模具钢材及零件英语6 _$ f' w6 l; A0 h1 v
alloy tool steel 合金工具钢 4 Y1 {; f8 i9 e( A9 A$ o5 B4 u
& a7 B( |. N8 A& ?% R
aluminium alloy 铝合金钢
: p4 X( E+ E h! L& H& E- ~; k" z1 D% ^% u
bearing alloy 轴承合金 ( t5 b3 s5 L& u b: ~
2 R3 b% ^0 F. P, u2 m# K1 Lblister steel 浸碳钢
- I* T+ Q- z3 j! {! C
0 d8 c1 [6 K$ u+ c$ y |9 Ibonderized steel sheet 邦德防蚀钢板 + ?( l9 i) D2 {7 o5 D' S# z
' M; W& [& S: X" J# _; Y. @& a
carbon tool steel 碳素工具钢
' o; h8 s9 V9 o3 c( v0 _0 W% _$ Z" B9 K
clad sheet 被覆板
. E% l: u9 O" T9 B
2 \/ d" w/ W+ I& _clod work die steel 冷锻模用钢 # J2 A+ k9 x2 f, o8 Q
7 W' P, x i6 k% y
emery 金钢砂 : m8 p* A, m6 U0 h$ L' `3 I
1 w# R# N: `, C0 T6 r& w
ferrostatic pressure 钢铁水静压力 6 |" v' \5 L5 [' e* W
+ v0 M2 E# {4 W- J. ?2 {
forging die steel 锻造模用钢 ( X+ k4 c- w& p2 P/ C! P7 s# x8 R1 K
' s& r. n+ V1 V8 q
galvanized steel sheet 镀锌铁板
' }/ I" Z6 D* e7 h
; V- X% B! Q' `hard alloy steel 超硬合金钢
% p3 y/ d- Y$ v# }% B9 a1 M' n. ~2 ? k/ ^
high speed tool steel 高速度工具钢
/ K9 b+ O7 k2 R- K5 g5 N! t" X
2 f0 w) F9 j. Q% s7 T# v/ Ehot work die steel 热锻模用钢 8 a$ K' e; E* U$ v/ w( R
' ^& _$ H2 F+ L( W) K
low alloy tool steel 特殊工具钢
( v3 ~* `: w, b9 p$ l
8 L/ s$ M8 |, R( ]2 ~7 C4 {. q. [4 }low manganese casting steel 低锰铸钢
( f/ I( s5 ?+ i, M0 U+ D i7 i( X
0 {' T9 o" x8 N3 }' ?/ `marging steel 马式体高强度热处理钢 8 b3 {% T! k w8 _* m
2 H/ ~' ]" G; B8 [- s5 F0 F- q! J
martrix alloy 马特里斯合金
+ ^+ E% T1 n6 k" C6 m4 U
/ r% K* q* E& \$ \& R( vmeehanite cast iron 米汉纳铸钢
0 I$ n3 w9 i8 _6 S& |
3 w# n9 |( O% \. V, P5 G4 N l2 ameehanite metal 米汉纳铁
- k1 q% O* E& d' Z0 T9 Y
& @ f8 v7 d, ]% |, M. [4 o$ _) Pmerchant iron 市售钢材
0 t% b- f4 q6 i% a4 z6 ~5 L( X1 \ ?# m! p/ J; X) |
molybdenum high speed steel 钼系高速钢 molybdenum steel 钼钢 - S6 E6 G$ n( B. J) y: C& G4 D9 I
- i8 j+ W. K+ |/ }( unickel chromium steel 镍铬钢
) @, `+ \6 C, y& |+ y: x7 t9 l! X' s
prehardened steel 顶硬钢 6 J+ }% V9 H6 l6 b: I% X
6 `& b1 F* ?) ?0 [1 xsilicon steel sheet 硅钢板
1 G" E8 u$ g( @! g& D; B
& p9 Z) M1 E x$ ]stainless steel 不锈钢 / c- C. G3 J7 Z9 w. Y, I
; o+ E& X- u) q& q! B7 x% F+ R
tin plated steel sheet 镀锡铁板
& p2 Y3 J" e* l4 s$ x# R7 i' r* u3 a: G, t2 @
tough pitch copper 韧铜
, ?/ Q. {8 b$ P V, f7 O; f& _ x
8 p* {0 F- ~. [# o8 Atroostite 吐粒散铁 * ~- z L; n" O, X6 J4 v
k- Y2 G. q! n" r P1 Ttungsten steel 钨钢
) F$ N/ Q5 Y+ V( l! L6 p* r7 t8 a! ]
vinyl tapped steel sheet 塑料覆面钢板 3 o* ~+ ~) ?5 u) X
