用户名  找回密码
查看: 970|回复: 0
[资料分享] 和大家分享下模具成形不良用语英汉对照
发表于 2010-12-12 08:56 | 显示全部楼层 |阅读模式
aberration 色差 atomization 自动化 " W8 F! B6 b& M  {$ u# F9 R
bank mark 料纹 bite 咬入 ! x- k" S" {& v9 N2 e
blacking hole 涂料孔(铸疵) blacking scab 涂料疤
6 [$ f7 r( P: g3 Yblister 起泡 blooming 起霜 ( a0 t+ ~  ?8 \' z! K
blow hole 破孔 blushing 泛白
3 x' w9 q! }' k( Pbody wrinkle 侧壁皱纹 breaking-in 冒口带肉 7 V" q5 {( L8 S. h' T6 [/ G
bubble 膜泡 burn mark 糊斑 ! A! P% z: Z) {- b# w: m1 w
burr 毛边 camber 翘曲 ' J) k* I+ L% S
cell 气泡 center buckle 表面中部波皱
5 ~: h& ?. z4 s" dcheck 细裂痕 checking 龟裂
) T' S/ s4 L- O! N' W0 b+ @chipping 修整表面缺陷 clamp-off 铸件凹痕   ?8 d' Y' ]7 f0 j* Q
collapse 塌陷 color mottle 色斑 9 k2 Q0 v- W' @2 Z0 ^
corrosion 腐蚀 crack 裂痕 , H7 J, w: x  m0 \. O
crazing 碎裂 crazing 龟裂
; D- m$ p8 b4 |( Bdeformation 变形 edge 切边碎片
  f3 F+ y  D7 X3 }" Eedge crack 裂边 fading 退色 / u# V8 n5 k! e1 f
filler speak 填充料斑 fissure 裂纹 ! {, K6 y( K* o. e6 M; E4 F. O
flange wrinkle 凸缘起皱 flaw 刮伤 : e4 J% F3 a9 N! o. P# W6 Y/ l
flow mark 流痕 galling 毛边
- A1 ?5 e  e7 A( p- mglazing 光滑 gloss 光泽
( M9 x1 ^9 V5 _* ogrease pits 污斑 grinding defect 磨痕
6 `8 X9 T2 I) ^) v( W# ehaircrack 发裂 haze 雾度 3 D4 \0 }9 k+ v0 Z' G- p- i0 H% L
incrustation 水锈 indentation 压痕 ; l# l! F  V; T( v3 U$ [
internal porosity 内部气孔 mismatch 偏模 . F8 {: r/ `. G; w2 ]7 ^% }+ [
mottle 斑点 necking 缩颈
$ u" Z+ r0 {" A/ E* c& Wnick 割痕 orange peel 橘皮状表面缺陷 , [" D8 g7 y1 c  ]
overflow 溢流 peeling 剥离
/ ]% Y! o& [& C7 n( A) ?$ Q* }pit 坑 pitting corrosion 点状腐蚀
/ F" w  r& N/ X5 M; _plate mark 模板印痕 pock 麻点 - N8 h5 k1 Z: p5 u
pock mark 痘斑 resin streak 树脂流纹
7 R/ }3 ^5 h  o) presin wear 树脂脱落 riding 凹陷 4 N" W' d9 V, S( ~  s
sagging 松垂 saponification 皂化
9 c% U5 l: p6 m9 z, H- H9 I, yscar 疤痕 scrap 废料 ' D/ p. e) ~- k. X6 r
scrap jam 废料阻塞 scratch 刮伤/划痕
0 u+ L9 y6 y7 [7 ~1 G- N' Kscuffing 深冲表面划伤 seam 裂痕 $ [1 L9 g8 e( S( M1 {
shock line 模口挤痕 short shot 充填不足 ; t( b5 b( r& l/ E
shrinkage pool 凹孔 sink mark 凹痕 + M0 |8 n& S& \% r. E& m* [' [
skin inclusion 表皮折叠 straightening 矫直 $ d! \# m3 z) s! P6 }$ H
streak 条状痕 surface check 表面裂痕 ; C# S8 I; G. m8 W9 ~
surface roughening 橘皮状表皮皱折 surging 波动
- H) _! P3 G) `/ jsweat out 冒汗 torsion 扭曲 . A7 h5 D0 j8 N
warpage 翘曲 waviness 波痕
& A5 {3 {) M& c2 O4 Xwebbing 熔塌 weld mark 焊痕
2 Y  U# V, U/ M7 Q% N* a) cwhitening 白化 wrinkle 皱纹
评分
参与人数 1G币 +4 收起 理由
青华老邓 + 4
查看全部评分
GMT+8, 2025-3-13 03:08 , Processed in 0.230095 second(s), 28 queries .
