查看: 3688|回复: 4
[疑难] 开发时出现这个问题怎么解决啊
发表于 2009-10-27 11:04 | 显示全部楼层 |阅读模式
error LNK2001: unresolved external symbol _main
6 Z7 o" h% ~$ t! u" o! P. Q- t6 z. u$ ]8 a" s# Y
源程序:, P+ R0 m, _, W. h9 s
. i' c6 z$ Z( a/ l: A  n   WARNING!!  This file is overwritten by the UIStyler each time the Styler
: t0 s) q4 z2 z: z0 ~; |   file is saved.
9 K2 u3 k: V7 ]$ T# a
. c6 G# C0 i8 Z* u- A+ l
4 y9 U# h6 D+ f+ x. s6 O# g0 ~4 L( d        Filename:  pro_design_template.c
) i1 T) g& e8 B; s) J" w: w
; k4 ?' w9 m8 r  i( f3 H        This file was generated by the NX User Interface Styler
& z/ Q; p" M4 ~( o, L        Created by: befree
9 y( E$ q7 u- I3 |3 P7 _% B        Version: NX 3
, g" l: L1 z: i. q: p              Date: 10-27- 6
/ Z" Y6 j+ ?8 }! `# \. d) |              Time: 10:04
7 j! A5 K) p; j8 ]. W! y' \
4 |0 z7 Q" X& T# s8 j  _3 d   This template file is overwritten each time the UIStyler dialog is
$ M  T( s+ B/ ~6 `: ^3 D   saved.  Any modifications to this file will be lost.
4 {) K: @( @7 Z: y( _2 _: `, U==============================================================================*/
% m9 K* z1 y% L 6 E" T/ g! D, i4 t/ \/ ^4 N3 W
# Y2 g4 g4 m: w
' c; d$ E" D1 h' u: N2 T   Purpose:  This TEMPLATE file contains C source and static structures to      * U6 f; c8 U& P8 g/ T6 ~! L
   guide you in the construction of your NX Open application dialog.
( i$ Q4 `8 u% u+ J& [) k' h   The generation of your dialog file (.dlg extension) is the first step towards( G3 H/ L0 z3 d/ Z
   dialog construction within Unigraphics.  You must now create a ugOpen
& t# B& }' ]% E   application that utilizes this file (.dlg).                                  1 \) m% k7 }. b- F
        ; e2 n5 n6 y  c
   The information in this file provides you with the following:                - t+ h5 D7 J) n
        4 y2 n! X4 y+ f4 n  a8 s
   1.  Help on the use of the functions, UF_MB_add_styler_actions and           3 j% ?4 K9 M' s8 s0 O
       UF_STYLER_create_dialog in your NX Open application.  These functions    ; _0 ~( H' a7 g1 K# E. a+ V
       will load and display your UIStyler dialog in Unigraphics.               2 R! a4 G* D& x6 d
. k* q) e9 _3 [  N       An example of the function, UF_MB_add_styler_actions to associate your
% L) f& Z& {% G5 S0 t8 J& E       dialog to the menubar is shown below (Search on Example 1).
" ~2 W( S' n6 N2 S        . R7 [: f7 w* g
       An example of a invoking a dialog from a callback utilizing
+ M" w( V) C* K4 U       UF_STYLER_create_dialog is also shown below (Search for Example 2).
* [3 G. x# t/ d
, l9 i7 t4 f9 H% }% F4 G: p       An example of a user exit utilizing UF_STYLER_create_dialog is also      # v& r4 o0 |) L4 L+ E& y
       shown below (Search for Example 3).
8 T/ r+ X4 G( Z4 S        " P9 x" j6 q/ e. e3 m6 P0 a
   2.  The callback structure: --- PRO_DESIG_cbs ---
8 D# x  Y# W# K9 N' b- w. `       This structure is VERY important if you have callbacks associated with
# n* x7 P1 S+ B3 ^" o* `5 a( Q       your dialog.  It correlates the dialog items in your dialog with the     ' G% s" d1 x7 A( e$ N
       callback functions you must supply.  You should not modify this          . p; U( w& k4 n1 z$ s, j6 u) i
       structure since it MUST match up to the information stored in your
; L. ^/ `3 v& w+ ?/ @9 V+ X# C5 m       dialog file (.dlg).  Any attempt to do so will cause an error while      & {5 o. Y# Q& q3 m$ k7 R* l
       constructing your dialog.   If you wish to modify the association of
9 S0 A. V1 ~, ~; M, i/ ~       your callbacks to your dialog, please reload your dialog file (.dlg) into1 S% q) Q/ h* T5 O  ?0 _) N
       the UIStyler and regenerate your files.
: j' M% X: j, a) A5 s       You do not need to be concerned about this structure, simply pass it as
! h( D% [3 y9 R* i       an argument to the function, UF_STYLER_create_dialog along with your
$ {& J- f( j' {' U       dialog file (.dlg).+ ~/ P3 P9 Q3 @6 \: ~+ k8 h
       6 I( u  |% u# X# h- T- k; L/ c
       Example 1 displays the actual call you may make for this particular
8 D! H2 K% ^3 |5 h3 ?6 Y       dialog.        7 s8 I! |7 x8 B% t0 X
. x$ v- Y1 o! b3 T! Q   3.  The empty callback functions (stubs) associated with your dialog items   0 {& @0 ~- l# X
       have also been placed in this file.  These empty functions have been
5 r3 L0 C# B* ^" M# p       created simply to start you along with your coding requirements.
