本帖最后由 p36288 于 2010-9-10 22:39 编辑 3 u) v) F1 F: Z
: \2 n$ [1 O M$ m' W7 |+ D
我想用NX Open C++编个简单的外部程序生成一条Studio Spline曲线,直接用操作记录稍微改了一下。程序没有报错,但是调试的时候在“studioSplineBuilder1->CommitFeature()”这句(代码倒数第九行)跳出来这个中断:“***.exe 中的 0x2031f7eb 处未处理的异常: 0xC0000005: 读取位置 0x00000000 时发生访问冲突”(Unhandled exception at 0x2031f7eb in test.exe: 0xC0000005: Access violation reading location 0x00000000.)。请大牛指教。5 I5 A7 a( B2 x+ {; R, P+ H
我尝试过生成直线或圆弧,都没有这个问题。5 ]" S0 y R: _0 m6 [
我的邮箱:p36288@gmail.com,用的是NX7.0,中文Visual Studio 2008,系统WinXP。下面是程序原文:- /* Include files */
) c; h1 `" N- C2 p3 d. ^ - #if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )# J% ^1 ?/ C& T( B
- # include <strstream>8 M1 R- b, W1 _% t+ _8 d( H
- # include <iostream>/ r+ A; _& i' d9 \) u
- using std::ostrstream;/ u& H; x- [# w0 p* A' i
- using std::endl; 1 v5 x8 D9 I% u
- using std::ends;
7 Y8 j8 F/ |' D# u% Y- j - using std::cerr;
( g1 C8 t- }0 { |3 S! a% D+ e9 i7 f - #else
/ \1 q+ Y/ ~# h$ g6 g0 u - # include <strstream.h>' M5 D U8 y% v1 B
- # include <iostream.h>, N# ? h6 ~0 C# d
- #endif
; b" H0 k' C' T. m - #include <uf.h>
7 j& m; S; m9 z4 q' R - #include <ug_session.hxx>1 p$ E2 y% c+ K9 p& h2 }3 `7 Q
- #include <UG_exception.hxx>3 Z8 v, o! h) e6 f* b/ e
- #include <uf_defs.h>
1 o5 X4 {* N$ W6 J! h! R - /*Your Code*/+ f9 M6 H& P' x, ?% z
- #include <NXOpen/NXException.hxx>
: K7 R* q* D" \ P; L - #include <NXOpen/Session.hxx>
' x" t4 O5 K( F6 C( ] - #include <NXOpen/BasePart.hxx>
9 Z2 c4 t) \% I, p/ |7 [3 V H: l. E2 X - #include <NXOpen/Builder.hxx>* t/ N( U( d: t7 v$ j
- #include <NXOpen/Features_Feature.hxx>
7 V+ S, ~* T% V9 X; m, e2 e - #include <NXOpen/Features_FeatureBuilder.hxx>& r8 k3 s5 H& E8 s+ a
- #include <NXOpen/Features_FeatureCollection.hxx>
6 p0 K) C% W# o" _* g1 b* G/ j - #include <NXOpen/Features_GeometricConstraintData.hxx>8 Y% w7 G% t4 W* X) t
- #include <NXOpen/Features_GeometricConstraintDataManager.hxx>; N9 z5 ~# ^) f* b( o
- #include <NXOpen/Features_StudioSplineBuilder.hxx>, P! g4 R% a0 s7 G9 p+ I( f9 N
- #include <NXOpen/Part.hxx>
- A4 Z4 j* w/ t0 l# F - #include <NXOpen/PartCollection.hxx>
+ f( ]$ O4 w2 W+ w3 c - #include <NXOpen/PartSaveStatus.hxx>
0 |9 c' k8 d. b - #include <NXOpen/Point.hxx>
% p+ n2 W* D( ], Y - #include <NXOpen/PointCollection.hxx>" d" z- W! M& [* r9 H
- #include <NXOpen/Preferences_PartModeling.hxx>
# E5 T0 d5 u& M4 { - #include <NXOpen/Preferences_PartPreferences.hxx>
( F! j* \# L+ c! T - #include <NXOpen/Session.hxx>
% x- F. n# K& P - #include <NXOpen/Spline.hxx>8 W& T p7 f* l# |( p8 p7 I- e8 n
- #include <NXOpen/Update.hxx>
% s/ |6 l3 j8 q8 q - using namespace NXOpen;
. P4 f/ Z7 \: `& p! a - ; C3 y9 C8 v) n. E3 }" @
- /* Main routine */
! W7 y( y! ]1 T - extern void main( char argc, char *argv[] )
# l6 s/ L/ z% V! M' {0 J - {5 D6 D' r) i, I B0 i4 F
- Session *theSession = Session::GetSession();
( J; z: M$ V6 l$ Y - NXOpen::NXString partName = "NXcurve.prt";$ n) t8 t0 ^ D$ Y- S
