 U: E( b& S. K7 B. u. ^5 j" W( e/ r6 ~+ z, q
UF_terminate ();
; m6 ^* v& R% ]$ O7 _, L; [
- ^+ H8 V$ M- ]5 Z4 F, v /* Callback acknowledged, do not terminate dialog */3 v4 w' S f, I* V. c2 I
/* A return value of UF_UI_CB_EXIT_DIALOG will not be accepted */
9 u1 ~1 @/ ~- T' T* P. g$ w3 ~3 H /* for this callback type. You must respond to your apply button.*/
1 z$ O: l- h& M/ Y return (UF_UI_CB_CONTINUE_DIALOG); . r( k, h8 U3 U: w# H, ~6 `
7 i- A3 u) O3 C% n# x' Z: y