% X4 h8 Z4 S8 {2 j. O# @! w; W7 B       The function name, argument list and possible return values have already
+ ]+ z" K9 [$ E       been provided for you.
. z$ @% ~" T' n# M  X. l1 B: T        9 B8 L4 l4 f/ [4 \. h$ d0 d
NOTE:  Each callback must be wrappered with the functions UF_initialize()
3 |* P4 [: G; G$ `% M6 s  A9 t       and UF_terminate().
& ~/ f( N9 S& k2 x: w
2 C8 H3 N1 k  Z4 V& J& C==============================================================================*/: _1 {6 t5 O6 l8 g; }9 X7 M
9 _4 t/ C% W% v" F& H) o6 U* t/* These include files are needed for the following template code.            */( P; @, P' ?2 T0 }& o4 b
#include <stdio.h>
- b+ A) h# m+ {8 V$ `: ?# G#include <uf.h>$ f. q* L6 B, `7 @8 M
#include <uf_defs.h>
: Y5 |* N% K; t( O+ V/ e#include <uf_exit.h>
6 A  T- N5 s$ L/ u+ J4 J#include <uf_ui.h>
: E9 a/ Y3 B' Y$ _9 n2 Y4 D#include <uf_styler.h>  p5 |; c% Q& }, k/ N( l0 W( T
#include <uf_mb.h> , \: A$ V( M. H! f( I% a
#include <uf_part.h>
9 t- K- X8 @. R. ~) o3 ]  J- j#include <uf_modl.h>
6 p% r& K4 c, Z( U; V#include "pro_design_dialog.h": [* L2 S4 e9 x+ \0 V
/* The following definition defines the number of callback entries */) i* F) I2 j* ~7 Y6 r+ ^& u& L& E+ Z
/* in the callback structure:                                      */
3 ~' X& o6 A+ @& `/* UF_STYLER_callback_info_t PRO_DESIG_cbs */! s% c! Q8 y( ^- A% K8 k- l  {+ z
#define PRO_DESIG_CB_COUNT ( 4 + 1 ) /* Add 1 for the terminator */
& ~# Q, O: F+ t: C" r& w % b( {: Q$ H' {2 t
8 N5 ~; h9 [/ }8 t' P* O0 tThe following structure defines the callback entries used by the
. k3 }7 G8 \  K- Y$ {styler file.  This structure MUST be passed into the user function,    3 `* v# g! `, R1 V
UF_STYLER_create_dialog along with PRO_DESIG_CB_COUNT.
6 i! ]# y, p5 l7 ^* ~$ J--------------------------------------------------------------------------*/
7 b: _; E6 X. ^, _- astatic UF_STYLER_callback_info_t PRO_DESIG_cbs[PRO_DESIG_CB_COUNT] = + N& M7 h( D. N6 q$ k9 ~+ E
{) m" [% G  a. {! Y  b& z! @( T- J
{UF_STYLER_DIALOG_INDEX, UF_STYLER_CONSTRUCTOR_CB  , 0, PRO_DESIG_construct_fun},
8 c+ p/ n; Q; |  W/ P {UF_STYLER_DIALOG_INDEX, UF_STYLER_OK_CB           , 0, PRO_DESIG_ok_fun},7 G, ?- e0 L2 ~2 e3 T1 S, Y( j
{UF_STYLER_DIALOG_INDEX, UF_STYLER_APPLY_CB        , 0, PRO_DESIG_apply_fun}," p% K9 V, P' [# L& d8 \5 l' a
{UF_STYLER_DIALOG_INDEX, UF_STYLER_CANCEL_CB       , 0, PRO_DESIG_cancel_fun},+ W) R. G0 N4 b4 G3 b! W' M  ^
{UF_STYLER_NULL_OBJECT, UF_STYLER_NO_CB, 0, 0 }( i3 h! H0 w6 t; V8 r0 q" c  ?0 @
};6 M* _5 u) R0 m1 I
$ o/ ~3 D$ N" w7 t/ T, [
/*--------------------------------------------------------------------------# n% d" k. `+ P, d8 _) G. R8 h2 D
UF_MB_styler_actions_t contains 4 fields.  These are defined as follows:8 [! O, V: _* k* Q* a. I2 o
7 o# {+ C3 S5 Q. m  J3 J2 WField 1 : the name of your dialog that you wish to display.% p4 Q7 ~" N: G" c0 F: ]1 a
Field 2 : any client data you wish to pass to your callbacks.3 M9 `* ~& e$ ]+ M$ n
Field 3 : your callback structure.
