IGES to UG
) g) q* j1 G! Y% p! INFO- NX V7.0 / IGES Specification 5.3
" a, E4 c" v2 d5 c! INFO-
" O% k( _% w6 s# T! INFO- Start of Translation: 3-JAN-2011 12:11:35 PM' q) c. s* h2 X: i
! INFO- $ n* m! D6 y" {" K& D
! STATUS- Converting Part: F:\01.03\GMT.IGS: X1 T7 c9 x* Q" a4 L1 m( N
! INFO- SolidWorks IGES file using analytic representation for surfaces
8 X2 R: q# c0 ~( z/ I! SUMMARY- 5 j" D# E6 ~# ^8 Y$ Z
! SUMMARY- Summary of Supported IGES Entities in file
1 b. z9 M- r! Q7 d1 Z) d' {! SUMMARY- ! n3 d) G, P+ v3 q' f* M
! SUMMARY- Entity Type Count- {6 z) ?4 n% M& X! _+ r) {+ j. L
! SUMMARY- ----------- -----7 W' d5 t1 H( p
! SUMMARY- Line (110/0).................: 6804 ^( {; U9 u& v& c" Y
! SUMMARY- Circular Arc (100/0).........: 4306 V" A2 n! G% D) O9 E' R/ i! J- u
! SUMMARY- B-Spline Curve (126/0-4).....: 1335
3 a' A% G0 C+ u! SUMMARY- Composite Curve (102/0)......: 448
/ J/ j6 S/ H7 n) s! G/ @! SUMMARY- Surface of Rev (120/0).......: 92/ X8 H, l- f* o: o; a" y& I
! SUMMARY- B-Spline Surface (128/0-9)...: 126
# u% Z+ G% N7 a6 Z; N2 L! SUMMARY- Curve of Surface (142/0).....: 224: W& y8 m, X8 L7 z k/ m
! SUMMARY- Trimmed Surface (144/0)......: 218! N2 C5 K; l/ Z1 b, D" Y7 ]
! SUMMARY- Trans Matrix (124/0,1,10,12).: 328; n; w: D) L' N& l! G
! SUMMARY- Color Definition (314/0,1)...: 1
. B' k- U. K9 G. r" t" T7 Q! SUMMARY- -----1 V! |7 { _- v1 g# p
! SUMMARY- Total 3882# ?5 ~- J, |8 ^0 Q) |1 Y
! STATUS- ! G( d6 G' S, T$ i( G
! STATUS- Converting to Output Form (Phase 2 of 3): 3-JAN-2011 12:11:35 PM3 H9 {9 ~, g- J- I# v5 N1 J0 }+ R6 R
! STATUS-
1 q# X6 w" \) ~0 f3 a- N% c! STATUS- Creating the UG part (Phase 3 of 3): 3-JAN-2011 12:11:35 PM
! E/ s& [1 d: u0 R% Y( L& j5 S! INFO- Degeneracy in b-spline entity 851 was corrected at or around these& Q5 E9 |0 `! Z1 x6 ]
! INFO- locations. A shape change has resulted:
6 ?' X. l5 I: K6 X7 N7 X! INFO- 0.666707 0.386276 0.0000005 ~, R/ H6 ?/ K5 K. K8 {
! INFO- Degeneracy in b-spline entity 939 was corrected at or around these* P7 n" p0 g7 n
0 k1 `3 T. X8 b6 d" n! INFO- 0.333082 0.386447 0.000000& v1 N, d2 _/ U
! INFO- Degeneracy in b-spline entity 1275 was corrected at or around these3 z) k/ |; z- r5 _) Q
9 ?0 I, \$ _% f$ L" Z) }' ~! INFO- 0.017365 0.057973 0.000000
, ?7 T: v! w4 t5 k! INFO- Degeneracy in b-spline entity 4645 was corrected at or around these
. k8 I3 X0 Y7 x! INFO- locations. A shape change has resulted:
, U$ ]: Q! o/ w$ m! INFO- 0.982661 0.058577 0.000000' K8 F1 X0 B& W- Q$ d
! INFO- Filing Part ..: F:\01.03\GMT_igs.prt) A+ p3 o! G# H: D$ R" K! H$ J
! SUMMARY-
& h* Q7 K2 | Q& _" ]0 C! SUMMARY- Summary of Unigraphics Input Entities
* V& Z; X- T! G! R& A7 ^7 A7 T) s! SUMMARY-
/ n" U' V4 h, p5 h6 e$ p, U% T! SUMMARY- Entities Processed Count/ \! i) a( S2 [, a
! SUMMARY- ------------------ -----
: }# t' X' n/ N' Y5 h. Y5 Y$ D! SUMMARY- Part Attribute ..............: 87 s8 Z# ^3 ?+ u' I5 I* I9 `( u
! SUMMARY- Solid .......................: 218* H0 {- Z6 Y2 O o4 w' \5 k
! SUMMARY- -----
3 j! p( k) k& ]4 V1 ~9 ?* E! SUMMARY- Total 2268 ?, `6 A! n1 N, z( R) k) `% n6 ]
! INFO-
6 Z: {) a; i! r: R111! INFO- End of Translation: 3-JAN-2011 12:11:38 PM- s! Q% \9 P/ u1 C4 D
! INFO- |
