Copyright moldflow Corporation and Moldflow Pty. Ltd. All Rights Reserved.6 i2 r1 T1 @% n0 G
(C)1993 1994 1995 1996 1997 1998 1999 2000 % {4 o" r6 c8 ]8 V' X$ @
(C)2001 2002 2003 2004
* B4 z" _7 c0 Y/ H; ^2 T+ W+ {This product may be covered by1 k: B! \9 w+ d6 s! k. e9 H
US patent 6,096,088 ,! M5 \' ]* Q, J h* l$ f6 j7 b
Australian Patent No. 721978 ,$ }, k0 P$ e$ n7 g# ]
and foreign patents and pending applications
+ H8 _8 p( X) B% \" p% [' _0 q2 O' N1 m
+ N* G4 ~: X* i6 z8 E
Cool Analysis/ T3 V V# H5 P+ B: r, [5 x
3 `1 Q9 F5 }' u7 V9 ?
# G5 ]4 W* I- `9 nVersion: mpi500 (Build 04305): u/ Q* W4 e3 F
2 Q5 G7 L) [( B
Analysis running on host: " z+ M: x- m0 W; J/ R; i9 K$ J: Q
Operating System: Windows 2000 Service Pack 4
$ a6 B; S- B4 v4 @0 H3 h Processor type: AuthenticAMD x86 Family 15 Model 12 Stepping 2 ~1602 MHz
V% P$ n' k) g( g) F Number of Processors: 1 1 m0 X7 I4 A. n" z3 E
Total Physical Memory: 511 MBytes" ~* ^4 _' E& B7 P
! h2 |/ t6 i+ G2 F: X& Z
% B3 V0 |6 I1 z; {2 ~* F( [Analysis commenced at Mon Feb 20 11:22:25 2006
. a: a# y0 @6 j1 y0 A6 K/ ZExecuted: Mon Feb 20 11:22:25 2006
9 u" ~) O' X) ? C( g Mesh Type = Fusion+ |$ M! Q* h; ?9 E: s/ p' j
Number of nodes = 4691
j+ v2 {/ x/ p, J. Y2 P' z5 n4 h Number of beam elements = 87 % W" u* ^2 q0 D; F
Number of triangular elements = 9254 : a0 C) Z) a* w7 W7 }
Number of tetrahedral elements = 0
' D2 q; x& U' ]7 N0 L% L' [$ h. [: l
Reading nodal data...
4 ~( ^0 |' o# r6 AReading beam element data...$ |. s, X0 O% h6 c: d7 S& L; z6 f) u9 J
Reading triangular element data...
% Q8 l* ^+ ^* k E+ R* B1 g Method of calculating geometrical influence = Automatic # g* p) }0 @1 G/ y; \
+ n0 v* P+ p0 @3 c# K5 Z- e9 d
Cooling analysis type = Manual
# Z2 R3 J* D8 D4 e! H
4 P# ]2 b; N- C" v& C7 X Total number of part elements = 9259
3 A+ A0 M! \$ t. [: {& h Total number of runner elements = 5
# `! N/ i( x6 V: R Total number of mold elements = 82 - P5 V7 z( b4 L" j/ b: x
Total number of circuit elements = 82 + d1 Q0 s/ r7 U3 g3 b
Co-ordinates of part extremity:
: L/ l/ A9 O2 c& A X Y Z1 x L& c8 q4 D3 ]% R
Maximum 36.55000 mm 36.55000 mm 71.52000 mm/ Z- x! W$ z- u6 ]
Minimum -36.54970 mm -36.55000 mm 0.00000 mm6 f) d, [7 m& x" G0 H
Orientation 109.65000 mm 109.65000 mm 143.04000 mm
$ e1 s% f/ I! H8 P0 `) O, H
, y \: q! _8 u: n, w/ M** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.1 E" t; N5 N. Y1 y+ z6 H
Angle between normals = 1.79844E+02 deg degrees.
1 c, s! H9 `& v
5 A1 G( h: E$ u( s" W** ERROR 701590 ** Check the orientation of element 438 ' R; w0 K9 Y8 l7 W9 I9 p# G! m9 {
4 M7 C r( F& E3 }& ?/ E
** ERROR 701590 ** Check the orientation of element 442 x. F7 ?* |2 ^& r2 _
: A- k, O0 ~, I& f** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.- H" G; I6 B# m9 Y; _/ g; l6 t
Angle between normals = 1.79841E+02 deg degrees.
1 z' B+ D* x9 l
7 @" t3 e# k, q5 e** ERROR 701590 ** Check the orientation of element 438
& F4 f4 P+ M% f8 U% [$ R" W: V, g% q# l% v6 d& i4 t; v. r' ]
** ERROR 701590 ** Check the orientation of element 1868
: ^& [& L$ h# @5 r9 h5 `4 q t: z9 c: r: a4 e8 h
$ |# S9 C9 r$ `1 K: P D3 _. M Angle between normals = 1.79729E+02 deg degrees. 2 o9 @- j$ v, G8 \
/ F* h6 e) [, V8 @! B% |( g5 U** ERROR 701590 ** Check the orientation of element 438 % y- n0 O! q! W: Y& m# y( ^* v3 ^
0 c: A8 G: N6 ^: s' y' r** ERROR 701590 ** Check the orientation of element 1880 5 Y# ^( H3 J' i" X
我用Moldflow5.1做的冷却分析,但是分析失败,请各位高手指点一下分析失败的原因.万分感谢! |