$ i0 J1 A' P3 j" q, c9 W, MField 4 : flag to inform menubar of your dialog location.  This flag MUST
9 w* K4 q, ?  C- U5 _          match the resource set in your dialog!  Do NOT ASSUME that changing % f/ R, i# y3 {# x$ k; v4 [
          this field will update the location of your dialog.  Please use the
  i  v) r0 \! _2 h          UIStyler to indicate the position of your dialog.
2 K, m9 s0 C2 w6 I3 k9 ]( h--------------------------------------------------------------------------*/; P7 ^& z) [7 R) x7 ?$ {
static UF_MB_styler_actions_t actions[] = {
5 e- o! d, U+ t: u% k, g5 O6 F    { "pro_design.dlg",  NULL,   PRO_DESIG_cbs,  UF_MB_STYLER_IS_NOT_TOP },
( l) \% U9 F/ A; Y- n    { NULL,  NULL,  NULL,  0 } /* This is a NULL terminated list */
! h( y1 q- ]+ V$ w2 z# U2 X};
- h+ P" }' H+ F9 p6 N5 e0 R: @
# P2 D$ `& b* X/ D3 [) `
! s3 s- D: ~) n7 A9 [
) t$ p$ c( f* U$ Z
- f% V0 Z$ `: c- z/ Y/*-------DIALOG CREATION FROM A CALLBACK HELP Example ----------" f' S2 b+ ^6 R1 o  O+ Y- d- D! ~# I& t
If you wish to have this dialog displayed from the callback of
& {: t2 Z4 L% l' \) B7 |3 `( k: ianother UIStyler dialog, you should:                           7 Y1 s' n7 Z: O9 v
1) Make sure that the callback of your UIStyler dialog is , a/ r4 K/ u' r
   designated as a dialog building callback.
: z: \; L4 L6 Q2 z8 x7 S2) Remove the conditional definitions:5 n' o1 c/ j2 a; X7 p+ {% C% A
   #ifdef DISPLAY_FROM_CALLBACK 7 u: l7 r3 z7 d4 F# D0 }
   #endif DISPLAY_FROM_CALLBACK* E3 d% [( ^$ }# R2 U
3) Your callback should issue a call to this function.
1 {( [9 {, P& K' o& u& V( W! C4) You should also add the funcitonal prototype to your header file ; ~+ X8 M7 x1 m3 h
   (pro_design.h) and ensure that the file is properly included.5 A9 a8 g  I4 z
All dialog files must be located in
: }+ p* J" \# d- C      $UGII_USER_DIR/application or + D1 @- z. `5 p# L4 q7 o/ a8 U5 K. A
      $UGII_SITE_DIR/application or
: |2 H' }! t7 L& W" f      $UGII_VENDOR_DIR/application directory
; n8 ]% L( a4 |# t9 W--------------------------------------------------------------*/1 K) x$ h! E! w3 E  o9 `3 q, a
5 ~( F) r3 y: Q; N5 D: E) M+ n% bextern int LaunchProDesignDialog( int *response )9 ]# {$ r+ T* e3 q* o3 Z9 I
5 j& Y- z! A; W: ]9 s. E    int  error_code = 0;
: R  E( f' ^8 H4 a% Y! j
# |8 A2 O! V6 C: w    if ( ( error_code = UF_initialize() ) != 0 )
' o& y5 O* T( i6 H           return (0) ;
, b3 d3 ]7 {- b. C    if ( ( error_code = UF_STYLER_create_dialog ( "pro_design.dlg",
0 U  @( F2 t, z) R+ j: O7 Q           PRO_DESIG_cbs,      /* Callbacks from dialog */3 G8 C' X+ m; K5 _- k5 ^: P
           PRO_DESIG_CB_COUNT, /* number of callbacks*/- f0 g) ^9 K" {8 u& {( v! U* p
           NULL,        /* This is your client data */
# K5 o  R: n, }' z           response ) ) != 0 )
0 Q; H: T, c5 K, p5 b    {
4 y7 X+ z" X6 Z; t$ c, w          char fail_message[133];
  V# e- S7 S; D( S) F3 t& m- J( J          /* Get the user function fail message based on the fail code.*/
) A9 g9 ?6 a$ [& @2 n) B4 B          UF_get_fail_message(error_code, fail_message);
, I9 U6 N" \- J2 o2 E/ c          UF_UI_set_status (fail_message);. h) {/ g2 ~5 [- S' y8 f! L& {. i
          printf ( "%s\n", fail_message ); 3 i8 j. @9 o# P) }& U; {% E' f
    }3 V6 V. L; I/ j) \
, I- }' f2 ^( q0 g0 W3 t+ E$ `    UF_terminate();
; R9 z$ F( u* h; p* s2 i+ `5 b    return (error_code);7 u, z. ^0 W. p* t
}; A$ A9 K# f8 Y6 o; V5 J
4 L& |) E$ ~* m+ R  j3 T6 h
