其实UG有过切检测的,如下是检测报告:* w3 D' o: g" ]# ~5 i/ E; X$ N u @" _
============================================================$ z( ~# I! x2 o1 t4 f
列出信息创建者: infodba
% j8 ?" E0 t6 S' M! \8 K T0 |1 n' ^$ S日期 : 2007-5-30 19:55:249 `" h5 c! F7 p
当前工作部件 : C:\Downloads\1.prt
3 ^1 k! P4 I0 N+ {; i1 d/ A% L节点名 : joy/ Y# t2 ~2 G* D# r: d
============================================================5 ]$ r- C, P$ w3 n# j, L
& G* Y7 F! G1 P
操作 CAVITY_MILL:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.4 E( X. p8 G3 K# J/ |* c
未发现过切运动。/ b& Z* B! `! Z/ k
. _% n+ d) U. w j3 A; D4 I操作 FACE_MILLING:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.
. H, P# c8 j" R! Y. U9 f未发现过切运动。) E- B# v( J( {: B3 B1 ?* m
- w L( C: l& L操作 FACE_MILLING_COPY:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.
]5 h( K* b+ K" _6 r" B未发现过切运动。
2 O* I& y. G: ^( z * O, n1 f- L+ j& [. B. W
操作 ZLEVEL_PROFILE:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.) i6 e$ d6 n* M6 _: ]
未发现过切运动。5 R p- G- `0 i
0 S7 q9 Y+ C5 u% c8 |4 M
操作 CAVITY_MILL_1:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.
) n0 R; [0 r0 |未发现过切运动。% U7 f& i+ B7 r2 m9 X. P) J
# i7 ^6 b0 N' @, X) ?) ^% h+ f" M' `
操作 FACE_MILLING_1:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.
$ j; G! D/ \5 N7 }* K0 J3 h未发现过切运动。8 z+ g/ `, n/ O; Z8 r4 ]
" s8 L2 B; x8 Q) S操作 FACE_MILLING_1_COPY:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.
1 ] ]4 F, o! E. ^+ P$ y: Z未发现过切运动。* _0 \7 v# X. M W, _
* A$ _ q6 D5 D9 T$ K
操作 PLANAR_MILL:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.
" L6 W) _& I3 M r6 H' M找到 2 个过切运动。/ P M) I) @4 L
; `2 L/ H' m, w2 U% l操作 PLANAR_MILL_COPY:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.4 O! S3 K6 u" u/ P
找到 2 个过切运动。
9 e2 C. S% U M1 G) [
, b" n$ j A0 n操作 CONTOUR_AREA:未发现过切运动。/ C% s0 D1 s0 D4 D+ _8 F; C* J
6 ]! ]# _3 w3 i5 E( m v操作 ZLEVEL_PROFILE_COPY_COPY_C~5:Only operations with a uniform effective stock are supported. Gouge checking report may not be re4 B3 H' t+ Q7 G' {0 e
liable.: v! E, c; c% g
未发现过切运动。
, |$ T" s2 @0 u! U0 _
5 }, @9 X3 g+ M操作 ZLEVEL_PROFILE_COPY_COPY_C~6:Only operations with a uniform effective stock are supported. Gouge checking report may not be re
4 z" ^& s6 i% V+ C3 p) Cliable.# P7 ~' g3 F- {. h# f; g8 @/ Z
未发现过切运动。+ H! z" @- {" Z/ I1 x: Y
: O M/ g! Q1 @
操作 ZLEVEL_PROFILE_COPY_COPY_C~7:Only operations with a uniform effective stock are supported. Gouge checking report may not be re5 W6 w' x4 u) u8 V# W1 k5 a; H
liable.
