查看: 3786|回复: 2
[疑难] 用ug/open函数实现几何链接器的功能
发表于 2010-3-30 08:40 | 显示全部楼层 |阅读模式
static void do_ugopen_api(void)
1 r" s7 t2 l9 L6 r) [{2 J: h2 m( @3 X4 y) F+ @
        int irc = 0;/ Y5 H* x" P0 k; I4 o# I, r
        char *message = "Select Objects";6 b9 E3 u/ q7 B  E# |9 q
        UF_UI_selection_options_t opts;
2 f1 Y0 O3 F8 {0 r: d1 x) N        UF_UI_mask_t mask[1] = {{UF_circle_type, 0, 0}};
5 m; A  F1 H5 G# U  O- M; |0 P5 u! K4 F; n+ ^- M
        int response, count;- ?. \7 [0 q4 M1 r
        tag_t objects;
- i; J& m8 j5 q# s% ]        tag_p_t object;
# _6 q1 n; U' |- |/ T2 R        tag_t obj;
0 W1 Y; j- ?+ s  _0 G$ x3 X8 t
0 j. `! c" n" Y: z1 t& d% w        opts.other_options = 0;! o" N3 |+ f0 }
        opts.reserved = NULL;
. A4 E: {) H, ], _        opts.num_mask_triples = 1;
6 m% M) l$ t- \! e0 x        opts.scope = UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY;
& s; m, S, R4 B! m9 Q  V2 l        opts.mask_triples = &mask[0];; L3 c! i& ]/ z& c
        //* set selection scope to be work part & occurrence */
! _# c/ Z% W2 b) J+ c0 n        irc = UF_UI_select_by_class(. Y$ X0 w1 ~7 n5 ]1 _" L1 ?
                message,&opts,&response,&count,&object );
, z9 b% w* W6 |2 m, k! q        //* if no error, print information about selected objects */$ q& D$ r. g1 ~% b$ Q+ r
8 R: `* e& `* T5 q  d$ R/ r        if(!irc)
! h, q0 A1 Z; \- S) l, i+ t: v! z: P        {9 d1 J0 V1 U8 H+ Z7 h0 w# r
        if (object != NULL)( V+ A7 V& y3 E4 O1 ^. r
1 \4 V5 h3 m( K8 R9 C4 R  H0 i         UF_DISP_set_highlight(object[0],0);
0 Z7 {! S3 z! Q0 @          obj = UF_ASSEM_ask_work_occurrence(); $ j+ x) x* W' G" o; N
          UF_CALL(UF_WAVE_create_linked_body(object[0],obj,true,&objects));
% T3 F. p- T& p) s8 m0 k1 w                  UF_MODL_update();6 l0 T% K* H! s( o: Z0 S( a+ q
9 ~3 m: W3 X  ~1 Z+ b! f, V' H) _9 H        }
3 H2 I( r! y" W( V" W        UF_free(object);
8 V) s' Y, K: b}6 E4 a( z( ^' P9 G0 E) H
程序实现后没反应,求高手帮忙指点,是不是我的函数找错了还是函数用错了??
 楼主| 发表于 2010-3-30 08:47 | 显示全部楼层
UF_CALL(UF_WAVE_create_linked_body(object[0],NULL_TAG,obj,true,&objects));' p: Y/ M2 x! ~, G6 m  g  x+ w
前面的函數參數少了一個
 楼主| 发表于 2010-3-31 11:12 | 显示全部楼层
現已解決了,哎,放了幾天了都沒人回答: x% Y2 @: ^/ |: e
函數搞錯了而已
GMT+8, 2025-6-28 16:45 , Processed in 0.373948 second(s), 22 queries .