]. O/ ]! T2 e+ |- B9 V# w零件英语
M% Q( f1 f. m. l. ]
4 C {6 b( C- _7 v8 |punch冲头 ) ]7 j& V0 }5 i0 H7 K8 m- e3 `
/ g" i% D/ T3 o U
insert入块(嵌入件)
( Q3 B4 Z% l+ e( o8 z' {5 G& n# V" w3 d+ C+ m9 w# D7 n$ ]
deburring punch压毛边冲子
5 J. A& t4 \' t+ N7 d _( X* p$ M$ x: v
groove punch压线冲子
" g+ q k' c7 Y# h+ k+ b4 u
! @, C2 Z. X) Nstamped punch字模冲子 ! c! \ X4 ]$ e0 e: K
/ D+ I( c9 }6 z
round punch圆冲子 , c- |- i1 o' X+ ~* q( _5 R) H
( R; W! A8 L6 y
special shape punch异形冲子
4 P" z# u# Z7 P$ a) W4 T9 I! W2 l
bending block折刀
7 a7 Q& n0 D# B1 g& g: ?1 T u8 F; o/ Y4 [' n
roller滚轴
& A y$ ^/ p5 C( R6 ~ z& J8 O- b7 d; n; b
baffle plate挡块
" E. G1 i! P$ c4 d& ?- O
+ ]/ J! O: c0 Rlocated block定位块 1 C) o% T& J5 d1 B8 h2 P
# ?+ |% Q# l" C; }: J
supporting block for location 定位支承块
) r/ G. B* d; T' }/ L5 o6 P
. | k% w# \- i' f( U% Pair cushion plate气垫板
! N. @* X4 Z% \ N" J- U- c+ g) E3 u* B/ F
air-cushion eject-rod气垫顶杆
+ t9 A4 ^9 _- R; W' J
# q" x: X# s5 M: I# w( Atrimming punch切边冲子 7 V! I5 ^ k9 W8 P$ r6 q
3 [' ?. _6 A, k" M
stiffening rib punch = stinger 加强筋冲子
* i0 }6 l( _* W' V: M- P8 p& R2 A: K$ v& ~& b% \
ribbon punch压筋冲子 4 X( l. B0 L! {, f
2 A, S# z* ~5 C6 R1 W, v, sreel-stretch punch卷圆压平冲子 - U U( |2 E7 l' a! J7 A9 W" ]
guide plate定位板 _# g: e7 [; a/ S1 `4 H
! ^$ F: F# Y: ?0 n3 k& Zsliding block滑块
. ~$ h% N. [# X- r6 m, t' K+ M' ]& c8 ^& r( t: A
sliding dowel block滑块固定块 - ^: P4 J K4 `+ V6 z. u. f
: G% P, x6 S0 k. c6 s6 Q% Xactive plate活动板
+ T2 o& R6 z$ e& f5 ]lower sliding plate下滑块板 : g* m) ]) t) I. R$ C% h7 i& m+ o- M
8 ~9 J+ U6 I% `+ A: p' [& b
upper holder block上压块
* ~7 x7 }9 Z: `1 f1 d$ G( ^/ D8 K' ~0 W: n
upper mid plate上中间板 . T3 X) T* @9 |- N9 s+ K* [
# v$ R: k j: S: d+ Rspring box弹簧箱
# {0 G1 a( j4 O6 ^( n3 Y/ I3 p. `: X
spring-box eject-rod弹簧箱顶杆 * q4 @9 v9 s+ u0 M3 |4 D: v0 F: M
9 h- i' J8 o! Q v; s: M$ C
spring-box eject-plate弹簧箱顶板 k; {% x& Y6 c/ r- Q; Q
0 v; s% a. F" m2 d1 S5 k: D. tbushing bolck衬套 ' w6 }- W' l/ ]/ \' K
( t9 R' [4 n8 z3 C+ }+ D' }9 O
cover plate盖板 ( d/ b. Q" ~' F3 c% m H9 k
8 a, N) j' R( a# d$ k" M
guide pad导料块 n/ m) b( Y9 ?0 d5 e
- B2 I8 y: K! Q
塑件&模具相关英文 : S( ~, E* E) M/ J) ]' M; a- m
! N q, u4 l) z9 j7 J) h( e* ccompre sion molding压缩成型 ) b0 B5 S2 }" W q; M% s
g$ ^, Z# ?! N( ~7 ^+ Sflash mold溢流式模具 - R' f% c1 ?# A- K
1 e u$ a$ {6 F. u7 f' qplsitive mold挤压式模具
