** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.
, A8 `4 F+ @5 x8 v1 R/ H Angle between normals = 1.79021E+02 deg degrees.
) L! N0 {* j+ X4 Y- Z! Q8 X2 f, u5 c/ y; x& O7 J8 z( f
** ERROR 701590 ** Check the orientation of element 20696
: ?& S7 U4 c" O' A* O
8 M, Z% z, O1 q8 M* ]0 V** ERROR 701590 ** Check the orientation of element 44471
1 E) {2 D" u/ R# l7 `" Q# ?+ l. n, M: S: h: a: h
: }) E9 m- B. ` Angle between normals = 1.77919E+02 deg degrees.
1 I: h9 i, z0 u# f* {5 K B
! f5 {2 a3 z% |** ERROR 701590 ** Check the orientation of element 20696 % K: R& }2 [! @( h3 q+ T
& N, r" y; i4 K' u& r% C4 m# c$ d
** ERROR 701590 ** Check the orientation of element 44500 z# W6 N" h$ S8 | I
, X6 F& s+ r; c% e, P; U5 I
% J' s+ u$ k0 P! R& U0 v Angle between normals = 1.75995E+02 deg degrees.
' b8 d4 b& u, R" X! _
$ g. g( I8 t. z' t6 _** ERROR 701590 ** Check the orientation of element 35117 J, v; m4 j( \2 k$ Z& W; q7 s" A
' t# d+ k1 n. t0 e( `
** ERROR 701590 ** Check the orientation of element 35494 * S; V P: K8 D" g- c6 d* l# B( h% X
分析检查发现 9 个错误和 0 个警告 |
