我有个测量不规则方块的0 V- i( ?4 c. d) Q
+ E' @ R% g; h
$$提件尺寸检验程序, S$ C2 h/ G7 t1 L- c9 M# D. n
: W J1 q3 ~* y; Y e3 l6 H$$$$$$$$$$$$$$$$$$$$$$$$$$# I. i( ?' X6 E, f
Entity/precsys,temcsys,xpt,opt,zlin,prept(3)
/ R& y. y0 y1 s0 B! K+ Z9 REntity/obj(100),zpl,xpl,ypl,zp2,xp2,yp2,xlin: ?$ K2 r4 [( _" b: g
string/zlang(50),unt(50),xlang(50),ylang(50)$ D! @* h: Z& [
number/hmax(7),hmin(7),lmax(7),lmin(7),wmax(7),wmin(7)
/ l% ?0 |/ Y+ l! ~/ R2 @% M Dnumber/hz,lx,wy,i,k,j: i4 Y" x& k% U& J" U/ [
data/i,0. v6 f8 m6 x$ T% X
data/zlang,'坯料高度(z)= ',unt,'毫米'
% x! K( b; v$ M& ^- Q$ Q) A5 X8 T% Hdata/xlang,'坯料长度(x)= ',ylang,'坯料宽度(y)= '- [: w0 I2 E" ?3 l8 y! E
Entity/pot(8)2 B, \) y) T+ j+ N2 S$ N
Entity/elin(12)$ ~ N/ {6 R; A- f# R/ f& S3 g
Entity/oeg,olin,oep1,oep2,gru
6 t! N7 k. y8 `: P& h+ _number/n1(3),n2(3)
" f5 l% K$ i `. M7 V6 C0 m) s L F! s% S* O, u& g' x/ h
$$$$$$$$$$$$$$$$$$$定义工作层,保存原始坐标系
2 V& W L$ u' }+ |" h* _* A1 hLayer/Work,&wlayer/ v2 _. R& p8 g% L/ ~: a
prept(1)=Point/0,0,0
+ }, h+ Q9 Q; j! LBlank/prept(1)
2 Q6 c; P* u: g4 e _% w5 qprept(2)=Point/1,0,0! M9 E& b) _# E. d+ Z+ o6 ?
Blank/prePt(2) E5 b. L- ?& g L: \- H
prept(3)=Point/0,1,0
4 q; Y- N: G- g9 u( {/ w& TBlank/prept(3), g) _- O3 {8 e5 x0 H3 W% H
precsys=Csys/prept(1),prept(2),prept(3)
' [5 t7 _% |2 \4 i- V. E8 A/ xDelete/prept(1..3)
/ ?! v9 `0 C& Q+ m: exlin=&nulent
) q# o" h) @/ m$ ]& C$$
6 [# v1 V) H4 ~; r$$$$$$$$$$$$$$$$$$$生成新坐标系4 l1 f9 H; I4 I! Z7 k* }4 H. k
4 p0 L! H& u: ks05:
. j5 z v3 ]- a. E5 B# Hdelim/''
1 r, A3 m! B ]5 k4 p# f: ]
6 s2 l$ n/ C3 R+ uChoose/'选择坐标系生成方式',$
7 J4 X6 x2 C d '边界线',$
9 J. v5 O6 b1 r, s8 o4 q4 D5 M '两点',$
9 C5 h* ]7 a! { '斜楔提件',Deflt,1,resp
5 G, c$ V4 R6 AJump/s05:,oo:,,,D10:,s10:,D20:,resp
( w, q5 W- h1 K s' h! k) X) e5 N2 K$ ]
d10:, J& @1 A* G$ k9 q
Mask/72
! A! k0 Q# a' c" H; mIdent/'选择边界直线',oeg,resp+ y1 g5 j/ G, T0 _
Jump/s05:,oo:,,resp
: n" C7 J7 J J9 ?, P+ w4 k/ polin=Soledg/oeg,Iferr,wro:
' B/ k6 e: }& G/ ~7 N) m* I* e&color(olin)=186# O1 w0 X$ ]3 s3 D9 R5 P- U
n1=&spoint(olin)
' Q& y8 g; q* \1 sn2=&epoint(olin)( `7 G% m: D1 W' R
x=n1(1)6 i2 y' G z) z4 H8 ]5 U/ |& Q
y=n1(2)' X) v( G0 A) L) R
z=n1(3)5 u4 j% J6 Z$ u! {! i% `
x1=n2(1)) B" i0 f) Y: d, _
y1=n2(2)/ U' b# T: q0 |
z1=n2(3)
/ ]& B& Y6 d8 O: F1 ?/ [) _Delete/olin
% I# C% X! ^6 N5 G1 B; SJump/s30:
. G1 L/ _% a5 U
' S# o& C2 s2 f4 zs10:
+ B- x" B" ?8 |+ s9 e" U/ ?5 EMask/2: V' ?* K( @& w5 `( e; [' a/ @ e7 v
Gpos/'选择新坐标系原点',x,y,z,resp- D- I# h& k: p9 p+ o: t7 x
Jump/s10:,oo:,,,resp6 w) }; O* |. b$ q# Z- ?
