查看: 1101|回复: 1
关于Moldflow建模问题,中心孔问题!!
发表于 2010-9-27 20:35 | 显示全部楼层 |阅读模式
我建了一个圆柱体,中间有通孔,在moldflow中划分网格时总是出现错误,请各位高手指点应该怎么解决!!
4 x( ]" P$ o% j+ a( L( o8 o谢谢大家
, _2 i* d. c; X6 o7 E网格分析出下列结果:
$ e, F2 M" w  V* `2 n; q* SEntity counts--------------------------------
( H# `$ s9 T; g" E    Surface triangles     2784
9 t) i- q' s/ w- l9 `, b    Tetrahedral elements   0 3 o8 b. A0 V6 ~; Z! Y
    Nodes       1390 8 P  Z' f4 g- p: x1 y' j- o7 _
    Beams       0
1 @+ N% j0 l( o    Connectivity regions   1
1 P5 @! ]: o- W2 @' _: U  7 D7 [6 y* U: i3 k& p( w- s8 x
Edge details---------------------------------
* I! u/ `! I* [, X    Free edges       0 : m' @7 M, A2 x
    Manifold edges     4158 ! {/ s5 k' ~: u1 R7 z8 b+ v" }
    Non-manifold edges     9 & j: ?6 [, Q# i
  5 Q3 m! k2 s" v& e
Orientation details--------------------------
7 e8 O" m: t2 k, P( P5 @/ |  g0 ?    Elements not oriented   34 6 f4 b* y% o" s" i" R- \
. o( ?* g! z1 O4 X4 a( I- [! s2 \7 zIntersection details-------------------------
& Y2 j1 k: P# j4 ^) D$ T    Element intersections   0
5 |. l1 {  c2 ~* l2 o+ t2 [$ R    Fully overlapping elements   4 + u8 D+ W0 J9 b
    Duplicate beams      0 ( l6 L' W4 z" Z, A2 {
  R, \8 d. P2 d. HSurface triangle aspect ratio---------------- * e* a' z. Y# Y$ i% ^+ z7 g
    Minimum aspect ratio   1.167628
" @9 m& L( a$ a    Maximum aspect ratio   21.836347
3 T8 k5 }) |+ F& C    Average aspect ratio   2.643638
& A$ w5 ~1 M% v; g+ O( o继续划分则出现下列错误: 1 d$ b* }8 M0 `4 U- ~. p
BEGIN: Generating tetras
! ^- J' A: ]8 c: y  Generating tetras
4 X- B. A7 l: s6 vTG    :-Start tetra mesh generation. 4 v- H: {# j8 m+ |* j7 S- H7 X
TG    :-The maximum allowed aspect ratio as intermediate control is: 25.0 ! G. _* R9 D, w$ ~) n. W( P
TG    :-Transfering Nodes... 2 v1 T. n6 u$ E1 z! m4 `
TG    :-1568
: N* ?7 o9 Z3 q, mTG    :-Transfering Faces
) r# p8 ?# j- d' nTG    :-Number of triangles: 2784
$ w" ?) R$ E# ~; X# N" _5 Z& aTG    :-Building Connectivity
# m8 d% {, _2 e) VTG    :-Triangle with nodes: [N594 N638 N653] not being connected properly. * _2 R% R( u! z& p: a/ i. p
  Meshing has failed
发表于 2010-9-28 10:01 | 显示全部楼层
请问你使用的是哪种网格类型,我记得之前我也遇到过,那是因为我导出的文档的问题,主要是直接在组件中导出而出的问题
GMT+8, 2025-6-21 19:31 , Processed in 0.268718 second(s), 26 queries .