& F% C" S' h7 V" R2 W2 A
2 L1 K6 Q/ K0 |$ z+ J9 s3 f4 A7 `split mold分割式模具 7 X3 X& Y/ m$ D7 e6 }; B2 [
0 ?6 R; I1 I4 q6 h! `, t7 I
cavity型控 母模 + A! Z/ z5 n2 i& `9 a# x) K% c
0 f$ U5 R: }$ T* _& n" L) @3 ?core模心 公模 ! u. s0 M5 N; ?" Q1 L
& O' R+ `5 _7 N& i
taper锥拔
! b( X" u% ?% g; r, K! Z7 N/ z; J: t# j7 b( U9 t. ]- a
leather cloak仿皮革
5 w& l5 N' G) |, p. j/ f! M+ Q- R' n
shiver饰纹 & [% Q7 z2 D" x" S5 F3 }
& z) d# O- F- O+ v
flow mark流痕
7 c5 V( H p; M* R3 b
/ e- f) M& G4 B, h$ Z& C2 Nwelding mark溶合痕 ! X d$ o1 H C t' p `
6 s7 Q6 {* |# E) n; Y) B
post screw insert螺纹套筒埋值
' i5 v# o9 B1 ]0 x3 j4 y0 z0 j8 [, ^8 N- R
self tapping screw自攻螺丝 9 m$ m1 a# B0 |6 x( C2 T' m R
0 B7 \7 ] a/ N# y7 f
striper plate脱料板
- X7 P' C* z) Z* b$ n& O/ ~7 e. r4 k3 g
piston活塞 $ x! W% y% X9 d$ I: i& r
1 P5 J6 H1 {- K. Z* [cylinder汽缸套
. E7 b- G3 l$ G& j4 D7 B! \9 i
3 z) v/ D' j6 @- E3 u) c" H( F* Nchip细碎物 ; `8 E1 r! q( v- a
9 J0 R; T( O* x8 _& L* D% p- Khandle mold手持式模具 移转成型用模具
7 A1 R2 P7 k- a) `. K; g7 H
$ S& E9 Z4 P+ F, B: oencapsulation molding低压封装成型 射出成型用模具two plate两极式(模具) 5 C G$ a! G' T" G O( ]0 S
5 h) n+ e& G$ F Dwell type蓄料井
' D) a$ R; q0 w/ U: Q6 R- H8 Q3 D' J+ ^) m& z B: W0 }% N
insulated runner绝缘浇道方式 & G$ p/ K& `# }
% j. ^* k: G- I9 _9 p% w
hot runner热浇道
" v7 O, O4 d G4 A! F/ b( a: Z- ^3 }7 D9 Z) j
runner plat浇道模块 2 @/ I! Y- l5 a- U; m
r s. \! j N5 ^8 Z' I- rvalve gate阀门浇口
- ]2 h) Q+ O1 J6 O3 p: G. p1 q
. `5 { e/ r: Mband heater环带状的电热器
) R/ j0 g: z+ c
" O! Z+ j& ]5 g7 {spindle阀针 ; E1 j7 g* u$ D7 L) N
' ~# }' h( o$ R) }. y9 ^
spear head刨尖头 , n( a4 B" U* G& u7 R: d" I/ u
3 {2 ~" G& a4 K* q- u3 oslag well冷料井
2 d% F' D) y. A% B$ G; y$ n5 l9 |
cold slag冷料渣
! S4 }- W6 @* A6 {. l( P+ S
( ]( Q! d% N/ a8 J6 Y1 C/ Lair vent排气道
# m, g9 Z, [+ h2 R
3 o) y* Z* B4 y, J3 Ch=0.02~0.05mm / ]3 x1 ^7 x3 M; J. V
( q& n# f! d) Y4 g4 \& uw=3.2mm , O- c9 S8 Q) |
/ Q5 ]& g) L. J" d: E
L=3~5mm $ k) o8 a/ P# N( {. g% y" I: o
% }7 ^4 `8 p# w# _
welding line熔合痕 4 y5 G0 e0 {4 }: ]! f. r6 W% w
eject pin顶出针
$ z3 g8 f, ?! q* h; I5 G6 L& B" B3 g1 S! z% k1 f6 P# s, ~1 ^
knock pin顶出销 - c1 f8 v1 g2 |. z
2 |% f1 }7 c g+ G+ g
return pin回位销反顶针 4 s6 J) l9 {& x8 ^1 v/ m0 Y
( Q8 a+ O- U, t- j/ u$ rsleave套筒 7 o$ L, w7 ?! L
6 E0 _1 a0 U; R5 w0 h% K) J& Kstripper plate脱料板 5 v- y, k, G* p4 h$ _) M
8 @. q K7 g1 ]9 Y8 m$ k% D8 ?
