我在作moldflow分析時,在分析filling時出現失敗,如下:
6 M5 M+ V" [' B, i* T) Z( s6 q! q' R! Q--------------------------------------------------------------------------2 Z5 \$ u# Q* E# Y/ u+ R' C: ^
+ v) @! b" v5 O( I' _7 N
Filling Analysis
7 A- K" Q; ^0 d: P; ~- XPacking Analysis5 z* C" V7 @4 ^( u/ s5 e) }4 R) Q
Fiber Orientation Analysis
5 n( g8 [. k( L5 FResidual Stress Analysis
: P5 ?- b4 ~( R4 L0 y( y9 [+ j2 {0 Oanalysis is beginning .... , V7 q% `" J- x+ S. b( F" ?
( I+ W, \# [ X. o# x Filling phase: Status: V = Velocity control
) w& n. @& r5 m: d- k. ?$ D3 O! e P = Pressure control
9 w9 J! H4 W \2 K4 J V/P= Velocity/pressure switch-over% Y% n% {0 [6 k* [0 N" }5 X
|-------------------------------------------------------------|5 e' \7 F0 U9 c- q
| Time | Volume| Pressure | Clamp force|Flow rate|Status |' W8 u u+ v F4 R6 g8 o; L2 x" T
| (s) | (%) | (MPa) | (tonne) |(cm^3/s) | |- H( s4 R1 W+ l% }
|-------------------------------------------------------------|. K- a( S3 a& o8 Q* m" @
' y3 z+ C& C( I2 p7 C** WARNING 98934 ** The maximum machine injection pressure reached at5 d4 Y4 D! _, _4 Q; A
time = 0.03 s; volume = 3.03 %" ?5 ? V8 D* Q
Using maximum machine injection pressure
- e- g: L6 Q* U! j2 V; I- x/ @9 v: f, A$ W
** ERROR 99817 ** Problem in solving for pressure solution
) r O& [7 J2 A2 Z. h1 _
% S1 K6 @! o( L; K* p" e我想了好多的辦法,卻無法解決問題,請問是出現的什麼問題,該如何解? |
