- |4 R n+ C9 X) E) v9 C- entity/FAC,PT(3),CSYS1,LN,in,b9,obj,w,yy,tt,ENT,ln1" k5 G5 a5 Z& v
- NUMBER/a(3),b(3),c(3),d(3)
" L% R. ?0 D) q - STRING/str(100)
- j& \( Z6 e) e- h; b# c ^ - * d% h! K- y+ z9 n) \
- L00:
* a- _+ H: l0 i0 N8 Y' T7 h' {7 R! h - MASK/71- ?2 N. d% a2 Z9 s; V( g1 P) U- w
- CSYS1=&WCS
2 x0 v6 g2 H9 |% N$ ]1 w8 T/ c6 C) u: U - IDENT/'选择放置面...',FAC,RESP7 i) X: m* w! q$ O3 p! _ D6 Y
- JUMP/L00:,END:,,,RESP
! ]6 ~/ H% M( k5 H( ^0 T! \ ^ - 5 y1 k, Z) [5 V3 a) S: z* H
- a=SNORF(FAC,0.5,0.5)
% I ?0 s1 M8 k - b=SPOSF(FAC,0.5,0.5)7 y N# Y" V8 S! r( V6 R* b" V6 t U# @! Q
- PT(1)=POINT/b
! @6 y- Z" c$ O - PT(2)=POINT/a(1)+b(1),a(2)+b(2),a(3)+b(3)8 m, `$ S: j# e
- ( ?& A4 t$ x+ M8 I
- c=SNORF(FAC,0.5,0.5)
$ Q7 ^- y$ y4 o9 E* i# ?1 Y - d=SPOSF(FAC,1,0.5), t* W+ I# x: v. c0 l7 j5 y6 q7 m
- PT(3)=POINT/d
2 c) `& R% H1 O/ r' I - LN=LINE/PT(1),PT(2)
1 Y: |- p' A! ?0 X - CSYS1=CSYS/PT(3),LN; _ \6 d8 x3 N" F2 b' z6 k
- &WCS=CSYS1
; d1 X' s- n/ v. Z: w - DELETE/PT,CSYS1,LN6 Q1 _: m. O& S2 G% y
. K& e z1 ]9 F5 }: T' h- L10:
. x% d! ^ g, W - MASK/70, w# a; Y8 T, j
- IDENT/'选择体...',ENT,RESP
, d- `: g. O8 _8 j7 X8 [0 r - JUMP/L00:,END:,,,RESP
1 e6 F7 [" h, I9 o# Q2 ~) G- v
s3 E; b/ {1 `( {! ?+ t- L20:
+ X& q7 O: a0 P' C. F% q* [2 N - GPOS/'pick a point',x,y,z,resp6 k, L7 z! q7 k8 a$ L' g/ L
- JUMP/L00:,END:,,,resp5 r; u, N2 I3 y) b' P2 Z
- ln1=LINE/x,y,z,x,y,z+2" D! A5 U) ^; P# I/ W" R
- w=point/x+1,y,z
8 P& @& c% [4 c5 ? - yy=csys/ln1,w8 W. y: R! n/ `) O: f; W
- &wcs=yy
8 G) _. v% e9 Y+ n! q* e - delete/w,ln1! A5 N0 x* f, z! v6 M; @
- RPATT/'D:D18.prt'
' b4 `. o3 U& w) T+ x - INEXTE/ALL $$ 初始化所有物体
6 z" Q; f7 D. V \& x+ H% Y: t( ~
?: i. V% r# X& ~- LOOP:
2 t. } W$ |6 T/ m! q - obj=NEXTE/IFEND,END: $$ 从第一物体开始 h# U. J! r4 ?9 b: \
- str=&NAME(obj) $$ 得到该物体的名称. d) D: a0 F+ ~. M" _% y
- IFTHEN/str=='OR' $$ 如果名称等于OR
, c+ K7 _8 s( _0 y# r& b- X - b9=SUBTRA/ENT,WITH,obj $$ 求差
+ k* Y5 n m$ A4 a! Y - ELSE) B/ r3 P g# \& l% p. E' l9 o6 J
- JUMP/LOOP: $$ 否则重新循环,去读下一个物体
6 \/ [# c* k9 q( U# Y! Y - ENDIF . k; a/ Q7 ]+ G" U) S9 L
- jump/L20:; m; X N d3 P' {( n) J
4 T$ X- ~. r3 ]6 U: O& E o" `6 B) E- END:&WCS=&ABS
' l2 j, z1 e/ n* \5 m- S - HALT$ n" |% i a: a2 A( Z2 Z: b
; N2 Y: P- N& I. t* H1 J4 [' L" q& n
复制代码
! m. g& H7 H, Z) s: R |