1 {8 ^- I: k: Q1 _9 M" A1 @) W3 Q
% \* X3 @- F# x! ?; g' X5 x7 i$ G4 f/ l/*-------------------------------------------------------------------------*/: H: }1 Q8 E; B4 V- f# l! V; @* X9 V
/*---------------------- UIStyler Callback Functions ----------------------*/
6 k; B( h! b( _" B* Z/*-------------------------------------------------------------------------*/
  I) Q" m" ~5 J0 T. L# p$ O/* -------------------------------------------------------------------------8 h, }3 C( ~# Q2 j6 G& }3 g/ ~
* Callback Name: PRO_DESIG_construct_fun+ j. [' P! O: v: Z  ~
* This is a callback function associated with an action taken from a9 m' k1 o- A0 g; E1 a" N) n
* UIStyler object. / d3 I6 g& F7 c; ~3 u0 I1 Z
+ O: v; c. H3 Q( @  { * Input: dialog_id   -   The dialog id indicate which dialog this callback
1 i, H6 V* G+ o* k- [ *                        is associated with.  The dialog id is a dynamic,
2 f, U3 s1 Q0 n2 o, \3 a *                        unique id and should not be stored.  It is/ t2 `  N& r) v7 {5 ?& y1 {1 e/ f$ r7 S
*                        strictly for the use in the NX Open API:
7 P4 V3 g: |- X9 |/ u *                               UF_STYLER_ask_value(s) ( w: B$ m  C$ B% Y
*                               UF_STYLER_set_value
; C3 I1 N$ b8 G *        client_data -   Client data is user defined data associated
' l0 A0 Z: B1 C  H *                        with your dialog.  Client data may be bound
# e, q# t- B5 i! r+ ? *                        to your dialog with UF_MB_add_styler_actions( T7 m" S/ B/ B7 e
*                        or UF_STYLER_create_dialog.                 0 C3 P) _7 e; A; a9 A  F
*        callback_data - This structure pointer contains information5 F7 @& {& M4 J/ H" l+ v* _) L; O8 I
*                        specific to the UIStyler Object type that
1 p9 W. `5 D4 X7 l( W' S *                        invoked this callback and the callback type.
# Y' V+ D& p$ N6 |' C1 { * -----------------------------------------------------------------------*/0 {! \- M' b$ E
int PRO_DESIG_construct_fun ( int dialog_id,2 m3 Z3 D- x0 A  d9 g3 O
             void * client_data,
1 B# f4 a/ F# h3 R: L. X             UF_STYLER_item_value_type_p_t callback_data); n: r8 V7 N% i: c  a
" K% h4 n; H! e0 w" \# F     /* Make sure User Function is available. */8 |! ~0 b6 @) Y8 d
  double       value;: g/ o# Y4 A# @5 T2 k* [( M; g4 A4 |
  char       prompt[256];  n: I# p  M* k+ z' W$ g
  UF_STYLER_item_value_type_t data;
+ B* p" z3 k+ H8 n: ]! e8 {& o/ i6 F" I     if ( UF_initialize() != 0) . R- X! }, V4 Z! L/ w5 b& p1 H
          return ( UF_UI_CB_CONTINUE_DIALOG );
7 n! ^2 X- @' f  data.item_attr=UF_STYLER_VALUE;
! X9 x. P, C% r; V  data.item_id=PRO_DESIG_REAL_L1;* C; Y7 Q: ]1 F$ ?! E* [  l- i
  UF_MODL_eval_exp("L1",&data.value.real);  I! O/ L" F* X0 n' p1 _- |
  UF_STYLER_set_value(dialog_id,&data);
  B; x( ^+ Y) ?: t. S  data.item_attr=UF_STYLER_VALUE;
6 g9 o7 @/ ]% I6 T0 F0 M1 e# E; S  data.item_id=PRO_DESIG_REAL_W1;% h8 t6 ~4 [7 A& ~0 C
  UF_MODL_eval_exp("W1",&data.value.real);
" P1 }4 F& ~" b: {  UF_STYLER_set_value(dialog_id,&data);
5 q, b1 H; p6 C/ d: U: g" R  data.item_attr=UF_STYLER_VALUE;
( f: K; q' }  R  data.item_id=PRO_DESIG_REAL_H1;8 u# W! `4 r% A2 o/ i
  UF_MODL_eval_exp("H1",&data.value.real);; q( @/ c. L$ l
& T. `. o: s) G& n  l' B
, g( R  A8 v/ J7 ~2 V4 J9 L  data.item_attr=UF_STYLER_VALUE;* f, }" i  M6 o4 l! u6 Z
  data.item_id=PRO_DESIG_REAL_H2;. x+ F& t7 v3 V, L# q: X* A& [/ d& M' c