- Part *workPart = theSession->;Parts()->NewDisplay(partName, NXOpen::Part::UnitsInches);
( _ [$ H! n( C* B; \: L- \ - /*创建Studio Spline*/3 |8 G5 O: R+ ^- T3 A# x' X; P$ a
- Point3d coordinates1(-60.9672168874869, -85.3444953331698, -16.2564577575515);
3 _; G& {4 u H+ H6 s. Q - Point *point1;
; l( @9 o; H' `' I6 S - point1 = workPart->;Points()->CreatePoint(coordinates1);
4 H: d b" x: q: \0 P& m2 Y. e1 p - Point3d coordinates2(-36.7798197522759, -26.6915553863001, 28.8322080982988);
* v2 E o0 d" D" B: W( J - Point *point2;3 j5 D8 E& c2 U7 E: V d. B+ l0 Y
- point2 = workPart->;Points()->CreatePoint(coordinates2);! t, z/ y: W. n+ C* H9 D
- Point3d coordinates3(-3.3110308509701, -13.9095206113823, -15.3362809033505);" F$ t$ f- r% e; M6 F9 g& o* [& a* C* p
- Point *point3;+ @1 o$ Q9 I/ R6 ?6 J( `
- point3 = workPart->;Points()->CreatePoint(coordinates3);
! y# ^6 w2 H' V( P6 `8 M8 Q - Point3d coordinates4(50.4956319822501, 34.6877235376336, -42.6348609113142);
& D4 a# B7 @( f" W4 L; X - Point *point4;) y2 H4 ]" r, S, z! a
- point4 = workPart->;Points()->CreatePoint(coordinates4);! R8 H, f4 `$ R; W9 B! J4 I6 @6 _
: t" t" |) w2 N- Features::StudioSpline *nullFeatures_StudioSpline(NULL);
! s& S. q. i6 {& X - Features::StudioSplineBuilder *studioSplineBuilder1;
! @+ f4 v0 \" H - studioSplineBuilder1 = workPart->Features()->CreateStudioSplineBuilder(nullFeatures_StudioSpline);8 L$ _3 \# Y! M; t( S* N
- studioSplineBuilder1->SetInputCurveOption(Features::StudioSplineBuilder::CurveOptionRetain);
% M6 g! f; Y. O& E) k: l - studioSplineBuilder1->SetSplineMethod(Features::StudioSplineBuilder::MethodByPoles);
+ Y/ c0 _5 j& { - studioSplineBuilder1->SetDegree(3);
3 t e9 U+ _- P* n8 K0 o' e2 L - studioSplineBuilder1->SetPeriodic(false);: l* J- ~7 R3 a3 V: ], K
- std::vector<double> knots1(0);
- n) }% ] e2 V. ]4 v - studioSplineBuilder1->SetKnots(knots1);# {" H# O, X- g) Z
- std::vector<double> parameters1(0);
* f2 } U: ~' H6 I/ P# t* ^ - studioSplineBuilder1->SetParameters(parameters1);# K5 q/ u" {) u
- ) q/ M {# Y: y
- Features::GeometricConstraintData *geometricConstraintData1;; V, @ O$ j9 y* l3 r
- geometricConstraintData1 = studioSplineBuilder1->ConstraintManager()->CreateGeometricConstraintData();
9 i% \ g% _+ B+ f - geometricConstraintData1->SetPoint(point1);
% Q# a* N5 b+ W) d- ~* d3 H - geometricConstraintData1->SetAutomaticConstraintDirection(Features::GeometricConstraintData::ParameterDirectionIso);
8 q! P0 f5 s! Z' z5 g3 O+ R" W. Z - geometricConstraintData1->SetAutomaticConstraintType(Features::GeometricConstraintData::AutoConstraintTypeNone);
! m8 q$ o3 O3 R" }* Z; K. i - Direction *nullDirection(NULL);' J- n) B+ I% A- ~. R: L" X2 M3 B
- geometricConstraintData1->SetTangentDirection(nullDirection);
- |( t! Y- c2 a - Scalar *nullScalar(NULL);
, j4 X) t1 L5 Z; [ - geometricConstraintData1->SetTangentMagnitude(nullScalar);
' B& K' _8 m% { - Offset *nullOffset(NULL);
$ M$ F: C9 Q9 m7 Q - geometricConstraintData1->SetCurvature(nullOffset);6 F: e; D! T; O6 c' z W ?
