* r% E2 [) K# @- F t9 `! K4 \1 {/ g列出信息创建者: Administrator6 O" `& |& |0 t' i4 t1 r- k
日期 : 2010-4-7 9:58:18
- I8 r x; l' Z7 e当前工作部件 : E:\3D\XSQ\d121_sim1.sim
/ {, i; p7 F% f& u5 m( i节点名 : pc-2008
: f, V9 u; p# L7 I9 W" x============================================================
% Z0 G, r% l- v
& T6 N' G, u8 S------------------------------------------------------------2 f) v. m6 k3 P) m
( `7 U" F- S i2 S. m9 D
解法综合检查错误汇总
, S7 G+ u* Y5 P! E% o1 |
2 K( N5 J7 Z g4 x' r( C" |------------------------------------------------------------
; A# g$ Y7 J" D6 c: `
, p2 \2 g* m& d: Q+ f. j. t 解算器是 NX NASTRAN DESIGN
, u) }) i5 \, K" p5 s
" D5 m8 p: I! v; @* M 环境: NX NASTRAN DESIGN - 结构- {' a. M5 D6 k2 {& T7 J
/ r8 J8 k+ h) F5 X9 f" J. v 解法是 线性静态 - 单个约束5 J5 p: V( ~, A* L+ A0 b7 B
" L: A7 y$ }1 G) ^* s, S
$ e" V5 F2 p8 }; Y: a ! Z& i- k3 c) C- _' n. u7 m" r
Mesh-Based Errors Summary1 o n* g; t# Z
+ C3 x" y6 R4 F) r: [' p/ {$ W# x! [' A3 S$ F
Total: 0 error and 0 warning
5 |, q0 p+ Z. }1 X+ V3 _- U
' u5 j0 I1 l) @: K7 l% S* P
+ ~5 `1 G4 J# V! aMaterial-Based Errors Summary. b' @' g8 c. w
1 j! d3 D, I$ k* E" s3 Q, J
# s$ T7 g# N; ?; y+ ]Total: 0 error and 0 warning t8 g9 m8 ?0 w3 J3 { D& Q
1 u) i% u0 S" Z. G% v! \$ e( ^
0 k# \0 H6 a0 j" ^$ E! |, E$ m# rSolution-Based Errors Summary
8 T/ P+ Y3 d( }. \# L! ^) {" s! d-----------------------------% N" A6 T i* o
& g% V: j- F7 f) [% o2 JTotal: 0 error and 0 warning
( a( Y# ], c* }4 t V1 w6 z X
1 g7 J( k1 C' d+ ]. {- D2 z
) r- P8 x6 ?" K+ kLoad/BC-Based Errors Summary' l$ k! e4 }- P: F
" x; {6 _4 ~" @6 Z2 G* k0 R( R$ u7 k; P
警告
X1 [; b5 z: J) OConstraint "Fixed(1)" is applied to a mesh that has a face affected by tiny features.
7 I. |% F, j0 s+ P1 ~# r1 X' @- L(highlighted).
* ]# K) U( V4 F& CThe geometric constraint may not be distributed completely. Use the expanded display
5 w/ p( v; Z! @, a4 hstyle of the constraint to verify. Meshing the highlighted geometry again may correct
+ [1 l0 `7 ^0 v: X. pthis condition.3 ^( U1 Y. ]% D& O3 P
( e+ [# g" S* M( {$ f+ \警告
" C6 Z k- Z% ^3 J' M0 gLoad "Force(1)" is applied to a mesh that has a face affected by tiny features.; I$ ?! j4 {4 q- z
(highlighted).. ^8 d( t. }2 r) ?; K
The geometric load may not be distributed completely. Use the expanded display style of- d. z7 V" m& q
the load to verify. Meshing the highlighted geometry again may correct this condition.# R$ A. a7 J* B/ f! K6 h
2 V. J \0 @2 n2 [ I8 Q; |Total: 0 error and 2 warnings
q" U$ X0 W0 z& P
0 X( Y) P- P2 h# P" o
; R2 G5 l) L* r$ F1 KNastran Model Check Completed2 a. N/ V, T2 ]3 {/ f
! I' @& z9 `2 ^7 P6 d* l3 {列出信息创建者: Administrator
