请问 使用UF_UI_mask_s mask_triples={}有几个参数啊?有的是三个,有的是5个?谢谢大家了!
! t; Z# w! e& m8 r9 }% L) }( a7 U' w5 q; g: S1 } W3 Q: a
Data Membersobject_typeint object_typeThis can be one of the object types that are listed in uf_object_types.h3 ?+ {4 e3 f4 P$ U0 n* m. ^
object_subtypeint object_subtypeThis can either be UF_all_subtype, or a proper subtype of the object type selected.% x: L4 R! y F m, t
solid_typeint solid_typeThis is only meaningful when the object_type is UF_solid_type. In that case, this should be set to one of the solid type constants
! O. G4 [5 ]( n9 F# W( ~, i |
