查看: 3287|回复: 3
塑料的模具专业用语和中英文对照简介
发表于 2010-12-22 09:22 | 显示全部楼层 |阅读模式
模具述语
. P9 i/ V9 x# e/ s3 u
一、入水:gate
# D  n" F4 o2 x6 l1 ?进入位: gate location
; l$ x- B3 o( N  Q# v' i水口形式:gate type
9 D6 B, c8 Y1 c8 K5 {/ P5 P8 b3 Z; Y大水口:edge gate ) {5 O6 Q6 h& C" {
细水口: pin-point gate
5 X( D0 i5 _. B" s水口大小:gate size 7 O4 j. R  \. f& u: F, p& K8 I6 s
转水口: switching runner/gate $ F7 B( }2 ~- S' ~2 g* A' d
唧嘴口径: sprue diameter
9 V5 O; F1 g; Q0 ]4 T  D二、流道: runner
( |' \3 C$ n$ B+ M) E6 @热流道: hot runner,hot manifold
6 b7 i! Y/ M& T$ d& V% Y: E热嘴冷流道: hot sprue/cold runner 3 o4 d; f. }0 s$ e4 f# y, ]
唧嘴直流: direct sprue gate . L2 b- j: C/ E: r
圆形流道:round(full/half runner
0 t" i, A" ?, i9 N+ N0 \+ i流道电脑分析:mold flow analysis + z7 B) V. y0 v9 O; z/ Q& f9 x) P
流道平衡:runner balance
* X1 q( c* x$ u. X% p热嘴: hot sprue
' m. ]1 E' \" k& Q2 I$ j$ u热流道板:hot manifold
& z5 U% `) L! A+ f9 E) e% C3 P发热管:cartridge heater
& T9 A: X7 q/ p6 ~4 r) O: x探针: thermocouples
9 R  u& b! m$ [/ T. N* I. m插头: connector plug
! H: G! i- b2 ]插座: connector socket
# f' f( K0 S" e4 H2 r6 U, I密封/封料: seal
9 I1 Q4 k. e4 h4 m8 ~3 P1 `' W三、运水:water line 8 _7 `9 @3 x1 v1 [5 @
喉塞:line lpUG : V7 J4 f1 m0 Z6 Z* F. |
喉管:tube
2 e7 @, S+ B/ K$ F3 y0 l塑胶管:plastic tube
1 F) b. n9 B$ o$ y快速接头:jiffy quick connector plug/socker & U% }/ n8 U2 l' |
四、模具零件: mold components 5 ]8 v4 m( Z0 h
三板模:3-plate mold
( ?* [1 _* z2 }5 g& V二板模:2-plate mold
$ S1 f  J9 K, l6 t! v- v1 t边钉/导边:leader pin/guide pin
! R& L; I) `: x+ U边司/导套:bushing/guide bushing
4 a* v  C/ M$ J1 U中托司:shoulder guide bushing : h2 Y# j% t, |
中托边L:guide pin
6 ~. ~* g$ ?* Q6 E: I( g: ?顶针板:ejector retainner plate
0 `. L1 ~3 e3 i# V1 d托板: support plate
/ s* A, H+ x- F" t: o* d螺丝: screw * \$ E: x& v5 u& i7 O1 S
管钉:dowel pin
* X# U# M4 @$ l% b0 D& g4 V开模槽:ply bar scot
! w8 K' G/ x5 x& i( X内模管位:core/cavity inter-lock
. o# r/ E) m0 V- e3 @3 N& T5 ~顶针: ejector pin 5 X  w( A. ]. j. p! @
司筒:ejector sleeve
- W$ e+ \: y! S  ]5 ?* d3 R司筒针:ejector pin
4 x  D7 C3 P* P5 m推板:stripper plate
( ?& b/ P3 T% V8 ~$ Z- b& [7 {缩呵:movable core,return core core puller 2 p" J/ G- t8 U
扣机(尼龙拉勾):nylon latch lock 1 D8 I5 C# u' h4 N: U: u4 s' U
斜顶:lifter
4 f9 ]! d; L& H0 Q. N1 c6 {模胚(架): mold base 6 f; L. X) h3 T; {  I
上内模:cavity insert 2 z& G* q  w$ S: p; l* K& J+ r
下内模:core insert 6 U5 ~& k( ^- ], R4 h
行位(滑块): slide . a0 s7 _% m; S8 ~) C7 I9 Y
镶件:insert
8 T' S! U- _. N5 X. o压座/斜鸡:wedge
. c4 v: p5 W' [+ |耐磨板/油板:wedge wear plate