s20:2 S9 l; R0 H- w
Mask/2
4 ]. [" q A1 w; TGpos/'选择X点',x1,y1,z1,resp2 P9 i8 p# O5 R" A2 j, l( p4 g! \
; z8 t* |8 m X4 V9 bIf/(x1==x and y1==y and z1==z),Jump/err:
: ]5 n* R/ k( I" c; ljump/s30:
* i9 \$ @; w! j. T5 f8 Z
) P8 @9 b% ^* W- BD20:
- i W. {/ c& ^olin=&nulent/ Y! }# q! r: E; Y+ R8 h& b
Mask/72 u( h6 m6 V) w
Ident/'选择边界直线以确定Z轴',oeg,resp8 Y* I$ ^( B& Z3 ]- Y5 W
Jump/s05:,xxtj:,,resp2 ~' M) o, w1 @1 ^
/ _: X. u4 O# m7 d&color(olin)=186
$ x9 q; G. T6 W' l& QD21:6 V; g+ F' \* }+ w% E
Mask/28 n/ u9 l3 S) Y, B5 N+ V7 O
Gpos/'选择新坐标系X点以确定X轴',x,y,z,resp3 A9 _; ]' z( ?, W, i
Jump/xxtj1:,xxtj:,,,resp3 V g: d7 y! t% }( Z" b; q+ c: n
1 l) ^ ~9 b- x- K! {xpt=Point/x,y,z
* h$ i% |. g, _; w8 O5 \, Jtemcsys=Csys/xpt,olin. y3 ~, R2 K' `) y" @( Z* p
Delete/olin,xpt
+ q7 @" R1 s, WJump/s50:, x" ^: |% x( [
9 ?* k/ O0 _3 ^8 r0 s# q# }: `5 q( d- J* ?2 P2 p
s30:5 U4 @# U' d; o I* R
opt=Point/x,y,z
: l: q/ L2 p. ~zlin=Line/x,y,z-1,x,y,z+1; A- Y4 I6 a, i) t
Blank/zlin
* q. J3 F1 T# [3 c: c# kxpt=Point/x1,y1,z1
' a6 @, T5 ~& o6 b$ Lxlin=Line/x,y,z,x1,y1,z1
' i$ U1 z3 p# ]$ _; K! ]; m, T&color(xlin)=1865 H0 ^2 s4 |: L, A: u8 [, i
6 H+ G( Q& S" w6 R0 `
temcsys=Csys/xpt,zlin,Origin,opt( z8 c* O$ N& u" G
Delete/zlin,opt,xpt
& y! X* s1 h' x% _s40:2 M5 x# c7 `- r8 {6 ?
Jump/s50:- |; { H) @, b8 P# S& ^# J. h7 a3 e
" s7 k5 R! ~" e& U9 w
: ?+ { }! c) }: z$$
8 e& U9 Y) V3 Q; r5 qs50:
4 J+ x9 I9 i/ G& \&Wcs=temcsys) P0 v$ o1 ^9 |! d9 f0 J: E% E$ Q
&wcsdrw=&yes
1 M* x _2 R& M, ?; `2 yMask/705 X7 g a/ _! e( D
i=i+1
- j! v0 V F' f8 A3 A0 jIdent/'选择实体',obj(i),resp8 A3 j- Q# ?4 H& i- t( a4 b' U- O
Jump/tt:,qq:,,resp
* T' ^4 M. y& A2 y, ]6 a6 R: T8 q. T6 Y
s60: & _1 z# [3 @5 K7 C
$$&Name(obj(i))=Substr(Fstrl(i),1,1)
+ B+ P$ z' F+ K9 Szpl=Plane/xyplan,5000- j J: T/ e5 K0 Q* W
zp2=Plane/xyplan,-5000& b8 _% r; n" P9 m
xpl=Plane/yzplan,5000 f" u3 p. T+ s- v
xp2=Plane/yzplan,-50008 M% b0 ~% U# f0 R$ a/ ^. G
ypl=Plane/xzplan,5000" C1 F8 m0 y/ W3 _
yp2=Plane/xzplan,-5000& V1 f% j C* q9 w
hmax(1..7)=Reldst/zpl,obj(i)
- P; F. O; t0 L: p O- Fhmin(1..7)=Reldst/zp2,obj(i)* {. I( p3 _6 e! {* Y
lmax(1..7)=Reldst/xpl,obj(i)- G0 }: A- S1 w; P0 o; r7 d
lmin(1..7)=Reldst/xp2,obj(i)
