查看: 4444|回复: 4
some phrase for your learning
发表于 2006-2-4 07:02 | 显示全部楼层 |阅读模式
down-to-earth  平易近人
) u/ h1 {: c- T) g<>* both feet on the ground  实事求是   * with one's head in the clouds   幻想的   </P>
/ a# b. _, Q, K' q4 ?<>           * go to sb's head冲昏某人头脑</P>
 楼主| 发表于 2006-2-5 00:33 | 显示全部楼层
<>hahaha,  </P><>i got them by put ENLGISH CLUB in the blank of GOOGLE .</P>
发表于 2006-2-4 16:19 | 显示全部楼层
<>It is so good and you are so down-to-earth.Would you like to let me know why there are - among the phrase? Pls. answer with your both feet on the ground.Maybe you would like to go to your head if you were a man often with your head in the clouds. </P>
发表于 2006-2-8 05:44 | 显示全部楼层
<>呵呵,down-to-earth 最好</P>
 楼主| 发表于 2006-2-9 04:04 | 显示全部楼层
<>i am living with my head in the clouds</P><>i can't allow my head is full of bees</P>
GMT+8, 2025-7-8 05:28 , Processed in 0.354884 second(s), 21 queries .
