查看: 3183|回复: 0
[疑难] 安装好NASTRAN后,怎么编辑nast5.rcf文件?
发表于 2010-4-8 20:23 | 显示全部楼层 |阅读模式
Memory=estimate
. n& {, b& z  Z2 SBuffsize=8193
1 m$ u+ a: t* A" n2 ?7 qsymbol=LM_NO_SNMP=1
7 w. }* u2 L, B8 j0 vishellpath=%NXN_BASE%\bin  C: w4 R& _8 j$ _* ~
scr=yes4 ~/ Q2 s% h  L) _+ X: x6 R
msgbell=no: f1 T3 @. x. y; ~  T
Auth=28000@jj. t3 j0 d- X1 }9 X- y
Sdir=$TEMP(主要是$TEMP应该改成什么)
* Y0 Y- r7 k2 w8 r& t% I: k# K( D* g  j
( `  x. F1 f; N3 [7 ]' b5 ^
下面是对修改它的提示! k% R/ ]5 Q# b% T
5. NX Nastran 5.0 settings
2 ]' \' g9 A+ P" A* [3 T+ [+ B0 k0 t) a-------------------------------------------------------------------------$ J7 X. X# p3 u; |& Z# F$ R3 q- D
7 I/ \* q6 s; |% x) T1 O  n, }After installing NX Nastran, edit the nast5.rcf file. This file is in the nastran" U$ [4 Y" ?4 M4 b+ u8 B
install\conf directory. You can also edit this file using the
( Q0 |4 v# J1 Z& m3 [8 E& G4 O$ Z- F' m
    Start->All Programs->NX Nastran 5.0
# D6 B8 p- F3 I8 n
. k, u1 X0 U$ Rand edit the nast5.rcf file. Make sure the sdir variable points to a scratch directory.
$ B& p4 x, ?0 \3 P: o1 ?The default for this in NX Nastran 5.0 is $TEMP.  In this file, $TEMP puts files in1 H: }  h3 u/ p7 l3 n2 J5 w
%TEMP% on Windows. You can also edit the auth or authorize variable. This needs to point' m+ ~! [8 x/ F. F
to the correct license server. The server entries need to be separated using semi-colons.
GMT+8, 2025-7-14 02:19 , Processed in 0.212153 second(s), 25 queries .