  UF_MODL_eval_exp("H2",&data.value.real);. D4 g6 [1 U4 h
/ U  C1 r7 |. m% ^# Z) X$ z0 }  data.item_attr=UF_STYLER_VALUE;$ }. \  E, l4 p! ^7 g" E! K( g+ m
  data.item_id=PRO_DESIG_REAL_L2;
" ~8 }9 O+ [- u8 s: ?8 `; I  UF_MODL_eval_exp("L2",&data.value.real);3 C3 L# M4 G' \& h4 E
8 f3 u/ B; U7 n! I; A  w4 a  data.item_attr=UF_STYLER_VALUE;
$ N) I2 S+ y* r. f0 J5 N' A  data.item_id=PRO_DESIG_REAL_W2;) \1 s1 s# C+ S3 ~9 W
  UF_MODL_eval_exp("W2",&data.value.real);* T3 P) d. A4 w8 {0 _: A
8 q' a) q+ h6 w$ c% {  data.item_attr=UF_STYLER_VALUE;
* V% l# d! N# m* Y. p& z+ U  }% \$ J  data.item_id=PRO_DESIG_REAL_L3;4 L1 M; {" [4 T7 p2 e
  UF_MODL_eval_exp("L3",&data.value.real);3 |, L9 j* i8 ~* B2 h
0 H6 k1 R1 l. J) R; b  UF_MODL_eval_exp("VOLUME",&value);
. g$ q9 b8 h7 D7 ?, n  sprintf(prompt,"当前压块的体积为%.3f",value);
/ |, T' S$ ^# z) E$ Y  data.item_attr=UF_STYLER_LABEL;
# Q# Y7 R& [  T' Z% b9 [  data.item_id=PRO_DESIG_LABEL_VOLME;* ]9 ~$ x. w6 T* ?8 a
  data.value.string=prompt;5 p- W& D" y$ K* a# y/ b/ X
+ S3 T; d2 s9 G! V, q5 q/ A! m  e& e     /* ---- Enter your callback code here ----- */
$ R) ]4 }0 ^5 S! ~! P9 ?     UF_terminate ();1 H" A: G0 b7 \6 f. z* K6 h
    /* Callback acknowledged, do not terminate dialog */
4 T! Z1 n7 p- ]) c  M2 X- E. Y    return (UF_UI_CB_CONTINUE_DIALOG); 8 |9 g! z0 y* x/ k, T) m) w
    /* A return value of UF_UI_CB_EXIT_DIALOG will not be accepted    */9 ~  z% e  t# ~; c' M7 i1 R- d/ e
    /* for this callback type.  You must continue dialog construction.*/- J% s* ^! m& k8 x2 W
}, o7 v. |+ r. O; D
' t* J8 x% U1 T7 Q9 Q: Z
/* -------------------------------------------------------------------------, i5 J2 E: U! k' q3 K& z) C$ q
* Callback Name: PRO_DESIG_ok_fun  w( i4 p% w* A/ e
  Y3 l% Y. E7 }: H1 d- K3 e * UIStyler object. , F! T& y( K. T0 \8 F; H1 o
*" [& m' T; W$ b! P
  ?4 l5 m  C. @6 k5 w *                        is associated with.  The dialog id is a dynamic,
6 e  w& G- K0 [2 j9 {! Y1 T% R" Y *                        unique id and should not be stored.  It is
# x7 l# [& _+ I$ i; g# ]( v *                        strictly for the use in the NX Open API:2 ^1 E1 y; y. h0 x+ T
*                               UF_STYLER_ask_value(s) 3 b9 {$ K, x3 Q9 o  j  A: v
  ^  o. S$ ~4 J/ i( W0 o+ K7 T8 X *        client_data -   Client data is user defined data associated
! W2 N4 W2 H- P  X% p& f *                        with your dialog.  Client data may be bound6 J# R5 E1 d0 Z7 }0 d6 Q
" X. D6 B% B1 U( {! p4 A *                        or UF_STYLER_create_dialog.                 ; s" j  D8 R& N& M* ]) V3 k
*        callback_data - This structure pointer contains information. `5 ~6 u/ \/ o( m3 ]) d
$ Q! ?, v% |# X+ s7 h- D+ P *                        invoked this callback and the callback type.$ N" c) W7 c: W9 A& j* n
: L/ r/ D4 n, n  g; Z3 p4 hint PRO_DESIG_ok_fun ( int dialog_id,( f; z8 a6 X3 U' x  W9 J
             void * client_data,
8 O8 l$ F- k5 I2 [             UF_STYLER_item_value_type_p_t callback_data)5 R5 f5 V! U: j: ~8 F7 S& h0 y6 _
6 D( u/ N2 F* v' k4 M" t     /* Make sure User Function is available. */
' _3 A* X/ _5 u7 K0 |6 K  k  UF_STYLER_item_value_type_t data;
  i7 h9 m' _% p% {  T     if ( UF_initialize() != 0)
" ~3 Q1 c. L6 A' j" ?; U; b, a2 N          return ( UF_UI_CB_CONTINUE_DIALOG );
8 m. G+ U$ a  ]  K5 C  - G$ r3 L- w. M1 r9 z# S
  data.item_attr=UF_STYLER_VALUE;) X5 G! S4 M) D7 f5 [( v. c
  data.item_id=PRO_DESIG_REAL_L1;! R( B% y( x6 t/ e/ O3 M/ A