9 Q1 _1 k3 |0 e- P! K日期 : 2010-4-7 9:58:18
! U( L4 a' X* k3 s1 h0 d当前工作部件 : E:\3D\XSQ\d121_sim1.sim! F% `% b ?; b, X& _: S4 _7 X
节点名 : pc-2008$ k+ u* ^7 z3 B+ E# w8 k/ O
============================================================/ \* o2 c# ~) c) [
7 m U" o( S! u. g/ U% j
# `" e k: o; a: ^7 i' @*** 09:58:19 **** }" o/ i8 H" g/ D( C+ M0 r
Starting Nastran Exporter# E9 m8 P# G4 c& O: x
' X8 j) |0 u. f9 c7 U*** 09:58:19 ***
* N% t+ \2 v9 H g7 b! g+ s+ ]Writing Nastran System section* U9 r& G4 E- q( {& a& y' L
5 e0 j& i4 ]1 s9 x; X8 C- U: E0 X
*** 09:58:19 ***; [6 y, n0 K Y O1 J, B
Writing File Management section/ S4 ?# S# d" s: t8 A
. J6 I5 X2 v' F: P! w
*** 09:58:19 ***
, s( O+ B( I. o+ fWriting Executive Control section- ]6 ?# E7 n1 a
* n9 X. \, m3 n% o% O3 `$ J
*** 09:58:19 ***9 c' t6 a1 u ~- Y3 [
Writing Case Control section
( B$ `6 C: v' z0 o; x9 i3 ?3 n$ ^ I# ]% t& r t0 o
*** 09:58:20 ***2 s1 g( I. [2 S, u$ e! O
Writing Bulk Data section
# z# z8 j! t! m& w9 G5 ~; [! y7 N: R x
& \5 H6 V& b) o @/ g*** 09:58:20 ***
- b7 n3 f; C8 r% O! _1 PWriting Nodes# S( m, g3 h Z: i; {
/ E' l0 H' S! B; f*** 09:58:20 ***: p3 s( a3 d* W* c
Writing Elements {" w" Z6 |1 s! ~) k" L$ h
4 ~9 ^9 p3 v6 i*** 09:58:20 ***1 w1 J% ]" X }1 `% V
Writing Physical Properties
- n) ~% k1 U# h- @2 u; E
& E. T. j' q) i$ P! s L*** 09:58:20 ***
/ o" D$ W/ L; ]9 J* }* Q2 XWriting Materials c4 k8 w1 P0 U
1 R7 M" L+ F' m' n( C+ |
*** 09:58:20 ***1 |8 `. {, s9 _/ F% ?. C4 g5 e" E
INFORMATION : Reference temperature for material ALUMINUM_2014 has been set to
q/ l4 J$ p, Y& j: x the solution's default temperature
+ T* Y2 s5 \8 z: q
( e- |; p: m$ I2 t& y. s2 }*** 09:58:20 ***
+ w; h- q5 s. eWriting Loads and Constraints
, m/ ^! K5 m: W. c+ L) x, ~
9 Z) O8 C' N8 c# H4 o*** 09:58:20 ***
- [7 H% {* j( ]' ?Writing Coordinate Systems
/ z5 j8 |1 Q" k% W7 ]4 O2 s$ A% j, T: }
*** 09:58:20 ***
/ e1 E5 q9 y/ d$ ISummary of Bulk Data cards written
6 U6 ^, {! }: c; J/ X/ p4 K( Z7 g9 ?: g, P, P
. K( A4 e' `8 E5 x| NAME | NUMBER |
$ q/ ^/ z) r$ L( S8 M, t0 S' }+----------+----------+9 i L1 m7 l& Z# {
| CTETRA | 1985 |
" \% I: `' F h* _ b3 j9 m| FORCE | 36 |+ ]/ L( `; p3 a+ ~2 b
| GRID | 598 |1 w' {! O- `6 m5 ~0 J. e
| MAT1 | 1 |
4 i6 f4 {) q7 L# a% Z) o| MATT1 | 1 |
9 I5 ]2 y y" Q; u4 ?7 [8 z| PARAM | 6 |. l' m* H4 O, T9 X9 a* j) X
| PSOLID | 1 |
, n3 O, f2 f5 i" a8 Y| SPC | 36 |: `) \) }/ W! J/ K0 C5 i- s
| TABLEM1 | 3 |
' S p4 T8 d/ H4 b; m& |1 B+----------+----------+9 o: N! x/ i4 o7 M, ~' M
1 t/ H! x7 H- W6 |( i7 R
*** 09:58:20 ***: [" Q; Q3 c' o' ^" F" x1 O0 ?
Nastran Deck Successfully Written |
