参考一下,导出IGES,这个BBS是不怎么火,燕秀那边比较火一点
. _( A' \6 l: {, R. d1 n9 l- T2 h& k2 X2 y) s. Q: A/ `( T
//full_path: path to save igs file/ e# U* J$ y, P, m
//part_name:current displayed part name 1 S! t; {' w# W7 j$ s) s
int Export_Part_to_IGES(CString full_path, CString part_name)
6 @! ?" }9 C' W1 _& N. p; s! p9 w{
+ z% l/ ~* ^) Q0 a6 ~% z! e9 D6 y7 S* b5 x6 q$ m0 D; [
char cmdfilename[MAX_FSPEC_SIZE+1];
2 @ Y/ l5 Q% E5 b0 F char cmdtext[256],trtool[256],trsour[256],trdes[256],trdef[256];
# j$ e2 O0 w* O# t7 h4 K% I FILE * filestream;
" _1 O- \6 k) j( U0 ?+ ` char *UG_dir; + j5 S1 I% Q% L6 }1 A* s
UF_translate_variable("UGII_BASE_DIR", &UG_dir); 6 G5 p! L n% A7 g1 c6 t0 f* c
strcpy(cmdfilename,full_path);
c8 R. b; e: P strcat(cmdfilename,"temp.bat"); $ }1 W2 _* u R) n0 I0 a; G
filestream = fopen(cmdfilename,"w");
* `8 Z4 h0 |1 g strcpy(cmdtext,"@echo off\n");
6 D/ C/ n0 @ a fprintf(filestream,"%s",cmdtext);
* x& e0 ]* n1 L- o strcpy(trtool,"\"");$ I$ Y+ N+ r. \- a' \7 U
strcat(trtool,UG_dir);% N" _& k) P# t+ u
strcat(trtool,"\\iges\\iges.cmd\" ");) b9 D* A" o; r6 `3 w5 O
strcpy(trsour,"\"");
" S2 w# B; F Y* R' W) x strcat(trsour,full_path); 2 @1 g6 F3 W! r# K9 x- z j. |
strcat(trsour,part_name);# Q) h6 Z1 b0 X5 f
strcat(trsour,".prt\" ");5 j" P; [$ R$ l7 C6 u, |
strcpy(trdes,"o=\"");9 v; x7 {( {4 i) |0 ?1 ?
strcat(trdes,full_path);
% w# X- L1 m/ Q strcat(trdes,part_name);
6 x% o/ Y/ A- J: a strcat(trdes,".igs\" ");
+ c F9 Z+ M' s6 P strcpy(trdef,"d=\"");
; S! M. |+ a- p* L2 R strcat(trdef,UG_dir);! @8 M* h' ?6 P* u3 G) U9 i
strcat(trdef,"\\iges\\igesexport.def\"");
' ]6 k9 x& c' i9 {+ n fprintf(filestream,"%s%s%s%s\n",trtool,trsour,trdes,trdef); G
- r3 Z1 ]7 h/ n5 R% c8 ? c
9 |4 P* z! z. Z1 l6 W3 n! i3 V fclose(filestream);
6 V+ |2 L1 L! P: ~ z SHELLEXECUTEINFO ShExecInfo;
# J- h1 T5 a. O0 e% U ShExecInfo.cbSize = sizeof( SHELLEXECUTEINFO );
+ I+ R* B7 d/ ? ShExecInfo.fMask = SEE_MASK_NOCLOSEPROCESS;
& s6 y8 p6 A1 O ShExecInfo.hwnd = NULL;
. b; \. M" }+ K# B- m1 `" v/ {; x ShExecInfo.lpVerb = NULL;* h1 H( ?! y+ |0 Z+ e# {7 [
ShExecInfo.lpFile = cmdfilename;
1 @0 m# t# m- O- k d8 R ShExecInfo.lpParameters = NULL;
* ?4 k# A' K# Z* Q- j( m' { [ ShExecInfo.lpDirectory = NULL;
' F9 n& B7 E" O! q+ |. X! M1 ~* ? ShExecInfo.nShow = SW_HIDE;
; G" X- s9 \7 I( [ ShExecInfo.hInstApp = NULL;
; M9 ]0 ?; t/ X8 Q5 R% }8 [ ShellExecuteEx( &ShExecInfo );
8 u! M: M& _8 I$ _2 D; k WaitForSingleObject( ShExecInfo.hProcess,INFINITE );
- O, Z5 y! l/ D return 0;! @) Q# [2 k Y) _
