查看: 3006|回复: 1
[加分结束] 请教:如何采用命令行启动并读入文件?
发表于 2009-11-10 10:34 | 显示全部楼层 |阅读模式
我需要在命令行中启动ug的同时打开模型文件,不知道该使用什么命令,知道的大侠告诉我吧
 楼主| 发表于 2009-11-10 15:11 | 显示全部楼层
Creating an NX Open for Java Program
3 P+ B' e' G" g7 v% B- X  X* z7 r6 a1 u! a; K  I
--------------------------------------------------------------------------------9 M3 B% t9 m# [& l+ D* D
0 w7 @8 c2 e4 _: i6 e8 Y& {' r$ WIntroduction
3 T. G0 j0 S6 {+ Y/ @. x( eYou can create an NX Open Java program by writing it manually or by using the NX journaling tool. After creating a Java program with the journaling tool, you can manually edit it, adding calls to Java-wrapped user functions or to other NX Open API methods. The NX Open for Java Reference Manual contains descriptions of the NX Open classes. 1 r- l: Z/ S, h$ ]
, @' [; L7 a1 j. j: Q3 b& A: F
Recording a Journal; {: b. b; y  g
To record a journal in Java, do the following:
& A/ D! }. V% y# _: \
" x( U& N: R: gSelect Preferences → User Interface → Journal and change the journal language to Java. 2 _' K5 s! y- a* X. A' s3 d
0 N5 m$ K: ~: ^9 ]% xClick Record on the Journal toolbar or select Tools → Journal → Record. Enter a journal filename. , U! [1 F5 y! ?! R* `4 r7 k
9 f, k  v3 _+ C  mPerform the commands that you want to record.$ g2 c+ A+ O0 u  D
0 N; Y) O: ?! @- S7 }5 c' `& m
To finish recording, click Stop on the Journal toolbar or select Tools → Journal → Stop.
5 `* \8 P/ \4 \& S' `$ I
( A! B* ~5 F* VTo run the journal that you recorded, you must compile the journal outside of NX, using the steps described in the next section. The Play button is intended for VB.NET journals only, and will not work with a Java journal. - R% y4 [% E$ h! t3 ^* O
7 L6 E0 U) p, x: P# d7 v
Setting Java as the Journaling Language
6 }/ y8 u0 C' a8 a! EIf you want Java to be the journal language every time NX starts, select File → Utilities → Customer Defaults. Under Gateway → General → Journal, change the journal language to Java. The next time you start NX, the journal language will be Java.
GMT+8, 2025-2-28 09:53 , Processed in 0.235248 second(s), 24 queries .
