查看: 2037|回复: 1
moldflow分析cool的时候就分析失败?
发表于 2010-1-4 20:49 | 显示全部楼层 |阅读模式
分析Fill 和Warp时没有问题,但是在加入水路,分析cool的时候就分析失败,请大虾们指教指教,小弟不胜感激!!!!
+ A' o) L) x, `' f
: K! g$ e4 H, m4 P2 a. K7 j! {% H, x+ j6 t, s1 C: |- N3 C
Copyright moldflow Corporation and Moldflow Pty. Ltd. All Rights Reserved. : A; q( \, N1 K* ~  ?/ d
(C)1993 1994 1995 1996 1997 1998 1999 2000
/ G; S: x7 X, ^/ x8 {9 O(C)2001 2002 2003 2004 4 @2 d# ~* h6 v; t- F
This product may be covered by- ^  t# H; H6 k6 z$ p, v" b
  US patent 6,096,088 ,
  ~* _; T# O  `/ a5 m/ `  Australian Patent No. 721978 ,1 G) n; r! A0 @. {/ r0 J# t  g
and foreign patents and pending applications
, R8 [  N; K& w$ h/ V0 q% NCool Analysis 1iig0l6\m  9 f: Z, L7 B$ t. `( [
Version: mpi500  (Build 04453) }+ z9 h3 {: q( I8 n' d
Analysis running on host: project01 0 e! |; E3 s  ?$ ^  T
        Operating System: Windows XP Service Pack 7 D2 s' D. u- b% [! ~
          Processor type: GenuineIntel x86 Family 15 Model 2 Stepping 7 ~2399 MHz
" N- a" A* O# b: w' z/ h2 C    Number of Processors: 8 y( y5 H9 Y7 e$ z# K' I* a
  Total Physical Memory: 1022  MBytes 0 Y- k& m/ e; a! g
Analysis commenced at        Thu Nov 29 15:20:07 2007 * C7 T' J5 W' V$ x/ g7 N$ W" l
Executed: Thu Nov 29 15:20:10 2007) @- Q$ \5 J; K
  Mesh Type                                          = Fusion AdU0 - l: n) ?$ \4 p& z; S0 w1 j8 F* ~
  Number of nodes                                    =      64185  ( n/ F# k2 m& o4 h/ I
  Number of beam elements                            =        3908
- l% C) }/ w% t, L3 y( ^, Q! I  Number of triangular elements                      =      120984 ( ^* ^0 x4 N5 J9 F. ?
  Number of tetrahedral elements                    =          0
& ^& ~( }% `( J0 ~3 }& NReading nodal data...
- S/ F. T- {7 aReading beam element data...
* D4 w8 I) P& f  a( ~Reading triangular element data..1 Y  O- y7 z8 v
  Method of calculating geometrical influence        = Ide% y% X% F2 I# U! x2 V+ Z7 l; M$ a
  Cooling analysis type                              = Manual
/ j% N% v7 z5 ?4 q4 G* a  Total number of part elements                      =      121052 l# F5 |7 A* _1 i1 v9 D  h3 J
  Total number of runner elements                    =          68
% M$ d- m3 f4 V5 @, [  Total number of mold elements                      =        4188 1 n% o! {/ U3 w
  Total number of circuit elements                  =        3840
* z  L0 C  r& s0 H* k/ f) _  Co-ordinates of part extremity:2 I2 C2 p! R1 Y
                        X            Y            Z  ; m! |* q; T9 o3 y% @
      Maximum        49.60010 mm    96.25000 mm    85.00000 mm
" Y0 b& ]1 x8 ~- c& Y      Minimum        -49.60010 mm    -97.50000 mm    -18.85000 mm
6 B5 s% F6 ~# m  u      Orientation    148.80000 mm    289.99999 mm    188.85000 mm
! j  F8 g% L$ H, S
% v+ o/ U- l2 t" ^" i** WARNING 701350 ** The aspect ratio of element    981  is very high
2 b1 |1 z! D* [/ H5 s. y' a- |& n- c( v8 b
** WARNING 701350 ** The aspect ratio of element    990  is very high
) G5 e6 y- `7 j& i1 S$ w9 E0 M! K
** WARNING 701350 ** The aspect ratio of element    996  is very high  9 a8 u  N# _) W- p) ?/ A
** WARNING 701350 ** The aspect ratio of element    1017  is very high
" [+ x  M7 C3 e% ]6 m0 L/ v** WARNING 701350 ** The aspect ratio of element    1278  is very high
( N; `1 ^- _; ]4 G, \  }** WARNING 701350 ** The aspect ratio of element    2352  is very high # ^" u2 d9 y7 Y; f
** WARNING 701350 ** The aspect ratio of element    2353  is very high
1 |' p- E1 L1 l# j* w
4 r5 [; h0 \: H+ A** WARNING 701350 ** The aspect ratio of element    6126  is very high *
8 y! m0 y+ @& l" A9 O! k6 x3 q- I4 I& V! I- h
** WARNING 701350 ** The aspect ratio of element    7260  is very high   1 C, ?* X/ K# C8 m. [2 j7 {
( I3 _& \8 ^, B# d/ ~, _9 @" ?
** WARNING 701350 ** The aspect ratio of element    7806  is very high ' }6 q8 W" \/ X/ T# r7 s" g
1 b- |/ _2 V% K+ ]9 {# C2 [& ?** WARNING 701350 ** The aspect ratio of element    8365  is very high
( @) R, V+ Z( f# C, `: n; j* X2 |+ Z) z
** WARNING 701350 ** The aspect ratio of element    9378  is very high
1 l  M9 _: R0 P* g
2 @- m/ A. U0 G$ v! Q& l** WARNING 701350 ** The aspect ratio of element    9514  is very high  1 N+ [- W, ]1 O6 ]$ \' H9 V
8 T- @# u% H5 Q! @! Q9 z** WARNING 701350 ** The aspect ratio of element  29191  is very high
发表于 2010-1-5 11:03 | 显示全部楼层
网格质量太差,而且1G内存分析12W网格冷却,嘿嘿,啥都不想说了
GMT+8, 2025-6-19 12:09 , Processed in 0.050990 second(s), 25 queries .