  UF_STYLER_ask_value(dialog_id,&data);
, [( ^8 [; s: k4 H7 u- d4 f. k  PRO_DESIGN_edit_exp("L1",data.value.real);
; n+ E7 y" r  P- Y6 I6 j) d# w+ u0 ]" Q  data.item_attr=UF_STYLER_VALUE;
8 {! G, P% _7 L/ k" o2 d9 r" L  data.item_id=PRO_DESIG_REAL_W1;
6 G8 `4 H! S0 |) w  UF_STYLER_ask_value(dialog_id,&data);% }$ D2 r) \& A5 k0 c9 h
  PRO_DESIGN_edit_exp("W1",data.value.real);4 S' R% ^+ Z" C) \- X1 z2 l
  data.item_attr=UF_STYLER_VALUE;4 n! D+ l  {1 Z( A, Q
8 Q) V2 P3 S, s: x' ~# N. N5 V  UF_STYLER_ask_value(dialog_id,&data);
% P- A  y  ]% b/ G2 E( M: n  PRO_DESIGN_edit_exp("H1",data.value.real);
; O: l" ?; \7 ^, S$ i
& g7 r: r+ G6 ^. Z' k  data.item_attr=UF_STYLER_VALUE;
3 E' v0 @  T* }5 ^( @3 B, _. P1 ]% D  data.item_id=PRO_DESIG_REAL_H2;* m: x2 ]2 I0 J' r6 P# l+ Q7 h- M2 J3 j
  UF_STYLER_ask_value(dialog_id,&data);1 c6 X) Y" D) `  ?& c8 a" |
  PRO_DESIGN_edit_exp("H2",data.value.real);
9 }  `8 m: c' n& N: R9 M( y1 u% _  data.item_attr=UF_STYLER_VALUE;
: P% n0 I# X- |  data.item_id=PRO_DESIG_REAL_L2;) Y8 X* N: I  _* K6 z  B9 ?
  UF_STYLER_ask_value(dialog_id,&data);3 }4 J2 ~" u  O, Q
  PRO_DESIGN_edit_exp("L2",data.value.real);
6 H$ ^& J: _5 l% z( C2 q  `  data.item_attr=UF_STYLER_VALUE;
" ~( ^8 V6 q8 t5 n& j% q* j( Q  data.item_id=PRO_DESIG_REAL_W2;4 i- n. ]9 q; \
  UF_STYLER_ask_value(dialog_id,&data);- q1 g1 F9 i1 Y! I$ }8 j! M6 A5 D
  PRO_DESIGN_edit_exp("W2",data.value.real);# H- R5 S( ~  T; U. o$ M; X
  data.item_attr=UF_STYLER_VALUE;! D, q% m1 y/ G4 [) \
  data.item_id=PRO_DESIG_REAL_L3;% }. A  M6 ?  h4 @: E+ ]9 L
2 x& m" v9 ^2 D- D' Y- \  PRO_DESIGN_edit_exp("L3",data.value.real);
) N) N9 x5 D5 r2 o0 G, N0 O% z0 d& b  UF_MODL_update();6 F- q0 o; Z* k7 D
    t' Q( \1 t) c; c& @$ y, q6 T5 Q
* q) T" {0 g+ @. g* t$ {     UF_terminate ();$ ?3 U3 H' p8 q8 j
    /* Callback acknowledged, terminate dialog             */; v+ w6 D4 E3 I' {
    /* It is STRONGLY recommended that you exit your       */6 Z+ n; ^# A/ y& J& `
    /* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/' t# {9 A5 @. J6 m$ K6 ^3 Y9 q+ P
    /* return ( UF_UI_CB_EXIT_DIALOG );                    */- ]9 t5 y: O+ Q' b. ]
    return (UF_UI_CB_EXIT_DIALOG);
. X( |& n/ K9 [  [7 `9 i/ Y1 J}
2 c+ U$ ~3 V, T- d
1 y! W+ L# `' e/* -------------------------------------------------------------------------
  u8 l+ Z" i) s6 x * Callback Name: PRO_DESIG_apply_fun% v$ ]9 Q' ~$ g, C  G( `" |8 ^
* This is a callback function associated with an action taken from a6 e% w2 O' l4 x) ]$ f' W
* UIStyler object. 1 _& K2 v  V) d' C! F
*5 w8 ], S2 m# \. Y
* Input: dialog_id   -   The dialog id indicate which dialog this callback' H$ p2 ]- V" w2 i
*                        is associated with.  The dialog id is a dynamic,& Q, ~1 v: @9 P- |) d+ ]/ l
*                        unique id and should not be stored.  It is/ t- v& R/ v+ I2 O) @% x$ T; s# [
*                        strictly for the use in the NX Open API:* Y) E. t3 l. q; f. D8 s
3 ?) W% A2 c7 x- ?: o1 ~ *                               UF_STYLER_set_value   6 F; T* X3 _) f$ Z) c+ V
*        client_data -   Client data is user defined data associated, g: o0 W( D) e3 t" z
/ m4 J( A" d2 p) ~! e *                        to your dialog with UF_MB_add_styler_actions1 d. ]! u) h+ d0 o6 S+ p
6 Q# B0 M* z$ u) } *        callback_data - This structure pointer contains information' A1 M+ o/ n( c1 l
* [1 E4 V5 Q2 B& f *                        invoked this callback and the callback type.
