查看: 582|回复: 0
模具术语
发表于 2010-9-29 09:04 | 显示全部楼层 |阅读模式
模具术语
一、入水:gate 5 C/ S8 }' m; C
0 x" C9 ]' r4 x8 D. i$ A
进入位: gate location 9 y0 h" s3 y* h% x; i+ M
水口形式:gate type
1 p: Z" {, g3 G& M  G大水口:edge gate & X% \* ?% h* k) O! m
细水口: pin-point gate
9 w# Z8 S5 p8 _0 J水口大小:gate size % j; T) V$ q% l! i) [/ L8 A
转水口: switching runner/gate
& g$ B1 l& k, O# w8 k3 c唧嘴口径: sprue diameter " ^/ e# i. M- I" c5 r- x
二、流道: runner
: Q) r) k# }7 U' ]5 t* {+ H4 A1 g0 k9 K
热流道: hot runner,hot manifold
* L0 E) q4 a; U( p热嘴冷流道: hot sprue/cold runner " S/ i, R( Q. [0 \& k
唧嘴直流: direct sprue gate 0 Z& L  k  v" X
圆形流道:round (full/half runner)
" a' t7 k3 P7 _5 Q. [: [6 r流道电脑分析:mold flow analysis " N9 J/ V* M, \2 j. T
流道平衡:runner balance
, g3 V% C3 C8 P; l  @) a& x热嘴: hot sprue
1 d# ^( f6 t0 k- A) X5 \+ d热流道板:hot manifold
: a6 N( }7 n& W3 ]2 f+ o- L发热管:cartridge heater
* M9 Q: e+ @* q3 K$ I" p" [6 w3 ]探针: thermocouples * G" [# S, U% I5 H. x% J# w2 O  @
插头: connector plug ! V* P& e# t4 |. K4 W' t
插座: connector socket , [5 ]6 h! G- x6 Z
密封/封料: seal ) }0 a, @5 f1 F( ~  L
三、运水:water line
1 a- n& @0 s2 Q2 I$ t9 m" ^. v% v: u+ z( w+ B  d# G3 _
喉塞:line lpUG $ N6 Z/ ?& N& C
喉管:tube 0 m8 n1 i% G" z! I
塑胶管:plastic tube . R$ Y) L$ W" K) t. I- v$ H( F. U
快速接头:jiffy quick connector plug/socker ! ?6 a: \8 B6 W9 |9 Q$ j
四、模具零件: mold components 0 P* ?8 p7 P  I: T  s
1 G: w: @* g7 F: {& S三板模:3-plate mold
6 p" T0 r9 m- @% L, u, C" `二板模:2-plate mold
; ^' I, |  f; z8 \9 ^( J- \$ J4 C2 A边钉/导边:leader pin/guide pin $ V4 c1 ~; ~6 K8 k
边司/导套:bushing/guide bushing 1 t- B# W% x* A1 M9 y
中托司:shoulder guide bushing " N& a6 ^; P( o4 U
中托边L:guide pin
) b+ d1 X5 F/ f+ L7 k8 N顶针板:ejector retainner plate
' D  U1 J) b' b! a% g托板: support plate ' w3 {1 t& q: `7 y, a& ?
