查看: 10841|回复: 2
PowerMILL 10, FeatureCAM 2010 and other Delcam soft new crack (by SSQ)
发表于 2010-1-28 18:18 | 显示全部楼层 |阅读模式
Here is a new Delcam FlexLM crack for some latest Delcam soft" P+ Y. E) Y% D5 s! x) H
) x1 _, M& t* f4 s. t% ~1) With this cracked Delcam FlexLM Server you can run the next Delcam products on computers Win32 & Win64 (XP, Vista and Win7)
, I# h/ c+ A5 B* N5 ^/ G/ [. K% n
PowerMill 8009, PowerMILL 9003, PowerMILL 10006  (up to SP5): _- V: p% m4 a. O& x* j0 T
PowerSHAPE 8080, PowerSHAPE 8124, PowerSHAPE 2010 SP2 (10203) 7 a: D7 n+ y4 F+ l. j
CopyCAD 7350, CopyCAD 2010 (10120)
% I" j# }7 E2 zPowerINSPECT 6020, PowerINSPECT 2010 (7.0.0)
& X% s. t0 i% [. j& W" p8 C2 WExchange 61205
/ p& X# y2 p- d9 ^Ductpost 1510, Ductpost 1516
+ [" s6 O6 |; i: IPostProcessor 4800
4 h$ g+ P6 u- n% s" ^; D9 aFeatureCAM 2010 SP4 (16.4.0.20)% `- p" K; N' L
DentMIIL 5070
0 N+ x+ D( _  l% W5 |! n: BDental Suit 2010" q/ U) X: \; S  w, j
Crispin Engineer 2.8, Crispin LastMaker 2.9, Crispin OrtoTec 2.8, Crispin ShoeDesign 2.8, Crispin StitchTec 2.8! _2 U) X" U- U* q( M
8 X4 w! c* f& p: p# ^  s- N7 U
2) I did not test this crack with the previous versions of the programs mentioned above and I can not promise that it will work with them and next versions.) Y0 y8 x9 }; {* h, K
7 m$ R" x, o  t6 W4 {0 Z  i! L7 T. o; v0 ^6 o* T4 t. q
3) For info about cracked DElcam FlexLM Server setup read Delcam FlexLM Server Setup.pdf in crack archive..
, z- S. J. a/ ~7 h
$ W* O7 j. l, W) x2 q4) If you have got a problems with Delcam FlexLM Server start on some Vista-Win7 computers try to use lmgrd.exe and lmtools.exe from archive flex_11.6.1.rar attached or try to start FlexLM server without setup but via bat-file ( delcam.exe lmgrd -z -c delcam.lic -l delcam.log ). Bat-file mast be placed in the same folder as all other Delcam FlexLM files6 S' A" s7 H5 T9 x) f; Q
  C1 F5 G5 }4 A; O3 g2 ?7 U) L
Good luck!/ c" I0 }! z8 t9 p" R: t9 n4 V1 S
Team SolidSQUAD
 楼主| 发表于 2010-1-28 18:19 | 显示全部楼层
发表于 2010-2-2 15:02 | 显示全部楼层
谢谢几位老大提供信息 虽然我都知道了 但仍然向你们的热心表示感谢
GMT+8, 2025-7-15 21:20 , Processed in 0.103190 second(s), 19 queries .