; p  ], w. t3 A' t * -----------------------------------------------------------------------*/
" I& X5 g4 q5 F; E7 iint PRO_DESIG_apply_fun ( int dialog_id,
7 D3 W4 S1 @; y" ~& p8 ~             void * client_data," Z) d$ E6 [" W! M
             UF_STYLER_item_value_type_p_t callback_data)  Q$ Q. _% M3 p/ M& F# A
{/ d' D8 w+ P; l2 W# F' v- A
     /* Make sure User Function is available. */& {, Y& [$ d1 C# p7 D; g' h' X+ B
# k- S, k' w* t% Q, y3 g; Y$ a  double       value;8 q# H5 b; i4 z
  char       prompt[256];" G6 h: a# O; A) l
% q1 H6 R: G# |1 x4 ~  Q& h( x; W          return ( UF_UI_CB_CONTINUE_DIALOG );
; P% G6 q0 `! U. X! z& c4 b  data.item_attr=UF_STYLER_VALUE;: B2 E6 x3 \8 P0 u$ M) }
  data.item_id=PRO_DESIG_REAL_L1;0 L) C( R0 y* Q# s5 j# z
8 O9 R% r7 d) S* R# O2 W  PRO_DESIGN_edit_exp("L1",data.value.real);
! y& a7 B, \! z+ c- k- C  o) ?  data.item_attr=UF_STYLER_VALUE;) }) z) F6 i1 E
$ {( g! N6 Y% Q. t8 E2 p8 d! g  UF_STYLER_ask_value(dialog_id,&data);$ B$ d# w( z/ ]
  PRO_DESIGN_edit_exp("W1",data.value.real);5 Z' p4 z/ a( F. S- \+ I
( P9 \2 ?7 T1 w5 @4 [% h  data.item_id=PRO_DESIG_REAL_H1;: K. `9 D) e9 z: _' [0 `- C2 o: ~7 u
  UF_STYLER_ask_value(dialog_id,&data);9 m3 \/ t+ i% r3 T0 b: E
  PRO_DESIGN_edit_exp("H1",data.value.real);% u) Z( \) r6 R( c5 r- ]3 N2 e
8 W; p' R; K* {1 F2 j  data.item_attr=UF_STYLER_VALUE;) \6 T; J* U4 g: p0 X7 N
: m& C7 I: l* }/ z5 b  UF_STYLER_ask_value(dialog_id,&data);/ M( J; v# G7 O, u" o% @
& C  B7 P! ~* _9 e$ u! U# e! P  data.item_attr=UF_STYLER_VALUE;- z# R9 j3 M+ k
9 a2 d! B, k4 ^, `, t  UF_STYLER_ask_value(dialog_id,&data);
/ H# h% j! X7 \1 E' d) @) V, c  PRO_DESIGN_edit_exp("L2",data.value.real);, C, }5 t- p1 ]; X# N! M
  data.item_attr=UF_STYLER_VALUE;, I5 i& l& _' o" U$ L/ D1 ^
' _- h8 F' V$ m, g2 ~8 {, [' X  UF_STYLER_ask_value(dialog_id,&data);" f8 b' r; [. w- q! V7 b
2 d$ q1 G. h5 S% r* l: T  data.item_attr=UF_STYLER_VALUE;
9 @7 Y( f/ b& D; ~( b$ t& E. ~! d  data.item_id=PRO_DESIG_REAL_L3;' [/ P) j+ r) B; L3 W- ^5 O
  ?/ p# h- p0 G# v5 |" y( S/ z  PRO_DESIGN_edit_exp("L3",data.value.real);6 p( b& o7 k/ }% L. `7 ^
  UF_MODL_update();
9 {+ h; p, q' C0 A# Y, `, |
6 t9 [- O  f# ^- J% @  UF_MODL_eval_exp("VOLUME",&value);
% i, t7 v+ |; S' W5 w  sprintf(prompt,"当前压块的体积为%.3f",value);7 |( z3 m. I( m' [* W
  data.item_attr=UF_STYLER_LABEL;) f& a- A+ e5 t) E# I* k/ A
4 J5 e8 a$ B4 V- P  data.value.string=prompt;
, ]' K2 L; o+ _  UF_STYLER_set_value(dialog_id,&data);; X! y8 Q+ s6 i# ?4 G! U
  /* ---- Enter your callback code here ----- */6 `" I& w3 ~" l7 d
     UF_terminate ();
5 }( R+ Y! W8 I* w) b4 N    /* Callback acknowledged, do not terminate dialog                 */2 j0 z1 i0 b( w2 C9 v* Q* M
    /* A return value of UF_UI_CB_EXIT_DIALOG will not be accepted    */) C7 J! a4 i, a2 q; ]6 _
    /* for this callback type.  You must respond to your apply button.*/7 i' W! K& n3 `/ Q# y' @
    return (UF_UI_CB_CONTINUE_DIALOG); 6 g! x  d5 q4 Z4 L# o3 `
}, S' t( c% s! C0 V9 M  z! y3 T
7 K; X& x9 @% @5 Y0 I" X3 ]$ }
int PRO_DESIGN_edit_exp(char *dim_name,double dim_value)
% i  `3 F  q. X& k6 d) M{! e0 n- m8 Y# P4 A
char exp[256],temp[50];
" ~6 m/ ]; p! n9 A" j8 M2 j% l int  err;
- \3 w* H* l. C. o: ~ strcpy(exp,dim_name);. h( N/ I+ O# h- _. c2 x
strcat(exp,"=");: p7 X: H. s( Z0 W
sprintf(temp,"%.5f",dim_value);
9 G" S0 S, P5 Y# D4 \# M strcat(exp,temp);. Q: V+ Z% F+ O+ \
err=UF_MODL_edit_exp(exp);2 b* i4 Z- A' {$ u
return err;7 d1 |9 i) e! m6 I% O9 S- Q
}  Q# }8 H7 b. S3 b* [3 _  ?