7 p$ c3 V7 Z2 s, Ewmax(1..7)=Reldst/ypl,obj(i)- o8 k& W, X' K( S
wmin(1..7)=Reldst/yp2,obj(i)
+ k+ Q1 I. l' ?7 o/ `Delete/zpl,zp2,xpl,xp2,ypl,yp23 h6 M7 i4 R0 S: `/ Q* \) x
hz=10000-absf(hmax(7))-absf(hmin(7))$$ z向长# d. |+ ~! V4 P. S K9 j
lx=10000-absf(lmax(7))-absf(lmin(7))$$ x向长- B m; W" f* _0 @
wy=10000-absf(wmax(7))-absf(wmin(7))$$ y向长
' J2 t- a9 o# g
! S9 Z) f; L* x( D- P" w4 F0 G: Npot(1)=Point/-(5000-absf(lmin(7))),-(5000-absf(wmin(7))),-(5000-absf(hmin(7))): P5 l. i4 W. _7 g4 a- P2 p6 R1 }
pot(2)=Point/5000-absf(lmax(7)),-(5000-absf(wmin(7))),-(5000-absf(hmin(7)))2 |2 F7 G# M8 Q: L9 Z' b4 M" M m
pot(3)=Point/5000-absf(lmax(7)),5000-absf(wmax(7)),-(5000-absf(hmin(7)))1 j2 H& e6 N2 C. \. g, T! q
pot(4)=Point/-(5000-absf(lmin(7))),5000-absf(wmax(7)),-(5000-absf(hmin(7)))+ w1 E4 r+ i. s, m) M. k5 N' }
* ~+ F8 M* @/ e
pot(5)=Point/-(5000-absf(lmin(7))),-(5000-absf(wmin(7))),5000-absf(hmax(7))- m! ]# ]1 l* i6 k3 T( K; X
pot(6)=Point/5000-absf(lmax(7)),-(5000-absf(wmin(7))),5000-absf(hmax(7))2 J" }- [0 v' P: [+ p0 z9 `# w5 y
pot(7)=Point/5000-absf(lmax(7)),5000-absf(wmax(7)),5000-absf(hmax(7))
1 J$ d, R! V* ?: {0 P: Fpot(8)=Point/-(5000-absf(lmin(7))),5000-absf(wmax(7)),5000-absf(hmax(7))' I: A% O) O/ E: g
$ Q+ {* }% z6 d/ T% H" H
; Z% M |6 o7 t" X+ }4 y3 p9 ~- o, ~$ U' C% Q
elin(1)=Line/pot(1),pot(2)$ k, d7 J$ f: Y
elin(2)=Line/pot(2),pot(3)" }8 Z3 n' F. U, F0 {# o
elin(3)=Line/pot(3),pot(4)7 x& Y' B. `5 R5 X: G* S* V7 j
elin(4)=Line/pot(4),pot(1)2 C! t% Y6 z; u0 X" J. ^
, C+ c" w* ]& N; l/ S J2 k- A% j
elin(5)=Line/pot(5),pot(6)& Q$ Q# q- g9 i6 p/ n4 }
elin(6)=Line/pot(6),pot(7)
2 t' S) e3 a! k8 E4 E" J+ ]elin(7)=Line/pot(7),pot(8)
. Q$ o) e9 W$ l9 ^+ j& E! i, O% Welin(8)=Line/pot(8),pot(5)5 ]1 F5 b+ Q1 { E5 q4 a: }
: ~% w0 w7 y& e0 L! ~7 B8 l" b# E
elin(9)=Line/pot(1),pot(5)
6 V( ^: ]' m: o3 J1 T8 jelin(10)=Line/pot(2),pot(6)9 O3 A* h' y) e. D R4 m2 S
elin(11)=Line/pot(3),pot(7)
1 p; K) w4 l: e8 Eelin(12)=Line/pot(4),pot(8): F8 J" p- v" Q: {1 [
8 A0 m" U5 `% h G6 h
Do/s65:,j,1,12
# j2 D$ V; ^: `4 x2 R&Color(elin(j))=36
/ P# g' P+ i4 h: u/ b& O% s. a&Lwidth(elin(j))=3, p/ Y6 u; W: }) M& G) k
&Font(elin(j))=3
: u- W( ~- u- x2 Us65:
- s7 ?4 s+ z, _7 o- X! y* o5 [
