查看: 780|回复: 0
[原创作品] element milling cutter
发表于 2010-6-1 09:43 | 显示全部楼层 |阅读模式
[audio][/audio]we are a trading co.of precision cutting .we have a lot of milling cutter for you choice .there are four brands .FRAISA is exported from Switzerland. ELEMENT which is made from Germany .JAPANESE BIG .Switzerland'fraisa and schaublin .all of the quality is perfect
Tool material and coating technology which are adapted for quench hardening stell milling are introduced. Aimed at willing of quench hardening stell, by cutting experiment, the cutting performance of carbide vertical milling carbide cutter which is coated with different coating material is compared. The high speed process method which is adapted adapts to high hardness metal is explored. if you are interested in some products .please let us know
GMT+8, 2025-5-13 12:36 , Processed in 0.073964 second(s), 22 queries .
