诸位ug大侠:
3 t, C7 u! I3 G$ `
/ E! q- R( I% f8 P# m 我在做UG nx7的一维,二维单元有限元分析,在解算时出现如下错误:
( B& r* r, d! f# S0 [% T
( N- }9 U2 n+ ZMesh-Based Errors Summary% T$ y7 e& m5 y
, ~; X# i$ S: H) J2 H2 m# O
, U( v1 z, d( [/ tERROR
" b/ L$ N" R' l" zThere is an update pending.
8 L/ b" K2 U. T: SIf the job is submitted before an update, the results will not reflect the changes made9 V1 {8 r" k ~' F7 q! b
to the part.7 Y/ \$ b" `, ]
SUGGESTION: Perform an FEM update or use File->Simulation->Export to write out the model
/ {6 E' n3 n* f5 e' I" G# W Odata without an update.) p, @7 l1 n/ e: G/ B9 E8 A. R
- n7 l+ a& Y& ?" H- A
Total: 1 error and 0 warnings4 {; Z0 u5 ~! z1 W8 K
; }, g0 F) J* N& Y& k0 m
' t- z& c- B# F4 s* ^
' N2 R {4 p+ e5 \
* U; r ^/ [: B* V
7 \; K, v$ [0 a# s8 U+ `8 `# \2 j* B+ d* U' }, U- C
Load/BC-Based Errors Summary
3 W' H8 B1 t6 H, l, J4 z; f----------------------------
/ Y8 o d0 d# x% S8 H( D: S# F% Z; q( S* w( W p( J
ERROR* J2 c# ]9 }2 R1 e! I: B
Load "Force(1)" has no underlying mesh that uses the same geometry as the load or the
% c2 j- }' `* w* L+ K; h x3 A9 x; Junderlying mesh is inconsistent with the load type.+ g: H: B6 n) a, J: K4 d' j6 ? J4 i4 ?
SUGGESTION: Create a mesh that uses the same geometry as the load or ensure that the% E6 p3 |- Y/ }
underlying mesh type is consistent with the applied load.7 m a V* L Z; K# C( a7 q
( ^) C0 U( e% P' ]
* _5 W2 S$ |, I8 W' R+ i0 R
4 u3 ^5 s4 }1 Y! Y, ^
% X. S- Y: ~8 x" o! u# m& t: Z6 b8 {* `3 ]" f( b$ I. z! b8 r
" U$ w! V, [. i A. W6 A g
; r9 @: K/ f9 p7 R以致未能成功解算出结果。) C0 I% Y8 W& y+ @ K
7 k+ D3 Z0 o: A% q请诸位大侠多多指正,还劳请长辈高手们发几个关于ug nx7版本的 一维,二维,三维装配之后整体的有限元分析视频,谢谢。
* C' C! y- t( D0 o D0 M# S$ M' i谢谢高手们,谢谢大侠们,谢谢朋友们。 |