; ?- m5 A) t) s/ K1 c* nDelete/pot(1..8), s& x! N4 N: w _! F
gru=Group/elin(1..12), b5 `8 _. l' Q, a, U( u
&Wcs=precsys" ?* c) c0 G% }! J
&wcsdrw=&yes
) E3 z6 I* K! v& Rs70:' d( V( i# M, j
Choose/'选择结果输出方式',$
4 u1 |. l3 S7 j! `5 o '生成报表',$; I/ H; [2 C7 [) j, q
'信息显示',Deflt,1,resp
7 ~# _* L9 Z* g9 _0 u$ l2 DJump/tz:,rr:,,,s90:,s80:,resp
0 u6 N3 H) l2 F% I/ P$ h9 x1 D+ C0 J: A+ Q0 [: |, `
s80:( ]2 z: f6 }# ^
Messg/'高(z):'+fstrl(hz)+' '+'长(x):'+fstrl(lx)+' '+'宽(y):'+fstrl(wy)6 {% {3 O: F+ E% g$ y' J* y& X4 N
Delete/gru) N* _* h+ C, w
Jump/q10:
4 i" i: X- e5 y) _' ~% C1 q- x* Z: B7 m! W! O# f' r& W
s90:
1 ~7 L5 G4 D1 S% Z+ b" Uk=k+1 $$ 记数
0 y4 ^8 f4 a4 t. ^ Oprint/'镶块'+Substr(Fstrl(k),1,1)( }; J- b' K6 ^9 f2 `# @
print/'-----'
4 ^4 d, ?% J# J: ]3 kprint/using,'#@@@@@@@@@.@@',zlang,fstrl(absf(hz)),unt
1 a/ L! H5 V% s# C) D1 Jprint/using,'#@@@@@@@@@.@@',xlang,fstrl(absf(lx)),unt
9 l& b( j( ^- t! Sprint/using,'#@@@@@@@@@.@@',ylang,fstrl(absf(wy)),unt
! G- W5 O/ J* Zprint/'-----'
+ w5 i, `6 s4 ^/ i0 iprint/using,'#@@@@@@@@@@@@@@@@@@@@','镶块放量(总长+3mm):': U$ {- L$ V/ q6 `3 c% L
print/'-----'
( S$ A. r) D" Y6 W! v; [xm1=intf(absf(hz)+3) O: N9 @" t; |% R# b
xm2=intf(absf(lx)+3)' z4 F5 W' o' ]( z' e
xm3=intf(absf(wy)+3)
2 H6 p7 r1 A/ x1 S& K2 O/ ^
: L' V3 y( [: G3 c: i. Mif/(absf(hz)+3)>=(xm1+0.5),xm1=xm1+1. d% Q @6 Y8 ?) m' I1 M3 W
if/(absf(lx)+3)>=(xm2+0.5),xm2=xm2+13 {9 m$ }0 C+ Q6 U
if/(absf(wy)+3)>=(xm3+0.5),xm3=xm3+1" n& | J- u. Y. _7 u
7 z j# v* t- C
print/istrl(xm1)+'X'+istrl(xm2)+'X'+istrl(xm3)3 w7 V; M* I: T- m
$ D q0 ]6 v2 _: N5 ?$ T- e3 }print/'============================================================'$ K5 V6 p. i. s. u9 `
- e! G$ K& q7 ^. d2 cs95:
- E( _9 ~* b0 \6 p7 @Choose/'选择毛坯线框操作',$+ M* ]) |+ f5 b K+ j
'删除坯料线框',$
4 [ `: |0 }) u '保留坯料线框',Deflt,1,resp
. A: v' `& B. y0 s1 e E x3 m5 d/ UJump/zz:,vv:,,,b10:,b20:,resp3 ^) g6 N$ p9 D
b10:% F+ h- c( T& L6 c
Delete/gru
1 n/ |" w% V, R# vJump/q10:0 o) [* W' U+ h- F! |- w6 }; y% w
b20:/ I5 w3 [$ O& x5 D, A
Jump/q10:
& ?* b6 Z# [ Q1 t0 _. h
, s& X9 w, ~6 _9 r4 T( Ttrm:$ S T' L C! `" l8 w) P: Z1 g# @
Chksol/xlin,result,nlist,Iferr,over:+ v5 @8 `4 ?- b6 z
&Wcs=precsys
# S* E0 H5 c" n: k9 H&wcsdrw=&yes+ Z- }8 ]( r" v8 m+ g: S
if/xlin<>&nulent,Delete/xlin