insert core放置入子 % ]+ H8 i5 K0 ^. Q# F5 H
* n4 K( i5 X6 I/ i! K* Qrunner stripper plate浇道脱料板
# I! c# f4 Y& A0 x* d# p( P
4 y$ P9 z" j1 ?/ F" g4 gguide pin导销
" O0 ]/ ] [9 U' {
8 M3 {$ Z6 ~8 {, h, K heject rod (bar)(成型机)顶业捧
) |* |8 @6 B3 F m8 y) X
" S9 |! w1 W8 P7 }8 d& p) Dsubzero深冷处理
* H# X: O; t( q7 }3 V8 e
' d% x3 R) d4 I- m: F! b7 z+ ?4 }% dthree plate三极式模具 ) s9 M9 K; L/ X* p. m1 o) v
G Y0 i* \0 z0 erunner system浇道系统 + b5 ~% A/ H+ U- U
& u9 h0 ~, c! z, d q* \8 I1 [
stress crack应力电裂
' G' H5 e5 C% \3 z; ^
$ W6 |* X1 V; [3 Oorientation定向 6 M/ n2 k! Z9 J' o+ [) p1 y, B, a
/ d& @0 j" @$ m/ n( G5 P- ?sprue gate射料浇口,直浇口 8 S/ @- Y) }4 d, }7 a. \$ X
4 }) N5 ?0 B" k4 J3 |% K. F
nozzle射嘴
/ C' n0 W- x# A) _7 M
2 a6 V' o/ [) m4 i Fslag well冷料井 9 n+ h- e- N4 A6 q9 d6 e
side gate侧浇口
2 t; }$ @9 ~4 O& v! M) z; E( \0 Z: I6 y, R) h! L
edge gate侧缘浇口 % W$ b) h6 x4 a" r0 u- j+ }6 ~
* e& T6 z) B7 m, T6 Q/ s. e2 o3 jtab gate搭接浇口 ( J- E1 G6 o/ E9 V. E* S
, J) V6 T& Y& [) L
film gate薄膜浇口
& f7 L2 |( c& Q+ _0 y. i3 s: r& ]) e
flash gate闸门浇口 : i' C; N+ h' G
' }0 J, y8 ^2 G$ V7 u. i
slit gate缝隙浇口
% F$ x3 k& t! H5 r4 c$ ?
- i9 x: t/ ]7 |' E1 K) `fan gate扇形浇口
H. q7 F; M- C" F" J
2 H. C) B: o: Gdish gate因盘形浇口 4 w7 P5 Q2 B2 }8 m% o
) X3 y8 O d) qH=F=1/2t~1/5t j5 Q7 k. l! H6 l
( I I7 c" B# {; o, H/ |& D- V; _* r" H& @
T=2.5~3.5mm * l6 l3 u8 ~& W: F; p
; {7 c' o; ^0 @diaphragm gate隔膜浇口
% N" r, _; z5 R: H0 a& Z& i% f9 _; A& ?* ~; {7 h, [2 O
ring gate环形浇口
* n2 B5 U# y' x2 o6 j- C3 f& t0 M! M4 d4 E2 I3 G
subarine gate潜入式浇口
# c- y K5 U) ]' ]" U% T* b: A0 l$ I- m
tunnel gate隧道式浇口 ' n* ]0 X1 P% Q* |2 l7 ~8 u" `
/ I, P& n; v: n0 t1 r4 n
pin gate针点浇口
8 ~7 L0 L: b7 ~# M7 f% ^& A% G9 e+ V( C1 A$ X$ t$ B
Φ0.8~1.0mm ) l* c) A5 ]5 R) v1 N
1 e) H9 f$ E* w6 i$ ~5 C
Runner less无浇道 5 Q# Q: [7 A: n; B! h8 H
2 t$ Y: R' h) I2 E% C! B! E% j7 s
(sprue less)无射料管方式
, `1 }) ^5 {$ D. `; ^# N( q& W) s& C7 s% q$ d# h! H: c) F$ [
long nozzle延长喷嘴方式 0 z. M: L3 T) U
9 L; x; o D3 a9 W$ H( g9 \% ssprue浇口;溶渣 - x7 I# d0 v# ]1 S: V
& F$ r5 u/ z8 Ysprue lock pin料头钩销(拉料杆) |