/* -------------------------------------------------------------------------+ t7 R9 N: m6 D7 \* N& S7 A
* Callback Name: PRO_DESIG_cancel_fun
0 r4 U0 _+ i0 W" B% c& j' C$ g * This is a callback function associated with an action taken from a: t+ L7 p( Z% Z+ P% I4 m4 U
* UIStyler object.   m# r+ L5 `- O2 j3 }6 M
*' N  u% J1 I6 F3 A- x; o1 V# T
3 G; m2 O. H! v  ^& O9 F  L3 O *                        is associated with.  The dialog id is a dynamic,
. k4 k4 m) O  f# T/ w. s( N& P *                        unique id and should not be stored.  It is; |' z6 m2 |8 _/ V) A
3 r6 w5 T6 f) `( q *                               UF_STYLER_ask_value(s) 2 B$ M! S6 s6 H2 k$ O# V
' c4 n+ Q' w1 ~( _. o *        client_data -   Client data is user defined data associated3 W/ H( a2 {- k9 ]7 _
6 K  L9 D9 G( N( ~( r- _4 U! d/ o7 U *                        to your dialog with UF_MB_add_styler_actions
" c  ]+ j3 v3 x! v *                        or UF_STYLER_create_dialog.                 6 i& v. t6 z$ U/ F  P* g) f
! U1 ~3 L+ \% l0 S3 W *                        specific to the UIStyler Object type that
" a1 h! ?3 P% h. R( Q) q* Z *                        invoked this callback and the callback type.5 Y( @" G2 E/ K9 t2 G5 u
* -----------------------------------------------------------------------*/$ F1 K% B4 Q- x+ e9 e
int PRO_DESIG_cancel_fun ( int dialog_id,0 x, t5 c4 H% c9 _0 ?6 G
             void * client_data,7 a* J' ^, u. m4 e
/ G$ ]$ E" j3 C, C  i7 g, m$ {{
; M& f& X( q9 Z6 w  @     /* Make sure User Function is available. */  2 K7 p+ I( L/ K  u+ c
- h( R8 I- g. q" x2 I  Z8 t          return ( UF_UI_CB_CONTINUE_DIALOG );  ^  {, C) R& ]$ V4 a
     /* ---- Enter your callback code here ----- */0 ~: `" Y/ a/ y, E
     UF_terminate ();
# a1 B8 v+ Z& w/ k  J    /* Callback acknowledged, terminate dialog             */
4 z3 L6 B$ w% d9 i    /* It is STRONGLY recommended that you exit your       */
, y) c) Q9 f+ u" X1 I. n    /* callback with UF_UI_CB_EXIT_DIALOG in a cancel call */7 t  F% ]1 Y: q4 ~. C5 A
    /* back rather than UF_UI_CB_CONTINUE_DIALOG.          */
8 R/ r2 b( _- g6 R* o    return ( UF_UI_CB_EXIT_DIALOG );                       2 I' R9 p. F: M) T
发表于 2010-1-9 01:18 | 显示全部楼层
因该是你没有入口函数ufusr(),
发表于 2010-1-9 19:24 | 显示全部楼层
哇这么多看不懂
发表于 2010-1-27 18:42 | 显示全部楼层
2lou 楼说的很对
9 W& v" E8 K. ]7 e1 Z! m看了你的一大堆代码3 k) J: t& N" a8 l
就是找不到 函数ufusr()或ufsta()$ x6 H; O8 I" a4 u, e
那UG是不知道从何入手的
: O7 J6 O% Q5 z估计是在按EXE的异步模式搞
5 y) Z1 q; r: O- }* W9 G$ \' l% l不做成同步的DLL动态运行库& K: m8 T6 b  ?, m" y5 g% i
又少了MAIN(),编译器在链接时也不知道从何入手* G1 |/ X& ]& l) {3 @, i6 _3 @
就跳出了- A1 _" N  K) Y( S
1 S0 r- g7 y0 W/ _" v$ a这样的错误
发表于 2016-9-11 18:54 | 显示全部楼层
6 O& K# W! g2 P
哇这么多看不懂
GMT+8, 2025-7-2 08:02 , Processed in 0.371209 second(s), 26 queries .
