查看: 26925|回复: 0
[求助]memory access violation
发表于 2006-11-9 04:56 | 显示全部楼层 |阅读模式
<p>今天在做运动仿真的时候又出现这个错误了strength wizard的时候也这样)<br/>1.Internal erro:memory access violation</p><p>2.Recovovery Failure:<br/>&nbsp;&nbsp;&nbsp; Error recovery failed be cause:Intenal error:memory access violation<br/>&nbsp;&nbsp; This occurred attempting to recover from&nbsp; the following error:Error number:1<br/>&nbsp;&nbsp; Parts in this session may be corrupt.Do not save your parts Restarting NX is recommended</p><p>3.Fatal error:<br/>&nbsp;&nbsp; Fatal error detected unable to continue</p><p>1 2 3表示对话框出现的顺序<br/>因为出现不只一次了,所以..............<br/>操作系统:WIN2003</p><p>谢谢</p>
GMT+8, 2025-8-6 04:03 , Processed in 0.158641 second(s), 25 queries .
