查看: 1154|回复: 0
[疑难] 求助grip错误,谢谢
发表于 2010-6-10 23:00 | 显示全部楼层 |阅读模式
number/k,j,m,z,B,i,toolinc,trans(12),trans1(12),$
rot(12),rot1(12),mat(12),mat1(12),mat2(12),pi
entity/cur(10),gear(1000,1000),gear2(1000,1000),tool(1000,1000)
pi=3.14
z=60
m=12
B=10
k=20
$$lb100:
$$param/'输入加工参数','模数',m,$
$$'齿数',int,z,$
$$'齿轮宽',k,$
$$'螺旋角',B,respond
$$jump/lb100:,stop:,,respond
$$刀具
cur(3)=circle/38,0,0,5
tool(1,2)=solext/cur(3),height,1.5
delete/cur(3)
mat1=matrix/yzrot,90-B
mat2=matrix/transl,0,0,-4
mat=matrix/mat1,mat2
tool(1,1)=transf/mat,tool(1,2)
delete/tool(1,2)
$$齿轮毛坯
cur(1)=circle/0,0,0,25
cur(2)=circle/0,0,0,35
gear(1,1)=solext/cur(1..2),height,k
delete/cur(1),cur(2)
mask/omit,70
, c) G. f$ |( d) F$ Gdelete/all
$$运动仿真
toolinc=0.5
trans1=matrix/transl,0,0,-(k+12*toolinc)
8 I, H: P; Q* Drot1=matrix/xyrot,5
do/lb110:,i,1,z,1
do/lb120:,j,2,k/toolinc+12,1
) e  d% S+ F! _+ i
trans=matrix/transl,0,0,toolinc
0 b9 X4 S4 V9 E
tool(i,j)=transf/trans,tool(i,j-1)
5 M: E$ j8 X2 H' @) d, l7 U
gear2(i,j-1)=subtra/gear(i,j-1),with,tool(i,j-1)
. B5 |+ g2 ^% S8 `rot=matrix/xyrot,-(360*toolinc*sinf(B)/cosf(B))/(m*z*pi)
. ?4 l, [+ `  s* [; @4 H8 p
gear(i,j)=transf/rot,gear2(i,j-1)
! R* \0 S  ^+ a. x7 h' E- `delete/gear2(i,j-1)
lb120:
* u# m6 _) U  \/ L. x
tool(i+1,1)=transf/trans1,tool(i,k/toolinc+12),move
  T- ^( K' o% e: B0 [( H  a  Rgear(i+1,1)=transf/rot1,gear(i,k/toolinc+12),move
lb110:
$ {. q1 m1 {& C% b1 i% O
messg/'success!'
. t; T9 ?: g' X# H5 N4 Z( r$$ delete/tool(k/toolinc+12)
* i5 O& e* w3 m4 Q2 I+ O& ?- s
mask/omit,70
( O3 v/ Y/ o5 G; L4 Q9 C$ x0 pdelete/all
$$stop:
Halt
这是一个加工仿真程序,编译可以通过,但是运行的时候中间会出错,求高手指点,谢谢
GMT+8, 2025-2-19 06:43 , Processed in 0.052420 second(s), 24 queries .
