请看下面的子程序., b( F8 c) |& k6 }9 W& Y
目的是对全局变量arrCurves()内的曲线对象进行两次变换. f- Y0 {( y' Z4 @
然后,建立回转体.' Y& }! Q5 H' O# L) b8 U. p; k$ M
+ C5 v5 X, R# G/ X
问题是,建立第一次变换矩阵成功后(status1=0),不可建立第二次变换矩阵.
5 h7 D; B1 ?7 l" J3 Z5 \. T否则就出错.奇怪?
{/ V: f% Z( U- f- v. P. u若将第二次变换代码删除,程序可顺利运行到下面的变换代码,但提示出错.
: M9 W+ R# D8 G" l3 }$ U看一下ug界面内的运行结果.是变换成功的.那为何还要提示错误呢?4 a+ ]( }: Q2 \5 y+ P& ` P: h
建立回转体是不可能了.8 Z3 t5 L7 b r l1 |* f
' Q" q& b) o: h5 F# T7 V
请高手指点,不甚感激!/ g1 S8 P+ X* o# {' i
1 U$ N& g5 _" |6 X" `7 Z7 r3 ]. H
Private Sub CreateRevolveSolid(ByVal Ang As Double, ByVal sp As Point3d, ByVal ep As Point3d)
- H6 b$ b% Z9 U& ]& G' _* i6 a Dim objTags(100) As NXOpen.Tag
; ~9 j+ v" x& V6 ^ i1 Q Dim i As Integer
9 W* ^! C/ J! L7 v5 U O' V M; _ For i = 0 To arrCurves.Length - 1
8 Z: s$ d6 K9 I objTags(i) = arrCurves(i).Tag
1 ]" q: [( w4 V Next3 M7 ?! t" f) M* k; g0 \* R+ L
Dim origin(2) As Double
3 T; Y; G _5 z2 a) V: u% L+ { Dim origin1(2) As Double0 ]* H/ b, x3 U/ b
Dim origin2(2) As Double) e/ C5 u' a1 \) }8 E8 N) E& k% l, o
origin(0) = 0 : origin(1) = 0 : origin(2) = 0
% J B+ y: q/ E# `9 }/ I6 h" X origin1(0) = 0 : origin1(1) = 0 : origin1(2) = 0
; y( K) M/ u! Y. @' c origin2(0) = 0 : origin2(1) = 0 : origin2(2) = 0& D0 o7 Q# s7 \% \8 D9 `
Dim direction(2) As Double0 g* W: F. P; p! H4 W
Dim direction1(2) As Double
7 J3 g L0 w2 g Dim direction2(2) As Double
0 L$ N. j% I) w Dim mat As Double5 E$ P0 B( t; o2 m/ m9 M8 O: D3 e
Dim mat1 As Double
2 A+ S1 T, q+ e" G# l Dim mat2 As Double
5 K6 |2 V* o) B5 T4 a Dim status As Integer8 s7 V- T8 X6 U3 |' e4 W- I& f
Dim status1 As Integer/ P* v6 O0 R" s5 `7 c; t$ f! F" b$ {" y. D
Dim status2 As Integer
7 b! C& ^. k7 B5 [2 b Dim Features(100) As NXOpen.Tag
# W0 T9 k" Q1 N# r Dim copies(100) As NXOpen.Tag8 h+ s$ [# z, G- M
Dim ang1 As Double = 901 e) S0 f% D% V* h
Dim ang2 As Double = 90
" A( n* H7 o+ @# E direction1(0) = 1 : direction1(1) = 0 : direction1(2) = 05 i# q: u- Z6 m( W- A3 S! Y, L
direction2(0) = 0 : direction2(1) = 0 : direction2(2) = 10 f" f2 Y7 a7 h6 ~. b+ e4 B' f3 ?; M
'构建第一变换矩阵
) o6 c3 ?& ?0 K/ H/ P F MsgBox("Matrix1" & status1.ToString)( U- X( C8 |$ H
ufse.Trns.CreateRotationMatrix(origin1, direction1, ang1, mat1, status1). s( ?# C7 r3 U" |( Q
MsgBox("Matrix1 status" & status1.ToString)
0 ^/ [9 l' }7 f$ j '构建第二变换矩阵
2 A2 ]/ \* @6 h4 |7 v' u9 x: S- A2 w ufse.Trns.CreateRotationMatrix(origin2, direction2, ang2, mat2, status2)
4 E! _" X/ C. S MsgBox("Matrix2 status" & status2.ToString)0 t/ W: W# l! P; }
4 n; [& N( }/ }/ g( ?
'ufse.Trns.MultiplyMatrices(mat1, mat2, mat)' T9 X1 X( P; w
'变换6 j& V5 |. f! [3 b
MsgBox("transform1")
7 D$ y9 S) d1 ]( m$ [ ufse.Trns.TransformObjects(mat1, objTags, arrCurves.Length, 2, 0, 2, copies, Nothing, status)+ f2 S6 z" X9 @; ?$ ?7 U
MsgBox("transform1 ok")
6 Q0 q: {% I# J; S8 ~. Q Dim limit(1) As String* z7 S: w3 {+ S; d: b
limit(0) = CStr(-Ang) : limit(1) = CStr(Ang)- u5 F e k7 \; u
Dim offset(1) As String% Q7 Z$ `6 G8 k2 c
offset(0) = "0.0" : offset(1) = "0.0"
, c8 e& t! x. r. w5 {; X '生成回转体+ d. v+ H! P: d1 m" R7 A
Dim cou As Integer
9 d& i, m* k' T B) |8 d MsgBox("revolution")( s# x8 M" J# t: c. b2 y8 q) u2 l
direction(1) = 0 : direction(2) = 1 : direction(3) = 04 u. A# J. K' L( u/ K
ufse.Modl.CreateRevolution(copies, arrCurves.Length, Nothing, limit, offset, origin, False, True, origin, direction, FeatureSigns.Nullsign, Features, cou)
; b. T7 l; m" U9 v& V7 F- f End Sub |