; ]: B$ p5 r* N5 A* v' I9 fJump/oo:
6 Z+ U$ b0 r' |1 @8 W1 K7 ]! F' Z/ a/ u1 u. h9 q2 \5 K( L
over:
* I [) @1 M) z- o- G+ D# C KChksol/obj(1..i),result,nl,Iferr,oo:
* T2 h3 c0 g5 w$ K5 |; U3 u: N8 O
oo:4 ]6 U) X) f4 v
&Wcs=precsys
2 i$ q* w+ m9 c2 d7 T7 [&wcsdrw=&yes
/ ~3 C" M. o6 e X+ Ehalt G$ Y% D6 k0 Y% _6 P
3 U J. E l4 j V* c5 G- R
err:7 Y# u1 ]6 } Z4 z
Messg/'所选的点与原点重合,请重新选点!'5 V9 X. M- N- G+ [7 l" u+ k9 N+ ~
Jump/s20:, R4 R0 X2 H: e
/ K3 r; X: i8 j0 U% s# z5 {
q10:
5 n7 d: m' S1 j0 h2 z) G4 \9 Z% XIf/xlin<>&nulent,delete/xlin+ h+ f9 \6 k; E# I4 C' n
Jump/s05:
8 f3 X0 Y9 H8 i0 A" W4 d% U* c5 U: j0 E: J# h. P; A4 Q2 H* Z
tt:
) x$ P( a# O- n& bi=i-13 B6 |3 h, S/ K: r }- }
&Wcs=precsys! v5 g7 ~8 A/ t. K, j
&wcsdrw=&yes
" K5 j+ }' ^0 yDelete/zlin,opt,xpt,xlin,temcsys
) Y i4 `5 f/ v$ e3 |Chksol/gru,result,nli,Iferr,s05:
0 `7 {3 ]6 U2 UDelete/gru
" }& v8 z. h; n8 |8 Y# \: zJump/s05:' U: ]8 j1 J2 w$ S
$ ^% C8 P7 J% Q ^) ] L' _tz:( \/ P! j. A9 b' v" r! T& i- U
i=i-12 N1 a4 V( y- F6 J6 y2 F
&Wcs=precsys6 D. h$ T2 e/ l' m6 l
&wcsdrw=&yes
$ ?) j6 t/ @( q/ kDelete/zlin,opt,xpt,xlin,temcsys7 r9 C! n& s' j: \! J
Delete/gru- D3 h8 `/ V' n8 }# {6 K3 ?1 d/ Q
Jump/s05:, d# p2 g; L c
7 U# ]4 h- x0 \2 I* Q: oqq:
$ W7 H' s7 l* x&Wcs=precsys
l/ s; n( g! k1 Q+ H% j M; g&wcsdrw=&yes! ^: X; M/ {0 A; J3 x
Delete/zlin,opt,xpt,xlin,temcsys. X" _% |4 e) e- ]( X' O
Jump/oo:" ^8 h" Y9 m4 h8 [4 G' B) }
9 O% G) d7 }: v; ~
rr:7 p, g2 A6 Q' ^
Delete/xlin,temcsys,gru( [) N, U. I7 `
Jump/oo:9 ?2 V8 T( l3 d2 r [
: f9 j0 j7 O/ a7 C2 R4 \wro:
. X! u- @; S! c, bMessg/'未生成边界曲线,请重新选择!'
% f& k7 O" y; H9 z+ B% I, E. @Jump/d10:
8 M! r4 U& a- z. G4 n/ J0 G T/ k _3 r
vv:
% I/ F, \* Y) nDelete/gru,xlin
- ^8 E* Z0 l, dJump/oo:0 M+ w( }% }. Y0 c$ F
/ F' a, M5 Z: ^! R9 k; k: F
zz:
( a+ w& b ]$ [9 u# y: V: xDelete/gru,xlin
. U; _: {, }6 B6 wJump/s05:* p9 G( ~6 u5 e! G, x, a
]( R5 F# ^" T. }0 O) v" a
xxtj:5 G7 y0 Q/ o# Q$ u! K* l F
&Wcs=precsys
' o! g6 W% @6 s" a2 e&wcsdrw=&yes! @7 X+ y7 V5 K& p+ @9 L( U8 O
If/olin<>&nulent,delete/olin! Z& n" d3 T0 o/ z6 N, z1 \) M# I
Jump/oo:
9 U9 @" J0 p- j. s* E! T( m! c8 w
xxtj1:
7 ^8 F6 r1 Y+ mIf/olin<>&nulent,delete/olin
0 y6 q. C0 S2 e" J7 q4 b9 u; IJump/D20: |
