这程序到最后能生成的孔,但就是不能控制孔的深度,应该是面的选择有问题,希望高手指点和帮助,谢谢!* S. H2 C3 L: V4 J' q- S
#include <uf_modl.h>- X6 A; I: g/ I4 W- R, s! L W
#include <uf_layer.h>. Y$ Z- q- @4 u; s; u( P0 u5 p/ g R2 {
#include <uf_obj.h>
+ c- v9 L9 `' W( e9 M9 d4 y#include <uf_vec.h>
]" _: I8 c2 e/ I+ K6 N8 G- ]#include <stdio.h>+ O" s. K8 v; q2 o7 ]: R5 A4 z
#include <math.h>6 T( M5 I$ y* _( {, x/ k4 }
#include <malloc.h>+ q, N+ j6 K4 N8 P
#include "SOLID_PLATE_dialog.H": p6 Z6 j' u0 H& U7 G% _+ B
#include <stdlib.h>
( p- Z6 c8 b1 R1 [4 ?8 P9 H
% `( R3 ^4 A( R0 yint SOLID_PLATE_Create_BLOCK(PartParameter *p_part_para,tag_t *m_block_tag)
( ~0 G- G2 G( @ \; ^{
* u+ v7 o& ~0 ]! c! C1 F) E 1 b# |( N, H% t6 o* F2 V
double corner_pt[3]; `2 a7 e% L$ ^+ l5 F9 Z8 ~
int err,sig=15;3 j/ @# h, e# L5 h$ T: d
char message[200];5 ^$ |4 c6 H/ h0 P! T) x
char len1[120],len2[120],len3[120];1 p5 J; U% M0 G4 a& N1 }+ X
. c% m& m% U7 I% a' n/ R5 ]. `& \
' v5 r* n+ k- c6 D char *block_len[3]={len1,len2,len3};
; O+ T$ P8 I. ` gcvt(p_part_para->L,sig,len1);8 k' i8 M4 {% C3 @$ {
gcvt(p_part_para->W,sig,len2);
* {- ?0 F& p1 C1 @" Y gcvt(p_part_para->H,sig,len3);
+ O& K) q1 W$ @# ~ corner_pt[0]=-(p_part_para->L*0.5);1 V+ f8 r- B- i4 ?2 r
corner_pt[1]=-(p_part_para->W*0.5);
+ T* d' E+ ]9 w$ {; j {7 d UF_LAYER_set_status(101,UF_LAYER_ACTIVE_LAYER);
0 n; }; J" A0 N- r+ c( KUF_LAYER_set_status(1,UF_LAYER_WORK_LAYER);
# q8 j7 W3 [0 m7 Nerr=UF_MODL_create_block(UF_NULLSIGN,NULL_TAG,corner_pt,block_len,m_block_tag);, R, J: g# m% [% X2 h8 r* u
if(err!=0)
. v% A+ U; F/ l! f' E; w{
- @: O4 M7 g/ q0 u. eUF_get_fail_message( err,message);9 W% _: v) X! z5 L" G: \. ]( y
uc1601(message,1);6 K5 C1 p) h, g' ^" }3 P
return err;
/ U9 x' j6 q9 b8 I. r3 f* V M7 V6 k} % @1 E/ K+ J9 l/ H/ T) G7 ?7 p4 V
return err;
, i! Z) b# V0 D7 N: X) A6 M: k}
, w3 ~4 g) a* u; lint SOLID_PLATE_Create_Hole(PartParameter *p_part_para,tag_t m_block_tag,tag_t *m_hole_tag)
$ F1 H: z) s3 {0 `+ x/ M3 O0 b{
) y1 T$ I$ {6 E9 E, b: m3 G/ I uf_list_p_t face_list;
$ C; R. \6 M A( d! o @+ H tag_t body_tag;) i% t7 N0 M1 k4 R% h
int body_type,sub_type,sig=50;1 {$ d7 o# O2 ^$ Q
tag_t bplanes[256];& M7 ?' ~: F4 b
double point[3],dir[3],box[6],direction[3] = {0.0,0.0,1.0};
! |* D/ p- F% [: Y" t& | double face_radius,rad_data,orgin[3];
4 C9 ~7 \3 U1 a. b int i,norm_dir,type,is_parallel;0 x) u1 n7 j+ _! Q8 h' a) ]' E
int list_num=0,count=0,err;
: i" |5 E* J2 C% J char diamf[256],diams[256],depthf[256],depths[256];
7 R* o1 j5 ~/ Y9 v
: E1 _- B* A) ~ S. U0 J% d$ H& P orgin[0]=-(p_part_para->L1*0.5);! t8 q7 v5 v$ ?& v( x1 q4 ?
