查看: 2223|回复: 3
[疑难] UF_DRAW_import_view
发表于 2010-3-25 21:22 | 显示全部楼层 |阅读模式
请教高手:8 y! i9 ]3 }, a7 i2 b
& F( e1 _6 R& R! J0 B  D& ?
如何实现ug本身 部件视图的功能,用这个函数' {5 ^" R  ?) ~
4 f% j1 ?+ Y+ }1 v/ H导入多个部件时,在同一个视图上都会显示,但
: w+ S/ B4 U1 Z7 F* M6 Z3 q* e: ^6 u: v& C9 y4 N) k" L
UG本身导入部件视图时不会
( Q" V: ^& R2 Q" h, B& z4 \+ B& d" c0 B5 N) [; L+ E
static tag_t AddBaseView(CString partname,tag_t drawing_tag,tag_t view_tag,double reference_point[2])
  F+ Z* [, d% c" N{; n( W4 _0 b- J8 s& m/ M6 t( N# I0 {
int         ifail = 0;
/ ]+ S' k& w+ \% _& |- s- W$ [* o tag_t       draw_view_tag = NULL_TAG;) J! o7 Q  c' C/ e- r9 j5 @  v
if( !ifail && view_tag != NULL_TAG ), S, n3 l7 g  i+ X
{* w4 S; O, Y7 S
  UF_DRAW_view_info_t view_info;
/ S2 |3 U5 ]9 a+ x* M; g  UF_DRAW_initialize_view_info (&view_info);
& X4 E- r( n9 f& T9 j  view_info.view_status = UF_DRAW_ACTIVE_VIEW;. y$ z; V+ b- K# _* g$ S. [, |- S
  view_info.anchor_point = NULL_TAG;  A2 P& ^8 X/ t
  view_info.view_scale = 1.0;
( {2 B; q7 i; w: S' X  ?( P  view_info.use_ref_pt = FALSE;& t' u' l- ?- I1 a: B1 J
  view_info.clean_model_view = TRUE;/ A( l6 @! b1 L/ X0 ^& d9 ^4 q& L
  view_info.inherit_boundary = FALSE;
( u: Q) Q& S0 \( j9 y- h7 V$ z  view_info.transfer_annotation = FALSE;
/ A$ v) F2 ~7 Q6 \6 u  strcpy(view_info.model_name,(LPSTR)(LPCTSTR)partname);0 u, s/ t3 i( r4 L& `
//  strcpy(view_info.arrangement_name,arrangement_name);7 k$ c  X$ w% V/ F! P8 m  t/ P. d: c
  ifail = UF_DRAW_import_view(drawing_tag, view_tag,
& @2 y+ n. [0 \5 b; h( ^    reference_point, &view_info,&draw_view_tag);
, v" R) `# K4 [" H+ Z }! i2 C6 {& T) H3 w4 ~4 m
return draw_view_tag;" ]8 g- J, C% k3 u  s( X5 k
' ?6 Q+ I6 }' `1 a5 c; m
 楼主| 发表于 2010-3-26 10:15 | 显示全部楼层
H:\\二次开发\\下载的资料\\屏幕录像专家\\屏幕录像专家\\ls\\录像2.avi
 楼主| 发表于 2010-3-26 10:20 | 显示全部楼层
高手在哪啊?????/ _  o; F7 \/ s0 ]1 M/ v1 {
7 b' f* V7 i; ^8 j( D录像是我的程序生成的效果,# A  b7 d0 B4 u5 l; r' l
- C  O. \* w- H8 U% R1 s
和ug 本身的效果为啥差别这么大啊,
  h, O, z5 ]. O4 `! T, v" X6 G& C6 W+ L
增加视图用的是上面的程序
 楼主| 发表于 2010-3-26 19:02 | 显示全部楼层
没有办法,苦等没人能给我办法啊,只有用图层隐了
7 ?% t7 }  D: ^. G& R& x+ D+ j0 E$ t5 C$ O# R6 M9 d
static BOOL DraftViewLayerInvisible(tag_t draft_view,int layer)
1 D; u4 H# I0 ~# U" [8 t9 I) x{
$ `( q$ v$ m' K0 I        char view_name[31];) @4 v& M- h% n" ], E( J  L" m
        int methods = 2;# M; v6 O) B- `5 x
        int layer_mask[256];% V* m1 `* E( H
        int i,err;# {  \0 P6 c' E
        if (draft_view == NULL_TAG)3 Y/ u/ v, c2 ?9 c( p% h1 |/ f
                return FALSE;* [6 r1 F9 H0 p1 N9 J
        UF_OBJ_ask_name(draft_view,view_name);
8 {6 p7 [7 O& N3 e* }: K        for(i =0;i < 256;i++)
; z: F/ S4 P  p, L! Z        {
* h9 V1 K, a( }: ^% M4 I                layer_mask[i] = 0;- a) `* v- j- v; H# }* I4 Z' U
        }! B' ]" [& M& k. B5 n. G
        layer_mask[layer-1] = 1;+ g% W6 c& b1 S$ P7 F3 @2 l  t
        err = uc6447(view_name,methods,layer_mask);- m9 o8 c  A* R% w' ]
        if (!err)
, |7 c: H; Q$ ]# A" U2 S. q2 `                return TRUE;
. q9 J; \8 ^. P, I: x' i, |8 O' y, L        return FALSE;$ S1 x' U' b8 g: n9 Y* k: z( G9 c0 L
GMT+8, 2025-6-28 16:24 , Processed in 0.061372 second(s), 28 queries .