: N9 L% I1 A, [5 C/ }压条:plate " i7 M+ Y: p% y% ^6 [( @
撑头: support pillar 1 q! v$ K- N7 H/ A! L
唧嘴: sprue bushing
. z, G4 y) p0 f% k" ~: o挡板:stop plate
0 ?4 [# t' d* k' r+ e6 |# K( ]( R定位圈:locating ring
( V8 N( z0 d, }8 T锁扣:latch
' a; l7 V/ W5 U, \' Z; o扣鸡:parting lock set
% r$ i5 e9 i# g% l' R推杆:push bar 8 i+ Q8 R" @; M- X  }$ j
栓打螺丝:S.H.S.B * m! d5 l' Y& x6 C2 ~0 Z5 w  A. n
顶板:eracuretun : p, a4 P6 S% K- c
活动臂:lever arm
4 B2 ]! [+ J0 |分流锥:spure sperader 5 n$ a$ o% V, ?. S+ g  v
水口司:bush 8 d- G  w! {9 e0 K. o
垃圾钉:stop pin ; j! J/ t( ?& W3 r6 b* _6 a7 L
隔片:buffle
' L% T! e7 u, s) `7 K' L  o弹弓柱:spring rod / T: D6 a- R1 B8 N
弹弓:die spring
2 {" E) ^/ j5 A. D, F7 k, e中托司:ejector guide bush
$ R1 K0 E# x9 a+ W5 k* Z! ]+ g中托边:ejector guide pin + d: h& ~9 ~( P  o0 U; I8 F0 y
镶针:pin / u9 `4 D( k6 d  }( B8 S
销子:dowel pin ; g6 Z- S9 z# M
波子弹弓:ball catch
% p* K" k$ T2 F+ h: o喉塞: pipe plug
1 x0 P4 N$ U, J  R$ h# ?锁模块:lock plate
5 S4 l7 U8 q5 h# S, x斜顶:angle from pin * C- P, M  [- ?+ s0 U
斜顶杆:angle ejector rod
4 J$ G9 F8 D2 X1 {4 e+ ~" H尼龙拉勾:parting locks 8 {5 e9 O. y- Y1 c
活动臂:lever arm
: c) e9 ]+ k& m4 A/ G9 u复位键、提前回杆:early return bar " y* ^9 r6 N2 ?  v5 d$ b3 K
气阀:valves
% n# y5 |9 i, o' F+ X; t斜导边:angle pin 6 o4 _- r9 I! C% l* E- F
术语:terms 7 d8 V( P/ C. r( N, `, H
承压平面平衡:parting surface support balance 0 Y0 n; e" w8 e! t7 F9 k
模排气:parting line venting
4 ^$ i! u3 J8 P9 H回针碰料位:return pin and cavity interference ! l  q& i) l3 V4 N3 e3 c
模总高超出啤机规格:mold base shut hight
5 J' q: U* i0 W2 ?6 `* K顶针碰运水:water line interferes withejector pin ' z8 B3 l/ [2 x  p/ Z/ i& p
料位出上/下模:part from cavith (core) side
. l) i1 ]! L- [/ E% }  _模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate. ! Q3 E# p% p# T3 F0 ~3 U
不准用镶件: Do not use (core/cavity) insert
) F" N0 z9 E7 i+ \3 |( H/ e用铍铜做镶件: use beryllium copper insert 0 m8 \8 `) G* D' o7 x% B
初步(正式)模图设计:preliinary (final) mold design
' R6 \/ @$ s6 X反呵:reverse core
9 [2 e- R+ V# S: n弹弓压缩量:spring compressed length
' }( d/ z- z& z( P% T稳定性好:good stability,stable $ d/ \5 G2 y8 v2 n
强度不够:insufficient rigidity ! l$ h1 e! g( z- F; b
均匀冷却:even cooling
# m0 N) ?. c; }7 e7 P扣模:sticking
! Z1 t5 B) [& ^' Z- Z3 l: z热膨胀:thero expansion
" e# G  l7 \4 m5 h6 p% j" ?5 u公差:tolorance 7 I# O' A% _( A8 \' n
铜公(电极):copper electrode
发表于 2011-4-25 11:41 | 显示全部楼层
不错......
发表于 2011-5-29 06:12 | 显示全部楼层
顶了,谢谢分享
发表于 2013-1-6 17:07 | 显示全部楼层
够全面 顶起
GMT+8, 2025-9-16 08:10 , Processed in 0.055345 second(s), 25 queries .
