查看: 3432|回复: 2
[原创] 关于设置图纸比例问题
发表于 2009-11-28 13:11 | 显示全部楼层 |阅读模式
/*# k# {% `- g" H8 \
The code in the following example modifies the scale of a drawing
) k( Y1 ~/ B5 @" x- v9 t, Vmember view., s3 s) ^3 s5 O6 v# e5 n
*/. L6 S& D3 a5 ^3 k3 ~' h, C
#include <stdio.h>
5 p  \8 c( ~" i1 d( K6 h5 ]& ]8 \& w2 x#include <uf.h>* D9 }5 b% j, l8 p
#include <uf_defs.h>
& z" V% S1 x8 D- u7 A  p9 L#include <uf_draw.h>
; V/ H% i4 H# @' B8 H% q#include <uf_draw_types.h>
+ L5 @6 l! V$ K7 g% _4 t& @#include <uf_modl.h>
7 Q, W2 e, R3 k( t#include <uf_obj.h>+ t, U/ o" q; }
#include <uf_view.h>5 h$ ?# x4 F' _
void ufusr(char *param, int *retcod, int param_len)
5 {2 M% N- u6 C4 s/ z, f{
0 c. w# {$ B# C- t1 B    char                drawing_name [MAX_ENTITY_NAME_SIZE] = "";( ?6 U$ F2 E! L, L' y) C
    char                view_name [MAX_ENTITY_NAME_SIZE] = "";
$ g% [" i0 e! T6 F9 g+ [    char                error_message[MAX_LINE_SIZE + 1] = "";1 G/ t5 O7 K& @( v9 Q! ?$ I
    tag_t               view_tag = NULL_TAG;
* O4 X4 ~+ {7 P    tag_t               drawing_tag = NULL_TAG;      // 1.这里的NULL_TAG 是什么意思?
+ O3 y  o( K/ f0 N% [    int                 ifail = 0;
1 m* d% ^3 }# o3 j1 h* m tag_t               exp_tag = NULL_TAG;
, _3 z& b, P4 t2 B/ e1 w double              scale;6 n! x" J6 |$ o3 P7 a. V; a
    ifail = UF_initialize();( U  W, ~. p, j9 o
    if (!ifail)
2 h/ I0 ^, x8 F* ?( x/ ?    {. p( s7 B' u  h8 M
        /* Get the tag of drawing. */
: p2 b: M. U$ l! a7 R3 m% ~        ifail = UF_DRAW_ask_current_drawing (&drawing_tag);
3 A6 R+ o2 M: ]5 ^' m' k    }
+ U' W. w/ p6 \& W, L0 R2 v    if (!ifail)) P4 d4 m6 r9 Z/ ~/ j7 S* R
    {$ i) u1 y7 V! t) v  o
        /* Get the name of first drawing. */$ k4 }6 b$ v$ c! O' O0 f) J
        ifail = UF_OBJ_ask_name(drawing_tag, drawing_name);  //2.这里的意思是 获取该图纸的名称吗?
. u" E/ X1 S& h+ j+ d    }
1 C) W: j0 p: O3 @/ f/ ^    if (!ifail)2 y- n7 L  {" s+ T; d1 w
    {, t+ X, S& J6 [3 K5 K9 P0 b
        /* Get the name of the drawing's first view. */      //3.如果我想获取第二个视图的名称,该怎么写?
1 b  r8 z6 K1 R2 a: s& Z' v        ifail = uc6499 (drawing_name, view_name);6 }9 u$ ?4 s$ F( t
    }- K! i4 W. O/ F8 v! z+ {5 S
    if (!ifail)
1 `; p+ j- A& r8 g; {6 s! F    {  d  [* ^3 U# P5 b
        /* Get the view's tag. */. W9 M2 a- D' ]
        ifail = UF_VIEW_ask_tag_of_view_name (view_name,
- {! Q. y' L2 j1 F0 n* e&view_tag);1 c( a: s9 `' W# |* T0 z
    }' J& r/ L3 I3 h: ~3 D& [
  if (!ifail)
$ z  Y2 i) H+ s# l8 J    {
& ]5 \& ^) x9 S       ifail =  UF_DRAW_ask_view_scale (view_tag, &exp_tag,&scale);0 X( c2 y$ d% A+ P/ b6 d7 Q
    }8 u( U1 A" J# {. ]  z1 j
    if (!ifail)7 _+ W; Q; i9 N- d
2 J$ m+ L6 `9 b, M        /* Set the parametric view scale. */9 @: G) S* J/ }1 }
        ifail = UF_DRAW_set_view_scale (view_tag, 1.5);+ X! Z, }  C; }1 O9 g8 T6 a
% o$ F, T! [7 \  ]' |    printf ("UF_DRAW_set_view_scale sample ");0 y8 D- l4 N: d
    if (ifail)7 i  Y; j& y, z
    {9 m" e0 P: v# }
        ifail = UF_get_fail_message( ifail, error_message );6 ^$ a; x; R8 L, B: h2 q2 p
        printf( "fails.\nError is: %s\n", error_message );& B$ ]* }2 ~$ b$ k! `
    }" n$ T/ s8 t/ a8 b9 S. g0 q+ ]8 M
    else8 C, n: L$ v* V( ~2 M
        printf( "is successful.\n" );8 e# k: q' x* f
    UF_terminate();( N# b8 p4 a( ?& G. n0 L
发表于 2010-6-5 20:53 | 显示全部楼层
学习来了……  看帖 回贴
发表于 2011-5-20 12:24 | 显示全部楼层
1, NULL_TAG是指没有标识,这比没有赋值要好.没有赋值的话,这个变量的值就是随机的了.
) K' w& }4 h  T8 A- M# [2,是的! z  K4 Z, s" [3 W- g  ~
3,用这个UF_DRAW_ask_views
GMT+8, 2025-7-12 22:33 , Processed in 0.441830 second(s), 24 queries .