螺丝: screw
0 w( _) L. Z2 ]! Z- h管钉:dowel pin 4 u% E$ W3 T: f% v4 y( c- u
开模槽:ply bar scot 4 M6 \) k5 {- a2 h. r3 j6 y
内模管位:core/cavity inter-lock
# s' s$ w% P. I$ v) P8 p6 j7 V顶针: ejector pin # e$ Y! q+ s5 p: y8 q+ S
司筒:ejector sleeve 5 B) Y: f; D- d( x: ]8 [* m) D
司筒针:ejector pin
1 h, T8 q3 v, b/ Q8 x4 \推板:stripper plate 1 u1 }8 a$ L, h) c: B
缩呵:movable core,return core core puller 1 [  W( _8 w9 I  _
扣机(尼龙拉勾):nylon latch lock   |* w; Y% `- E+ i1 m
斜顶:lifter & D1 ^* S0 ]+ G6 ~: g! l; }
模胚(架): mold base + ~  W: D4 j9 _% C# `8 f/ B0 u* D
上内模:cavity insert 2 Y( b  b, I" [" M, ^3 Q5 c. R
下内模:core insert
  m# J$ S( H4 u: Q! F行位(滑块): slide - l) m2 W8 O7 F9 @% z9 E
镶件:insert 8 R( {) X$ u+ x8 A+ L3 B7 p
压座/斜鸡:wedge
0 Q9 L1 e$ q6 @0 O$ y$ h* Q耐磨板/油板:wedge wear plate 8 _) c. n- W' q; ~
压条:plate ' D. m: s8 z  w6 {( x* J1 y; N
撑头: support pillar   u& n: ]) ~+ U) w1 U3 y6 o
唧嘴: sprue bushing
# Y$ R/ e; P5 w3 `挡板:stop plate + q  n1 U$ H: s+ e# _) J2 D1 @
定位圈:locating ring
( N4 ^$ D5 A0 G5 j锁扣:latch
) o$ E; A/ b2 r# @* R  B扣鸡:parting lock set
* V5 B6 X3 H! d" d7 A! ~推杆:push bar
0 [, X) g9 `7 }& ]栓打螺丝:S.H.S.B ; W. ~& H$ W1 K* a
顶板:eracuretun / n2 ~: L% J+ g6 x
活动臂:lever arm ' x" I: M9 K, [0 ^
分流锥:spure sperader ; F2 t0 I& o) j# E) y2 {
水口司:bush
. @4 @1 b0 n  ?3 H  a* u垃圾钉:stop pin , Z  o( v- `1 T2 E$ d! {( I
隔片:buffle ! V' r% u9 V: l3 S/ k9 \3 F
弹弓柱:spring rod * Z& r0 M( K' v1 T6 J0 z! G  G( X% @
弹弓:die spring . }* p& @) H' c2 g3 E
中托司:ejector guide bush
2 s/ P& t8 Y. K0 h中托边:ejector guide pin
0 q$ S# V* i3 w* K# m& _镶针:pin $ T% e# J& t" [6 O
销子:dowel pin
9 n* C: U$ _6 u5 p, g9 {8 H: P波子弹弓:ball catch ; E% s* y! B$ m4 N
喉塞: pipe plug 1 U- k0 X8 X* P" i% p5 t4 d8 \
锁模块:lock plate $ W# G- i: ^$ s" }+ D
斜顶:angle from pin
3 P' s& q' E6 R) W+ F斜顶杆:angle ejector rod
* t$ T( r7 `- g" ^- s. c( P尼龙拉勾:parting locks
, h& e/ w5 ?- B3 M活动臂:lever arm
: b( W+ U* u4 h# j复位键、提前回杆:early return bar 5 j% K4 e  b# l" |
气阀:valves 2 ^# n/ F+ y8 _. C5 q+ @2 F5 P) b
斜导边:angle pin $ s; @3 O3 `& P* `; E! n- Q" @. W
术语:terms 6 w+ x" l- o9 W2 h8 u
承压平面平衡:parting surface support balance
. X7 S& [5 V+ r+ c( f. g: P8 \模排气:parting line venting 3 L0 F4 T4 a: ^% ?
回针碰料位:return pin and cavity interference + h# k6 f" [* D. J: F0 W
模总高超出啤机规格:mold base shut hight , _' A# V/ O  h! U# T6 R
顶针碰运水:water line interferes withejector pin # _! p2 x  Y/ @. S! c! R
料位出上/下模:part from cavith (core) side
# r# q3 Z+ B( v  L: d  V, d9 M模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate.
* g, P/ r( c) p8 Z
$ Y* N. z! [, t+ F; P6 G( I3 s1 ?# F不准用镶件: Do not use (core/cavity) insert 7 K+ y. J/ r  n5 d9 J
用铍铜做镶件: use beryllium copper insert & ~7 `' ?' W; d+ {& |
初步(正式)模图设计:preliinary (final) mold design 7 b2 g4 p6 ?' v2 p
反呵:reverse core
  s* C, L! ~+ v' l4 `1 V弹弓压缩量:spring compressed length 3 i# o5 ?" s; o3 {0 y- q5 _
稳定性好:good stability,stable 4 B- u+ g% L# ?: f7 q, D
强度不够:insufficient rigidity & G9 J9 f& l/ m3 r
均匀冷却:even cooling ' R# @9 B: s2 r+ N$ g+ b+ ~0 F
扣模:sticking
/ {& a( M$ b& F2 B热膨胀:thero expansion $ j5 o/ H! W  ^% I
公差:tolorance - {' ~% q' ]6 M
铜公(电极):copper electrode
GMT+8, 2025-7-4 21:56 , Processed in 0.159849 second(s), 25 queries .