orgin[1]=p_part_para->W1*0.5;
5 g x. h. u d" @5 P" @1 R; f! j* C orgin[2]=0;/ F" s8 a# B, g+ j
UF_initialize( );3 d7 ~8 r, h4 e" i
UF_MODL_ask_feat_body(m_block_tag,&body_tag);
. _, l. P0 n6 X1 f, G4 v& o 7 n3 @, N/ X5 X1 C# Z
UF_OBJ_ask_type_and_subtype(body_tag,&body_type,&sub_type); : Y$ F: R* o) @5 l
if(body_type==UF_solid_type&&sub_type==UF_solid_body_subtype)
) R% G, I M2 Z1 d5 Z: J {0 u; C n/ o4 e h$ P# Q
tag_t face_object;* t5 S' u% p$ R) ^0 o$ ~6 ^. N
UF_MODL_ask_body_faces(body_tag,&face_list);" V. {+ p; _, h4 K) `. Q5 z
UF_MODL_ask_list_count(face_list,&list_num);
- ?# P" U( l$ c" Z for(i=0;i<list_num;i++)
2 d' F9 A: F3 J( Z4 l6 ]1 w K {0 I# ~2 c1 Q/ M6 Z* b* W
UF_MODL_ask_list_item(face_list,i,&face_object);
$ F2 ^7 s- D) n1 W, \6 B UF_MODL_ask_face_data(face_object,&type,point,dir,box,&face_radius,
+ _- a: s* `9 K, }2 H2 S8 k &rad_data,&norm_dir);6 o; a; R' x$ X p: Z: x5 f6 `& U$ |
if(type==22)
$ N- J9 C2 h! ]) a% c; O {1 l" y% `. J8 E$ V
UF_VEC3_is_parallel(dir,direction,0.000001,&is_parallel);* A' o, f m4 {1 H
if(is_parallel)- h/ R: C3 x( C
{6 a! v9 Z w, L" d4 h) w& N4 w
bplanes[count]=face_object;! u, V( p" G0 f* e7 y! s
count++;
' H( Z! w$ a3 {- d7 | }3 [0 M" G' f- g7 T- B |
1 w {6 E/ P& `1 T& K" { }. d+ K+ o5 a7 t+ K) P
UF_MODL_delete_list(&face_list);( v" c% V; j* B; V' A/ q( K
8 H! Y1 F/ } S; W else
3 a7 L0 V# O! L1 i! S/ ^ {
. K3 |1 R* R# X% [! q uc1601("没有找到打孔的平面,程序错误",1); p* m( u. |, h/ P. B1 h
return 1;
2 [# \' n: O8 n6 z6 g }, Y( p7 I$ |2 |9 G3 U
diamf[0]='\0',diams[0]='\0',depthf[0]='\0',depths[0]='\0';, _) M' V* C( L0 T. g
sprintf(diamf,"%lf",p_part_para->D1);
* `& D% w" ~, x5 D5 d sprintf(depthf,"%lf",p_part_para->H1);
: `( j+ q9 _- [ sprintf(diams,"%lf",p_part_para->D2);# E2 g! H& \% \0 Y& V/ r, Q
sprintf(depths,"%lf",p_part_para->H1);: Q4 m* V) u% v& }2 b/ P4 Z$ \
! i* o9 Q! }# l) b
% X+ ?& `, U& ]: J err=UF_MODL_create_c_bore_hole(orgin,direction,diamf,depthf,diams,depths,"0",bplanes[1],bplanes[0],m_hole_tag);, { h$ K6 p6 T( v/ x: M6 t
if(err!=0)7 o5 t9 f8 `$ ? D/ I7 {- P% j- _# O
err=UF_MODL_create_c_bore_hole(orgin,direction,diamf,depthf,diams,depths,"0",bplanes[0],bplanes[1],m_hole_tag);
9 y6 X$ z6 }/ y1 ~4 Z: D) L7 v6 x return err;
% y% x H: r! X9 J} |
