楼主 |
发表于 2010-9-28 13:55
显示全部楼层
接上材料和设备9 i) b3 T$ B, _$ N4 G' q) v
1 水的软化 softening of water
4 t- N" j1 R! t/ d0 H. y0 T1 K2 汇流排 busbar
: D$ q- u% }. u, h3 r+ `5 |3 阳极袋 anode bag
( C$ ~) a4 G( |- n) K& W4 光亮剂 brightening agent (brightener)
9 O. A9 N7 M$ v: l4 V- E5 {& p( Z5 助滤剂 filteraid% R: d" v8 J q. n, F' G# K
6 阻化剂 inhibitor. A) F7 U- r/ T! _
7 表面活性剂 surface active agent(surfactant)
5 l- I0 A" c5 Z/ b$ M8 乳化剂 emulsifying agent(emulsifier) 3 X! N( D+ \3 d" h3 `* p
9 配位剂 complexant; T: Q' a/ M/ j
10 绝缘层 insulated layer(resist)9 l! G1 m6 _. m( _0 N
11 挂具(夹具) plating rack
/ x5 A: J0 i& C1 W. w! {# c% s12 润湿剂 wetting agent; }* C+ C: w& X# N5 [7 \
13 离心干燥机 centrifuge
8 K. p% c) \$ P1 N! u14 添加剂 addition agent(additive)
4 o4 u4 Z' C2 B% V2 e* ]15 缓冲剂 buffer B6 ]4 g, n6 D7 c# s5 u
16 移动阴极 swept cathode
: H R' s/ _8 l% r$ Y17 隔膜 diaphragm5 B5 x0 d. y, u! f/ V M' j
18 整合剂 chelating agent( I( ^) K$ p1 J
19 整平剂 leveling agent
' l( V9 O% Y% x20 整流器 rectifier8 b2 M2 ^1 c9 m. i
/ {% }+ v) v$ h) O. c2 V* b- Z# ?( x3 O* q镀覆方法
! E& u: h1 b$ N7 O, x, `1 化学气相沉积 chemical vapor deposition
. Y# l7 M5 C, s) ^1 q2 物理气才目沉积 physical vapor deposition! ]1 \/ H6 B; Y' y0 x: `
3 化学钝化 chemical passivation2 c/ f" l; m$ K' P
4 化学氧化 chemical oxidation
" S3 ?: I" s G' W( o5 阳极氧化 anodizing" }/ n# Y6 X$ C X
6 化学镀(自催化镀) autocalytic plating! Y k, R! g+ i5 j- q
7 激光电镀 1aser electroplating
" h( O% J* k9 c( s& a! a8 闪镀 flash(flash plate)
u: s; V4 \" }9 电镀 electroplating( }' B5 ^ K- N* |) u. E
10 机械镀 mechanical plating( ]8 E; v. r0 X' B. E1 V' V1 f
11 浸镀 immersion plate " c C8 [: m Q
12 电铸 electroforming, n& S; f# J1 S$ y
13 叠力口电流电镀 superimposed current electroplating6 t) [( P- x ~. e0 c$ q4 B ?) Q
14 光亮电镀 bright plating
% o; \) X0 J/ M3 X15 合金电镀 alloy plating( n( _2 _/ t$ i X3 A& h
16 多层电镀 multiplayer plating2 R; s, A7 e% |+ ]
17 冲击镀 strike plating
$ _4 p9 L5 U! E' V* {; X8 M18 金属电沉积 metal electrodeposition
! e4 O) n, X2 F$ k19 刷镀 brush plating2 A! L J: t1 v% k8 c
20 周期转向电镀 periodic reverse plating2 Q' D& e J) m7 [9 M% o
21 转化膜 conversion coating ( Q/ J: ~6 s& i; E y" T
22 挂镀 rack plating2 C( f' b$ Z' L- E/ W# H
23 复合电镀(弥散电镀) composite plating* @, e( D& m. t; R2 O
24 脉冲电镀 pulse plating# N3 J1 I" ^2 z* y/ G
25 钢铁发蓝(钢铁化学氧化) blueing (chemical oxide)
3 i, C( }, ?' D. K+ }. T9 E% b6 z26 高速电镀 high speed electrodeposion5 M& ]# o) D2 h% u: k6 V2 T
27 滚镀 barrel plating + z9 I% ^& b8 V8 |+ D9 ]. g m
28 塑料电镀 plating on plastics
- J( a- L1 [% C" b6 X29 磷化 phosphating
/ v0 b: Z. s- d- @ Z2 D7 o* x2 r* x: R$ ]+ c3 w* i$ r! e
- s ]- M, D$ u) X/ g
" z. T: E/ t& F* A+ i. o p) l; H/ @ Q+ V3 y' i9 v
1 a9 s. E9 [5 Q2 A
; N& K/ [# X4 { X, |, A: D
& @! @' r8 ^ j1 u' V/ ^: K) [: \
% v H5 ^) U+ K5 r% u1 w测试和检验, I, B9 R2 d) I) t9 a8 M6 p
1 大气暴露试验 atmospheric corrosion test
* b2 L. K2 U- r# Q- V0 U2 中性盐雾试验(NSS试验) neutral salt spray test(NSS-test)
. o9 F/ ]0 [$ a' s3 不连续水膜 water break
, O' e& `7 s# f/ C2 x* T8 ~0 w9 l. a4 pH计 pH meter( s9 o0 F8 {* N1 H+ g; ] Z
5 孔隙率 porosity
4 S0 l2 c( `2 h6 内应力 internal stress9 I7 L( k1 L) H! e2 S* X
7 电导仪 conductivity gauge1 c8 L5 V/ q N6 k9 b# u4 E/ l
8 库仑计(电量计) coulomb meter
' |$ N+ s. [* J- Y5 B( x9 旋转圆盘电极 rotating disk electrode
* {0 @+ V3 [% V/ I* b7 i10 旋转环盘电极 rotating ring disk electrode' H& j4 W' R' c# C
11 针孔 pores; Q3 ]1 `. D1 m9 ^
12 铜加速盐雾试验(CASS试验) copper accelerated salt spray
# }3 a) M/ P$ K! z" c3 e (CASS test )4 j! p8 r' G ^/ t% a( V4 d( m* x
13 参比电极 reference electrode
9 y# F5 c: L6 r, @8 t14 甘汞电极 calomel electrode
+ h) J9 I9 r; z( |, s8 H V5 |15 可焊性 solder ability
0 ?. m7 o- L% c3 v16 硬度 hardness+ c. j1 a) C4 R" ?3 o
17 金属变色 tarnish
/ q9 }1 d' M( \) c$ J, _/ r/ f0 ?18 点滴腐蚀试验 dropping corrosion test/ ~" y: f; k; f6 t; F f
19 玻璃电极 glass electode
* _- ]' X1 O! f3 ]" @/ v3 C; W20 结合力 adhesion
% I- K3 e" d2 U! ~' T ~21 哈林槽 Haring cell
. w. |. O* J9 j. s/ b' ^# ]: ` x22 恒电势法 potentiostatic method
, R& m( c& |3 c6 C% K& b23 恒电流法 galvanostatic method% H" E* {$ I: V; W2 F+ b6 D3 [
24 交流电流法 a.c method
# E0 v ~/ R4 F9 H25 树枝状结晶 trees5 D( h) S, q- q5 [
26 脆性 brittleness! U3 K4 N3 z! J
27 起皮 peeling
/ m3 K: |: X5 X- J! q28 起泡 blister0 h7 m l( I+ r8 c
29 剥离 spalling . @' ]7 z; m2 _1 V
30 桔皮 orange peel |