2 y; }) `+ ~3 h8 }9 B0 S未发现过切运动。
7 x, m W1 x* f5 ~) L * X( \. H( W7 l
操作 ZLEVEL_PROFILE_COPY_COPY_C~8:Only operations with a uniform effective stock are supported. Gouge checking report may not be re, V" L% h# N9 Z! Q
liable.' y3 h: Z+ `0 X6 b% q9 r9 A2 M( Q
未发现过切运动。
2 x; u, m9 q; P2 |4 E0 F
: V% i4 I# n7 m/ q2 |/ U操作 FACE_MILLING_COPY_1:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.% k5 A, [9 D3 c: s# ~+ o3 P
未发现过切运动。0 R5 ]8 H: d6 P; g- o) w; ^
2 |! Q# I& h# U7 E
操作 FACE_MILLING_COPY_COPY:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable
* O7 \; B5 |& O. Y' V$ l3 ^/ W.' Z3 O7 C& N$ s& W8 r
未发现过切运动。7 z8 b# j8 X( z2 E3 }) X
9 L7 W0 \( c+ u- }9 w! k
操作 FACE_MILLING_COPY_COPY_COPY:Only operations with a uniform effective stock are supported. Gouge checking report may not be rel8 Z% x5 E" t4 P2 y q
iable.8 J4 L0 h- S5 g7 Y A9 k
未发现过切运动。
/ z+ I6 ?5 e5 q L1 L . Y! K: G9 w' A! X) T
操作 ZLEVEL_PROFILE_COPY_COPY_1:Only operations with a uniform effective stock are supported. Gouge checking report may not be reli$ f! o0 g+ a2 M2 R, ~
able.8 i# J& I' d& U7 B9 E
未发现过切运动。- l/ \7 b% o& E7 B7 [9 Z& ^
6 P: [) A4 p% d操作 ZLEVEL_PROFILE_COPY_COPY_1~1:Only operations with a uniform effective stock are supported. Gouge checking report may not be re
9 O& C; U5 y# F5 ^, o6 _1 Oliable.7 z$ d2 M7 X( X% L+ |- w( ^
未发现过切运动。/ i3 N! x) F0 @& |1 L
7 {1 o8 e9 y1 x/ j/ | r& q操作 ZLEVEL_PROFILE_COPY:Only operations with a uniform effective stock are supported. Gouge checking report may not be reliable.. q5 F" [- o$ y5 h) X1 R- h
未发现过切运动。
1 p7 }6 _' a$ L ( q; B9 l9 ~- j% F1 x0 ?
操作 ZLEVEL_PROFILE_COPY_COPY_C~3:未发现过切运动。
; `- m" L7 v: a1 B/ W9 P$ ?1 W : j4 j" g* H8 b9 i* T, h" U- f0 p2 M0 [, l
操作 ZLEVEL_PROFILE_COPY_COPY_C~4:未发现过切运动。: X1 K" D# H* e, H7 Y0 l) w. Z
( k4 u( n5 D# d$ u2 i" r# }操作 ZLEVEL_PROFILE_COPY_COPY_C~1:Only operations with a uniform effective stock are supported. Gouge checking report may not be re& c' D% R( N+ j- `, v
liable.
3 H( p( \/ n* T未发现过切运动。7 I6 R+ q! n! P0 T) \
6 A* I0 k& |0 m7 c
操作 ZLEVEL_PROFILE_COPY_COPY_C~2:Only operations with a uniform effective stock are supported. Gouge checking report may not be re" X1 U9 j! t0 }+ W1 }6 s
liable.
1 b+ B" t7 y: |% I未发现过切运动。1 Q* o6 U0 r; n2 d
/ x$ x E: S6 u+ ?5 C# z6 i
操作 ZLEVEL_PROFILE_COPY_COPY_C~9:Only operations with a uniform effective stock are supported. Gouge checking report may not be re& t7 w6 z* D+ i: j( ]2 C: r
liable.
- K8 M' Y1 f, n" b2 I未发现过切运动。
( C8 a$ M) |% B7 e 4 I) _$ X, b2 P! k; x( |
操作 ZLEVEL_PROFILE_COPY_COPY_C~10:Only operations with a uniform effective stock are supported. Gouge checking report may not be r
0 K5 D! n8 F) W% [eliable.
- u9 T% b# K3 m0 ^9 S% o. f未发现过切运动。: {- [6 @* w6 {0 T# T: B& S
$ D3 {7 O3 w, A5 z* s0 n
操作 ZLEVEL_PROFILE_COPY_COPY_1~2:未发现过切运动。1 t L4 o1 C! j0 D3 J" t0 U
: {2 }! A( @1 Y% [7 X# o
操作 ZLEVEL_PROFILE_COPY_COPY_1~3:未发现过切运动。
2 Q6 Z9 z8 l: x2 W" G& b0 J1 N
; d6 m4 ^- w& H4 t" U8 d& O1 \6 _' r操作 ZLEVEL_PROFILE_COPY_COPY_2:未发现过切运动。5 H3 P+ A! l- n3 @& `: P, z
3 N9 ^; S4 y" j/ c% k操作 CONTOUR_AREA_COPY:未发现过切运动。1 [6 a; P8 O! _6 c
- B. Q0 d7 M2 y7 t# T1 r4 w' q: X/ D% g操作 CONTOUR_AREA_COPY_COPY:未发现过切运动。 |
