无论是凸凹模还是型心型腔都要% _* y+ |, h) D
刚进行了塑料模的设计,说明书里有成型零件的一部分计算:; h1 V( t( t; v" _
该塑件精度等级为一般精度,(6级),故选取制造公差为零件公差的1/4,模具磨损系数为0.5。模具工作部分尺寸计算过程为:4 }6 g9 \& H- o+ Q* j; y* i m
A1M+δz =[(1+S)AS1-xΔ1]+δz1=[(1+2.0%)*80-1/2*0.76]+0.76/4=81.22+0.190mm- m# k5 k( [8 L9 r( F+ {
A2M+δz =[(1+S)AS2-xΔ2]+δz2=[(1+2.0%)*25-1/2*0.48]+0.48/4=25.26+0.120mm
6 H7 F( j0 l' F3 `" w; k B1M-δz =[(1+S)BS1+xΔ3]-δz3=[(1+2.0%)*72+1/2*0.76]-0.76/4=73.82-0.190mm
0 ?4 x- M9 W8 U3 J% W B2M-δz =[(1+S)BS2+xΔ4]-δz4=[(1+2.0%)*22+1/2*0.44]-0.44/4=22.66-0.110mm
$ F$ E" S- M- y. @) w. ?7 y; ] B3M-δz =[(1+S)BS3+xΔ5]-δz5=[(1+2.0%)*7+1/2*0.32]-0.32/4=7.3-0.080mm, D$ U, [7 B% E) g }
CM±δz =[(1+S)Cs]±δz/2=[(1+2.0%)*50]±0.28/4=51±0.07mm) r3 c8 Y( S& m8 p, K- ~6 b
上标看不出来,-δz, δz1,+0.76/4这些都是上标,1/4就是制造公差,说得乱七八糟的,你大概也懒得看了,反正一句话,理论上是要算的 |