- geometricConstraintData1->SetCurvatureDerivative(nullOffset);$ f! t# ~1 o. f3 B" N( {3 t
- geometricConstraintData1->SetHasSymmetricModelingConstraint(false);
: \* T- e/ E0 D! w% Q - ) {5 m7 B" ` ?8 D6 E% `$ _
- Features::GeometricConstraintData *geometricConstraintData2;
3 P+ A ^- i- j) d - geometricConstraintData2 = studioSplineBuilder1->ConstraintManager()->CreateGeometricConstraintData();% A: ^9 \2 P; s7 ` b* H
- geometricConstraintData2->SetPoint(point2);# ]: C- b2 C5 x6 T* u
- geometricConstraintData2->SetAutomaticConstraintDirection(Features::GeometricConstraintData::ParameterDirectionIso);
4 s' Y( f" V1 F0 e3 v5 |8 M - geometricConstraintData2->SetAutomaticConstraintType(Features::GeometricConstraintData::AutoConstraintTypeNone);
|, @$ L0 Q( c4 ] - geometricConstraintData2->SetTangentDirection(nullDirection);
7 ` \0 b0 H, d6 h, s - geometricConstraintData2->SetTangentMagnitude(nullScalar);* w/ C. x& d* Q; V' m: |+ x) t$ G
- geometricConstraintData2->SetCurvature(nullOffset);- n+ p! f+ A5 h4 O0 n/ u
- geometricConstraintData2->SetCurvatureDerivative(nullOffset);
! y& x- i7 C6 ~5 R& x$ `# W - geometricConstraintData2->SetHasSymmetricModelingConstraint(false);: w6 Y3 k! H# T3 ? r
- 4 w% o8 l( y6 t
- Features::GeometricConstraintData *geometricConstraintData3;- h/ b$ N! q1 U! M" E$ [* T. T
- geometricConstraintData3 = studioSplineBuilder1->ConstraintManager()->CreateGeometricConstraintData();8 u9 ? z& K3 F/ G
- geometricConstraintData3->SetPoint(point3);
. }+ f7 h4 a& Z. A - geometricConstraintData3->SetAutomaticConstraintDirection(Features::GeometricConstraintData::ParameterDirectionIso);
$ D* }% J" }' \! ~$ Z% T4 H - geometricConstraintData3->SetAutomaticConstraintType(Features::GeometricConstraintData::AutoConstraintTypeNone);( ^! V* w3 v1 l) h0 B& k, b
- geometricConstraintData3->SetTangentDirection(nullDirection);7 a3 Y u7 u3 n6 b4 c
- geometricConstraintData3->SetTangentMagnitude(nullScalar);* G! T/ J" O' u% j6 d& n# d- ]
- geometricConstraintData3->SetCurvature(nullOffset);4 X+ u7 w3 k U
- geometricConstraintData3->SetCurvatureDerivative(nullOffset);
; t X7 B/ L+ Q* M" C - geometricConstraintData3->SetHasSymmetricModelingConstraint(false);
9 b, E3 l3 S0 x. @ T' H
+ \% L! c$ R y3 Q0 E' Q, a- Features::GeometricConstraintData *geometricConstraintData4;7 }, _- Z( k, m3 R- Z
- geometricConstraintData4 = studioSplineBuilder1->ConstraintManager()->CreateGeometricConstraintData();
2 r+ D A& |+ x/ z1 y - geometricConstraintData4->SetPoint(point4);
: r; U1 d$ f% ]' w) H3 X1 j - geometricConstraintData4->SetAutomaticConstraintDirection(Features::GeometricConstraintData::ParameterDirectionIso);
' X2 p/ Z6 ^+ V8 z. f - geometricConstraintData4->SetAutomaticConstraintType(Features::GeometricConstraintData::AutoConstraintTypeNone);
1 a+ J; W G0 s2 l' z+ B' A - geometricConstraintData4->SetTangentDirection(nullDirection);
! C8 `1 H3 g: N) h ?4 a4 s6 a - geometricConstraintData4->SetTangentMagnitude(nullScalar);' V! X7 T3 d/ K% c$ S5 } G# O
- geometricConstraintData4->SetCurvature(nullOffset);
; C, {, o7 ?' Y0 k# I - geometricConstraintData4->SetCurvatureDerivative(nullOffset);" w# G7 t! |6 f/ v1 C, D1 B
- geometricConstraintData4->SetHasSymmetricModelingConstraint(false);: h6 B$ Z$ r' i
8 J8 l8 B" r1 p- std::vector<Features::GeometricConstraintData *> constraints1(4);
5 F+ v* ^7 e. m% O4 H - constraints1[0] = geometricConstraintData1;
3 [2 m3 x0 \$ ~' r# G7 P - constraints1[1] = geometricConstraintData2;
' _% s! x9 N& ` - constraints1[2] = geometricConstraintData3;
3 V2 s# O+ p4 [+ z H$ |# A1 D - constraints1[3] = geometricConstraintData4;
% H1 v8 V. W/ w2 ~( ^; R - studioSplineBuilder1->ConstraintManager()->SetContents(constraints1);! b$ w6 a, N3 F% ?
* g3 B' B5 b9 ^! {' y& f$ O- Features::Feature *feature1;
4 d$ ~$ d3 m3 h) Q' s& U - feature1 = studioSplineBuilder1->CommitFeature();2 O% O% q1 W) S2 Y9 @
- Spline *spline1;
( i N p- A6 i7 g* v6 { - spline1 = studioSplineBuilder1->Curve();
. A+ D8 S/ D# J/ V1 _! u9 } - studioSplineBuilder1->Destroy();9 g+ Z4 j0 G# L1 g
- /*Save*/
6 n0 _+ \* u, A, v* L; O* }$ { - NXOpen::PartSaveStatus *partSaveStatus;
, F+ i" ^: K1 `! e1 l9 G - workPart->Save(NXOpen::Part::SaveComponentsTrue, NXOpen::Part::CloseAfterSaveTrue, &partSaveStatus);
. l% c5 R' o( ` - }
复制代码 |
